Studio Environment Editor SSL Tab
Use the Studio Environment editor SSL tab to encrypt your cartridge data prior to deployment.
Before you deploy cartridges from Design Studio using an SSL connection, you must enable SSL in the WebLogic server to ensure that the Cartridge Management Web Service accepts the SSL connection. See Design Studio System Administrator's Guide for more information.
Field | Use |
Keystore |
Identify the location of your keystore file. The keystore is a file (encrypted with a password) that contains private keys and trusted certificates. |
