Defining Order Data Changed Notifications
You define order data changed notifications to update external systems with status updates when a specific data node in the order data is updated with a new value. Data change notifications are triggered by changes to order data.
See "Creating Order Data Changed Notifications" for information about creating data change notifications at the order level.
This feature is not available in releases prior to OSM 7.0.
