About Import Summary Reports
When you import an existing project into Design Studio, the system generates a summary report that describes the errors generated and the actions Design Studio took to resolve the error. Design Studio creates an importReport directory in the project. Then, Design Studio uses the name of the cartridge to generate a default file name for the Import Summary report and saves the report to the importReport directory.
The Import Summary report lists the entities in the model that were not imported, (such as entities that are not associated with orders) and entities that are not supported in Design Studio (for example, test category or rule entities, even if they are associated with orders).
Also, if you import a model that includes a task that is used in multiple orders, Design Studio renames the task and notes in the Import Summary report the original name; the new name; and the associated order type, source, and view name.
The Import Summary report lists all entity name changes made during import. You may be required to edit references to the affected entity names in Java code or XSLT files.
