3 EAGLE EIR Commands
This chapter contains brief descriptions of the EAGLE commands that can be used for configuration of the EIR feature.
EAGLE Commands for EIR
This chapter describes the EAGLE commands that are used for the configuration of the EIR feature.
Refer to Commands User's Guide for complete command descriptions including parameter names, valid parameter values, examples, and dependencies.
Table 3-1 Commands used for EIR
| Type | Commands |
| System Serial Number | ent/rtrv-serial-num |
| Card | ent/dlt/rtrv/alw/inh/init/rept-stat-card |
| Feature Control | chg/rtrv-feat, enable/chg/rtrv-ctrl-feat |
| EAGLE STP Self Identification | chg/rtrv-sid |
| Mated Application (MAP) | chg/dlt/ent/rtrv-map |
| Subsystem Application | chg/dlt/ent/rtrv-ss-appl |
| Service Selector | chg/dlt/ent/rtrv-srvsel |
| EIR GSM Options | chg/rtrv-gsmopts |
| Local Subsystem Activation | alw/inh-map-ss |
| SCTP Associations in Table IPAPSOCK | chg/dlt/ent/rept-stat/rtrv-assoc |
| IP Host Table | dlt/ent/rtrv-ip-host |
| Alarm Thresholds | chg/rtrv-th-alm |
EAGLE EIR GSM Options Commands
The GSM Options (gsmopts) commands are used to change and report on the values of one or more of the system-level processing options maintained in the GSMOPTS table. All values are assigned initially to system defaults at STP installation time, and they can be updated later using the chg-gsmopts command.
The options described in Table 3-2 apply to EIR.
Table 3-2 GSMOPTS Options for EIR
| Parameter | Range | Description |
EIRIMSICHK |
OFF or ON |
EIR IMSI Check status |
EIRRSPTYPE |
TYPE1, TYPE2, TYPE3 |
EIR Response Type |
EIRGRSP |
OFF, WHITELST, GRAYLST, BLKLST, UNKNOWN |
EIR Global Response status |
The EIRIMSICHK (EIR IMSI Check status) parameter is used to indicate whether or not the IMSI will be used when determining if an IMEI is to be Block Listed. If this parameter is on and an IMEI is found on the Block List, then the corresponding IMSI is retrieved. If the IMSI found in the message matches the IMSI retrieved, then the IMEI is considered to be on the Allow List. If the IMSIs do not match or the IMSI is not found, then the IMEI will remain Block Listed.
The EIRRSPTYPE parameter is used to determine the EIR Response Type. The Response Type is used to determine how the lists are searched, as shown in Table 3-3.
Table 3-3 Individual IMEI List Determination
| Block List | Gray List | Allow List | IMSI Check | IMSI Match | Result Type | LOG Entry | LOG Entry Result | MSU Result Equipment Status |
Y |
N |
N |
Y |
Y |
1 |
N |
White with IMSI Override |
0 |
Y |
N |
N |
Y |
Y |
2 |
N |
0 |
Y |
N |
N |
Y |
Y |
3 |
N |
Unknown |
Return Error=7 |
Y |
N |
N |
Y |
N |
1 |
Y |
Black with IMSI Failed |
1 |
Y |
N |
N |
Y |
N |
2 |
Y |
1 |
Y |
N |
N |
Y |
N |
3 |
N |
Unknown |
Return Error=7 |
Y |
N |
Y |
N |
DC |
1 |
Y |
Black |
1 |
Y |
N |
Y |
N |
DC |
2 |
Y |
Black |
1 |
Y |
N |
Y |
N |
DC |
3 |
Y |
Black |
1 |
Y |
N |
Y |
Y |
Y |
1 |
N |
0 |
Y |
N |
Y |
Y |
Y |
2 |
N |
0 |
Y |
N |
Y |
Y |
Y |
3 |
N |
0 |
Y |
Y |
N |
N |
DC |
1 |
Y |
Black |
1 |
Y |
Y |
N |
N |
DC |
2 |
Y |
Black |
1 |
Y |
Y |
N |
N |
DC |
3 |
N |
Unknown |
Return Error=7 |
Y |
Y |
N |
Y |
Y |
1 |
Y |
0 |
Y |
Y |
N |
Y |
Y |
2 |
Y |
0 |
Y |
Y |
N |
Y |
Y |
3 |
Y |
0 |
N |
Y |
N |
Y |
DC |
1 |
Y |
Gray |
2 |
N |
Y |
N |
Y |
DC |
2 |
Y |
Gray |
2 |
N |
Y |
N |
Y |
DC |
3 |
Unknown |
Return Error=7 |
N |
Y |
Y |
DC |
DC |
1 |
Y |
Gray |
2 |
N |
Y |
Y |
DC |
DC |
2 |
Y |
Gray |
2 |
N |
Y |
Y |
DC |
DC |
3 |
Y |
Gray |
2 |
N |
N |
Y |
DC |
DC |
1 |
N |
White |
0 |
N |
N |
Y |
DC |
DC |
2 |
N |
White |
0 |
N |
N |
Y |
DC |
DC |
3 |
N |
White |
0 |
N |
N |
N |
DC |
DC |
1 |
N |
White |
0 |
N |
N |
N |
DC |
DC |
2 |
N |
Unknown |
Return Error=7 |
N |
N |
N |
DC |
DC |
3 |
N |
Unknown |
Return Error=7 |
Y |
Y |
Y |
N |
DC |
1 |
Y |
Black |
1 |
Y |
Y |
Y |
N |
DC |
2 |
Y |
Black |
1 |
Y |
Y |
Y |
N |
DC |
3 |
Y |
Black |
1 |
Y |
Y |
Y |
Y |
Y |
1 |
N |
0 |
Y |
Y |
Y |
Y |
Y |
2 |
N |
0 |
Y |
Y |
Y |
Y |
Y |
3 |
N |
0 |
Y |
Y |
Y |
Y |
N |
1 |
N |
1 |
Y |
Y |
Y |
Y |
N |
2 |
N |
1 |
Y |
Y |
Y |
Y |
N |
3 |
N |
1 |
For EIR Response Types 1 or 2, the IMEI searches are handled in the following manner:
If the IMEI is found in the Block List table, the search stops without searching the White and Gray List tables. The IMEI is considered Block Listed regardless of IMEI’s presence on the White or Gray List tables.
If the IMEI is found in the Gray List table, but not found in the Block List table, the search stops without searching the Allow List table. The IMEI is considered Gray Listed regardless of the IMEI’s presence on the Allow List table.
For EIR Response Type 3, the IMEI searches are handled in the following manner:
The Allow List table is searched first. If the IMEI is not found in the Allow List table, the IMEI is treated as unknown - no other table searches need to be performed.
If the IMEI is found in the Allow List table, the Block List table is searched next. If the IMEI is in the White and Block List tables, the IMEI is considered Block Listed - no need to search the Gray List table.
If the IMEI is found in Allow List table, but not in the Block List table, the Gray List table is searched. If the IMEI is in the White and Gray list tables, the IMEI is considered Gray Listed. If the IMEI is in the Allow List table, but not in the Gray List table, the IMEI is considered Allow Listed.
The EIRGRSP parameter is used to turn on the EIR Global Response Type. The Global Response Type is used to override the response that is normally sent back to the MSC. The default is set to OFF. When set to OFF, the normal list logic is applied to the IMEI. If the Global Response Type is set to something other than OFF, then there is no list logic processing and the corresponding response is sent to the MSC.
EAGLE EIR Service Selector Commands
The EIR service is eir.
EIR supports ANSI, ITU-I, and ITU-N Global Title Indicators.
The Global Title Indicator (GTI) value can be either 2 or 4. The Numbering Plan and Nature of Address Indicator cannot be specified when the GTI is 2, and must be specified when the GTI is 4.
EIR does not support the Service Nature of Address or the Service Numbering Plan.
The Subsystem Number (SSN) must be defined in the MAP table, and supports the asterisk (*) value.
EAGLE Feature Control Commands
The chg/rtrv-feat commands are used to turn on and display the on/off status of features, such as the GTT feature, that are controlled with feature bits. After a feature that is controlled with a feature bit is turned on, the feature cannot be turned off.
The enable/chg/rtrv-ctrl-feat commands are used to enable, turn on, and display the status of controlled features that are controlled by feature access keys. The feature access key is based on the feature part number and the serial number of the system that uses the feature, making the feature access key site-specific. When a feature is enabled by entering the enable-ctrl-feat command with the feature part number and feature access key, the feature is recognized by the system. Other actions might be required to make the feature fully operational, such as turning the feature on, installing hardware, and provisioning information in database tables.
Some features can be enabled with a temporary part number and feature access key for a limited trial of the feature. When the trial period expires, the feature must be enabled with a permanent part number and feature access key to continue use of the feature.
EIR S13/S13' Interface Support Commands
The commands in Table 3-4 support the EIR S13/S13' Interface Support feature.
Table 3-4 Commands for EIR S13/S13' Interface Support feature
| Command | Description |
configures S13-specific options |
displays S13-specific options |
configures Diameter connection and flow control by entering Diameter connection values associated to a particular association in table IPAPSOCK |
changes Diameter connection and flow control configuration values |
deletes Diameter connection |
displays Diameter connection status and flow control data |
displays S13 card statistics |
Table DEIROPTS
The
chg-deiropts and
rtrv-deiropts commands configure and
display the EIR S13/S13' Interface Support options of the virtual table
DEIROPTS, which is part of table EGLEOPTS. The table DEIROPTS options are shown
in
Table 3-5.
Table 3-5 Table DEIROPTS options
| Name | Values | Description |
DEIRIMSICHK |
OFF ON |
IMSI Check The IMSI Check specifies whether IMSI is used when determining if an IMEI is to be blocklisted. If this option is set to ON and an IMEI is found on the Blocklist, then the corresponding IMSI will be retrieved. If the IMSI found in the message matches the IMSI retrieved, then the IMEI is considered to be on the Allowlist. If the IMSIs do not match or the IMSI is not found, then the IMEI will remain blocklisted. Default value is OFF. |
DEIRRSPTYPE |
TYPE1 TYPE2 TYPE3 |
S13 Response Type The S13 Response Type is used to determine how the lists are to be searched. Default value is TYPE1. |
DEIRGRSP |
OFF WHITELST GRAYLST BLKLST UNKNOWN |
S13 Global Response Type The S13 Global Response Type is used to override the response that is sent to the MME or SGSN. When S13 Global Response Type is set to OFF, the normal list logic is applied to the IMEI. If the S13 Global Response Type is set to any value except OFF, then list logic processing is not performed and the corresponding response is sent to the MME or SGSN. Default value is OFF. |
CONGERR |
3004 5006 |
Congestion Error This is the value in the result code Attribute Value Pair (AVP) of the response sent at the time of congestion. If the incoming messages on the card running the DEIR64 GPL exceed the card or connection capacity and the card is not able to process the messages, the messages are discarded and the card responds with the configured value in the result code.
VENDID |
unsigned32 |
S13 local Vendor ID All outgoing messages that require Vendor ID in VENDOR_SPECIFIC_APPLICATION_ID use this configured value. Because only the value 10415 is supported, the CEA message contains 10415 as the Vendor Id in the response. Default value is 0. |
PRODUCT |
alphanumeric string |
Product Name The configured value contains the vendor-assigned name for the product. All outgoing messages that require the Product Name AVP use this configured value. Default value is NONE. |
APPLID |
unsigned32 |
Authentication Application ID The configured Application ID should match the Auth-Application-Id (AVP Code 258) value in the Vendor-Specific-Application-ID AVP. Currently, only 16777252 APPLID is supported by EAGLE and this parameter cannot be changed. Default value is 16777252. |
DPRCAUSE |
REBOOTING (0) BUSY (1) DO_NOT_WANT_TO_TALK (2) |
Disconnect Cause The Disconnect Cause in all DPR messages generated by EAGLE use this value. Default value is DO_NOT_WANT_TO_TALK (2). |
Table DCONN
The
ent-dconn,
chg-dconn,
dlt-dconn, and
rtrv-dconn commands configure and
display the EIR S13/S13' Interface Support options of the table DCONN, which
supports the provisioning information associated with the Diameter connection.
The table DCONN options are shown in
Table 3-6.
Table 3-6 Table DCONN options
DCNAME |
Diameter Connection Name The Diameter Connection Name identifies the Diameter connection linked to an association. This option is mandatory. |
ANAME |
Association Name This name identifies the association configured in the association table with the Diameter adapter. This option is mandatory. |
RSVDTPS |
integer from 100 to 8000, inclusive |
Reserved TPS This is the guaranteed TPS for a connection. Total RSVDTPS on a card cannot exceed 8000. Default value is 250. |
MAXTPS |
Max TPS The unused S13 card capacity is allocated among the connections that have exceeded their RSVDTPS values up to the limit of MAXTPS value provisioned for the particular connection. Default value is 8000. |
TW |
6sec - 30sec |
Diameter Watchdog Timer Default value is 6sec. |
TD |
1sec - 10sec |
Diameter Peer Disconnect Timer Default value is 3sec. |
REPT-STAT-DEIR Command
rept-stat-deir command displays the
overall status of the Diameter EIR S13/S13' service on the EAGLE. This command
is similar to the
rept-stat-sccp and
rept-stat-sip commands. The Diameter
connection status is displayed in the
Status field when
the
rept-stat-deir command is entered with
the
dcname parameter. The possible values
for Diameter
Status parameter
are:
- UP - The Diameter connection status is up and active. This status supports the following Diameter connection states: Active, Closing, Pending.
- DOWN - The Diameter connection status is down or closed. This status supports the following Diameter connection states: Inactive, Open, Closed.
rept-stat-deir command can be entered
with or without parameters. If the
without parameters, the displayed consists of a
per diameter card
status, TPS on each S13 card, total S13 statistics, and alarms associated with
the Diameter EIR S13/S13' service in the
DEIR ALARM STATUS field. The following
parameters can be entered with the
rept-stat-deir command:
loc- Diameter card location for which card status, overall card TPS, and per-connection card statistics are reportedpeakreset- Reset peak values for a card or a specified Diameter connectionmode- Overall S13 TPS and per diameter connection statistics in the EAGLE displayed; allowed value: perfdcname- Diameter connection name, which is the unique logical name assigned to each diameter connection; output display: status, TPS, and statistics of the specified Diameter connection
The
pegs shown in
eagle-eir-commands.html#GUID-A94EEFF7-3261-4A53-9E67-BC3D80052885__V5594134.
Table 3-7 REPT-STAT-DEIR Pegs
| Pegs | Condition |
| SUCCESS |
Messages which fall in these categories:
| ERROR |
| WARNING |
| OVERFLOW | Number of message discarded due to congestion |
| TOTAL MSGS | Total number of messages received: Success + Error + Warning messages |
PASS Commands supported by S13 card
- ARP - displays and modifies the Internet to Ethernet address translation tables used by the address resolution protocol
- ASSOCRTT - displays round-trip statistics for a given association
- CPUM - displays CPU utilization
- MSUCOUNT - displays MSU count for particular association and routes, including S13/S13' protocol
- NETSTAT - displays network statistics from the IP stack
- NSLOOKUP - returns the IP address for a specified hostname, or returns a hostname for a specified IP address
- PING - tests for the presence of hosts on the network
- SCTP - displays MSU count and current state of specific association
- SYSSTAT - display system buffer, CPU configuration, and database-related information
- TRACEROUTE - returns/traces the complete path a message has taken to reach the destination
