Defining Order Jeopardy Notifications
You define order jeopardy notifications when you want to alert users or systems that an order may be at risk. Jeopardy notifications are based on rules that you configure in Design Studio and which the OSM server evaluates at regular intervals. A jeopardy notification can be sent to a user group or may be consumed by an automation plug-in.
See "Creating Jeopardy Notifications in the Task or Order Editor" for information about defining jeopardy notifications at the order level.
