Order Editor Fallout Groups Tab
Use the Order editor Fallout Groups tab to link similar types of fallouts together. You associate data nodes with the fallout and review the values for those data nodes in the Order Management web client when the corresponding fallout occurs for an order. The following table describes the fields on the Order editor Fallout Groups tab.
| Field | Use |
Display Name |
You can associate the fallout group display name at the order template level to a specific language by using the optional language attribute. Only those languages defined on the Oracle Design Studio dialog box appear as options. See "Defining OSM Preferences" for information about defining languages for use in OSM. |
Name |
Click Add to open the Add Fallout Group dialog box, where you can create a new fallout group to associate with the order. Select any fallout group defined in the Name column and click Rename to specify a different fallout group name, or click Remove to delete the fallout group from the list. |
Fallouts |
Associate the fallout groups whose values you will want to review (in the Order Management web client) when this fallout occurs. Click the corresponding Add button to open the Order Select Fallouts dialog box, where you can select one or multiple data fallouts to associate with the fallout group. Select any fallout and click Remove to delete the fallout from the list. |
