About Zoom Controls
The following zoom tools are available in the Process editor context menu and Process editor toolbar.
In addition to the menu controls, you can press the Control key and simultaneously rotate your mouse wheel to zoom in and out of a graphic.
Field Use
Zoom In, Zoom Out
Select to magnify and reduce the size of a graphic, respectively.
Reset Zoom
Select to reset the graphic to the original size.
Fit to Contents
Select to increase or decrease the size of a graphic so that it fills as much of the editor as possible.
Zoom Box
Select to magnify a section of the Process editor. Drag a selection rectangle with the Zoom Box tool, and that part of the image will be magnified to fill the editor. If the Selection tool is active, you can activate the Zoom Box tool by pressing the Control and shift keys simultaneously and dragging a selection rectangle in the Process editor to magnify that area.
