Properties View Usage Tab
Use the Properties View Usage tab to view in which tasks and cartridges the corresponding data element is defined. You can right-click any attribute in the Order Template area and select Open Properties View to access and edit the information defined for the corresponding data element at the order template level.
Select any row in the table and click Open to open the task in the appropriate editor.
