NET MGT Port
The server has one 100/1000BASE-T Ethernet management domain interface, labeled NET MGT. There are two status indicators (LEDs) on this port. The NET MGT port, located on the back panel, provides an optional Ethernet connection from Oracle ILOM to the SP. The NET MGT port uses an RJ-45 cable for a 100/1000 BASE-T connection.
If your network does not use a DHCP server, this port is not available until you configure network settings through the SER MGT port. See E6-2L Back Panel Features.
Figure 6-3 NET MGT Port
NET MGT Port
