Order Editor Notification Automation Tab
Use the Notification Automation tab to configure an automation plug-in that performs the work or sends data to an external system when the notification is triggered. The following table describes the fields on the Order editor Notification Automation tab.
This feature is not available in releases prior to OSM 7.0.
Field Use
Name
Enter a name for the automation plug-in.
Automation Type
Select the automation plug-in type from the available list.
Click OK to add the automation entry to the Automation table.
View
Click an automation, and click Select in the View field to choose a query task to use with the automation.
You must define an OSM user in the automation plug-in Run As field to run the automation plug-in and configure one or more roles and default query tasks using the Order editor Permissions tab. Associate the roles with the OSM user using the OSM Administration area of the Order Management web client.
If the Run As OSM user has more than one role, each with a different default query task, then multiple query task views are available to run the automation plug-in. You can select a query task to allow OSM to predictably use one query view to run the automation plug-in.
If the query task view has already been selected, click Open to view the query task. To create a new query task, click New to start the New Studio Entity wizard.
Note: You must configure the View field if you are creating an OSM 7.2 (or later) cartridge. You can deploy older cartridges with the OSM 7.2 (or later) server, but random selection of query task views may occur if an OSM user has more than one role, each with a different default query task.
See "Configuring Automation Plug-In Properties" for information about defining automation properties on the Properties tab.
