Order Editor Jeopardy Notify Roles Tab
Use the Order editor Jeopardy Notify Roles tab to select the roles to be notified when the jeopardy occurs.
Select a predefined jeopardy from the list in the left column to activate a list of available roles. See "Working with Roles" for information about defining roles. Using the directional arrow buttons, move the roles (those groups to whom you want the notification sent) from the Available column into the Selected column.
If the jeopardy notification is sent to an external system via an automation plug-in, ensure that you include the role whose credentials are used when running the automation plug-in. See "Configuring Automation Plug-In Properties" for more information.
