Exception Path Properties Restrictions Tab
Use the Exception Path Properties Restrictions tab to restrict exceptions to specific roles.
Field Use
Role Restriction
To restrict the ability to throw an exception to specific roles, select Allow Restricted Roles, then select those roles from the Available list and move them into the Selected list using the arrow buttons.
Available, Selected
Move roles between the Available and Selected fields by highlighting one or multiple roles and clicking the appropriate arrow button. To move all roles from one column to the other, use the double arrow buttons.
