B Unsolicited Output Message Groups
This appendix provides a list of the unsolicited alarm messages (UAMs) and unsolicited information messages (UIMs) generated by the EAGLE and the output groups to which these messages are assigned. The output message groups are shown in alphabetical order.
These messages are broadcast to the EAGLE terminals. To
control which terminals these messages are broadcast, the messages have been
placed into these output message groups. The
chg-trm command is used to control to
which terminals these groups of output messages are broadcast. For details
about using the
chg-trm command, see the “Changing
Terminal Characteristics” procedure in
Database Administration - System Management User's
Guide, or the
chg-trm command description in
Commands User's Guide.
Scheduled Measurements for systems up to 700 links are sent to the Traffic Unsolicited Output Message Group and are not included in this appendix. No other unsolicited output is sent to this output group. Refer to Measurements Reference for traffic measurements information. Refer to System Administration - System Management User's Guide for information on configuring the measurements terminal for systems up to 700 links.
Each table contains the number of the UAM or UIM, the alarm level assigned to the message, and the text of the message.
Application Subsystem Unsolicited Output Message Group
Table B-1 Application Subsystem Unsolicited Output Message Group
| UAM/UIM Number | Alarm Level | Message Text |
| 0283 | Major | LNP Ported LRNs approaching Feat. Capacity |
| 0284 | None | LNP Ported LRNs Capacity Normal |
| 0285 | Major | LNP Ported NPAs approaching Feat. Capacity |
| 0286 | None | LNP Ported NPAs Capacity Normal |
| 0287 | Critical | RTDB Table Level 2 FAK Cap Exceeded |
| 0288 | Major | RTDB Table Level 1 FAK Cap Exceeded |
| 0289 | None | RTDB Table FAK Capacity Normal |
| 0394 | None | INP Subsystem is available |
| 0395 | Critical | INP Subsystem is not available |
| 0396 | Critical | INP Subsystem is disabled |
| 0397 | None | INP Subsystem is removed |
| 0398 | Minor | INP Subsystem normal, card(s) abnormal |
| 0424 | Critical | LNP Subsystem is not available |
| 0425 | Minor | LNP Subsystem normal, card(s) abnormal |
| 0426 | None | LNP Subsystem is available |
| 0427 | Major | LNP Subsystem degraded, card(s) abnormal |
| 0428 | Major | INP Subsystem degraded, card(s) abnormal |
| 0429 | Major | ATINPQ Subsystem degraded, card(s) abnormal |
| 0434 | None | LNP Subsystem is removed |
| 0435 | Critical | LNP Subsystem is disabled |
| 0436 | Major | LNP ACG node overload |
| 0452 | Major | Exceeded Service Error Threshold Lvl 1 |
| 0453 | Critical | Exceeded Service Error Threshold Lvl 2 |
| 0454 | Normal | Service Error Threshold Alarm Cleared |
| 0455 | Critical | EIR Subsystem is not available |
| 0456 | Critical | EIR Subsystem is disabled |
| 0457 | Minor | EIR Subsystem normal, card(s) abnormal |
| 0458 | None | EIR Subsystem is available |
| 0459 | None | EIR Subsystem removed |
| 0460 | Major | EIR Subsystem degraded, card(s) abnormal |
| 0500 | None | Alarm for this entity is being cleared |
| 0526 | None | Service is available |
| 0527 | Minor | Service abnormal |
| 0528 | Critical | Service is not available |
| 0529 | Critical | Service is disabled |
| 0530 | None | Service is removed |
| 0547 | Major | Service degraded |
| 0551 | Critical | V-Flex Subsystem is not available |
| 0552 | Critical | V-Flex Subsystem is disabled |
| 0553 | Minor | V-Flex Subsystem normal, card(s) abnormal |
| 0554 | None | V-Flex Subsystem is available |
| 0555 | None | V-Flex Subsystem is removed |
| 0556 | Major | V-Flex Subsystem degraded, card(s) abnormal |
| 0565 | Critical | ATINPQ Subsystem is not available |
| 0566 | Critical | ATINPQ Subsystem is disabled |
| 0567 | Minor | ATINPQ Subsystem normal, card(s) abnormal |
| 0568 | None | ATINPQ Subsystem is available |
| 0569 | None | ATINPQ Subsystem is removed |
| 0598 | Major | Subsystem degraded, card(s) abnormal |
| 1030 | None | Inh EIR SS request already outstanding |
| 1031 | None | Failure Inhibiting EIR SS |
| 1102 | None | Invalid Length for Map IMEI Parameter |
| 1103 | None | LSS:No Map IMEI Parameter present |
| 1121 | None | LNP rcvd query from unknown CGPA PC |
| 1122 | None | LNP rcvd query with undefined TT |
| 1123 | None | LNP rcvd query with Message Relay TT |
| 1124 | None | SIP: Dgts truncated in 302 response |
| 1139 | None | DEIROPTS: DEIR Global Response is ON |
| 1140 | None | DEIROPTS: DEIR Global Response is OFF |
| 1164 | None | Inh LNP SS request already outstanding |
| 1166 | None | ACG Node Overload Level Change |
| 1169 | None | SCCP rcvd inv TCAP portion |
| 1174 | None | Inh Local SS request already outstanding |
| 1242 | None | Conv to intl num - Dflt CC not found |
| 1243 | None | Conv to intl num - Dflt NC not found |
| 1244 | None | Conv to intl num - Dflt MCC not found |
| 1245 | None | Conv to intl num - Dflt MNC not found |
| 1246 | None | Invalid length of conditioned digits |
| 1247 | None | Conversion of MGT to IMSI not possible |
| 1255 | None | IS-41 LNP Qry rejected: WNP is OFF |
| 1256 | None | NP Circular Route detected |
| 1260 | None | LSS: Unsupported TCAP msg type |
| 1261 | None | LSS: Invalid len in transaction portion |
| 1262 | None | LSS: Invalid len in dialogue portion |
| 1263 | None | LSS: Invalid len in component portion |
| 1264 | None | LSS: No originating transaction ID |
| 1265 | None | LSS: Invalid transaction ID len |
| 1266 | None | LSS: Destination transaction ID in Begin |
| 1267 | None | LSS: No External element |
| 1268 | None | LSS: No External Object Identifier |
| 1269 | None | LSS: Not Structured Dialogue |
| 1270 | None | LSS: No External ASN1-Type |
| 1271 | None | LSS: No Dialogue Request |
| 1272 | None | LSS: No Application Context Name |
| 1273 | None | LSS: No ACN Object Identifier |
| 1274 | None | LSS: No component portion |
| 1275 | None | LSS: First component not an Invoke |
| 1276 | None | LSS: No Invoke ID |
| 1277 | None | LSS: No operation code |
| 1278 | None | LSS: No parameter (set/sequence) |
| 1279 | None | LSS: Unsupported network type |
| 1280 | None | LSS: Unsupported SCCP msg type |
| 1282 | None | LSS: Unsupported SCCP CDPA GTI |
| 1283 | None | LSS: Unsupported SCCP CGPA RI |
| 1284 | None | LSS: Unknown SSP PC |
| 1285 | None | LSS: No SCCP CGPA SSN |
| 1286 | None | LSS: Invalid INAP CalledPartyNumber len |
| 1287 | None | LSS: Unsupported ACN Object ID len |
| 1288 | None | LSS: Unsupported operation code |
| 1289 | None | LSS: No parameter sequence |
| 1290 | None | LSS: No INAP ServiceKey parameter |
| 1291 | None | LSS: No INAP CalledPartyNumber parameter |
| 1292 | None | LSS: Parameters out of sequence |
| 1293 | None | LSS: Linked ID in query |
| 1294 | None | Invalid digits in MAP MSISDN parameter |
| 1295 | None | Translation PC is EAGLE's |
| 1296 | None | Translation PC type is ANSI |
| 1297 | None | Invalid length of prefix/suffix digits |
| 1298 | None | SIP message decode failed |
| 1306 | None | GSMOPTS: EIR Global Response in ON |
| 1307 | None | GSMOPTS: EIR Global Response in OFF |
| 1342 | None | ANSI IS-41 INP Qry rejected: AINPQ is OFF |
| 1343 | None | INAP INP Qry rejected: INPQ is OFF |
| 1346 | None | IS-41 Missing Mandatory Parameters |
| 1347 | None | IS-41 Digits - Bad Encoding Scheme |
| 1348 | None | IS-41 Number of dgts exceeds the maximum |
| 1374 | None |
SMS NP Destination address decode failed SMS B-Party address decode failed |
| 1375 | None |
SMS NP Failed to modify TCAP message SMS B-Party Failed to modify TCAP MSU |
| 1376 | None |
SMS NP outbound digits length exceeds limit SMS Failed to modify B-Party digits |
| 1378 | None | Inh VFlex SS request already outstanding |
| 1379 | None | Failure Inhibiting VFlex SS |
| 1380 | None | VFLEX: No RN digits provisioned |
| 1381 | None | VFlex: CD entry not found |
| 1382 | None | LSS: Too many digits for DRA parameter |
| 1384 | None | G-Flex MLR: Op without IMSI erroneous |
| 1385 | None | G-Flex MLR: Op without IMSI skipped |
| 1386 | None | G-Flex MLR: Op with bad TCAP skipped |
| 1387 | None | G-Flex MLR: Op with bad IMSI skipped |
| 1395 | None | Inh ATINPQ SS request alrdy outstanding |
| 1396 | None | Failure Inhibiting ATINPQ SS |
| 1397 | None | LSS: Missing Mandatory Parameter |
| 1398 | None | ATINPQ: Badly formatted Subs Id |
| 1399 | None | ATINPQ: Subscriber Identity not MSISDN |
| 1400 | None | LSS: Invalid MSISDN digits length |
| 1401 | None | LSS: Unsupported numbering plan |
| 1402 | None | ATINPQ: Invalid Requested Info |
| 1403 | None | LSS: Dgts truncated in encd parms |
| 1408 | None | TIF: Modified MSU too large to route |
| 1410 | None | MOSMS: Migrated Subscriber with no entity |
| 1416 | None | MAP Missing Mandatory Parameters |
| 1425 | None | SMS A-party Address decode failed |
| 1426 | None | S-Port: Missing GRN for srvc prtd subs |
| 1433 | None | AIQ: Inhibit request already pending |
| 1434 | None | AIQ: Failure Inhibiting SS |
| 1435 | None | AIQ: TriggerType not provisioned |
| 1436 | None | AIQ: : Unsupported Digits(Dialed) length |
| 1439 | None | SIP card exceeded threshold TPS |
| 1440 | None | G-Flex MLR: Op with bad MSISDN skipped |
| 1448 | None | G-Flex MLR: Op w/o IMSI/MSISDN skipped |
| 1450 | None | IDPRCDPN CDPN Encoding Failed |
| 1451 | None | IDPRCDPN CGPN Encoding Failed |
Card Unsolicited Output Message Group
Table B-2 Card Unsolicited Output Message Group
| 0001 | Major | Card has reset |
| 0008 | Major | Active MASP has become isolated |
| 0009 | None | MASP became active |
| 0010 | None | MASP became standby |
| 0013 | Major | Card is isolated from the system |
| 0014 | None | Card is present |
| 0021 | Minor | Clock A for card failed, Clock B normal |
| 0022 | Minor | Clock B for card failed, Clock A normal |
| 0023 | Minor | Clocks A and B for card failed |
| 0024 | None | Clock A for card normal |
| 0025 | None | Clock B for card normal |
| 0026 | None | Clocks A and B for card normal |
| 0030 | Minor | HIPR2 detected a minor Congested Second |
| 0031 | Major | HIPR2 detected a major Congested Second |
| 0032 | None | HIPR2 Congestion cleared |
| 0033 | None | Card database has been corrected |
| 0034 | Minor | Card database is inconsistent |
| 0035 | Minor | Card database is corrupted |
| 0036 | None | Card backup database has been corrected |
| 0037 | Minor | Card backup database is inconsistent |
| 0038 | Minor | Card backup database is corrupted |
| 0053 | Major | Standby TDM failure |
| 0054 | None | Standby TDM failure cleared |
| 0055 | Minor | Persistent device state tbl corrupt |
| 0056 | Minor | Persistent device state tbl diff version |
| 0057 | None | Persistent device state tbl corrected |
| 0077 | Critical | Card temperature is critical lvl:T2 |
| 0078 | Major | Card temperature above nominal |
| 0079 | None | Card temperature within nominal levels |
| 0080 | Major | Shelf FAN bit is OFF |
| 0081 | None | Shelf FAN bit is ON |
| 0092 | Critical | MDAL not responding |
| 0093 | None | MDAL alarm cleared |
| 0096 | None | Card has been reloaded |
| 0099 | Major | Incompatible HW for provisioned slot |
| 0102 | Minor | Motherboard BIP invalid |
| 0103 | None | Motherboard BIP valid |
| 0124 | Minor | ENUM Threshold -Level1 exceeded |
| 0125 | Major | ENUM Threshold -Level2 exceeded |
| 0126 | Normal | ENUM Threshold Condition cleared |
| 0127 | Critical | ENUM card capacity exceeded |
| 0129 | Normal | ENUM card TPS is normal |
| 0130 | None | Card successfully loaded with data |
| 131 | None | HW alarm cleared for Intgd Measurements |
| 0132 | Major | Loading failed: table not found |
| 0133 | Major | Loading failed: data read Error |
| 0134 | Major | Loading failed: bad checksum returned |
| 0135 | Major | Loading failed: GPL load timeout |
| 0136 | Major | Loading failed: data load timeout |
| 0137 | Major | Loading failed: invalid GPL |
| 0138 | Major | Loading failed: GPL format error |
| 0139 | Major | Loading failed: disk read prep error |
| 0140 | Major | Loading failed: disk read response error |
| 0141 | Major | Loading failed: disk read failed |
| 0145 | Minor | HS Clock A for card failed, B normal |
| 0146 | Minor | HS Clock B for card failed, A normal |
| 0147 | Minor | High Speed Clocks A & B for card failed |
| 0148 | None | High Speed Clock A for card normal |
| 0149 | None | High Speed Clock B for card normal |
| 0159 | None | High Speed Clocks A & B for card normal |
| 0225 | Major | CARD running outdated Flash GPL |
| 0297 | Major | Incorrect LIM port configuration |
| 0298 | Minor | Card not using config. SCTP csum method |
| 0299 | None | Config. SCTP csum method alarm cleared |
| 0300 | Major | TVG Grant Failure |
| 0301 | None | TVG Grant Recovery |
| 0400 | None | Alarm cleared by deleting card |
| 0422 | Major | Insufficient memory for LNP |
| 0423 | None | Card reload attempted |
| 0441 | Major | Incorrect MDB - CPU |
| 0442 | Critical | RTDB database capacity is 95% full |
| 0443 | Major | RTDB database is corrupted |
| 0444 | Minor | RTDB database is inconsistent |
| 0445 | None | RTDB database has been corrected |
| 0446 | Major | RTDB database capacity is 80% full |
| 0447 | None | RTDB database memory alarm cleared |
| 0448 | Minor | RTDB database is incoherent |
| 0449 | Major | RTDB resynchronization in progress |
| 0450 | Major | Invalid HW for Integrated GLS |
| 0451 | Major | RTDB reload is required |
| 0452 | Major | Exceeded Service Error Threshold Lvl1 |
| 0454 | None | Service Error Threshold Alarm Cleared |
| 0486 | Minor | DEIR Threshold - Level1 exceeded |
| 0487 | Major | DEIR Threshold - Level2 exceeded |
| 0488 | Normal | DEIR Threshold Condition Cleared |
| 0489 | Critical | DEIR capacity exceeded |
| 0490 | Normal | DEIR normal |
| 0548 | Major | GTT HexTree DB corrupted. TPS derated |
| 0549 | Major | GTT HexTree DB incoherent. TPS derated |
| 0550 | Normal | GTT HexTree DB alarm cleared |
| 0570 | Minor | Incompatible flash image for sys rel |
| 0573 | Major | BERT Test Failed |
| 0574 | None | BERT Test Passed |
| 0575 | Major | Card type not HIPR2 |
| 0622 | Minor | SIP Threshold - Level1 |
| 0623 | Major | SIP Threshold - Level2 |
| 0624 | None | SIP Threshold condition cleared |
| 0625 | None | SIP SYSTEM normal, card(s) abnormal |
| 0626 | None | SIP Threshold Level Critical |
| 0901 | Major | Card DB load timeout, check GLS card |
| 0902 | None | Card DB is stable |
| 0903 | Major | IP Link A is down |
| 0904 | None | IP Link A is up |
| 0905 | Major | IP Link B is down |
| 0906 | None | IP Link B is up |
| 0907 | None | HW limiting TPS rate alarm cleared |
| 0908 | Major | HW cannot support purchased TPS rate |
| 1082 | None | A mem single bit error report |
| 1119 | None | Cards out of phase with flash procedure |
| 1141 | None | AIN INP Qry rejected: AINPQ is OFF |
| 1158 | None | Minor HIPR2 switching capacity reached |
| 1159 | None | Major HIPR2 switching capacity reached |
| 1238 | None | Full database reload initiated |
| 1241 | None | SCCP Card logging capacity exceeded |
| 1453 | None | EE Collection started |
| 1454 | None | EE Collection end |
| 1455 | None | EE Queue Full, Package dropped |
| 1456 | None | Hub Congested, Package dropped |
| 1457 | None | GEDTI Port enabled |
| 1458 | None | GEDTI Port disabled |
| 1459 | None | TCP Connection lost b/w IPSM and EEPC |
| 1462 | None | EE not configured |
| 1472 | None | SCTP Buffer full timer expired, Restart |
| 1473 | None | Unable to connect to socket |
| 1474 | None | GTT DB reload initiated |
Clock Unsolicited Output Message Group
Table B-3 Clock Unsolicited Output Message Group
| 0113 | None | Clock alarm(s) cleared |
| 0128 | Critical | All clocks have failed |
| 0160 | Minor | 1116-S clock failed |
| 0161 | Minor | 1116-P clock failed |
| 0162 | Major | 1116-P, 1116-S clocks failed |
| 0163 | Minor | 1114-S clock failed |
| 0164 | Major | 1114-S, 1116-S clocks failed |
| 0165 | Minor | 1114-S, 1116-P clocks failed |
| 0166 | Major | 1114-S, 1116-P, 1116-S clocks failed |
| 0167 | Minor | 1114-P clock failed |
| 0168 | Minor | 1114-P, 1116-S clocks failed |
| 0169 | Major | 1114-P, 1116-P clocks failed |
| 0170 | Major | 1114-P, 1116-P, 1116-S clocks failed |
| 0171 | Major | 1114-P, 1114-S clocks failed |
| 0172 | Major | 1114-P, 1114-S, 1116-S clocks failed |
| 0173 | Major | 1114-P, 1114-S, 1116-P clocks failed |
| 0183 | Minor | 1116-SHS clock failed |
| 0184 | Minor | 1116-PHS clock failed |
| 0185 | Major | 1116-PHS, 1116-SHS clocks failed |
| 0186 | Minor | 1114-SHS clock failed |
| 0187 | Major | 1114-SHS, 1116-SHS clocks failed |
| 0188 | Minor | 1114-SHS, 1116-PHS clocks failed |
| 0189 | Major | 1114-SHS, 1116-PHS, 1116-SHS clks failed |
| 0190 | Minor | 1114-PHS clock failed |
| 0191 | Minor | 1114-PHS, 1116-SHS clocks failed |
| 0192 | Major | 1114-PHS, 1116-PHS clocks failed |
| 0193 | Major | 1114-PHS, 1116-PHS, 1116-SHS clks failed |
| 0194 | Major | 1114-PHS, 1114-SHS clocks failed |
| 0195 | Major | 1114-PHS, 1114-SHS, 1116-SHS clks failed |
| 0196 | Major | 1114-PHS, 1114-SHS, 1116-PHS clks failed |
| 0197 | Critical | All High Speed Clocks have failed |
| 0198 | None | High Speed Clock Alarm(s) Cleared |
| 0403 | Major | 1114 E1/T1 clock requires TDM-GTI |
| 0404 | Major | 1116 E1/T1 clock requires TDM-GTI |
| 0405 | Major | 1114, 1116 E1/T1 clock requires TDM-GTI |
| 0406 | Major | 1114 Clock selection mismatch |
| 0407 | Major | 1116 Clock selection mismatch |
| 0408 | Major | 1114, 1116 Clock selection mismatch |
| 0409 | None | Clock configuration corrected |
| 1185 | None | GTI input clock anomalies detected |
Database Unsolicited Output Message Group
Table B-4 Database Unsolicited Output Message Group
| 1114 | None | Database BACKUP started |
| 1115 | None | Database RESTORE started |
| 1116 | None | Database action ended - OK |
| 1117 | None | Database action ended - FAIL |
| 1257 | None | DB restore has cleared and Disabled PDS |
GTT Unsolicited Output Message Group
Table B-5 GTT Unsolicited Output Message Group
| 0262 | Major | GTT Duplicate Actn processing stopped |
| 0263 | None | GTT Duplicate Actn processing resumed |
| 0328 | None | SCCP is available |
| 0329 | None | SCCP capacity normal, card(s) abnormal |
| 0330 | Major | System SCCP TPS Threshold exceeded |
| 0331 | Critical | SCCP is not available |
| 0335 | None | SCCP is removed |
| 0336 | Major | LIM(s) have been denied SCCP service |
| 0437 | Critical | System SCCP TPS Capacity Exceeded |
| 0630 | Major | Throttle Threshold - exceeded |
| 0631 | None | Throttle Threshold - cleared |
| 0632 | Minor | Alarm Threshold - exceeded |
| 0633 | None | Alarm Threshold - cleared |
| 1019 | None | SCCP rcvd invalid UDTS/XUDTS msg |
| 1020 | None | IARCDPN NPP Service is off |
| 1021 | None | IARCGPN NPP Service is off |
| 1023 | None | SCCP rcvd unknown msg type |
| 1024 | None | SCCP rcvd inv msg length |
| 1025 | None | SCCP rcvd inv msg class |
| 1029 | None | SCCP rcvd inv Cld Party - bad GT ind |
| 1033 | None | SCCP rcvd inv Cld Party - bad network |
| 1034 | None | SCCP rcvd inv Cld Party - no SSN |
| 1035 | None | SCCP rsp did not route - invalid GTI |
| 1036 | None | SCCP rsp did not route - invalid TT |
| 1037 | None | SCCP rsp did not route - bad Xlation |
| 1038 | None | SCCP rsp did not route - SSP not True PC |
| 1039 | None | SCCP rsp did not route - bad Selectors |
| 1040 | None | ITU <-> ANSI translation not supported |
| 1041 | None | SCCP did not route - no SSN in msg or DB |
| 1042 | None | SCCP rcvd inv GT - invalid Trans. Type |
| 1043 | None | SCCP did not route - bad translation If the UIMRD field in rtrv-stpopts is set to yes, this message is output in the UIM Redirect output group (see Table B-16). |
| 1044 | None | SCCP did not route - DPC OOS |
| 1045 | None | SCCP did not route - DPC congested |
| 1046 | None | SCCP did not route - DPC not in MAP tbl If the UIMRD field in rtrv-stpopts is set to yes, this message is output in the UIM Redirect output group (see Table B-16). |
| 1047 | None | SCCP did not route - SS OOS |
| 1048 | None | SCCP did not route - SS congested |
| 1049 | None | SCCP did not route - SS not in MAP tbl |
| 1050 | None | SCCP-CNV: Unable to convert ANSI CDPA GT |
| 1051 | None | SCCP-CNV: Unable to convert ANSI CGPA GT |
| 1052 | None | SCCP-CNV: Unable to convert ITU CDPA GT |
| 1053 | None | SCCP-CNV: Unable to convert ITUCGPA GT |
| 1054 | None | SCCP rcvd inv LSS - bad SSN |
| 1055 | None | SCCP rcvd inv SCMG - bad AFTPC |
| 1056 | None | SCCP rcvd inv SCMG - bad subsystem |
| 1057 | None | SCCP rcvd inv SCMG - bad length |
| 1058 | None | SCCP rcvd inv SCMG - bad msg type |
| 1063 | None | SCCP screen set is too large |
| 1077 | None | GTT Action TCAP ERROR DISCARDED MSU |
| 1078 | None | GTT Action DUPLICATE FAILED |
| 1079 | None | GTT Action FORWARD FAILED |
| 1107 | None | SCCP XUDT (S) msg: Hop Counter violation |
| 1108 | None | SCCP XUDT (S) msg: inv opt portion len |
| 1109 | None | XUDT(S) msg: inv segmentation parm |
| 1143 | None | GTT(FLOBR) failure: duplicate settype |
| 1144 | None | GTT(FLOBR) warning: duplicate settype |
| 1145 | None | MBR decoding failed |
| 1178 | None | Cnvrsn Discard: Invalid SCCP msg type |
| 1179 | None | Cnvrsn Discard: CGPA PC alias undefined |
| 1180 | None | Cnvrsn Discard: Aft. PC alias undefined |
| 1181 | None | Cnvrsn Discard: Invalid SCMG msg type |
| 1182 | None | Cnvrsn Discard: Invalid TCAP element |
| 1183 | None | Cnvrsn Discard: Invalid TCAP element len |
| 1189 | None | SCCP did not route: DPC not in RTE table |
| 1190 | None | SCCP rcvd inv Clg Party - bad GT ind |
| 1191 | None | SCCP rcvd inv Clg Party - bad selectors |
| 1192 | None | GTT Action UDTS DISCARDED MSU |
| 1193 | None | GTT Action DISCARD DISCARDED MSU |
| 1195 | None | SCCP did not route: DPC/SS not in Mapset |
| 1231 | None | SCCP Encode Failure |
| 1232 | None | SCCP Encode Failure 2 |
| 1240 | None | MAP SCCP Validation Fail |
| 1248 | None | GSM Map Screening rcvd unknown orig |
| 1249 | None | SCCP rcvd GSM Map Opcode w/ forbid param |
| 1250 | None | SCCP rcvd undefined Map Op-Code |
| 1341 | None | SRI rcvd - GSM2IS41not provisioned |
| 1344 | None | MSU discarded: In-Service Thresholding |
| 1388 | None | Invalid prefix/suffix digit len for CdPA |
| 1389 | None | Invalid prefix/suffix digit len for CgPA |
| 1392 | None | IDPRCDPN(X) NPP SERVICE is OFF |
| 1393 | None | IDPRCGPN NPP SERVICE is OFF |
| 1412 | None | GTT(FLOBR) failure: max search depth |
| 1413 | None | GTT(FLOBR) failure: duplicate set name |
| 1414 | None | GTT(FLOBR) warning: max search depth |
| 1415 | None | GTT(FLOBR) failure: duplicate set name |
| 1418 | None | SCCP did not route - no SSN in CgPA |
| 1419 | None | SCCP did not route - no SSN in CdPA |
| 1427 | None | IAR CdPN parameter invalid or not found |
| 1428 | None | IAR CgPN parameter invalid or not found |
| 1429 | None | IAR TRIGTYPE invalid or not found |
| 1430 | None | IAR CdPN parameter encoding failed |
| 1431 | None | IAR CgPN parameter encoding failed |
| 1443 | None | GTT Action FAILED TO SEND TCAP ERROR |
| 1444 | None | GTT Loadsharing fail: PC not in MRNSET |
| 1446 | None | XUDT UDT conversion failed |
| 1447 | None | Cnvrsn Discard: inv segmentation parm |
| 1475 | None | TOBR Multiple Comp: Translation found |
| 1476 | None | TCAPMulComp: Dup Opcode MSU discarded |
Gateway Screening Unsolicited Output Message Group
Table B-6 GWS Unsolicited Output Message Group
| 0290 | None | GLS is available |
| 0291 | Major | GLS is at minimum service limit |
| 0292 | Critical | GLS is not available |
| 0293 | None | GLS have been removed from the system |
| 1005 | None | GWS rcvd OPC that is not allowed |
| 1006 | None | GWS rcvd DPC that is not allowed |
| 1007 | None | GWS rcvd OPC that is blocked |
| 1008 | None | GWS rcvd DPC that is blocked |
| 1009 | None | GWS rcvd SIO that is not allowed |
| 1010 | None | GWS rcvd a priority that is not allowed |
| 1011 | None | GWS rcvd TFC, AFTPC not in routing tbl |
| 1012 | None | GWS rcvd Clg Party that is not allowed |
| 1013 | None | GWS rcvd Cld Party that is not allowed |
| 1014 | None | GWS rcvd Translation Type not allowed |
| 1015 | None | GWS rcvd SCMG with not allowed AFTPC |
| 1060 | None | Map Screening cannot generate ATIERR |
| 1062 | None | Text string with screen set name & line #( <screen set name> too large) |
| 1064 | None | GWS rcvd TFP, AFTPC not in routing tbl |
| 1065 | None | GWS rcvd TFR, AFTPC not in routing tbl |
| 1066 | None | GWS rcvd TFA, AFTPC not in routing tbl |
| 1067 | None | GWS rcvd UPU, AFTPC not in routing tbl |
| 1068 | None | GWS rcvd RSP, AFTPC not in routing tbl |
| 1069 | None | GWS rcvd RSR, AFTPC not in routing tbl |
| 1110 | None | GWS rcvd AFTPC that is not allowed |
| 1111 | None | GWS rcvd TCA, AFTPC not in routing tbl |
| 1112 | None | GWS rcvd TCR, AFTPC not in routing tbl |
| 1113 | None | GWS rcvd TCP, AFTPC not in routing tbl |
| 1125 | None | GWS rcvd CDPA that could not be RDCTd |
| 1126 | None | GWS rcvd CGPA that could not be RDCTd |
| 1127 | None | GWS rcvd AFTPC that could not be RDCTd |
| 1128 | None | GWS rcvd TT that could not be RDCTd |
| 1142 | None | GWS Strip Stop Action Failed |
| 1161 | None | GWS rcvd nonSNM msg in DESTFLD screening |
| 1162 | None | GWS rcvd nonSCCP msg in CGPA/CDPA screen |
| 1163 | None | GWS rcvd invalid GTI in TT screening |
| 1215 | None | GWS rcvd CDPA that could not be CNCFd |
| 1216 | None | GWS rcvd CGPA that could not be CNCFd |
| 1217 | None | GWS rcvd AFTPC that could not be CNCFd |
| 1218 | None | GWS rcvd TT that could not be CNCFd |
| 1258 | None | Map Screening cannot Forward MSU |
| 1259 | None | Map Screening cannot Duplicate MSU |
| 1301 | None | SECMTPMATE - rcvd mate PC on non C-link |
| 1302 | None | SECMTPSID - rcvd MSU with OPC = SID |
| 1303 | None | SECMTPSNM - no rte to OPC/AFTPC |
| 1304 | None | SECSCCPSCMG - no rte to AFTPC |
| 1407 | None | Unexpected SI in TIF Stop Action |
| 1449 | None | Binding Failed for screen set: <screen set name> |
| 1460 | None | GWS Duplicate Stop Action Failed |
Link Maintenance Unsolicited Output Message Group
Table B-7 Link Maintenance Unsolicited Output Message Group
| 0084 | Major | IP Connection Unavailable |
| 0085 | None | IP Connection Available |
| 0086 | Minor | IP Connection Congested |
| 0087 | None | IP Connection manually removed |
| 0115 | Major | Linkset IP TPS threshold exceeded |
| 0116 | Minor | Link expected IP TPS threshold exceeded |
| 0118 | None | Linkset IP TPS normal |
| 0119 | None | Link IP TPS normal |
| 0200 | None | RCVRY-LKF: link available |
| 0201 | Major | REPT-LKF: remote NE loopback |
| 0202 | Major | REPT-LKF: HWP - too many link interrupts |
| 0203 | Major | REPT-LKF: lost data |
| 0204 | Major | REPT-LKF: XER - SUERM threshold exceeded |
| 0205 | Major | REPT-LKF: APF - lvl-2 T1 expd (ready) |
| 0206 | Major | REPT-LKF: APF - lvl-2 T1 expd (not ready) |
| 0207 | Major | REPT-LKF: APF - lvl-2 T3 expired |
| 0208 | Major | REPT-LKF: APF - lvl-2 T2 expired |
| 0209 | Major | REPT-LKF: APF - failed proving period |
| 0210 | Major | REPT-LKF: OSA - received SIO |
| 0211 | Major | REPT-LKF: OSA - received SIN |
| 0212 | Major | REPT-LKF: OSA - received SIE |
| 0213 | Major | REPT-LKF: OSA - received SIOS |
| 0214 | Major | REPT-LKF: ABN - rcvd 2 of 3 invalid BSN |
| 0215 | Major | REPT-LKF: ABN - rcvd 2 of 3 invalid FIB |
| 0216 | Major | REPT-LKF: remote congestion timeout |
| 0217 | Major | REPT-LKF: excess acknowledge delay |
| 0218 | Major | REPT-LKF: COO - rcvd changeover order |
| 0219 | Major | REPT-LKF: false congestion restart |
| 0220 | Major | REPT-LKF: MTP link restart delayed |
| 0222 | Major | REPT-LKF: remote FE loopback |
| 0223 | None | REPT-LKF: remote NE loopback cleared |
| 0224 | Major | REPT-LKF: link test failed |
| 0230 | Major | REPT-LKF: local blocked - thermal |
| 0232 | Major | REPT-LKF: remote blocked |
| 0233 | Major | REPT-LINK-MANUAV: local blocked |
| 0234 | Major | REPT-LKF: RMI remote inhibited |
| 0235 | Major | REPT-LINK-MGTINH: local inhibited |
| 0236 | Major | REPT-LKF: not aligned |
| 0237 | Major | REPT-LKF: LM Timer NO-CREDIT expired |
| 0238 | Major | REPT-LKF: XDA-Timer NO-RESPONSE expired |
| 0239 | Major | REPT-LKF: MBL - local processor outage |
| 0240 | Major | REPT-LKF: rcvd remote processor outage |
| 0241 | Major | REPT-LKF: rcvd remote out of service |
| 0242 | Major | REPT-LKF: rcvd remote protocol error |
| 0243 | Major | REPT-LKF: rcvd remote mgmnt initiated |
| 0244 | Major | REPT-LKF: FAC - DS1/E1 LOS failure |
| 0245 | Major | REPT-LKF: FAC - DS1/E1 LOF failure |
| 0246 | Major | REPT-LKF: FAC - DS1/E1 LCD failure |
| 0247 | Major | REPT-LKF: XER - ISERM threshold exceeded |
| 0264 | None | REPT-LINK-CGST: congestion level 0 to 1 |
| 0265 | None | REPT-LINK-CGST: congestion level 1 to 2 |
| 0266 | None | REPT-LINK-CGST: congestion level 2 to 3 |
| 0267 | None | RCVRY-LINK-CGST: congestion level 3 to 2 |
| 0268 | None | RCVRY-LINK-CGST: congestion level 2 to 1 |
| 0269 | None | RCVRY-LINK-CGST: congestion has cleared |
| 0270 | None | REPT-LINK-CGST: discard level 0 to 1 |
| 0271 | None | REPT-LINK-CGST: discard level 1 to 2 |
| 0272 | None | REPT-LINK-CGST: discard level 2 to 3 |
| 0273 | None | RCVRY-LINK-CGST: discard level 3 to 2 |
| 0274 | None | RCVRY-LINK-CGST: discard level 2 to 1 |
| 0275 | None | RCVRY-LINK-CGST: discard has cleared |
| 0304 | Minor | REPT-NMTSK-DSCD: SNM Discard Onset |
| 0305 | None | RECVY-NMTSK-DSCD: SNM Discard Abated |
| 0306 | Minor | SNM Overload Onset |
| 0307 | None | SNM Overload Abated |
| 0311 | None | DPC is allowed |
| 0312 | Minor | DPC is restricted |
| 0313 | Critical | DPC is prohibited |
| 0314 | None | Route is allowed |
| 0315 | None | Route is restricted |
| 0316 | None | Route is prohibited |
| 0317 | None | RCVRY-LKSTO: link set allowed |
| 0318 | Major | REPT-LKSTO: link set prohibited |
| 0319 | Critical | REPT-MTPLP-DET: Circ rte det(cong) |
| 0320 | Critical | REPT-MTPLP-SUST: Sustained circ rte(cong) |
| 0321 | Minor | X-LIST occupancy threshold exceeded |
| 0322 | None | X-LIST occupancy below threshold |
| 0324 | None | DPC subsystem is allowed |
| 0325 | Critical | DPC subsystem is blocked |
| 0326 | Critical | DPC subsystem is prohibited |
| 0327 | None | DPC subsystem has been deleted |
| 0332 | Critical | DPC Subsystem is prohibited and blocked |
| 0333 | None | DPC Subsystem is Normal |
| 0334 | Critical | DPC Subsystem is Abnormal |
| 0337 | None | DPC-SS status changed |
| 0338 | Major | X-LIST space full-entry(s) discarded |
| 0339 | None | X-LIST space full condition abated |
| 0340 | None | RCVRY-MTPLP-RST:Circ rte status cleared |
| 0369 | Major | REPT-T1F:FAC-T1 unavailable |
| 0376 | Major | REPT-T1F:FAC-T1 LOS failure |
| 0377 | Major | REPT-T1F:FAC-T1 LOF failure |
| 0378 | Major | REPT-T1F:FAC-T1 Remote Alarm |
| 0379 | Major | REPT-T1F:FAC-T1 Alarm |
| 0380 | None | RCVRY-T1F:FAC-T1 available |
| 0381 | Major | REPT-E1F:FAC-E1 LOS failure |
| 0382 | Major | REPT-E1F:FAC-E1 LOF failure |
| 0383 | Major | REPT-E1F:FAC-E1 AIS detected |
| 0384 | Major | REPT-E1F:FAC-E1 Far End Failure |
| 0385 | Major | REPT-E1F:FAC-E1 10E-3 BER failed |
| 0386 | None | RCVRY-E1F:FAC-E1 available |
| 0387 | Major | REPT-E1F:FAC-E1 unavailable |
| 0399 | None | RCVRY-LKSTO: Alarm clr'd by deleting SLK |
| 0401 | None | Alarm cleared by deleting SLK |
| 0402 | None | Alarm cleared by deleting route |
| 0491 | Major | Connection TPS exceeded |
| 0492 | Normal | Connection TPS normal |
| 0493 | Major | Diameter Connection Down |
| 0494 | Normal | Diameter Connection Up |
| 0495 | Normal | Diameter Connection Closed |
| 0497 | Major | REPT-J1F:FAC-J1 LOS failure |
| 0498 | Major | REPT-J1F:FAC-J1 LOF failure |
| 0499 | Major | REPT-J1F:FAC-J1 Remote Alarm |
| 0504 | Major | REPT-J1F:FAC-J1 Alarm |
| 0505 | Normal | RRCVRY-J1F:FAC-J1 available |
| 0506 | Major | REPT-J1F:FAC-J1 unavailable |
| 0532 | None | RTX is allowed |
| 0533 | Minor | RTX is restricted |
| 0534 | Critical | RTX is prohibited |
| 0535 | Minor | IP Connection Restricted |
| 0537 | Major | Ethernet error threshold exceeded |
| 0538 | None | Ethernet error threshold cleared |
| 0539 | Major | Ethernet Interface Down |
| 0540 | None | Ethernet Interface Up |
| 0560 | Minor | REPT-LKSTO: link set restricted |
| 1016 | None | MTP Adj PC not in routing table |
| 1018 | None | REPT-MTPERR: MTP received - invalid SIO |
| 1070 | None | SLTC failure: invalid Point Code (OPC) |
| 1071 | None | SLTC failure: invalid SLC |
| 1072 | None | SLTC failure: no response |
| 1073 | None | SLTC failure: bad data pattern |
| 1075 | None | MTP: link bypassed SLT phase |
| 1076 | None | SLTC failure: invalid Point Code (DPC) |
| 1081 | None | MTP: Changeback T5 timeout |
| 1084 | None | GWS MSU discarded by redirect function |
| 1085 | None | GWSMSU too large to be redirected |
| 1086 | None | LFS test terminated with OAM switch over |
| 1087 | None | MTP RSTRT rcvd unexpected user traffic |
| 1088 | None | REPT-MTP-RSTRT: MTP Restart started |
| 1089 | None | RCVRY-MTP-RSTRT: MTP Restart Completed |
| 1090 | None | ITU GWY:CPC conversion failure |
| 1091 | None | ITU GWY:OPC conversion failure |
| 1092 | None | ITU GWY:H0H1 conversion failure |
| 1093 | None | ITU GWY:rcvd msg type cannot convert |
| 1094 | None | ITU GWY:Invalid ISUP msg structure |
| 1095 | None | ITU GWY:GRS buffer full |
| 1096 | None | ITU GWY:RSC buffer full |
| 1097 | None | ITU GWY:CGB buffer full |
| 1100 | None | GWS rcvd H0/H1 that is not allowed |
| 1104 | None | IP Connection Failed |
| 1133 | None | Diameter msg decode failed |
| 1134 | None | Diameter msg encode failed |
| 1135 | None | Invalid Diameter msg received |
| 1136 | None | Invalid Diameter msg length |
| 1137 | None | Diameter AVP decode failed |
| 1138 | None | Connection Refused |
| 1146 | None | REPT-XLST-TIMO: X-LIST entry expired |
| 1147 | None | MTP Invalid TFA received |
| 1148 | None | MTP Invalid TFR received |
| 1149 | None | SLK Level-3 T19 timer expired |
| 1150 | None | SLK Inhibit denied |
| 1151 | None | SLK Inhibit response timeout |
| 1152 | None | SLK Uninhibit denied |
| 1153 | None | SLK Uninhibit response timeout |
| 1154 | None | MSU-received threshold exceeded |
| 1155 | None | MSU-rejected threshold exceeded |
| 1160 | None | GWS rcvd ISUP that is not allowed |
| 1167 | None | SIP connection established |
| 1168 | None | SIP connection terminated |
| 1172 | None | REPT-OVSZMSG: SCCP MSU too large to route |
| 1173 | None | REPT-OVSZMSG: MTP MSU too large to route |
| 1177 | None | Cnvrsn Discard: SCCP MSU too large |
| 1184 | None | Cnvrsn Discard: Invalid SCCP element len |
| 1233 | None | MTP Invalid ITU TFR RCVD |
| 1305 | None | MTP rcvd UPU-User SCCP, Cause invalid |
| 1314 | None | IPS TCP connection established |
| 1315 | None | IPS TCP connection terminated |
| 1332 | None | Invalid Initial M2PA FSN Received |
| 1350 | None | Discrd Rcvd Lrg MSU CTRL-FEAT Off |
| 1351 | None | Discrd Trans Lrg MSU Unsupported SLK |
| 1352 | None | Discrd Rcvd Lrg MSU Unsptd Outbnd SLK |
| 1353 | None | DTA Bypassed for Rcvd Lrg MSU |
| 1357 | None | Negotiation at 100Mbps/Full Duplex failed |
| 1358 | None | MSU discarded - too big after MTP conv. |
| 1372 | None | SLTC Failure-SLTM not sent, Invalid SIO |
| 1390 | None | EMAP connection established |
| 1391 | None | EMAP connection terminated |
| 1394 | None | Flushing undelivered MSUs |
| 1442 | None | Invalid EMP SCR Message Received |
| 1452 | None | Invalid IP Address From SCTP Heartbeat Response |
Measurements Maintenance Unsolicited Output Message Group
Table B-8 Measurements Maintenance Unsolicited Output Message Group
| 0012 | Major | Invalid HW for Integrated Measurements |
| 0500 | None | Alarm for this entitiy is being cleared |
| 0516 | Minor | Degraded Mode - 1 card failed |
| 0517 | Major | Degraded Mode - multiple cards failed |
| 0518 | Critical | Measurements subsystem unavailable |
| 0519 | None | Measurements subsystem available |
| 1022 | None | System Meas limit exceeded for LSONISMT |
| 1026 | None | System Meas. limit exceeded for LSORIGNI |
| 1027 | None | System Meas. limit exceeded for LSDESTNI |
| 1028 | None | System Meas. limit exceeded for ORIGNET |
| 1061 | None | Meas sync not allowed from old version |
| 1080 | None | disk measurement status unreadable |
| 1186 | None | Meas data load failure: old version |
| 1199 | None | LNP DTH Measurements Discarded for DPC |
| 1234 | None | LNP Day Meas. Discarded for NPANXX |
| 1251 | None | Measurements data copy failure |
| 1252 | None | Report generation failure |
| 1253 | None | Report transfer failure FTP Server |
| 1254 | None | Scheduled transer failure |
| 1310 | None | System Meas. Limit exceeded for LRN |
| 1311 | None | System Meas. Limit exceeded for NPANXX |
| 1417 | None | PublicKey doesn’t match known-host file |
| 1445 | None | LNP Day Meas. Discarded for LRN |
Monitor Unsolicited Output Message Group
Table B-9 Monitor Unsolicited Output Message Group
| 0051 | Major | TSC sync is in simplex mode |
| 0052 | None | TSC sync feature is available |
| 0088 | Major | Clocks A and B TSCs are out of sync |
| 0089 | None | Clocks A and B TSCs are re-synchronized |
| 0468 | Critical | All STC Networks Unavailable |
| 0469 | Critical | All STC Cards Unavailable |
| 0470 | None | EROUTE is Removed |
| 0471 | None | EROUTE System is Available |
| 0472 | Minor | EROUTE System Threshold Exceeded |
| 0473 | Major | EROUTE System Capacity Exceeded |
| 0474 | None | EROUTE capacity normal card(s) abnormal |
| 0475 | Minor | NTP Time Unavailable |
| 0476 | None | NTP Time Available |
| 0477 | Minor | Congestion: Copy Function De-activated |
| 0478 | None | Copy Function Activated |
| 0479 | None | Link not Monitored |
| 0480 | Minor | Timestamp Invalid |
| 0481 | None | Timestamp Valid |
| 0482 | Major | Card(s) have been denied EROUTE service |
| 0531 | Minor | Insufficient HW Copy Function Inhibited |
| 0571 | Minor | Sentinel socket is inactive |
| 0572 | None | Sentinel socket is active |
| 0576 | Major | All FC Network Unavailable |
| 0577 | None | All FC cards removed |
| 0578 | None | FC System is Available |
| 0579 | Minor | FC Network Unavailable |
| 0580 | None | FC Network Available |
| 0581 | Minor | Loss of heartbeat |
| 0582 | None | Heartbeat Available |
| 0583 | Minor | Unexpected SAM Received |
| 0584 | None | Expected SAM Received |
| 0588 | Major | FC Port De-activated |
| 0589 | None | FC Port Activated |
| 0590 | Minor | Fast Copy Application De-activated |
| 0591 | None | Fast Copy Application Activated |
| 0597 | Minor | FC System is Deactivated |
MPS Unsolicited Output Message Group
Table B-10 MPS Unsolicited Output Message Group
| 0041 | Critical | LNP DB Maintenance required |
| 0042 | None | LSMS bulk load complete |
| 0250 | None | MPS available |
| 0261 | Critical | MPS unavailable |
| 0355 | None | LSMS is available |
| 0356 | Critical | LSMS unavailable |
| 0357 | None | All OAP terminals are removed |
| 0358 | Major | LSMS connection unavailable |
| 0359 | None | LSMS connection available |
| 0362 | Major | LSMS is at min service limit |
| 0370 | Critical | Critical Platform Failure(s) |
| 0371 | Critical | Critical Application Failure(s) |
| 0372 | Major | Major Platform Failure(s) |
| 0373 | Major | Major Application Failure(s) |
| 0374 | Minor | Minor Platform Failure(s) |
| 0375 | Minor | Minor Application Failure(s) |
Program Update Unsolicited Output Message Group
Table B-11 Program Update Unsolicited Output Message Group
| 1083 | None | REPT COND: system alive |
SEAS Maintenance Unsolicited Output Message Group
Table B-12 SEAS Maintenance Unsolicited Output Message Group
| 0341 | Major | OAP unavailable |
| 0342 | Major | SEAS UAL unavailable |
| 0343 | Major | SEAS X.25 Link unavailable |
| 0344 | Minor | SEAS PVC unavailable |
| 0345 | Major | All SEAS UAL sessions unavailable |
| 0346 | Minor | SEAS UAL session unavailable |
| 0347 | None | SEAS X.25 Link is available |
| 0348 | Major | SEAS is at min service limit |
| 0349 | Critical | SEAS unavailable |
| 0350 | Critical | OAP terminals inhibited |
| 0351 | None | SEAS is available |
| 0352 | None | SEAS is removed |
| 0353 | None | OAP is available |
| 0354 | Major | One OAP terminal unavailable |
| 0360 | Major | EMS Agent unavailable |
| 0361 | None | EMS Agent available |
| 0363 | Minor | OAP filesystem full |
| 0364 | Minor | Config. data checksum mismatch |
| 0365 | None | Config. data checksum alarm cleared |
| 1099 | None | Text string that was received from the OAP |
Security Administration Unsolicited Output Message Group
Table B-13 Security Administration Unsolicited Output Message Group
| 0174 | Minor | %full threshold reached - upload required |
| 0175 | Minor | LOGBUFROVFL-SECULOG -upload required |
| 0176 | Minor | Stdby security log -- upload required |
| 0177 | None | Security log exception cleared |
| 0178 | None | Security log failed |
| 0199 | None | OA&M IP Security feature disabled |
| 1493 | None | SSH Host Keys Regenerated |
| 1494 | None | SSH Host Keys Loaded |
SFAPP Unsolicited Output Message Group
Table B-14 SFAPP Unsolicited Output Message Group
| 0543 | Critical | VLR Dynamic Learning is suspended |
| 0544 | Normal | VLR Dynamic Learning Started |
| 0634 | Normal | SFAPP is available |
| 0635 | Critical | SFAPP is not available |
| 0636 | Normal | SFAPP is removed |
| 0637 | Minor | SFAPP Threshold Level1 Exceeded |
| 0638 | Major | SFAPP Threshold Level2 Exceeded |
| 0639 | Critical | SFAPP Threshold Level Critical |
| 0640 | Normal | SFAPP Threshold Condition Cleared |
| 0641 | Minor | SFAPP Capacity normal, card(s) abnormal |
| 0642 | Normal | System SFAPP TPS normal |
| 0643 | Major | System SFAPP Threshold Exceeded |
| 0644 | Critical | System SFAPP capacity exceeded |
| 0645 | Major | LIM/SCCP card(s) denied SFAPP service |
| 0646 | Normal | SFAPP Dynamic Learning Alarm Cleared |
| 1312 | None | Dynamic VLR profile table full |
| 1313 | None | Dynamic VLR roaming table full |
| 1316 | None | SFAPP(P) to OAM Sync started |
| 1317 | None | SFAPP(P) to OAM Sync Completed |
| 1483 | None | SFAPP VLR Status Changed |
| 1484 | None | SFAPP New VLR Created |
| 1485 | None | SFAPP New Roaming Entry Created |
| 1486 | None | SFAPP New Primary Card Chosen |
| 1487 | None | SFAPP Dyn VLR ROAM Entry Deleted |
| 1488 | None | SFAPP Velocity Threshold Crossed |
| 1489 | None | SFAPP Dyn VLR Prof Entry deleted |
| 1495 | None | TCP IPS Message Failure |
| 1496 | None | EAGLE EEDB Message Failure |
System Maintenance Unsolicited Output Message Groups
Table B-15 System Maintenance Unsolicited Output Message Groups
| 0002 | Minor | Card is not running approved GPL |
| 0003 | None | Alarm cleared for GPL |
| 0004 | Minor | Card is running non-activated GPL |
| 0005 | None | Alarm cleared running non-activated GPL |
| 0011 | Major | Entering forced simplex mode |
| 0018 | None | Exiting forced simplex mode |
| 0027 | Minor | IMT Bus util rate exceeds minor thresh |
| 0028 | Major | IMT Bus util rate exceeds major thresh |
| 0029 | None | IMT Bus utilization threshold cleared |
| 0039 | None | GPL has been corrected |
| 0040 | Minor | GPL is corrupted |
| 0043 | Major | Incorrect feature configuration |
| 0044 | Minor | Real time clock battery low |
| 0045 | None | Real time clock battery restored |
| 0046 | None | Terminal enabled |
| 0047 | Major | Card type not valid for application |
| 0048 | Minor | Terminal failed |
| 0058 | Critical | Critical customer trouble detected |
| 0059 | Major | Major customer trouble detected |
| 0060 | Minor | Minor customer trouble detected |
| 0061 | None | Customer trouble detected |
| 0062 | None | Customer trouble cleared |
| 0063 | Critical | Critical holdover clock trouble detected |
| 0064 | Major | Major holdover clock trouble detected |
| 0065 | Minor | Minor holdover clock trouble detected |
| 0066 | None | Holdover clock trouble cleared |
| 0082 | Major | Alarm in Fuse Panel |
| 0083 | None | Fuse Panel alarm has cleared |
| 0097 | None | IMT allowed |
| 0098 | None | IMT inhibited |
| 0106 | None | IMT Bus alarm cleared |
| 0107 | Minor | Minor IMT failure detected |
| 0108 | Major | Major IMT failure detected |
| 0109 | None | All IMT System level alarms cleared |
| 0110 | Minor | Failure detected on one IMT bus |
| 0111 | Major | Failure on both IMT A and IMT B |
| 0112 | Critical | Major failures detected on both IMTs |
| 0120 | Critical | ENUM SYSTEM is not available |
| 0121 | None | ENUM SYSTEM is available |
| 0122 | Major | ENUM SYSTEM normal, card(s) abnormal |
| 0123 | None | ENUM SYSTEM is removed |
| 0142 | None | System release alarm cleared |
| 0143 | Minor | System release GPL(s) not approved |
| 0144 | Minor | System release version unknown |
| 0276 | Major | Insufficient memory for IP7 provisioning |
| 0277 | Major | AS Unavailable |
| 0278 | None | AS Available |
| 0279 | Minor | AS Restricted |
| 0280 | None | AS Unrestricted |
| 0294 | None | REPT-ALMINH: alarm output PERM inhibit |
| 0295 | None | REPT-ALMINH: alarm output enabled |
| 0296 | None | REPT-ALMINH: alarm output TEMP inhibit |
| 0302 | Minor | Cooling fan failure |
| 0303 | None | Cooling fan normal |
| 0308 | Critical | Node isolated due to SLK failures |
| 0309 | None | Node is no longer isolated |
| 0366 | None | Temp Key(s) expiration alarm cleared |
| 0367 | Major | Temp Keys(s) expiring soon |
| 0368 | Critical | Temp Keys(s) have expired |
| 0388 | None | Illegal Address Error Cleared |
| 0389 | None | Card responding normally |
| 0390 | Major | Illegal Address Error |
| 0391 | Major | Card not responding Error |
| 0392 | Major | OA&M IP Security feature is OFF |
| 0393 | None | OA&M IP Security feature is ON |
| 0438 | Critical | Degraded Mode, Invalid OAM HW config |
| 0439 | None | Exiting Degraded Mode |
| 0466 | Major | STC Network Unavailable |
| 0467 | None | STC Network Available |
| 0483 | Critical | DEIR System is not available |
| 0484 | Major | DEIR System normal, card(s) abnormal |
| 0485 | None | DIER System is available |
| 0496 | None | DEIR System is removed |
| 0514 | Major | Standby MASP is inhibited |
| 0515 | None | Standby MASP is allowed |
| 0520 | Critical | Frame power usage reached LVL3 |
| 0521 | Major | Frame power usage reached LVL2 |
| 0522 | Minor | Frame power usage reached LVL1 |
| 0523 | None | Frame power usage normal |
| 0524 | None | REPT-ALMINH: alarm output TIMED inhibit |
| 0525 | None | Timed alm inh rdy to expire |
| 0561 | Critical | Can't establish Hi Bit rate;All HW OK |
| 0562 | None | High Bit rate established |
| 0563 | Major | IMT Bit rate mismatch detected |
| 0564 | None | IMT Bit rate mismatch cleared |
| 0592 | Critical | <subsystem> Subsystem is not available |
| 0593 | Critical | <subsystem> Subsystem is disabled |
| 0594 | Minor | <subsystem> Subsystem normal, card(s) abnormal |
| 0595 | None | <subsystem> Subsystem is available |
| 0596 | None | <subsystem> Subsystem is removed |
| 0619 | Critical | SIP SYSTEM is not available |
| 0620 | None | SIP SYSTEM is available |
| 0627 | Critical | SFLOG SYSTEM is not available |
| 0628 | None | SFLOG SYSTEM is available |
| 0629 | None | SFLOG SYSTEM is removed |
| 0911 | Major | Dynamic database is inconsistent |
| 0912 | None | Dynamic database is now consistent |
| 1000 | None | MTP rcvd UPU - user part is not SCCP |
| 1001 | None | MTP rcvd Transfer Controlled (TFC) |
| 1002 | None | MTP rcvd invalid TFC - status 0 |
| 1003 | None | MTP rcvd invalid H0/H1 code |
| 1004 | None | MTP rcvd unknown DPC |
| 1059 | None | Telnet terminal connection disconnected |
| 1098 | None | Unexpected disk access timeout |
| 1101 | None | SDRAM single bit error report |
| 1105 | None | REPTEVT:IMT GPL reloading |
| 1106 | None | REPT COND:IMT GPL reloading |
| 1118 | None | TOD change affects MEAS collection |
| 1120 | None | TRBL Queue is full: elements overwritten |
| 1129 | None | Ported subs SMSC matches Home SMSC Addr |
| 1130 | None | LOCREQ rcvd - IS412GSM not provisioned |
| 1131 | None | Invalid digits in IS41 MAP Digits parm |
| 1156 | None | Minor congestion event detected |
| 1157 | None | Major congestion event detected |
| 1187 | None | GPL Table Checksum Mismatch |
| 1188 | None | DB Subset Checksum Mismatch |
| 1194 | None | IP connection Refused, RHOST mismatch |
| 1196 | None | IP Connection Congestion Timeout |
| 1197 | None | IP Connection refused |
| 1198 | None | IP Connection, Cannot resolve RHOST |
| 1200 | None | INW ALT card as first to be preloaded |
| 1201 | None | INW MAIN card as last to be reset |
| 1202 | None | INW Asserted DDL inhibition |
| 1203 | None | INW Card reset command issued |
| 1204 | None | INW Waiting for card loading validation |
| 1205 | None | INW Detected card loaded |
| 1206 | None | INW Detected card reset or removed |
| 1207 | None | INW Allowed card to skip DDL inhibited |
| 1208 | None | INW Removed DDL inhibition |
| 1209 | None | INW Card must be reset/removed/inhibited |
| 1210 | None | INW Card failed to reset |
| 1211 | None | INW Failed to assert DDL inhibition |
| 1212 | None | INW Failed to remove DDL inhibition |
| 1213 | None | INW Card failed to DDL crossload |
| 1214 | None | INW Allowed card to DDL crossload |
| 1235 | None | Unable to connect Primary SFLOG Server |
| 1236 | None | Unable to connect both SFLOG Servers |
| 1237 | None | Dynamic database audit not current |
| 1239 | None | Ntwrk Card Reload Failed during Upg |
| 1308 | None | Updates inhibited: Target-Cell CRC Fail |
| 1309 | None | Updates inhibited: Source-Cell CRC Fail |
| 1320 | None | FPT value unprovisioned for frame |
| 1321 | None | EAGLE RTDB Birthdate Mismatch |
| 1322 | None | EAGLE RTDB Levels Invalid |
| 1323 | None | EAGLE/ELAP TN Quantity Mismatch |
| 1324 | None | EAGLE/ELAP NPANXX Quantity Mismatch |
| 1325 | None | EAGLE/ELAP LNRN Quantity Mismatch |
| 1326 | None | EAGLE RTDB Depth Alert |
| 1327 | None | Mate PC not found in table |
| 1328 | None | Incorrect network domain |
| 1330 | None | Mismatched UA Routing Context |
| 1331 | None | IP Route Table Entry Conflict |
| 1333 | None | UA RCVD MSG DISCARDED |
| 1334 | None | UA TX MSG DISCARDED |
| 1335 | None | Table Information |
| 1336 | None | UA ERROR MSG RECEIVED |
| 1337 | None | UA HEARTBEAT TIMEOUT |
| 1338 | None | SCCP did not route - no PC in CgPA |
| 1339 | None | SCCP did not route - no dflt Clg PC Set |
| 1340 | None | REPT COND: TRBL resynch required |
| 1349 | None | MSU invalid size – discarded |
| 1356 | None | EXT BERT terminated with OAM switchover |
| 1369 | None | ISUP IAM decode failed |
| 1370 | None | ISUP IAM Cld Pty decode failed |
| 1371 | None | ISUP encode Failed |
| 1377 | None | SSH session disconnected - server busyl |
| 1424 | None | IMT A [B] requested to re-align at LOW [HIGH] Rate |
| 1437 | None | IMT [A|B]: Rate change not initiated |
| 1490 | None | Telnet terminal connection successful |
| 1491 | None | Terminal enabled |
| 1492 | None | Terminal disabled |
| 1170 | None | OAMHC Meas transition complete |
| 1171 | None | Schd UI Rpt disbld-link cnt exceeds 700 |
UIM Redirect Unsolicited Output Message Group
Table B-16 UIM Redirect Unsolicited Output Message Group
| 1043 | None | SCCP did not route - bad translation |
| 1046 | None | SCCP did not route - DPC not in MAP tbl |
| The UIM Redirect output message group is used only if the UIMRD field in rtrv-stpopts is set to yes. Otherwise, this message is output in the GTT Unsolicited Output Message Group (see GTT Unsolicited Output Message Group). | ||
