Order Editor Notification Details Tab
Use the Order editor Notification Details tab to name the notification, set the priority level, enable or disable the notification, and specify whether to send the notification by email. The following table describes the fields on the Order editor Notification tab.
This feature is not available in releases prior to OSM 7.0.
| Field | Use |
Name |
Enter a name to identify the notification. |
Priority |
Enter a priority from 1 to 255 (1 is the highest priority). The notification with the highest priority is evaluated first. |
Enabled |
Select to enable this notification, or deselect the option if you intend to implement the notification at a later time. |
Select to send email notifications to all users in the workgroup associated with the specified role. When you assign users to a workgroup in the OSM Administration area of the Order Management web client, you can set up OSM to notify users by email when a notification occurs with the notification ID number. See OSM Order Management Web Client User's Guide for information about configuring email notification properties for user roles. Note: Order-data-changed notifications are intended to update external systems with status updates when a specific data node in the order data is updated with a new value. The OSM server does not send order-data-changed event notifications to Task web client Notifications pages. When notifying users, the server sends these notifications to email addresses only. |
