Data Center Environment Checklist
Complete the following checklist to ensure that the data center environment requirements are met for the server.
| Data Center Environment Considerations | Yes | No | N/A | Comment |
| Does the computer room air handling meet temperature and humidity requirements? | ||||
| Does the installation floor layout satisfy the ventilation requirements? | ||||
| Will the equipment be positioned so that the exhaust air of one rack does not enter the air intake of another rack? | ||||
| Are the perforated floor tiles each rated at 400 CFM or greater? | ||||
| Do the data center air conditioners provide sufficient front to back airflow? | ||||
| Is airflow adequate to prevent hot spots? | ||||
| Can the data center continuously satisfy environmental requirements? | ||||
| Can more vented floor tiles be obtained if required? |
