Order Editor Notification Notify Roles Tab
Use the Order editor Notification Notify Roles tab to select the roles to be notified when the notification occurs.
This feature is not available in releases prior to OSM 7.0.
Select a predefined notification from the list in the Available column to activate a list of available roles. See "Working with Roles" for information about defining roles. Using the directional arrow buttons, move the roles (those groups to whom you want the notification sent) into the Selected column.
If the notification is sent to an external system via an automation plug-in, ensure that you include the role whose credentials are used when running the automation plug-in. See "Working with Automated Tasks" for more information.
