Update System Firmware Using Oracle ILOM
You can update Oracle ILOM system firmware while the host is powered on. The Oracle ILOM firmware image includes firmware for the service processor (SP, Oracle ILOM) and the server's host components (FPGAs). The Oracle ILOM firmware update goes into effect immediately. However, the update of host components is deferred until the affected host is power cycled. Because Oracle ILOM can be updated while the host is powered on, this feature reduces the total system downtime.
Before You Begin
Determine the Oracle ILOM firmware version currently installed on the system. See Checking Your Current Firmware Version.
Download the Firmware Pack (Patch) update from My Oracle Support. See Update System Firmware Using Oracle ILOM.
This procedure uses the Oracle ILOM command-line interface to update the system firmware. You can also update system firmware using the Oracle ILOM web interface. For web interface instructions, refer to the Oracle ILOM documentation at Servers Documentation Systems Management.To update system firmware, follow these steps:
