About Layout Controls
Use the following context menu options to control the Process editor layout features:
| Field | Use |
| Layout All Nodes | Select to automatically arrange all nodes in a standard flow chart format. |
| Layout Selected Nodes | Select to automatically arrange a selection of the process in a standard flow chart format. Use a drag selection to activate multiple tasks for selection. |
