Order Editor Fallouts Tab
Use the Order editor Fallouts tab to create new order fallouts. You associate data nodes with the fallout and review the values for those data nodes in the Order Management web client when the corresponding fallout occurs for an order. The following table describes the fields on the Order editor Fallouts tab.
Field Use
Display Name
You can associate the fallout display name at the order template level to a specific language by using the optional language attribute. Only those languages defined on the Oracle Design Studio dialog box appear as options. See "Defining OSM Preferences" for information about defining languages for use in OSM.
Name
Click Add to open the Add Fallout dialog box, where you can create a new fallout category to associate with the order. Select any fallout category defined in the Name column and click Rename to specify a different fallout name, or click Remove to delete the fallout category from the list.
Nodes
Associate the data nodes whose values you will want to review (in the Order Management web client) when this fallout occurs.
Click the corresponding Add button to open the Order Template Node Selection dialog box, where you can select one or multiple data nodes to associate with the fallout. Select any data node and click Remove to delete the node from the list.
