4 INP/AINPQ Feature Configuration
This chapter describes prerequisites and procedures for configuration of the INP and AINPQ features on the EAGLE. The INP and AINPQ features can be enabled and turned on independently or together in the system. This chapter also includes procedures for configuration of the Service Portability feature for use with INP, and for enabling and turning on the INP Circular Route Prevention (INP CRP) feature.
Introduction
This chapter describes prerequisites and procedures for configuration of the INP and AINPQ features on the EAGLE. The INP and AINPQ features can be enabled and turned on independently or together in the system. This chapter also includes procedures for configuration of the Service Portability feature for use with INP and AINPQ, and for enabling and turning on the INP Circular Route Prevention (INP CRP) feature.
INP and AINPQ Configuration Procedure lists the steps for enabling and turning on the features, and for the provisioning required for the features. Each step contains a link or reference to information and procedures to use to complete the step. Feature provisioning can be performed only after the INP or AINPQ feature is turned on. Refer to Commands User's Guide for complete descriptions of the commands used in these procedures.
The INP feature, AINPQ feature, and other related features are optional and must be purchased from Oracle before they can be used in your system. If you are not sure whether you have purchased a specific feature, contact your Oracle Sales or Account Representative.Caution:
For an in-service environment, contact the unresolvable-reference.html#GUID-F6B3D647-C34D-4046-83F4-3D37AC9F2F63 before continuing to configure either the INP feature or the AINPQ feature. For an environment that is not yet in-service, continue with the configuration.System Prerequisites
Before any feature that is described in this manual can be enabled, the prerequisites listed in Table 4-1 are required in the system.
Table 4-1 System Prerequisites
| Prerequisite | Verification and Provisioning |
The system serial number must be correct and locked. For new installations, the system is shipped with an unlocked serial number. The serial number can be changed if necessary and must be locked after the system is on-site. For systems that are being upgraded, the serial number is usually already verified and locked. |
Note: The serial number cannot be changed after it is entered
and locked in the system.
Locate the serial number for the system on a label affixed to the control shelf (1100). Enter the Verify that the displayed serial number is correct for the system. If no
serial number is displayed, enter the Enter the |
A sufficient number of Service Module cards must be equipped. |
Enter the If more cards or cards of a different type are needed, refer to the procedures in Database Administration - GTT User's Guide to add or remove Service Module cards. |
The GTT feature must be on in the system. Some features require an additional GTT-related feature such as EGTT. See the specific feature prerequisites in this section. |
Enter the If the GTT feature is on, the gtt=on entry appears in the output. If the gtt=off entry appears in the output, use the procedures in Database Administration - GTT User's Guide to turn on and provision the GTT feature and any other GTT-related features and functions that will be used in the system. |
INP and AINPQ Feature Prerequisites
Before the INP feature or the AINPQ feature can be enabled, the following prerequisites are required in the system:
Table 4-2 INP and AINPQ Feature Prerequisite
| The LNP feature cannot be on in the system |
Enter the If the LNP feature is on, shown with a quantity greater than zero for the LNP ported TNs entry in the command output, features described in this manual cannot be enabled. |
| The system must be configured for HLR destinations. | The system must be configured to communicate with the system of the HLR database. See Configure the System for HLR Destinations. |
The EAGLE configuration of the INP feature and the AINPQ feature consists of the following steps. The steps contain links and references to detailed procedures and information needed to complete each step.
EPAP Provisioning
- EPAP-administered entity data can possibly become out-of-sync with the EAGLE MAP table when the creation of point codes and/or subsystem numbers in the MAP table is performed after EPAP database administration.
- If this mismatch is discovered in real-time operations, a UIM (such as SCCP did not route - DPC not in MAP tbl or SCCP did not route - SS not in MAP tbl) is sent to the EAGLE maintenance terminal.
- Verify, and provision if needed, the system prerequisites. See System Prerequisites.
- Verify, and provision if needed, the feature prerequisites. See INP and AINPQ Feature Prerequisites.
- Enable the INP feature, the AINPQ feature, or both features. See Enabling the INP and AINPQ Features.
- Turn on the INP feature, the AINPQ feature, or both features. See Turning On the INP and AINPQ Features.
- If the INP CRP feature will be used with INP, enable the INP CRP feature. See Enabling the INP Circular Route Prevention (INP CRP) Feature.
- If the INP CRP feature is enabled, turn on the INP CRP feature. See Turning On the INP Circular Route Prevention (INP CRP) Feature.
- Provision capability point codes for INP Query service (used by INP and AINPQ). See Provisioning True Point Codes and Capability Point Codes.
- Refer to the procedures in Database Administration - GTT User's Guide to provision the following items in the Mated Application (MAP) table for the INP local subsystem:
- Translation types and mappings
- Concerned signaling point code (CSPC) of the EAGLE mate and of any nodes that will send Route-on-SSN queries to the INP local subsystem for INPQ queries (for INP and AINPQ)
- Mated Application table entries for entity point codes and/or subsystem numbers for the INP local subsystem. Only solitary and dominant loadsharing are supported.
- Provision the state and subsystem number for the INP local subsystem (used by both INP and AINPQ for Query processing). See Provisioning the INP Local Subsystem.
- Provision the service selector mechanism to route MSUs to the INP subsystem. See Provisioning the INP Service Selectors.
The INP services are inpq and inpmr.
The Translation Type and Subsystem Number are the values assigned for the INP local subsystem when the MAP table entries were defined. See Step 8 in this procedure.
INPQ supports the ITU-N Global Title Indicator; ANSI and ITU-I are not supported. INPQ does not support the Service Nature of Address Indicator and the Service Numbering Plan.
INPMR support ITU-I and ITU-N Global Title Indicators. ANSI is not supported. The Service Nature of Address (SNAI) must be ccrndn, rnidn, rndnd, or rnsdn. The Service Numbering Plan must be e164.
If the AINPQ feature is enabled and the INP feature is not enabled, the INPMR service selector can still be provisioned, but the INPOPTS table cannot be provisioned. INPMR service will still be available and MSUs will be processed, but default values of the INPOPTS table will be used. To provision the INPOPTS table, the INP feature must be enabled. -
If non-international numbers need to be handled, verify that the STPOPTS values for the Default Country Code ( DEFCC parameter) and the Default Network Destination Code (DEFNDC parameter) are not none. Refer to the
chg-stpoptsandrtrv-stpoptscommand descriptions in Commands User's Guide to change and display the STPOPTS DEFCC and DEFNDC values. - Enable the Service Portability feature, if it will be used with the INP or AINPQ feature. See Enabling the Service Portability Feature.
- Turn on the Service Portability feature, if it will be used with the INP feature, the AINPQ feature, or both features. See Turning On the Service Portability Feature.
- Provision option values for the feature or features that will be used in the system - INPOPTS options for the INP feature, AINPOPTS options for the AINPQ feature, options used for Service Portability, and options used for the INP CRP feature. See Provisioning the INP and AINPQ Options.
- Enable the S-Port Subscriber Differentiation feature, if it will be used with Service Portability for the INP feature with the INPMR service. See Enabling the S-Port Subscriber Differentiation Feature.
- Turn on the S-Port Subscriber Differentiation feature if it will be used with the Service Portability feature. See Turning On the S-Port Subscriber Differentiation Feature.
- Provision the SCCPOPTS option for S-Port Subscriber Differentiation if it will be used with Service Portability for the INP feature with the INPMR service. See Provisioning the S-Port Subscriber Differentiation SCCPOPTS Option.
- Provision Home RNs that are prefixed to DNs for incoming INPQ and INP MR messages. See Provisioning HOMERN Entries.
- Provision the INPQ service selector, the INPMR service selector , or both service selectors. See Provisioning the INP Service Selectors.
- Activate the INP local subsystem. See Activating the INP Local Subsystem.
- Initialize the Service Module cards to load the RTDB, OAM, GPL, and GTT data to the cards. Refer to the procedures in Database Administration - GTT User's Guide.
- Verify the operating status of the system, using the
rept-stat-sccp,rept-stat-mps, andrept-stat-db:display=allcommands.
EPAP can now be used to administer INP and AINPQ entity objects and subscribers. For the details about performing these actions, refer to Administration Guide for EPAP.
This section describes the configuration of the system for HLR destinations, so that the system can communicate with the system of the HLR database. The route to this database may already be configured.
Perform the steps in the following procedure to verify that all HLR destinations for INP/AINPQ are entered, and make configuration changes as needed. The steps contain links and references to procedures and information that is needed to complete each step.
This procedure is used to enable the INP and AINPQ features in the EAGLE.
- INP - Part Number 893017901
- AINPQ - Part Number 893017801
Controlled features are optional and you must be entitled to use them in your system. If you are not sure whether you are entitled to use a specific feature, contact your Oracle Sales or Account Representative.Provisioning of INP and AINPQ options and other information can be done after each feature is enabled and before each feature is turned on.
After a feature has been enabled and database provisioning is complete, the feature status must be set to on (the feature must be “turned on”) See Turning On the INP and AINPQ Features.
Before the INP or AINPQ feature can be turned on, the feature must be enabled in the EAGLE 5 ISS.
Provisioning of INP or AINPQ options and other information can be done after the feature is enabled and before the feature is turned on.
After each feature has been enabled and database provisioning is complete, the feature status must be set to on (the feature must be “turned on”). MSUs will not be processed by the feature until the feature is turned on.
After the features are enabled and turned on, they cannot be turned off again.
This procedure explains briefly how to provision EAGLE true point codes and capability point codes (CPCs) for EPAP-related features. Refer to the detailed procedures in Database Administration - SS7 User's Guide for provisioning true and capability point codes, and the CLLI if needed.
The INP Query service is used by both INP and AINPQ. The INP Message Relay service is used only by INP.
- For the INP Query service (INPQ), use CPCTYPE=INP.
- For the INP Message Relay service (INPMR), use CPCTYPE=STP.
INP Query processing supports queries from ITU-N point codes, and supports use of the ITU National Duplicate Point Code feature.
INP Message Relay processing supports ITU-I and ITU-N point codes, including group codes and use of the ITU National Duplicate Point Code feature.
This procedure explains how to provision EAGLE true point codes and INP capability point codes.
See the procedures in Changing the State of a Subsystem Application to take the subsystem application online or offline.
The EAGLE supports the operation of two or more local subsystems for EPAP-related features in the system at one time. For example, the local subsystems for INP and EIR can coexist in the system.Adding the INP Local Subsystem Application
This procedure is used to define the INP subsystem application. The subsystem application can be taken online when it is defined or later in the configuration process (see Changing the State of a Subsystem Application).
Before the INP subsystem application can be added to the database, the following conditions must exist in the system:
Table 4-3 INP Local Subsystem Prerequisites
| Prerequisite | Verification |
| The INP feature or AINPQ feature must be enabled and turned on. |
Enter the If the INP entry or AINPQ entry with Status of on does not appear in the output, see the Enabling the INP and AINPQ Features and Turning On the INP and AINPQ Features procedures. |
| The application specified by the appl parameter (inp) cannot already be in the database. |
Enter the If the INP entry appears in the output, this procedure cannot be performed. |
| EAGLE true point codes, STP capability point code for INPMR, and INP capability point codes for INPQ must be defined, and entered in the Mated Application table with a subsystem number to be used for the INP subsystem application. |
Only one subsystem number for the application can be defined, and must be used for all point code types assigned to the local subsystem. Enter the Enter the |
The examples in this procedure reserve the subsystem number 100 for the INP subsystem application and set the INP subsystem application status to online.
This procedure is used to provision the configuration options for the INP feature, the AINPQ feature, or both features, and the options required for using Service Portability.
See INP/AINPQ Configuration Options for information and considerations about provisioning INP and AINPQ configuration options.
If INP Circular Route Prevention will be used with INP, use this procedure to enable the INP CRP feature in the EAGLE.
Controlled features are optional and you must be entitled to use them in your system. If you are not sure whether you are entitled to use a specific feature, contact your Oracle Sales or Account Representative.After the S-Port feature has been enabled, the INP CRP feature must be turned on before INP CRP processing will occur.
This procedure is used to turn on the INP CRP feature in the EAGLE, using the feature part number 893028501.
Before the INP CRP feature can be turned on, the feature must be enabled in the EAGLE.
After the INP CRP feature has been enabled, the INP CRP feature status must be set to on (the feature must be “turned on”). MSUs will not be processed by the INP CRP feature until the feature is turned on.
The ent-homern command is used to provision the prefix RNs in the HOMERN table.
Enter any Home RNs that are prefixed to DNs for incoming INPQ and INPMR messages, and that are used to determine INP Circular Routes. This command can be used to enter up to 100 routing number prefixes for the operating network into the HOMERN table.
The procedures in this section describe how to add, change, and remove a service selector. The INP-specific information is indicated.
Adding Service Selectors for INP and AINPQ
This procedure is used to add service selectors that are used by the INP and AINPQ features.
The INP or the AINPQ feature must be enabled and turned on before an INP service selector can be added.
Removing a Service Selector
This procedure is used to remove a service selector from the database.
To remove a service selector, the GTI, GTII, GTIN, tt, and ssn parameter values must be entered as shown in the rtrv-srvsel output.
These parameters can also be used to limit the amount of information displayed with the rtrv-srvsel command.
Changing an Existing Service Selector to an INP Service Selector
This procedure is used to change an existing non-INP service selector to an INP service selector.
The only parameters that can be changed using this procedure are:
The chg-srvsel command requires that the following parameters be specified with the values shown in the rtrv-srvsel output for the service selector that is being changed. If any of these parameter values need to be changed for a new INP service selector, use the the procedure in Removing a Service Selector to remove the existing service selector. Then use the procedure in Adding Service Selectors for INP and AINPQ to add the new INP service selector with the new parameter information.
The procedure in this section explains how to activate the INP local subsystem.
INP and AINPQ share operation of the INP local subsystem in the EAGLE.
When all configuration is complete for the feature or features, the INP subsystem application must taken online and the local subsystem must be activated to allow it to begin operation.
When the local subsystem operating state is Inhibited, the chg-ss-appl:appl=inp command can be used to specify the value online or the value offline to control the persistent setting for the local subsystem. The rtrv-ss-appl command always displays the online or offline provisioned value. When the first Service Module card is loaded, this state tells whether the subsystem should be considered allowed (online) or inhibited (offline). This is a database state. If the command is accepted, then the change is made to the tables and can be read after an init-sys command is entered to initialize the system.
When the Service Module cards are in-service and the subsystem application is online, the alw/inh-map-ss commands can be used to change the dynamic operating state of the local subsystem. The inh-map-ss command does not necessarily force a state change, because it can fail if the mate does not send SOG. The force=yes parameter must be specified to bypass the SOR/SOG exchange and inhibit immediately. (There is no rtrv-map-ss command.)
The procedures in Changing the State of a Subsystem Application explain how to take a local subsystem online and offline.
Table 4-4 Subsystem Allow/Inhibit
| Command\ Subsystem State | Offline | Online |
alw-map-ss
Command is rejected. | Attempts to make the local subsystem active. |
| inh-map-ss | Command accepted, but no action because offline implies inhibited. | Attempts to inhibit the local subsystem. Use of the force=yes parameter bypasses the SOR/SOG exchange and inhibits immediately. |
chg-ss-appl :appl=inp :nstat=online
Command is rejected, because the subsystem must be online to be in the allowed state. | Changes local subsystem database status to online. |
chg-ss-appl :appl=inp :nstat=offline
Command is rejected because the subsystem must be inhibited to go offline. | Changes local subsystem database status to offline. |
The procedures in this section are used to set the state of an existing subsystem application to either online or offline.
The online or offline status of the subsystem application is shown in the STAT field of the rtrv-ss-appl command output.
The rept-stat-sccp command displays the operating state (in or out of service) of the subsystem.
If the subsystem application is to be taken online, the subsystem application must be offline.
When the subsystem is taken online (regardless of how the subsystem was taken offline), the EAGLE sends SNR/SSA. A UAM is generated, indicating that the subsystem is ALLOWED.
If the subsystem application is to be taken offline, the subsystem application must be online. The subsystem must be taken out of service (OOS-MT-DSBLD) with the inh-map-ss command before it can be taken offline.
A subsystem application can be taken offline using coordinated state change, or forced offline without using coordinated state change.
When the inh-map-ss command is entered for the subsystem, a coordinated shutdown is attempted. If the coordinated shutdown fails, a UIM is generated, indicating that the shutdown failed. If the force parameter is specified, the subsystem is forced to shut down; a coordinated shutdown is not performed.
For coordinated state change, SCMG sends an SOR message to the mated subsystem and will start a Tcoord timer (30 seconds). If SCMG receives an SOG message from the mated subsystem before the Tcoord timer expires, SCMG will broadcast SSPs to the concerned point code group, send SBR/SSP, and take the subsystem offline. A UAM is generated, indicating that the subsystem is PROHIBITED. If the SOG is not received before Tcoord expires, then the inhibit request is denied and a UIM is generated.
When the subsystem is taken offline without coordinated state change, the EAGLE sends SBR/SSPs. A UAM is generated, indicating that the subsystem is PROHIBITED.
- The local subsystem is available
- The total load on the DSM subsystem is less than 45% of its capacity
If either of these conditions is not met, the EAGLE will not reply to the SOR message.
Service Portability Feature Configuration Procedures
The procedures in this section are used for configuration of the Service Portability (S-Port) feature.
If Service Portability can be applied to the messages processed by a feature described in this guide, use this procedure to enable the Service Portability feature in the EAGLE.
Controlled features are optional and you must be entitled to use them in your system. If you are not sure whether you are entitled to use a specific feature, contact your Oracle Sales or Account Representative.Provisioning of S-Port options can be done after the feature is enabled and before the feature is turned on.
After the S-Port feature has been enabled and database provisioning is complete, the S-Port feature status must be set to on (the feature must be “turned on”) before S-Port processing will occur.
This procedure is used to turn on the Service Portability feature in the EAGLE, using the feature part number 893034301.
Before the Service Portability (S-Port) feature can be turned on, the feature must be enabled in the EAGLE.
After the S-Port feature has been enabled and database provisioning is complete, the Service Portability feature status must be set to on (the feature must be “turned on”). MSUs will not be processed by the Service Portability feature until the feature is turned on.
After the Service Portability feature is enabled and turned on, it can be turned off again. Service Portability processing can occur only when the Service Portability feature is on and a feature that uses S-Port is on.
Turning Off the Service Portability Feature
Before the Service Portability (S-Port) feature can be turned on and off, the feature must be enabled in the EAGLE.
This procedure is used to turn off the Service Portability feature, using its feature part number 8930343001.
MSUs will not be processed by a feature when the feature is turned off in the system.S-Port Subscriber Differentiation Feature Configuration Procedures
The procedures in this section are used for configuration of the S-Port Subscriber Differentiation feature.
If S-Port Subscriber Differentiation will be used with Service Portability for the messages processed by a feature described in this manual, use this procedure to enable the S-Port Subscriber Differentiation feature in the EAGLE.
Controlled features are optional and you must be entitled to use them in your system. If you are not sure whether you are entitled to use a specific feature, contact your Oracle Sales or Account Representative.After the S-Port Subscriber Differentiation feature has been enabled, the S-Port Subscriber Differentiation feature status must be set to on. See Turning On the S-Port Subscriber Differentiation Feature. The S-Port Subscriber Differentiation feature cannot be turned off after the feature is turned on.
Provisioning of the S-Port Subscriber Differentiation SCCPOPTS configuration option can be done only after the feature is enabled and turned on. See Provisioning the S-Port Subscriber Differentiation SCCPOPTS Option.
Before S-Port Subscriber Differentiation processing of MSUs can occur, the Service Portability feature, the S-Port Subscriber Differentiation feature, the S-Port Subscriber Differentiation option, and a feature that uses Service Portability must be on.
This procedure is used to turn on the S-Port Subscriber Differentiation feature in the EAGLE, using the feature part number 893037901.
Before the S-Port Subscriber Differentiation feature can be turned on, the feature must be enabled in the EAGLE.
After the S-Port Subscriber Differentiation feature has been enabled, the S-Port Subscriber Differentiation feature status must be set to on (the feature must be “turned on”). After the S-Port Subscriber Differentiation feature is enabled and turned on, it cannot be turned off again.
Provisioning of the S-Port Subscriber Differentiation option can be done only after the feature is enabled and turned on. The S-Port Differentiation option can be turned on and off.
MSUs will not be processed by the S-Port Subscriber Differentiation feature until the feature and the option are turned on. S-Port Subscriber Differentiation processing can occur only when the Service Portability feature, the S-Port Subscriber Differentiation feature, the S-Port Differentiation option, and a feature that uses Service Portability are all on.
This procedure is used to provision the SCCPOPTS configuration option for the S-Port Subscriber Differentiation feature.
The S-Port Subscriber Differentiation feature must be enabled and turned on before SCCPOPTS SUBDFRN option can be provisioned.
