Properties View Rules Expression Tab
Use the Properties view Rules Expression tab to define rule expressions. To access the Rules Expression tab, select a rule attribute on the Order editor Rules tab Definition tab and click Properties.
The fields on the Rules Expression tab are identical to those on the Definition tab. However, the options that are available for the Value field and the Operator lookup list on the Rules Expression tab change depending on the element type. For example, if you select an element that is a lookup type, the values that you defined in the Data Dictionary for this element appear as available options in the list. If you define a datetime element, the options available enable you to define a system datetime or a calendar datetime.
