Defining Order Event Notifications
You define order event notifications to generate a milestone-based event that works with automation plug-ins. You select the order milestone that triggers the automation and then configure the automation plug-in that will perform the work.
See "Creating Order Milestone and Task State Automation Event Notifications" for information about creating order event notifications.
