E6-2L Back Panel Features
The following figure shows the Oracle Communications Server E6-2L back panel and the location of status indicators (LEDs), connectors, and PCIe slots.
For information about how to interpret the status indicators (LEDs), refer to Oracle Communications Server E6-2L Service Manual.
Figure 3-2 E6-2L Back Panel Features
Call Out Description
1 Power supply (PS1)
2 Power Supply 1 (PS1) status indicators: Fault-Service Required LED: amber; AC OK LED: green
3 Power Supply 1 (PS1) AC Power Inlet (AC1)
4 Power supply (PS0)
5 Power Supply (PS0) status indicators: Fault-Service Required LED: amber; AC OK LED: green
6 Power Supply (PS0) AC Power Inlet (AC0)
7 (Oracle internal use only) Dedicated Root-of-Trust (RoT) card slot
8 PCIe slot 1 (PCIe5, x16 electrical interface)
9 PCIe slot 2 (PCIe5, x16 electrical interface)
10 PCIe slot 3 (PCIe5, x8 electrical interface)
11 PCIe slot 4 (PCIe5, x8 electrical interface)
12 PCIe slot 5 (x16 electrical interface)
13 PCIe slot 6 (PCIe5, x8 electrical interface, x16 electrical interface with MB PCIe Flyover cable)
14 PCIe slot 7 (PCIe5, x8 electrical interface with PCIe Flyover cable)
15 PCIe slot 8 (PCIe5, x8 electrical interface)
16 PCIe slot 9 (PCIe5, x8 electrical interface, x16 electrical connector)
17 LOCATE: Server Locate Button/LED
18 SP: Reset service processor (SP)
19 NET 0: Network (NET) 1GbE 100/1000BASE-T RJ-45 Gigabit Ethernet (GbE) port
20 NET MGT: Oracle Integrated Lights Out Manager (ILOM) service processor (SP) network management (NET MGT) 1GbE RJ-45 100/1000BASE-T port
21 USB 3.1 connector
22 SYSTEM: Fault-Service Required: amber; System OK: green.
23 SER MGT: Serial management (SER MGT) RJ-45 serial port
Single-processor systems: PCIe slots 1-4 are nonfunctional in single-processor systems.
