Log In to Oracle ILOM Using a Local Serial Connection Connect a terminal or a terminal emulator to the serial management (SER MGT) port on the server. Set the terminal device to 115200 baud, 8 bit, no parity, 1 stop bit (115200/8-N-1). At the Oracle ILOM login prompt, type your user name, and press Enter. At the password prompt, type the password associated with your user name, and press Enter. Oracle ILOM displays a default command prompt (->).
