About Task Controls
Use the following context menu options to control the Process editor task-related features:
Field Use
Rename
Select to modify the display name that represents the entity in the Process editor.
Note: You can also press the F2 key to rename an entity in the Process editor.
Assign Order
Select to associate the task with an order.
Clear Activity Reference
Select to remove from the task any existing entity associations. The task activity remains in the Process editor if you clear the reference or if you delete the referenced entity.
Convert to
Select to convert the task to a different task type.
Important: When converting from one type of task to another, the system displays a prompt if the potential for data loss exists (for example, when converting from an automated task to a manual task). Consider your task conversions carefully before implementing.
