Troubleshooting Oracle ILOM
This section addresses two issues that might occur on the Oracle ILOM service processor (SP):
You need to reset the Oracle ILOM SP to complete an upgrade or to clear an error.
Resetting the server SP automatically disconnects any current Oracle ILOM sessions and renders the SP unmanageable until the reset process is complete.
As the system administrator, you forgot the
rootaccount password and need to recover it.
x86 Delay BIOS Firmware Option can cause a longer reset and multiple reboots during server BIOS upgrades. If the server has a pending BIOS upgrade, a routine reset will take longer to complete. The pending BIOS upgrade will cause the server to power cycle and reboot several times. This is expected behavior. If the upgrade includes an FPGA update, the process can take as long as 26 minutes to complete.
A pending BIOS upgrade exists when both of these conditions are true: You updated the BIOS and SP firmware using Oracle ILOM. During the Oracle ILOM firmware update process, you selected Delay BIOS Upgrade.
For instructions to address each issue, see the following sections:
