B Setting Up a Secure Telnet Connection to the EAGLE using PuTTY
Appendix B, Setting Up a Secure Telnet Connection to the EAGLE using PuTTY contains the procedure for setting a secure telnet connection to the EAGLE using PuTTY.
This appendix describes the steps to set up a Telnet connection to to the EAGLE using the PuTTY client program.
The PuTTY client program must be installed on the machine that will be connecting to the EAGLE before this procedure can be performed. The PuTTY client program can be obtained at this website.
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
The examples shown in this procedure are based on version 0.58 of the PuTTY client program.This procedure is finished.
