Host Management Ethernet Port
The server has one 100/1000BASE-T Gigabit Ethernet port (NET 0). The 1 Gbps RJ-45 connector port labeled NET 0, located on the server back panel, provides connection to the service processor for both host management and sideband management. Oracle Communications Server E6-2L have one 1 Gbps Host Management RJ-45 connector port labeled NET0 on the server back panel.
Figure 6-4 Host Management Ethernet Port
To achieve 1 Gbps network speeds, use Category 6 (or better) cables and network devices that support 1 Gbps networks.There are two status indicators (LEDs) for each Ethernet port. Indicators for RJ-45 ports are located above each port and display Link/Activity (left) and Speed (right).
The following tables list the Ethernet transfer rates and the Speed LED colors for each server.
