Order Editor Behaviors Tab
Click the Order editor Behaviors tab to quickly view all of the behaviors defined for the data nodes in an order. The Behaviors table displays the name and type of the behavior, whether the behavior is enabled, the inheritance properties, the path name of the data node on which the behavior is defined, and the order where the behavior was originally defined.
The information on the Order editor Behaviors tab is read only. To change the information that appears on this tab, select a behavior from the table and click the Properties button to access the Behaviors Properties tabs. See "Working with Behaviors" for more information about defining behavior properties.
