Assigning Task States and Statuses
When you create a task, the system assigns three mandatory processing states, which cannot be removed, to the task: Accepted, Completed, and Received. You can also select additional predefined states. Similarly, you assign completion statuses to the task by selecting from a list of predefined statuses or by adding your own.
When assigning task states and statuses, see the following topics:
