3 GPL Management Procedures
Chapter 3, GPL Management Procedures, describes the procedures used for managing the system data (GPLs) on the EAGLE.
Introduction
A GPL is the software that is loaded onto a card that allows the various features in the EAGLE to work. The EAGLE currently uses the following GPLs:
- ATMHC– The application GPL used for high-speed ANSI and E1 ATM signaling links that are assigned to E5-ATM-B cards.
- BLDC32–A flash GPL containing a tar image with all code required on E5-MCAP cards to support VxWorks6.9 32-bit application, as in OAMHC69, E5-ENET-B for running IPSHC69, and E5-MCPM-B for running MCPHC69.
- BLDC64–A flash GPL containing a tar image of 64-bit code required on E5-SM8GB cards for SCCP64, ENUM64, SIP64 and DEIR64 applications.
- BLMCAP–A flash GPL containing a tar image of 32-bit code for the following cards: E5-MCAP, E5-E1T1-B, E5-ENET-B, E5-ATM-B, E5-MCPMB, and SM8GB.
- BLSLC32– A flash GPL containing a tar image of 32-bit code required on SLIC cards for 32-bit applications.
- BLSLC64–A flash GPL containing a tar image of 64-bit code required on SLIC cards for 64-bit applications, as in SCCP64, ENUM64, SIP64, and DEIR64.
- BLSL932–A flash GPL containing a tar image with all code required on SLIC card for 32-bit application on VxWorks6.9, as in IPSHC69 and MCPHC69.
- DEIR64–The 64-bit application GPL used on the E5-SM8G-B and SLIC cards to support the S13/S13' EIR feature.
- ENUM64–The 64-bit application GPL used on the E5-SM8G-B and SLIC cards for the ENUM Mobile Number Portability and Tier One Address Resolution feature.
- ERTHC–The application GPL used on E5-ENET-B cards for the EAGLE 5 Integrated Monitoring Support feature.
- HIPR2 –The communication GPL used on the High-Speed IMT Packet Router (HIPR2) card.
- IPSG –The application GPL used for the IP Signaling Gateway M2PA and M3UA signaling links.
- IPSG32–The 32-bit application GPL used on SLIC cards that combines GTT and IPSG capabilities.
- IPSHC –The application GPL used on E5-ENET-B or SLIC cards for the IP User Interface and FTP Retrieve and Replace features.
- IPSHC69–Used by E5-ENET-B and SLIC cards to support the IPS application when running on VxWorks69.
- MCPHC– The application GPL used on the E5-MCPM-B (Measurement Collection & Polling Module) and SLIC cards for the Measurements Platform feature.
- MCPHC69– Used by E5-MCPM-B and SLIC cards for the Measurements Platform feature when running on VxWorks69.
- OAMHC–The application GPL used by the E5-MCAP card for enhanced OAM functions.
- OAMHC69–Used by E5-MCAP cards for enhanced OAM functions, when running on VxWorks 69
- SCCP64–The 64-bit application GPL used on E5-SM8G-B and SLIC cards to support EPAP-based features and the LNP ELAP Configuration feature. If no EPAP-based or LNP ELAP Configuration feature is turned on and an E5-SM8G-B card is present, then the GPL processes normal global title translation traffic.
- SFAPP–Used by SLIC cards to support Stateful Firewall Application.
- SIP64–The 64-bit application GPL used on the E5-SM8G-B and SLIC cards to support a SIP stack of TCP.
- SS7HC– The application GPL used by E5-E1T1-B and SLIC cards to support E1 and T1 signaling links.
Managing GPLs
Managing these GPLs consists of loading them onto the EAGLE from a removable media, downloading these GPLs to the appropriate cards in the EAGLE, then allowing the cards to run these GPLs. The GPLs can be in one of two states, trial and approved.
Refer to the Maintenance and Administration Subsystem section for more information about the control cards.The approved GPL is the GPL that has been approved for use and the EAGLE should be running, unless otherwise advised by Oracle technical support. The approved GPL version number matches the version number of the GPL contained in the system release ID table.
A trial GPL is usually a duplicate of the approved GPL; it can also be a GPL that has not been approved for use and does not match with the version number in the system release ID table. The trial GPL is a GPL that the EAGLE should normally not be running.
The system release ID table contains the version numbers
of the approved GPLs that the EAGLE should be running. The system release ID
table is contained on the E5-TDMs (Terminal Disk
Modules) and on the removable media containing the GPLs that are being loaded
onto the EAGLE. The GPLs are loaded onto the EAGLE from a removable media. To
get the GPLs from the removable media onto the EAGLE in the approved state, two
commands are used,
chg-gpl and
act-gpl.
CHG-GPL Command
The
chg-gpl command copies a GPL from the
removable media to the E5-TDMs. The new GPL becomes the trial version on each
of the E5-TDMs. This command also copies the system release ID table from the
chg-gpl command uses these parameters.
gpl – the GPL being
ver – the version
number of the GPL
audit – Specifies
whether the active
MASP system release
version is to be audited every 90 seconds.
src – Specifies the
source drive containing the GPL that is being copied. This parameter has two
values.
remove– the removable media flash drive on the E5-MCAP card.usb– This parameter is to be used by Oracle personnel only and cannot be used with thechg-gplcommand.
If you are loading a GPL onto the EAGLE, the
gpl and
ver parameters must be specified with
the
chg-gpl command and a removable media
containing the GPL being loaded must be in the removable media drive on the
E5-MCAP card of the active MASP.
The
audit parameter is required only when
turning the GPL auditing on or off.
ACT-GPL Command
The
act-gpl command changes the state of
the trial GPL from “trial” to “approved.” This is also referred to as
activating the GPL. The state of the previously approved GPL is changed from
“approved” to “trial.”
The version of the GPL shown in the
RELEASE column of the
rtrv-gpl output (the GPL version in
the system release ID table) is updated to the new approved version when this
command is performed.
The
act-gpl command uses these parameters:
gpl – the GPL being
ver – the version
number of the GPL
Displaying GPL Information
Two commands can be used to display the GPL information
in the database,
rept-stat-gpl and
rtrv-gpl. The
rept-stat-gpl command shows the
versions of the GPLs that are running on the cards in the EAGLE. The
rtrv-gpl command shows the versions of
the GPLs contained on the fixed disks.
REPT-STAT-GPL Command
The
rept-stat-gpl command output contains
these five columns and displays this information.
GPL– The GPLs contained on the TDMs (Terminal Disk Modules). The TDMs contain the fixed disks.CARD– The cards that are running the GPLsRUNNING– The version number of the GPLs the cards are runningAPPROVED– The version numbers of the approved GPLsTRIAL– The version numbers of the trial GPLs
The following is an example of the
rept-stat-gpl command output.
rept-stat-gpl:loc=1103
tklc9010801 16-09-07 00:21:39 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
GPL CARD RUNNING APPROVED TRIAL
SS7HC 1103 139-010-000 139-010-000 139-010-000
BLMCAP 139-010-000 139-010-000 085-009-009
Command Completed.
The example
rept-stat-gpl output shows that the
card in slot 1103 is running the SS7HC GPL, version number 139-010-000, which
is also the approved version of the SS7HC GPL. The trial version number of the
SS7HC GPL is also 139-010-000.
You can display all the GPLs used by all the cards in the EAGLE except the flash (or communication) GPLs, a specific GPL, or all application and flash GPLs used by all the cards in the EAGLE. The flash GPLs are the BLMCAP, BLDC32, BLDC64, BLSLC32, BLSLC64, BLSLC932, and HIPR2 GPLs. The application GPLs are the other GPLs in the EAGLE.
If you specify the
rept-stat-gpl command with no
parameters, all the GPLs on all the cards in the EAGLE are displayed except for
the communication GPLs, as shown in this example.
tklc9010801 16-09-07 00:22:18 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
OAMHC 1113 139-010-000 139-010-000 139-010-000
OAMHC 1115 139-010-000 139-010-000 139-010-000
SS7HC 1104 139-010-000 139-010-000 139-010-000
SS7HC 1107 139-010-000 139-010-000 139-010-000
SS7HC 1108 139-010-000 139-010-000 139-010-000
SS7HC 1203 139-010-000 139-010-000 139-010-000
SS7HC 1207 139-010-000 139-010-000 139-010-000
SS7HC 1208 139-010-000 139-010-000 139-010-000
SS7HC 1213 139-010-000 139-010-000 139-010-000
SS7HC 1303 139-010-000 139-010-000 139-010-000
SS7HC 1304 139-010-000 139-010-000 139-010-000
SS7HC 1307 139-010-000 139-010-000 139-010-000
SS7HC 1308 139-010-000 139-010-000 139-010-000
SS7HC 1313 139-010-000 139-010-000 139-010-000
SS7HC 1314 139-010-000 139-010-000 139-010-000
GLSHC 1102 139-010-000 139-010-000 139-010-000
ATMHC 2102 139-010-000 139-010-000 139-010-000
ATMHC 3306 139-010-000 139-010-000 139-010-000
ATMHC 6101 139-010-000 139-010-000 139-010-000
ATMHC 6102 139-010-000 139-010-000 139-010-000
IPSG 1101 139-010-000 139-010-000 139-010-000
IPSG 1105 139-010-000 139-010-000 139-010-000
IPSG 1106 139-010-000 139-010-000 139-010-000
IPSG 1201 139-010-000 139-010-000 139-010-000
IPSG 1211 139-010-000 139-010-000 139-010-000
IPSG 1301 139-010-000 139-010-000 139-010-000
IPSG 1305 139-010-000 139-010-000 139-010-000
IPSG 1306 139-010-000 139-010-000 139-010-000
MCPHC 1212 139-010-000 139-010-000 139-010-000
MCPHC 5302 139-010-000 139-010-000 139-010-000
ENUM64 2305 139-010-000 139-010-000 139-010-000
ENUM64 3105 139-010-000 139-010-000 139-010-000
ENUM64 3115 139-010-000 139-010-000 139-010-000
ENUM64 3117 139-010-000 139-010-000 139-010-000
DEIR64 3215 139-010-000 139-010-000 042-010-003
DEIR64 3217 139-010-000 139-010-000 042-010-003
DEIR64 3315 139-010-000 139-010-000 042-010-003
Command Completed.
If a specific GPL, including the communication GPLs, is
specified, then all the cards running that GPL are displayed. For example, if
the
rept-stat-gpl:gpl=ss7hc command is
entered, then all cards running the SS7HC GPL are displayed as shown in the
following example.
tklc9010801 16-09-07 00:22:40 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
Command Completed.
If a communication GPL (BLMCAP ) is specified with the
rept-stat-gpl command, for example,
rept-stat-gpl:gpl=blmcap, then all
cards running the communication GPL are displayed. In the following example,
all the cards running the BLMCAP GPL are displayed as the output for the
rept-stat-gpl:gpl=blmcap command.
eagle1 16-09-09 18:53:40 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
BLMCAP 1101 138-022-000 ALM 139-002-000 139-002-000
BLMCAP 1102 138-011-000 ALM 139-002-000 139-002-000
BLMCAP 1112 139-001-000 ALM 139-002-000 139-002-000
BLMCAP 1205 138-011-000 ALM 139-002-000 139-002-000
BLMCAP 1206 138-011-000 ALM 139-002-000 139-002-000
BLMCAP 1207 139-010-000 ALM 139-002-000 139-002-000
Command Completed.
If the
display=all parameter is specified
with the
rept-stat-gpl command, then all GPLs,
application and communication GPLs used by all the cards in the EAGLE are
displayed as shown in these examples.
This example shows the output when the display=all parameter is specified. IMT and application GPL information is shown.:
tekelecstp 18-01-18 21:30:11 EST EAGLE 46.5.1.5.0-73.10.0
rept-stat-gpl:display=all
Command entered at terminal #18.
Command Accepted - Processing
GPL Auditing ON
OAMHC 1113 033-010-001 033-010-001 ----------- *
BLMCAP 033-010-001 033-010-001 033-010-001
OAMHC 1115 033-010-001 033-010-001 ----------- *
HIPR2 1109 141-003-000 ALM 143-005-000 143-005-000
HIPR2 1110 141-003-000 ALM 143-005-000 143-005-000
SFAPP 1103 009-011-001 009-011-001 033-010-000
BLDC64 143-006-000 ALM 000-000-000 033-010-001
SS7HC 1106 033-010-000 033-010-000 033-010-000
BLMCAP 077-005-000 ALM 033-010-001 033-010-001
IPSHC 1112 033-010-000 033-010-000 033-010-000
BLIXP 077-005-000 ALM 033-010-001 033-010-001
SCCP64 1107 033-010-000 033-010-000 033-010-000
BLDC64 064-011-000 ALM 000-000-000 033-010-001
Command Completed.
Command Executed
If the
loc parameter is specified with the
rept-stat-gpl command, all the GPLs
running on the specified card are displayed. For HC MIMs, this includes all
non-activated flash GPLs, as shown in the following example.
eagle1 16-09-09 18:52:13 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
SS7HC 1102 139-006-000 139-006-000 139-008-000
BLMCAP 139-002-000 + 139-002-000 139-002-000
Command Completed.
Notes:
The
display=all,
gpl, and
loc parameters cannot be specified in
the same command.
If GPL auditing is on, a minor alarm is generated, and
ALM is displayed for each GPL in the
RUNNING column whose version does not
match the version of the GPL shown in the system release ID table. The GPL
versions in the system release ID table are shown in the
rtrv-gpl command output.
If GPL auditing is
off, the minor alarm is not generated,
but
ALM is displayed for each GPL whose
version does not match the version of the GPL shown in the system release ID
table. The detection, marking, and reporting of corrupt GPLs continues to be
performed and is not affected by turning GPL auditing off.
If a GPL is not found, a version of “-----------” is displayed.
If a card is inhibited, “-----------” is displayed in the
RUNNING column.
A plus (+) symbol appears in the output when any of the
communication or flash GPLs are specified for the
rept-stat-gpl command. The plus symbol
indicates that the specified GPL currently running on the card has not yet been
activated on the card.
RTRV-GPL Command
The
rtrv-gpl command output contains these
six columns and displays this information.
GPL– The GPLs contained on the TDMs.CARD– The card location of the TDMs, either card locations 1114 or 1116RELEASE– The version number of the GPL contained in the system release ID table.APPROVED– The version numbers of the approved GPLsTRIAL– The version numbers of the trial GPLsREMOVE TRIAL– The version number of the GPLs contained on the removable media. Entries in theREMOVE TRIALcolumn are shown only if the removable media is inserted into the removable media drive. If the removable media is not inserted in an E5-MCAP card, dashes are shown in theREMOVE TRIALcolumn. Dashes are displayed in theRELEASE,APPROVED, andTRIALcolumns.
For E5-based control cards installed in the EAGLE
installed in the E5-MCAP card of the active MASP (card location 1113), the
rtrv-gpl command output. In this
example, removable media is installed in the E5-MCAP card of the active MASP
(card location 1113), shown by the GPL version number in the
REMOVE TRIAL column for card location
1114. Removable media is not installed in the E5-MCAP card of the standby MASP
(card location 1115), shown by the dashes in the
1116.
tklc9010801 16-09-07 00:26:49 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL
SS7HC 1114 139-010-000 139-010-000 139-010-000 139-010-000
SS7HC 1116 139-010-000 139-010-000 139-010-000 -----------
SS7HC 1113 ----------- ----------- ----------- -----------
You can display all the GPLs in the EAGLE or a specific GPL in the EAGLE.
If you specify the
rtrv-gpl command with no parameters,
all the GPLs in the EAGLE are displayed as shown in this example. This is an
example of the
rtrv-gpl output when E5-based control
cards are installed in the EAGLE:
tklc9010801 16-09-07 00:28:42 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
BLMCAP 1114 139-010-000 139-010-000 085-009-012 085-009-012
BLMCAP 1116 139-010-000 139-010-000 085-009-012 085-009-012
BLMCAP 1113 ----------- ----------- ----------- -----------
OAMHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
OAMHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
OAMHC 1113 ----------- ----------- ----------- -----------
HIPR2 1114 139-009-000 139-009-000 139-009-000 139-009-000
HIPR2 1116 139-009-000 139-009-000 139-009-000 139-009-000
HIPR2 1113 ----------- ----------- ----------- -----------
SS7HC 1116 139-010-000 139-010-000 139-010-000 139-010-000
GLSHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
GLSHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
GLSHC 1113 ----------- ----------- ----------- -----------
SCCP64 1114 139-010-000 139-010-000 139-010-000 139-010-000
SCCP64 1116 139-010-000 139-010-000 139-010-000 139-010-000
SCCP64 1113 ----------- ----------- ----------- -----------
ERTHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
ERTHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
ERTHC 1113 ----------- ----------- ----------- -----------
IPSHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
IPSHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
IPSHC 1113 ----------- ----------- ----------- -----------
ATMHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
ATMHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
ATMHC 1113 ----------- ----------- ----------- -----------
IPSG 1114 139-010-000 139-010-000 139-010-000 139-010-000
IPSG 1116 139-010-000 139-010-000 139-010-000 139-010-000
IPSG 1113 ----------- ----------- ----------- -----------
PKTGHC 1114 169-010-000 169-010-000 169-010-000 169-010-000
PKTGHC 1116 169-010-000 169-010-000 169-010-000 169-010-000
PKTGHC 1113 ----------- ----------- ----------- -----------
BLMCAP 1114 139-010-000 139-010-000 085-009-009 139-010-000
BLMCAP 1116 139-010-000 139-010-000 085-009-009 139-010-000
MCPHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
MCPHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
MCPHC 1113 ----------- ----------- ----------- -----------
SIPHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
SIPHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
SIPHC 1113 ----------- ----------- ----------- -----------
DEIR64 1114 139-010-000 139-010-000 139-010-000 139-010-000
DEIR64 1116 139-010-000 139-010-000 139-010-000 139-010-000
DEIR64 1113 ----------- ----------- ----------- -----------
ENUM64 1114 139-010-000 139-010-000 139-010-000 139-010-000
ENUM64 1116 139-010-000 139-010-000 139-010-000 139-010-000
ENUM64 1113 ----------- ----------- ----------- -----------
PKTG64 1114 169-010-000 169-010-000 169-010-000 169-010-000
PKTG64 1116 169-010-000 169-010-000 169-010-000 169-010-000
PKTG64 1113 ----------- ----------- ----------- -----------
BLDC64 1114 139-010-000 139-010-000 085-009-006 139-010-000
BLDC64 1116 139-010-000 139-010-000 085-009-006 139-010-000
BLDC64 1113 ----------- ----------- ----------- -----------
BLSLC32 1114 139-010-000 139-010-000 085-009-009 139-010-000
BLSLC32 1116 139-010-000 139-010-000 085-009-009 139-010-000
BLSLC32 1113 ----------- ----------- ----------- -----------
BLSLC64 1114 139-010-000 139-010-000 042-010-003 139-010-000
BLSLC64 1116 139-010-000 139-010-000 042-010-003 139-010-000
BLSLC64 1113 ----------- ----------- ----------- -----------
SIP64 1114 139-010-000 139-010-000 139-010-000 139-010-000
SIP64 1116 139-010-000 139-010-000 139-010-000 139-010-000
SIP64 1113 ----------- ----------- ----------- -----------
DEIR64 1114 139-010-000 139-010-000 042-010-003 139-010-000
DEIR64 1116 139-010-000 139-010-000 042-010-003 139-010-000
Command Executed
In this example, removable media is installed in both MASPs.
If a specific GPL is specified, then only that GPL is
displayed. For example, if the
rtrv-gpl:gpl=ss7hc command is entered,
then only the SS7HC GPL is displayed as shown in the following example.
eagle1 16-09-12 12:03:53 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
ALM is displayed for each approved GPL
version that does not match the GPL version shown in the
RELEASE column. If GPL auditing is
but
ALM is displayed for each GPL version
RELEASE column. The detection,
marking, and reporting of corrupt GPLs continues to be performed and is not
affected by turning GPL auditing off. The GPL version shown in the
RELEASE column is updated when the
act-gpl command is performed.
Loading a GPL onto the System
This section gives a general overview as to how a GPL is
loaded onto the EAGLE to be used by the applicable cards. The requirements and
steps for each GPL are different and are detailed in the procedures contained
in this chapter. The
rtrv-gpl examples shown in this
section are examples that are shown when E5-based control cards are installed
in the EAGLE.
A removable media is inserted into the removable media drive on the E5-MCAP card of the active MASP. If a specific GPL is displayed with the
rtrv-gplcommand, for example the SS7HC GPL, the following would be displayed.eagle1 16-09-09 18:30:48 MST EAGLE 46.4.0.0.0-69.6.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SS7HC 1114 139-006-000 139-006-000 139-004-000 ----------- SS7HC 1116 139-006-000 139-006-000 139-004-000 139-008-000 SS7HC 1115 ----------- ----------- ----------- ----------- ; Command ExecutedDisplaying the SS7HC GPL with the
rept-stat-gplcommand would display all the cards running the SS7HC GPL, as shown in this example.eagle1 16-09-09 18:31:17 MST EAGLE 46.4.0.0.0-69.6.0 GPL Auditing ON GPL CARD RUNNING APPROVED TRIAL SS7HC 1102 139-006-000 139-006-000 139-004-000 SS7HC 1205 139-006-000 139-006-000 139-004-000 SS7HC 1206 139-006-000 139-006-000 139-004-000 SS7HC 1207 139-006-000 139-006-000 139-004-000 Command Completed - When the
chg-gplcommand is executed, the specific GPL is copied from the removable media to the fixed disks. The specific GPL and the version number of the GPL on the removable media must be specified with thechg-gplcommand. The version number is found in theREMOVE TRIALcolumn of thertrv-gploutput. For this example thechg-gpl :gpl:SS7HC:ver=139-008-000command would be entered at the EAGLE terminal. -
The new version of the GPL is now the trial version of the GPL as shown in the examples of the
rtrv-gplandrept-stat-gploutputs.rtrv-gpl:gpl=ss7hceagle1 16-09-09 18:33:48 MST EAGLE 46.4.0.0.0-69.6.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SS7HC 1114 139-006-000 139-006-000 139-008-000 ----------- SS7HC 1116 139-006-000 139-006-000 139-008-000 139-008-000 SS7HC 1115 ----------- ----------- ----------- -----------rept-stat-gpl:gpl=ss7hceagle1 16-09-09 18:34:26 MST EAGLE 46.4.0.0.0-69.6.0 GPL Auditing ON GPL CARD RUNNING APPROVED TRIAL SS7HC 1102 139-006-000 139-006-000 139-008-000 SS7HC 1205 139-006-000 139-006-000 139-008-000 SS7HC 1206 139-006-000 139-006-000 139-008-000 SS7HC 1207 139-006-000 139-006-000 139-008-000 Command Completed. -
To make the trial version of the GPL the approved version, the
act-gplcommand is executed after the GPL has been copied from the removable media with thechg-gplcommand (steps 1 to 3). The trial and approved versions of the specific GPL are swapped as shown in thesertrv-gplandrept-stat-gploutput examples.rtrv-gpl:gpl=ss7hceagle1 16-09-09 18:35:31 MST EAGLE 46.4.0.0.0-69.8.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SS7HC 1114 139-008-000 139-008-000 139-006-000 ----------- SS7HC 1116 139-008-000 139-008-000 139-006-000 139-008-000 SS7HC 1115 ----------- ----------- ----------- -----------The system release ID table is updated with the version of the GPL specified with the
act-gplcommand. This GPL version is shown in theRELEASEcolumn of thertrv-gploutput after theact-gplcommand is performed.The
ALMindicator is not displayed in thertrv-gploutput because the approved version of the GPL matches the version in the system release ID table.rept-stat-gpl:gpl=ss7hceagle1 16-09-09 18:35:52 MST EAGLE 46.4.0.0.0-69.8.0 GPL Auditing ON GPL CARD RUNNING APPROVED TRIAL SS7HC 1102 139-006-000 ALM 139-008-000 139-006-000 SS7HC 1205 139-006-000 ALM 139-008-000 139-006-000 SS7HC 1206 139-006-000 ALM 139-008-000 139-006-000 SS7HC 1207 139-006-000 ALM 139-008-000 139-006-000 Command Completed.The
ALMindicator is displayed for the cards that are running the version of the GPL that does not match the version in the system release ID table (shown in theRELEASEcolumn of thertrv-gploutput). In this example, the cards are running the trial version which does not match the version in the system release ID table. -
To load the card with the new version of the application GPL, the card must be inhibited with the
inh-cardcommand, then placed back into service with thealw-cardcommand. To load the approved version of the GPL onto the card, thecode=apprparameter can be specified with thealw-cardcommand. It is not necessary to specify thecode=apprparameter to load the approved version of the GPL. Entering thealw-cardcommand without the code parameter loads the approved version of the GPL onto the card.If you wish to load the trial version of the GPL onto the card, the
code=trialparameter must be specified with thealw-cardcommand.To load the card with the new version of the flash GPL, the card must be inhibited with the
inh-cardcommand and flashed with theinit-flashcommand. The new flash GPL on the card should be activated with theact-flashcommand and then placed back into service with thealw-cardcommand.The following examples show the outputs of the
rtrv-gplandrept-stat-gplcommands after the card has been reloaded. The outputs will vary depending on whether or not the new version of the GPL has been made the approved version with theact-gplcommand, and which version (trial or approved) of the GPL is loaded onto the card.Example 1
The new GPL is the
APPROVEDversion and the card 1102 was reloaded with theAPPROVEDversion of the GPL. Card 1102 is now running theAPPROVEDandRELEASEversions of the GPL. TheALMindicator is not shown in thertrv-gploutput and is not shown for card 1102 inrept-stat-gploutput. TheALMindicator is shown for cards 1205, 1206, and 1207 because they are not running theRELEASEversion of the GPL.RTRV-GPL Output
eagle1 16-09-09 18:36:26 MST EAGLE 46.4.0.0.0-69.8.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SS7HC 1114 139-008-000 139-008-000 139-006-000 ----------- SS7HC 1116 139-008-000 139-008-000 139-006-000 139-008-000 SS7HC 1115 ----------- ----------- ----------- -----------REPT-STAT-GPL Output
eagle1 16-09-09 18:38:34 MST EAGLE 46.4.0.0.0-69.8.0 GPL Auditing ON GPL CARD RUNNING APPROVED TRIAL SS7HC 1102 139-008-000 139-008-000 139-006-000 SS7HC 1205 139-006-000 ALM 139-008-000 139-006-000 SS7HC 1206 139-006-000 ALM 139-008-000 139-006-000 SS7HC 1207 139-006-000 ALM 139-008-000 139-006-000 Command Completed.Example 2
The new GPL is the
APPROVEDversion and the card 1102 was reloaded with theTRIALversion of the GPL. The card is now running theTRIALversion of the GPL which is not theRELEASEversion of the GPL. TheALMindicator is not shown in thertrv-gploutput, but is shown for all the cards inrept-stat-gploutput because they are not running theRELEASEversion of the GPL.RTRV-GPL Output
eagle1 16-09-09 18:41:06 MST EAGLE 46.4.0.0.0-69.8.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SS7HC 1114 139-008-000 139-008-000 139-006-000 ----------- SS7HC 1116 139-008-000 139-008-000 139-006-000 139-008-000 SS7HC 1115 ----------- ----------- ----------- -----------REPT-STAT-GPL Output
eagle1 16-09-09 18:41:59 MST EAGLE 46.4.0.0.0-69.8.0 GPL Auditing ON GPL CARD RUNNING APPROVED TRIAL SS7HC 1102 139-006-000 ALM 139-008-000 139-006-000 SS7HC 1205 139-006-000 ALM 139-008-000 139-006-000 SS7HC 1206 139-006-000 ALM 139-008-000 139-006-000 SS7HC 1207 139-006-000 ALM 139-008-000 139-006-000 Command Completed.Example 3
The new GPL is the
TRIALversion and the card 1102 was reloaded with theTRIALversion of the GPL. Card 1102 is now running theTRIALversion of the GPL, but not theRELEASEversion of the GPL. TheALMindicator is not shown in thertrv-gploutput because theRELEASEversion of the GPL has not changed. TheALMindicator is shown for card 1102 in therept-stat-gploutput because card 1102 is not running theRELEASEversion of the GPL.RTRV-GPL Output
eagle1 16-09-09 18:43:39 MST EAGLE 46.4.0.0.0-69.6.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SS7HC 1114 139-006-000 139-006-000 139-008-000 ----------- SS7HC 1116 139-006-000 139-006-000 139-008-000 139-008-000 SS7HC 1115 ----------- ----------- ----------- -----------REPT-STAT-GPL Output
eagle1 16-09-09 18:44:12 MST EAGLE 46.4.0.0.0-69.6.0 GPL Auditing ON GPL CARD RUNNING APPROVED TRIAL SS7HC 1102 139-008-000 ALM 139-006-000 139-008-000 SS7HC 1205 139-006-000 139-006-000 139-008-000 SS7HC 1206 139-006-000 139-006-000 139-008-000 SS7HC 1207 139-006-000 139-006-000 139-008-000 Command Completed.Example 4
The new GPL is the
TRIALversion and the card 1102 was reloaded with theAPPROVEDversion of the GPL. Card 1102 is now running theAPPROVEDversion of the GPL which is theRELEASEversion of the GPL. TheALMindicator is not shown in thertrv-gploutput, and for all the cards inrept-stat-gploutput because they are running theRELEASEversion of the GPL.RTRV-GPL Output
eagle1 16-09-09 18:46:20 MST EAGLE 46.4.0.0.0-69.6.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SS7HC 1114 139-006-000 139-006-000 139-008-000 ----------- SS7HC 1116 139-006-000 139-006-000 139-008-000 139-008-000 SS7HC 1115 ----------- ----------- ----------- -----------REPT-STAT-GPL Output
eagle1 16-09-09 18:46:41 MST EAGLE 46.4.0.0.0-69.6.0 GPL Auditing ON GPL CARD RUNNING APPROVED TRIAL SS7HC 1102 139-006-000 139-006-000 139-008-000 SS7HC 1205 139-006-000 139-006-000 139-008-000 SS7HC 1206 139-006-000 139-006-000 139-008-000 SS7HC 1207 139-006-000 139-006-000 139-008-000 Command Completed
Updating the BLMCAP and OAMHC GPLs
This procedure updates the BLMCAP and OAMHC GPLs on the E5-MCAP cards in card locations 1113 and 1115 as a trial version from the removable media, then making the trial version of these GPLs the approved version of these GPLs. The E5-MCAP card in card locations 1113 and 1115 is used in combination with the TDM to form the Maintenance and Administration Subsystem Processor (MASP).
chg-gpl,
act-gpl, and
flash-card commands.
Caution:
Theflash-card command cannot be entered
if the IMT Rate Change sequence or the Extended Bit Error
Rate Test (BERT) is being performed.
The OAMHC GPL is updated using the
chg-gpl command.
Caution:
This procedure can be performed only on EAGLEs that contain E5-based control cards. Refer to Maintenance and Administration Subsystem for more information about the control cards.If any card is not running the version of the
GPL shown in the
rtrv-gpl output, the indicator
ALM is displayed next to the
GPL version in the
RUNNING column of the
rept-stat-gpl output, and next to the
GPL version in the
APPROVED column in the
rtrv-gpl output.
Removable media containing the BLMCAP and OAMHC GPLs that are being updated is required.
Figure 3-1 Updating the BLMCAP and OAMHC GPLs
Updating the Signaling Link and Data Link GPLs
This procedure is used to update the following GPLs: SS7IPGW, IPGWI, SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, and
IPSG. These names are used as the value of the gpl
parameter of the chg-gpl, act-gpl, rept-stat-gpl, and rtrv-gpl commands.
Signaling links are assigned to cards running the following GPLs: SS7IPGW, IPGWI, SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, and IPSG. The signaling link GPLs are assigned to the card types shown in Table 3-1.
Table 3-1 SS7 LIM Card Types
| GPL | Card Type |
atmansi, atmhc |
limatm (cards running the atmhc GPL must be E5-ATM cards) |
atmitu, atmhc |
lime1atm (cards running the atmhc GPL must be E5-ATM cards) |
ss7ipgw, ipgwi, iplhc, ipghc, ipsg |
dcm (cards running the iplhc, ipghc, or ipsg GPLs must be E5-ENET cards) |
ss7hc |
lime1, limt1 (these cards can be HC MIMs or E5-E1T1 cards) |
The data link GPLs are assigned to the card types shown in gpl-management-procedures1.html#GUID-8C0D8482-CC38-44BB-892D-8DCCB783A9FB__V2909559.
The card types shown in Table 3-1 and gpl-management-procedures1.html#GUID-8C0D8482-CC38-44BB-892D-8DCCB783A9FB__V2909559 are the values used for the type parameter of the ent-card command.
The cards running the SS7HC GPL are E5-E1T1-B cards. E5-E1T1-B cards are single-slot cards that can support up to 32 signaling links. These cards are either LIM-E1 or LIM-T1 cards. The rtrv-card output shows these cards running either the SS7ANSI or CCS7ITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the SS7HC GPL.
The cards running the SS7EPM GPL are E5-E1T1 cards which are single-slot cards that can support up to 32 signaling links. The E5-E1T1 cards are either LIM-E1 or LIM-T1 cards. The rtrv-card output shows these cards running either the SS7ANSI or CCS7ITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the SS7EPM GPL.
The cards running the IPLHC and IPGHC GPLs are E5-ENET, E5-ENET-B and SLIC cards supporting IP signaling links. The rtrv-card output shows this card running either the IPLIM or IPLIMI applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the IPLHC GPL. The IPGHC GPL allows the E5-ENET card to support SS7IPGW (ANSI IP Gateway) or IPGWI (ITU IP Gateway) signaling links. The rtrv-card output shows this card running either the SS7IPGW or IPGWI applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the IPGHC GPL.
The cards running the ATMHC GPL are cards that can contain the ATM high-speed signaling links on E5-ATM cards. The rtrv-card output shows these cards running either the ATMANSI or ATMITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the ATMHC GPL.
If the GPL is being updated to a new version, a removable media containing the GPL being updated is required.
If any card is not running the version of the GPL shown in the RELEASE column of the rtrv-gpl output, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output, and next to the GPL version in the APPROVED column in the rtrv-gpl output.
Canceling the REPT-STAT-SLK and RTRV-SLK Commands
Because the rept-stat-slk and rtrv-slk commands used in this procedure can output information for a long period of time, the rept-stat-slk and rtrv-slk commands can be canceled and the output to the terminal stopped. There are three ways that the rept-stat-slk and rtrv-slk commands can be canceled.
- Press the
F9function key on the keyboard at the terminal where therept-stat-slkorrtrv-slkcommands command were entered. - Enter the
canc-cmdwithout thetrmparameter at the terminal where therept-stat-slkorrtrv-slkcommands were entered. - Enter the
canc-cmd:trm=<xx>, where<xx>is the terminal where therept-stat-slkorrtrv-slkcommands were entered, from another terminal other that the terminal where therept-stat-slkorrtrv-slkcommands were entered. To enter thecanc-cmd:trm=<xx>command, the terminal must allow Security Administration commands to be entered from it and the user must be allowed to enter Security Administration commands. The terminal’s permissions can be verified with thertrv-secu-trmcommand. The user’s permissions can be verified with thertrv-userorrtrv-secu-usercommands.
For more information about the canc-cmd command, go to Commands User's Guide.
Figure 3-2 Updating the Signaling Link and Data Link GPLs
Sheet 1 of 5
Sheet 2 of 5
Sheet 3 of 5
Sheet 4 of 5
Sheet 5 of 5
Updating the Service GPLs
This procedure is used to update these GPLs: GLS, SCCPHC, and IPSHC. These names are used as the value of the gpl parameter of the chg-gpl, act-gpl, rept-stat-gpl, and rtrv-gpl commands.
These GPLs are assigned to the card types shown in Table 3-2.
Table 3-2 Service GPL Card Types
| GPL | Card Type |
| sccphc | dsm (these cards must be E5-SM4G/E5-SM8G cards) |
| iphsc | ipsm (these cards must be E5-ENET-B or SLIC cards) |
| glshc | tsm (these cards must be E5-TSM cards) |
The card types shown in Table 3-2 are the values used for the type parameter of the ent-card command.
If the GPL is being updated to a new version, a removable cartridge containing the GPL being updated is required.
Figure 3-3 Updating the Service GPLs
Sheet 1 of 7
Sheet 2 of 7
Sheet 3 of 7
Sheet 4 of 7
Sheet 5 of 7
Sheet 6 of 7
Sheet 7 of 7
Updating the Flash GPLs
GPLs: The GPLs are used as the value of the
chg-gpl,
act-gpl,
rept-stat-gpl, and
rtrv-gpl commands.
Table 3-3 EAGLE Card Applications and GPLs
| Intended Application GPL | Card configuration
(rtrv-card)
Hardware Type Used | Required Flash GPL | |
| APPL | Type | |||
| SCCP64 | VSCCP | DSM | SM8G-B | BLDC64 |
| VSCCP | DSM/SLIC | SLIC | BLSLC64 | |
| IPSG | IPSG | ENET/ENETB | E5-ENET-B | BLMCAP |
| IPSG | ENET/ENETB/SLIC | SLIC | BLSLC32 | |
| IPSG32 | IPSG | SLIC | SLIC | BLSLC32 |
| IPSHC69 | IPS | IPSM | E5-ENET-B | BLDC32 |
| IPS | IPSM | SLIC | BLSL932 | |
| MCPHC69 | MCP | MCPM | E5-MCPM-B | BLDC32 |
| MCP | MCPM | SLIC | BLSL932 | |
| OAMHC69 | OAM | E5-MCAP | E5-MASP | BLDC32 |
| SIP64 | SIPHC | DSM | SM8G-B | BLDC64 |
| SIPHC | DSM/SLIC | SLIC | BLSLC64 | |
| DEIR64 | DEIRHC | DSM | SM8G-B | BLDC64 |
| DEIRHC | DSM/SLIC | SLIC | BLSLC64 | |
| ENUM64 | ENUMHC | DSM | SM8G-B | BLDC64 |
| ENUMHC | DSM/SLIC | SLIC | BLSLC64 | |
| SFAPP | SFAPP | SLIC | SLIC | BLSLC64 |
| ATMHC | ATMITU | LIME1ATM | E5-ATM-B | BLMCAP |
| ATMANSI | LIMATM | E5-ATM-B | BLMCAP | |
| ERTHC | EROUTE | STC | E5-ENET-B | BLMCAP |
| EROUTE | STC | SLIC | BLSLC32 | |
| SS7HC | CCS7ITU | LIME1 | E5-E1T1-B | BLMCAP |
| SLIC | BLSLC32 | |||
| SS7ANSI | LIMT1 | E5-E1T1-B | BLMCAP | |
Updating the BLMCAP GPL for the E5-MASPs is not covered in this procedure. To update the OAMHC GPLs, perform Updating the BLMCAP and OAMHC GPLs .
If the GPL is being updated to a new version, removable media containing the GPL being updated is required.
Canceling the
REPT-STAT-SLK and
RTRV-SLK Commands
Because the
rept-stat-slk and
rept-stat-slk and
rept-stat-slk and
- Press the
Figure 3-4 Updating the Flash GPLs
Sheet 1 of 10
Sheet 2 of 10
Sheet 3 of 10
Sheet 4 of 10
Sheet 5 of 10
Sheet 6 of 10
Sheet 7 of 10
Sheet 8 of 10
Sheet 9 of 10
Sheet 10 of 10
Updating the HIPR2 GPL
This section presents the procedure for updating the HIPR2 generic program load (GPL). The HIPR2 GPL is used by the High-Speed IMT Packet Router 2 (HIPR2) card to control the IMT bus and resides on the fixed disk. The HIPR2 card resides only in slots 9 and 10 in each shelf in the EAGLE.
This section presents the procedure for loading the HIPR2 GPL onto the EAGLE as a trial version from a removable media, then making the trial version of the HIPR2 GPL the approved version.
If any card is not running the approved version of the GPL shown in the RELEASE column of the rtrv-gpl output, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output, and next to the GPL version in the APPROVED column in the rtrv-gpl output.
The removable media that contains the HIPR2 GPL to be loaded on to the EAGLE is required.
Figure 3-5 Updating the HIPR2 GPL
Sheet 1 of 5
Sheet 2 of 5
Sheet 3 of 5
Sheet 4 of 5
Sheet 5 of 5
Making the Trial Utility GPL the Approved Utility GPL
This procedure is used to make the trial UTILITY generic program load (GPL) the approved UTILITY GPL.
The UTILITY GPL cannot be loaded and run from the removable cartridge like the other GPLs. The approved version of the UTILITY GPL is on the fixed disk. The trial version of the UTILITY GPL is located on the removable cartridge or removable media. This procedure loads the trial UTILITY GPL from the removable cartridge to the fixed disk and makes it the approved UTILITY GPL.
The removable cartridge or removable media that contains the UTILITY GPL to be loaded on to the EAGLE is required.
When the UTILITY GPL is displayed with the rtrv-gpl command, the entry CDU appears in the GPL column of the rtrv-gpl output.
Figure 3-6 Making the Trial Utility GPL the Approved Utility GPL
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
Reloading the TDM LCA Clock Bitfile
This procedure is used to reload the clock LCA (logic cell array) bitfile on the TDMs using the init-card command. To reload the TDM clock LCA bitfile, the E5-MCAP card associated with the TDM being reloaded is initialized by entering the init-card command with the initclk=yes parameter.
It is recommended that the card specified in the init-card command is the GPSM-II or E5-MCAP card in the standby MASP. The rept-stat-db output in 7 shows which TDM is the standby TDM with the indicator ( STDBY) after the TDM’s card location. If the TDM in card location 1114 is the standby TDM, card location 1113 must be specified. If the TDM in card location 1116 is the standby TDM, card location 1115 must be specified.
The TDM clock LCA bitfile can be reloaded only on TDMs with part numbers 870-0774-15 or later. If the EAGLE contains older TDMs, these TDMs must be replaced with TDMs 870-0774-15 or later to perform this procedure.
Contact My Oracle Support (MOS) before replacing the TDMs.The init-card also contains the force=yes parameter. The force=yes parameter can be used only with the initclk=yes parameter. The force=yes parameter must be used if reloading the TDM clock LCA bitfile would cause a system clock outage.
Caution:
A system clock outage can be caused by either the EAGLE having only one TDM (a simplex MASP configuration) or if the status of the high-speed clocks, shown in therept-stat-clk output in 1, on the TDM which is not being reset is Fault. A system clock outage will result in a loss of traffic on some or all signaling links.
Figure 3-7 Reloading the TDM LCA Clock Bitfile
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
Updating the BLIXP GPL
The BLIXP GPL is a tar image of all the flash GPLs that are necessary to operate the cards shown in Table 3-4. When the BLIXP GPL is downloaded to the card, the tar image is un-archived and the flash GPLs are loaded onto the card.
Table 3-4 High-Capacity Cards
| HC MIM | E5-E1T1 | E5-ENET |
| E5-STC | E5-SM4G | |
| E5-ATM | E5-TSM |
This procedure updates the BLIXP GPL using the init-flash and act-flash commands.
Caution:
Theinit-flash command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed. The act-flash command cannot be entered if the Extended Bit Error Rate Test (BERT) is being performed.
The applications and entities supported by the high-capacity cards are shown in Table 3-5.
Table 3-5 High-Capacity Card Applications
| High-Capacity Card | Card Name (as shown on the card label) | Application | Application GPL Running on the Card | Supported Entities |
| HC MIM | HC MIM | SS7ANSI, CCS71TU | SS7HC | E1 or T1 signaling links |
| E5-E1T1 | E5-E1T1 | SS7ANSI, CCS71TU | SS7HC | E1 or T1 signaling links |
| E5-ENET | E5-ENET | SS7IPGW, IPLIM, IPLIMI, IPGWI, IPSG | IPLHC, IPGHC, IPSG | IP signaling links |
| E5-STC | E5-ENET | EROUTE | ERTHC | EAGLE 5 Integrated Monitoring Support |
| E5-SM4G | E5-SM4G | VSCCP | SCCPHC | GTT-related features |
| E5-ENET-B/SLIC |
E5-ENET-B SLIC |
IPS | IPSHC | Telnet sessions for remote connections to the EAGLE and SEAS terminals for the SEAS over IP feature |
| E5-ATM | E5-ATM | ATMANSI, ATMITU | ATMHC | ANSI and ITU ATM high-speed signaling links |
| E5-TSM | E5-TSM | GLS | GLSHC | Gateway Screening related features |
A removable cartridge or removable media containing the BLIXP GPL that is being updated is required.
Caution:
Before any high-capacity card can be updated with the BLIXP GPL, all the traffic hosted by the high-capacity card must be stopped, and the high-capacity card must be taken out of service.Canceling the REPT-STAT-SLK and RTRV-SLK Commands
- Press the
Figure 3-8 Updating the BLIXP GPL
Sheet 1 of 7
Sheet 2 of 7
Sheet 3 of 7
Sheet 4 of 7
Sheet 5 of 7
Sheet 6 of 7
Sheet 7 of 7
Updating a High-Capacity Card to Run the BLIXP GPL
High-capacity cards that were issued before EAGLE Release 43.0 may not be loaded with the BLIXP GPL. This procedure updates the high-capacity card with the BLIXP GPL using the flash-card command. The BLIXP GPL is a tar image of all the flash GPLs that are necessary to operate the high-capacity cards. The high-capacity cards are shown in Table 3-6. When the BLIXP GPL is downloaded to the card, the tar image is un-archived and the flash GPLs are loaded onto the card.
Table 3-6 High-Capacity Cards
| E5-ATM | E5-TSM |
Caution:
Theflash-card command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed.
The applications and entities supported by the high-capacity cards are shown in Table 3-7.
Table 3-7 High-Capacity Card Applications
| E5-ENET-B/SLIC |
E5-ENET-B SLIC |
Caution:
- Press the
Figure 3-9 Updating a High-Capacity Card to Run the BLIXP GPL
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
Conversion of SM8G-B Cards
There are two types of cards that can operate in 32-bit or 64-bit mode: SM8G-B and SLIC cards. SM8G-B cards are equipped with 8G bytes of RAM. The operator must convert the cards to operate on 64-bit mode in order to enable access to memory ranges beyond the 4G byte, the memory range limit for 32-bit mode cards.
Because the GPL image contains either 32-bit or 64-bit mode code, the card must be flashed with the correct version before being able to run on the desired mode. Follow the steps in SM8G-B 32-bit to 64-bit Conversion or SM8G-B 64-bit to 32-bit Conversion in order to convert an SM8G-B card to operate from one mode to the other.
SM8G-B Bootloader Swap
An SM8G-B card running on a BLMCAP version from a release prior to EAGLE 46.3 may contain the 32-bit mode only bootloader. This bootloader must be updated before converting to 64-bit mode. The following procedure is used to update the 32-bit mode bootloader to 64-bit. Skip this procedure if the card is already running the BLDC64 GPL.
The following procedure is used to convert the 32-bit mode to 64-bit. The target card must already be running on the BLMCAP GPL and had its bootloader swapped, as completed in SM8G-B Bootloader Swap. Skip this procedure if the card is already running the BLDC64 GPL.
The following procedure is used to convert the 64-bit mode to 32-bit. The target card must already be running on the BLDC64 GPL and contain the correct bootloader, as completed in SM8G-B Bootloader Swap. Skip this procedure if the card is already running the BLMCAP GPL.
Conversion of SLIC Cards
SLIC cards are equipped with 16G bytes of RAM. They can run on either the 32-bit mode BLSLC32 flash GPL or on the 64-bit mode BLSLC64 flash GPL.
Follow the steps in SLIC 32-bit to 64-bit Conversion or SLIC 64-bit to 32-bit Conversion in order to convert a SLIC card to operate from one mode to the other.
