Installing Updates Using Other Methods
In addition to using My Oracle Support, you can install firmware and software updates using one of the following methods:
  • Oracle Enterprise Manager Ops Center – Use Oracle Enterprise Manager Ops Center to automatically download the latest firmware from Oracle and then install the firmware onto one or more servers. You also can load firmware updates manually into the Enterprise Controller. Refer to product information. For documentation, refer to Enterprise Manager Cloud Control Documentation
  • Oracle Hardware Management Pack – Use the fwupdate CLI Tool in the Oracle Hardware Management Pack software to update firmware in the system. Refer to product information. For documentation, refer to Oracle Hardware Management Pack Documentation at Servers Documentation Systems Management.
  • Oracle ILOM – Use the Oracle ILOM command-line interface (CLI) or web interface to update Oracle ILOM and BIOS firmware. Refer to product information. For documentation, refer to Oracle Integrated Lights Out Manager (ILOM) Documentation at Servers Documentation Systems Management.
