Order Editor Jeopardy Details Tab
Use the Order editor Jeopardy Details tab to name the jeopardy, select the notification rule, set the priority level, enable or disable the notification, and specify whether to send the notification by email. The following table describes the fields on the Order editor Jeopardy Details tab.
Field Use
Name
Enter a name to identify the jeopardy.
Rule
Select the rule the system should evaluate before generating this jeopardy. This field defaults to the system-based null_rule.
If you do not change the default value, OSM will always trigger this notification at the specified polling interval. See "Defining Order Rules" for more information about setting up new rules.
Priority
Enter a priority from 1 to 255 (1 is the highest priority). The notification with the highest priority is evaluated first.
Enabled
Select to enable this jeopardy notification, or deselect the option if you intend to implement the notification at a later time.
Email
Select to send email notifications to all users in the workgroup associated with the specified role.
By default, notifications appear in the Notifications page of the Task web client. However, you can specify that notifications be sent by email by selecting the Email check box.
When you assign users to a workgroup in the OSM Administration area of the Order Management web client, you can set up OSM to notify users by email. When a notification occurs, the system sends a notification ID number through email.
See OSM Order Management Web Client User's Guide for information about configuring email notification properties for user roles. See OSM Installation Guide for information about configuring the outgoing email server.
