Reset the Server Using Oracle ILOM
- Log in to the Oracle ILOM web interface or command-line interface (CLI) using an account with admin (a) role privileges.
- To reset the server:
From the web interface:
In the left pane, click Host Management → Power Control, and select
Resetfrom the Select Action list box. -
Click
Saveand clickOKto reset the server.
From the CLI:
Type the following command:
->reset /System -
When prompted, type
yto confirm:Are you sure you want to reset /System (y/n)? y
Performing hard reset on /System
