Exception Path Properties General Tab
Use the Exception Path Properties General tab to define the reporting status that will display in the Task web client and the task completion status that initiates the exception.
Field Use
Reporting Status
Enter the reporting status that you want to display in the Process Exception section of the Task web client. This status is tracked in the client's History. The Reporting Status Value field is an open text field. In the Value field enter a status name to indicate how the exception should be reported.
Status
Specify the task completion status that initiates the exception. If the exception is thrown from the Start activity, the values available include all of the statuses defined within the process. If the exception is thrown from a specific activity, the values available include only those statuses defined for that specific activity.
