Associating Order Fallouts with Fallout Groups
You can group similar types of fallouts into groups, enabling you to review multiple fallouts together in the Order Management web client when the corresponding types of fallout occur.
To associate order fallouts with fallout groups:
From the Studio menu, select Show Design Perspective.
Click the Studio Projects tab.
Double-click an order.
The order displays in the Order editor.
Click the Fallout Groups tab.
See "Order Editor Fallout Groups Tab" for more information about the fields on this tab.
In the Name area, click the corresponding Add button.
The Add Fallout Group dialog box is displayed.
In the Name field, enter a name for the new fallout group.
The name must be unique among fallout group types in the same namespace.
Click OK.
The new fallout group is displayed in the Name column. You can select the value in the Name column at any time to edit the name.
In the Name column, select the new fallout group.
Enter a display name for the fallout group.
You can associate the display name that appears in the Task web client with a specific language by using the optional language attribute. Only those languages defined appear as options. See "Defining Language Preferences" for information about defining languages for use in OSM.
In the Fallouts area, click the Add button.
The Select Fallouts dialog box is displayed.
Select one or multiple fallouts to group together.
(Optional) In the Fallouts area, click the Remove button to delete the association with the data node.
Click Save.
