Order Editor Notification Data Changed Tab
Use the Order editor Notification Data Changed tab to identify the data node for which changes to the value triggers the data change notification. All of the data nodes visible in the order template (defined on the Order editor Order Template tab) are available as options.
Click Add to open the Order Template Node Selection dialog box, where you can select the data node. Select any node defined in the Nodes column and click Remove to delete the node from the list.
This feature is not available in releases prior to OSM 7.0.
