Process Editor Task Properties Events Tab
Use the Process Editor Task Properties view Events tab to create event notifications for a single task instance in a specific process that only triggers when the task reaches a specific state or status and (optionally) if a specific rule evaluates to true. Use the Details sub-tab to choose the task and transitional events, specify the rule that triggers the event, set the priority level, enable or disable the event, and specify whether to send the notification by email. Use the Automation sub-tab to create automation plug-ins to perform the work of the notification.
See "Properties Events Detail Tab" for more information about the fields on the Detail sub-tab. See "Creating Process-specific Task Event Notifications" for information about creating event notifications at the Process editor level.
