3 UAM and UIM Troubleshooting Procedures
3.1 Troubleshooting Procedures
The following procedures are listed by message reference number (MRN). Locate the message reference number in the output message on your screen, find the MRN in this chapter, and follow the procedure to troubleshoot the problem.
The outputs in the following procedures are examples. Some outputs have several variations. In most cases only one variation is shown.If a linkset is in test mode, any GWS failure UIMs are reported, but the failed traffic is still switched through. The UIM displays a line identifying the test mode state. A linkset in test mode performs the GWS action, but does not screen out MSUs which do not pass screening. The GWSM action is on and the GWSA or GWS Activated action is off.
The system header information is shown in the example outputs and includes the following information:
Figure 3-1 System Header Information
3.2 UAMs
The following are UAMs that may be displayed.
3.2.1 0001 - Card Has Reset
This could have been the result of a manual reset, or software reset. If the system software detects trouble with a card, the processors on the card (application or communication processors) are reset by software. The system software is responsible for this function.
RLGHNCXA21W 94-02-07 12:01:43 EST EAGLE 35.0.0
** 0014.0001 ** CARD 1113 OAM Card has reset
Alarm Level: Major
Recovery
3.2.2 0002 - Card is not Running Approved GPL
This alarm indicates a card or cards are running a generic program load (GPL) other than the approved GPL. This is determined by a system audit, which compares the GPL running on each card with the approved version for each card type. If any card(s) are running a GPL other than its approved GPL, an alarm is created. Only one alarm for each card application is displayed.
* 0014.0002 * GPLSYSTEMOAM Card is not running approved GPL
Alarm Level: Minor
Recovery
There are three procedures for this output. Choose the procedure based on the GPL System indicated in the alarm message. Refer to the following to help determine the correct procedure:
Use the Recovery Procedure for All Cards Without Flash Memory if the following GPLs are indicated in the output as the GPL System.
ATMANSI, ATMITU, CCS7ITU, EBDABLM, EBDADCM, EMDC, EOAM, EROUTE, GLS, IMT, IPGWI, IPLIM, IPLIMI, IPS, MCP, SCCP, SS7ANSI, SS7HC, SS7IPGW, SS7ML, VSCCP
Use the Recovery Procedure for Cards With Flash Memory (Except HMUX and HIPR) if the following GPLs are indicated in the output as the GPL System.
BLBIOS, BLCPLD, BLDIAG, BLVXW, BPDCM, BPHCAP, BPHCAPT, BPMPL, BPMPLT, IMTPCI, PLDE1T1, PLDPMC1
Use the Recovery Procedure for HIPR2 Card if the following GPL is indicated in the output as the GPL System.
BPHMUX, HIPR
3.2.2.1 Recovery Procedure for All Cards Without Flash Memory
Caution:
This procedure causes the identified card to reload, and should be used only during periods of low traffic or the maintenance window.3.2.3 0003 - Alarm Cleared for GPL
This message indicates that all the cards of a specific type are running the approved GPL and the alarm condition, specified by message “0002 - Card is not running approved GPL” has been cleared.
0014.0003 GPL SYSTEM OAM Alarm cleared for GPL
Alarm Level: No alarm condition. The message is informational only.
Recovery
This message indicates a previous fault has been corrected.
No further action is necessary.
3.2.4 0004 - Card is Running Non-activated GPL
This alarm indicates a card or cards are running a non-activated Trial or Approved generic program load (GPL). This output is expected when changing a flash GPL. This alarm occurs after a successful download to the card, and the card boots. This is determined by a system audit, which compares the GPL running on each card with the activated version for each card type. If any card(s) are running a GPL other than its activated GPL, an alarm is created. Only one alarm for each card application is displayed. UAM 0002 might also be produced.
* 0014.0004 * GPLSYSTEMBPDCM Card is running non-activated GPL
Alarm Level: Minor
Recovery
3.2.5 0005 - Alarm Cleared Running Non-activated GPL
This message indicates that all the cards of a specific type are running the non-activated GPL and the alarm condition, specified by message “0004 - Card is running non-activated GPL” has been cleared.
0014.0005 GPL SYSTEM BPDCM Alarm cleared running non-activated GPL
Recovery
3.2.6 0008 - Active MASP has Become Isolated
This messages indicates the active MASP has a fault and the system switched to the standby MASP. This could be caused by the MASP losing a connection to the IMT, a failure with the GPSM-II card, or a card reset.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 35.0.0
** 0014.0008 ** CARD 1113 OAM Active MASP has become isolated
Alarm Level: Major
Recovery
3.2.7 0009 - MASP Became Active
This message indicates which MASP is active.
0014.0009 CARD 1113 OAM MASP became active
Recovery
This message indicates a previous fault or condition has been corrected.
3.2.8 0010 - MASP Became Standby
This message indicates which MASP is standby.
0012.0010 CARD 1113 OAM MASP became standby
Recovery
3.2.9 0012 - Invalid HW for Integrated Measurements
The E5-OAM Integrated Measurements feature runs on the E5-MASP card. This UAM indicates that the E5-OAM Integrated Measurements feature is enabled and on, but one of the paired E5-MASP cards was removed from the active or standby MASP locations and replaced with an incompatible GPSM-II (OAM) card.
** 0014.0012 ** CARD 1113 OAM Invalid HW for Integrated Measurements
Alarm Level: Major
Recovery
3.2.10 0013 - Card is Isolated from the System
This indicates a card has become isolated and is unable to communicate to other cards in the system. This could be caused by a defective card, a power failure occurred on the card, a thermtrip when the shutdown temperature is exceeded, or the system software ordering a reset.
This also appears when the card has been manually reset by a command.
** 0014.0013 ** CARD 1113 OAM Card is isolated from the system
ASSY SN: 102199815a1234
Alarm Level: Major
Recovery
3.2.11 0014 - Card is Present
The card indicated was isolated from the system, but is now communicating with the active MASP. The maintenance software has begun recovery action.
0014.0014 CARD 1201 SS7ANSI Card is present
Recovery
No immediate action is required.
The maintenance software is attempting to recover the card by reinitialization of the card.
3.2.12 0021 - Clock A for Card Failed, B Normal
This indicates that the A clock signal for the indicated card is not present.
* 0014.0021 * CARD 1116 OAM Clock A for card failed, Clock B normal
Alarm Level: Minor
Recovery
3.2.13 0022 - Clock B for Card Failed, A Normal
This indicates that the B clock signal for the indicated card is not present.
* 0014.0022 * CARD 1116 OAM Clock B for card failed, Clock A normal
Alarm Level: Minor
Recovery
3.2.14 0023 - Clocks A and B for Card Failed
The A and B clock sources for the indicated card are not present.
* 0014.0023 * CARD 1116 OAM Clocks A and B for card failed
Alarm Level: Minor
Recovery
3.2.15 0024 - Clock A for card normal
This message indicates that the clock A distribution for the specified card is now normal.
0014.0024 CARD 1116 OAM Clock A for card normal Alarm Level: No alarm condition. The message is informational only.
Recovery
This message indicates a previous fault in the clock A distribution has been cleared.
No action is necessary.
3.2.16 0025 - Clock B for card normal
This message indicates that the clock B distribution for the specified card is now normal.
0014.0025 CARD 1116 OAM Clock B for card normal Alarm Level: No alarm condition. The message is informational only.
Recovery
This message indicates a previous fault in the clock B distribution has been cleared.
3.2.17 0026 - Clocks A and B for card normal
This message indicates that clock A and B for the indicated card has returned to a normal state.
0014.0026 CARD 1116 OAM Clocks A and B for card normal Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.18 0027 - IMT Bus util Rate Exceeds Minor Thresh
This message indicates that the combined IMT bus utilization rate has exceeded its minor threshold level.
RLGHNCXA21W 09-02-07 12:01:43 EST EAGLE 41.1.0
* 0590.0027 * IMT SYSTEM IMT Bus util rate exceeds minor thresh
Alarm Level: Minor
Recovery
- Note the time, duration, and frequency of the alarm(s).
- Enter the
rept-stat-muxcommand to note the rate at which the high-speed ring is operating. - Note any unusual conditions, such as one IMT bus inhibited, mate failed, SS7 link failures, etc.
- If this is an isolated occurrence, no further action is required other than monitoring the system for a re-occurrence.
- If the problem persists and the high-speed ring is operating at "low bit rate," this is an indication that the system is operating at low capacity and an upgrade of the high-speed ring to operate at "high rate" is required. Contact My Oracle Support (MOS) for information on how to purchase the HIPR2 High Rate Mode feature.
- If the problem persists and the high-speed ring is operating at "high rate," contact My Oracle Support (MOS) for assistance.
3.2.19 0028 - IMT Bus util Rate Exceeds Major Thresh
This message indicates that the combined IMT bus utilization rate has exceeded its major threshold level.
** 0590.0028 ** IMT SYSTEM IMT Bus util rate exceeds major thresh
Alarm Level: Major
Recovery
- Enter the
3.2.20 0029 - IMT Bus utilization threshold cleared
This message indicates that the alarm condition specified by the previous IMT bus utilization alarm has been cleared.
0590.0029 IMT SYSTEM IMT Bus utilization threshold cleared Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.21 0030 - HIPR2 Detected a Minor Congested Second
The congestion on an IMT bus segment has reached a level 1 congestion threshold. A congested second is a one second time slice that contains 10 or more congestion events that happen on that node.
When there are no minor congested second events being reported for a node for a period of five minutes, all congested second alarms are cleared for that node.
* 0594.0030 * Card 1109 HIPR2 detected a minor Congested Second
Alarm Level: Minor
Recovery
- Enter the
- Note the segment(s) reporting the congestion.
- If the problem persists and the high-speed ring is operating at "low rate," this is an indication that the system is operating at capacity and an upgrade of the high-speed ring to operate at "high rate" is required. Contact My Oracle Support (MOS) for information on how to purchase the HIPR2 High Rate Mode feature.
3.2.22 0031 - HIPR2 Detected a Major Congested Second
This message indicates that the congestion on an IMT bus segment has reached a level 2 congestion threshold. A congested second is a one-second time slice that contains 10 or more congestion events that happen on that node.
When there are no major congested second events reported for a node for a period of five minutes, the major congested alarm is replaced with the minor congested second alarm for that node.
** 0590.0031 ** Card 1110 HIPR2 detected a major Congested Second
Alarm Level: Major
Recovery
- Enter the
3.2.23 0032 - HIPR2 Congestion cleared
This message indicates that the alarm condition specified by the previous HIPR2 congestion alarm has been cleared.
0590.0032 Card 1209 HIPR2 Congestion cleared
Recovery
3.2.24 0033 - Card database has been corrected
This message indicates that the database has been reloaded to the indicated card by system software. This typically occurs when the system software finds the card database is not synchronized with the other cards in the system (incoherent database).
0014.0033 CARD 1113 OAM Card database has been corrected Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.25 0034 - Card database is inconsistent
This message indicates that the database on the indicated card is not at the same level as the source database level. For more information about database management procedures, refer to the Database Administration Manual - System Management.
* 0014.0034 * CARD 1201 LIMDS0 Card database is inconsistent Alarm Level: Minor
3.2.26 0035 - Card database is corrupted
This message indicates that the card database has been modified by some unknown process and is not usable. For more information about database management procedures, refer to the Database Administration Manual - System Management.
* 0014.0035 * CARD 1113 OAM Card database is corrupted Alarm Level: Minor
3.2.27 0036 - Card backup database has been corrected
This message indicates that the backup database version level and content on the standby MASP is synchronized with the reference database.
0014.0036 CARD 1113 OAM Card backup database has been corrected
Recovery
3.2.28 0037 - Card Backup Database is Inconsistent
This message indicates that the backup database version level and/or content on the MASP is not synchronized with the database on the active MASP. This typically occurs if a different level counter, last update day/time-stamp, or contents is detected, or the database is incoherent.
* 0014.0037 * CARD 1113 OAM Card backup database is inconsistent
Alarm Level: Minor
Recovery
3.2.29 0038 - Card backup database is corrupted
This message indicates that the backup database has been modified by some unknown process and is no longer usable.
* 0014.0038 * CARD 1113 OAM Card backup database is corrupted Alarm Level: Minor
Recovery
3.2.30 0039 - GPL has been corrected
All copies of the generic program load are satisfactory.
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 35.0.0
0100.0039 GPL SYSTEM OAM GPL has been corrected Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.31 0040 - GPL is Corrupted
This message indicates that a generic program load (GPL) has become corrupted. This typically occurs when the system software detects that a generic program load has been unexpectedly modified.
* 0100.0040 * GPL SYSTEM OAM GPL is corrupted
Alarm Level: Minor
Recovery
3.2.32 0041 - LSMS Bulk Load Required
This message indicates that the entire system LNP database must be repopulated, either from the LSMS or a backup disk. This process must be started manually.
* C0009.0041 *C LSMS SYSTEM LSMS bulk load required
Alarm Level: Critical
Recovery
Refer to the LNP Database Synchronization Manual for the LSMS Bulk Load procedure.
3.2.33 0042 - LSMS Bulk Load Complete
This message indicates that the alarm condition is removed, the association is reestablished, the LSMS is downloading transactions, and the automatic resynchronization is in progress.
0100.0042 LSMS SYSTEM LSMS bulk load complete
Recovery
3.2.34 0044 - Real Time Clock Battery Low
The battery power in the HC MIM card is low.
station1234 00-11-30 16:28:08 EST EAGLE 35.0.0
* 0012.0044 * CARD 1201 LIMT1 Real time clock battery low
Alarm Level: Minor
Recovery
Refer to the Maintenance Manual for card removal/replacement procedures for details about replacing cards.3.2.35 0045 - Real Time Clock Battery Restored
The HC MIM card has been replaced and the battery power in the HC MIM card is normal.
0012.0045 CARD 1201 LIMT1 Real time clock battery restored
Recovery
3.2.36 0046 - Terminal enabled
The indicated terminal has been returned to service and can handle normal user input and output.
0014.0046 TERMINAL 15 Terminal enabled Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.37 0047 - Card Type Not Valid for Application
This message indicates that a TSM card was replaced by an ASM card. The ASM card is automatically inhibited because it is no longer supported.
** 0012.0047 ** CARD 1109 Card type not valid for application
HW VERIFICATION CODE: xxx
Alarm Level: Major
Recovery
Replace the ASM card with the correct version of the TSM card.
Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.38 0048 - Terminal Failed
The MASP has detected that the terminal is faulty. The maintenance software has removed the terminal from service.
* 0014.0048 * TERMINAL 15 Terminal failed
Alarm Level: Minor
Recovery
3.2.39 0049 - Bit Rate change ACK failure
This error is displayed when OAM does not receive the acknowledgement of the Rate change request from an all HIPR2 IMT Bus.
During IMT Bus Rate change execution, no physical status change of IMT Bus (such as unplugging HIPR2 cards) should take place. RLGHNCXA21W 00-02-09 12:01:43 EST EAGLE 41.1.0
* 0100.0049 * IMT Bus A Bit Rate change ACK failure
Alarm Level: Minor
Recovery
No action necessary.
3.2.40 0050 - Bit Rate change ACK received
This message is the clearing alarm for the previous IMT rate change alarm.
0101.0050 IMT Bus A Bit Rate change ACK received
Alarm Level:None
Recovery
3.2.41 0051 - TSC Sync is in Simplex Mode
Due to one or both GPSM-II cards being replaced with MCAPs after the feature bit has been set, the hardware configuration no longer supports the TSC Synchronization feature.
** 0100.0051 ** CARD 1113 OAM TSC sync is in simplex mode
Alarm Level: Major
Recovery
Replace the MCAP(s) with GPSM-II card(s).
3.2.42 0052 - TSC sync feature is available
This indicates that the GPSM-II card(s) is now seated in the appropriate slot and is functioning correctly.
0100.0052 CARD 1113 OAM TSC sync feature is available
Recovery
3.2.43 0053 - Standby TDM Failure
This message indicates the communication between the GPSM-II and TDM has failed.
station1234 94-03-30 16:28:08 EST EAGLE 35.0.0
** 0012.0053 ** CARD 1113 OAM Standby TDM failure
Alarm Level: Major
Recovery
3.2.44 0054 - Standby TDM failure cleared
This message indicates that the communication between the GPSM-II and TDM has been reestablished.
0012.0054 CARD 1113 OAM Standby TDM failure cleared
Recovery
3.2.45 0055 - Persistent device state tbl corrupt
This message indicates that after attempting an automatic recovery from a first checksum error, a Persistent Device States (PDS) checksum error still exists in the standby System Configuration Manager (SCM). PDS features are disabled.
* 0014.0055 * CARD 1115 OAM Persistent device state tbl corrupt
Alarm Level: Minor
Recovery
3.2.46 0056 - Persistent Device State tbl diff Version
This message indicates that the PDS table version in the standby SCM does not match the PDS table version in the active SCM. PDS features are disabled.
* 0014.0056 * CARD 1115 OAM Persistent device state tbl diff version
Alarm Level: Minor
Recovery
3.2.47 0057 - Persistent device state tbl corrected
This indicates that the This message indicates that a problem PDS table has been corrected.
0100.0057 CARD 1115 OAM Persistent device state tbl corrected
Recovery
3.2.48 0058 - Critical customer trouble detected
A critical customer trouble has been detected. There are connections on the control shelf backplane for customer detected troubles (CDTs). Each connection is assigned an identifier 1-16. CDT connections 2-4 are applicable to UAM 0058. CDT connections 6-8 are applicable to UAM 0059. CDT connections 10-16 are applicable to UAM 0060. The customer determines the connections on the backplane (these are dry contact closures). The system reports the alarm according to the connection location.
RLGHNCXA21W 96:07:02 11:02:30 EST EAGLE 35.0.0
*C 0100.0058 *C CDT 4 Critical customer trouble detected
Recovery
Follow local procedures for clearing the indicated trouble.
3.2.49 0059 - Major customer trouble detected
A major customer trouble has been detected. There are connections on the control shelf backplane for customer detected troubles (CDTs). Each connection is assigned an identifier 1-16. CDT connections 2-4 are applicable to UAM 0058. CDT connections 6-8 are applicable to UAM 0059. CDT connections 10-16 are applicable to UAM 0060. The customer determines the connections on the backplane (these are dry contact closures). The system reports the alarm according to the connection location.
** 0100.0059 ** CDT 8 Major customer trouble detected
Alarm Level: Major
Recovery
3.2.50 0060 - Minor customer trouble detected
A minor customer trouble has been detected. There are connections on the control shelf backplane for customer detected troubles (CDTs). Each connection is assigned an identifier 1-16. CDT connections 2-4 are applicable to UAM 0058. CDT connections 6-8 are applicable to UAM 0059. CDT connections 10-16 are applicable to UAM 0060. The customer determines the connections on the backplane (these are dry contact closures). The system reports the alarm according to the connection location.
* 0100.0060 * CDT 16 Minor customer trouble detected
Alarm Level: Minor
Recovery
3.2.51 0061 - Customer trouble detected
A customer trouble has been detected.
RLGHNCXA21W 96:07:02 11:02:30 ESTEAGLE 35.0.0
0100.0061 CDT 11 Customer trouble detected Alarm Level: No alarm condition. The message is informational.
Recovery
This message indicates that a customer-defined trouble is detected. Follow local procedures to clear the trouble.
3.2.52 0062 - Customer trouble cleared
A customer trouble has been cleared.
0100.0062 CDT 11 Customer trouble cleared Alarm Level: No alarm condition. The message is informational.
Recovery
3.2.53 0063 - Critical Holdover Clock trbl Detected
A critical trouble has been detected with the holdover clock. This could include a problem with the reference input and stratum clock cards.
*C 0100.0063 *C CLOCK Critical holdover clock trbl detected
Recovery
Check for any visual alarms.
Note any visual alarms and refer to the Maintenance Manual for Holdover Clock Troubleshooting Procedures to perform the corrective action procedures.3.2.54 0064 - Major Holdover Clock Trouble Detected
A major trouble has been detected with the holdover clock. This could include a problem with the reference input and/or stratum clock cards.
** 0100.0064 ** CLOCK Major holdover clock trouble detected
Alarm Level: Major
Recovery
3.2.55 0065 - Minor Holdover Clock Trouble Detected
A minor trouble has been detected with the holdover clock. This could include a problem with the reference input and/or stratum clock cards.
* 0100.0065 * CLOCK Minor holdover clock trouble detected
Alarm Level: Minor
Recovery
3.2.56 0066 - Holdover clock trouble cleared
A problem with the holdover clock has been corrected.
0100.0066 CLOCK Holdover clock trouble cleared Alarm Level: No alarm condition. The message is informational.
Recovery
This message indicates that a problem with the holdover clock has been cleared.
3.2.57 0077 - Card Temperature is Critical lvl:T2
An HC-MIM card, EPM based card (E5-E1T1, E5-ATM, E5-ENET, ET-IPSM, E5-TSM) EPM-B based card (E5-ATM-B, E5-ENET-B, E5-MCPM-B), or E5-SM8G-B card has reached an operating temperature that is above the operational limit.
*C 0100.0077 *C CARD 1102 LIMT1 Card temperature is critical lvl:T2
Recovery
WARNING:
There is a very limited time to solve this problem. For an HC-MIM card, once the card exceeds its operation limit, all the links on the HC-MIM card will be blocked (ACT-LPO), causing the links to go into local processor outage. All traffic on the blocked links is re-directed elsewhere in the system (based on the current route provisioning). For information about EPM based, EPM-B based, and E5-SM8G-B cards, see "Changing the High-Capacity Card Temperature Alarm Thresholds" procedure in Database Administration Manual - SS7.3.2.58 0078 - Card Temperature Exceeds Nominal lvl:T1
An HC-MIM card, EPM based card (E5-E1T1, E5-ATM, E5-ENET, E5-IPSM, E5-TSM), EPM-B based card (E5-ATM-B, E5-ENET-B, E5-MCPM-B), or E5-SM8G-B card has reached an operating temperature that is above the pre-defined limit.
** 0100.0078 ** CARD 1102 LIMT1 Card temperature exceeds nominal lvl:T1
Alarm Level: Major
Recovery
warning:
There is a very limited time to solve this problem. Once the card exceeds its operation limit, all the links on the HC-MIM card will be blocked (ACT-LPO), causing the links to go into local processor outage. All traffic on the blocked links is re-directed elsewhere in the system (based on the current route provisioning). For information about EPM based, EPM-B based, and E5-SM8G-B cards, see "Changing the High-Capacity Card Temperature Alarm Thresholds" procedure in Database Administration Manual - SS7.3.2.59 0079 - Card temperature again at nominal levels
The operational temperature of the HC-MIM (HC Blade), EPM based card (E5-E1T1, E5-ATM, E5-ENET, ET-IPSM, E5-TSM), EPM-B based card (E5-ATM-B, E5-ENET-B, E5-MCPM-B), or E5-SM8G-B has returned to normal levels.
0100.0079 CARD 1102 LIMT1 Card temperature again at nominal levelsAlarm Level: No alarm condition. The message is informational only.
Recovery
3.2.60 0080 - Shelf FAN bit is OFF
The Eagle Shelf FAN bit is not turned on.
1 2 3 4 5 6 7 8
12345678901234567890123456789012345678901234567890123456789012345678901234567890
xxxx.0080 *C CARD 1103 LIMT1 Shelf FAN bit is OFF Alarm Level: Major
Recovery
To turn the Shelf FAN bit on, use the following command:
chg-shlf
3.2.61 0081 - Shelf FAN bit is ON
The Eagle Shelf FAN bit is turned on. This UAM is an informational message that confirms that the feature is restored to operational status
1 2 3 4 5 6 7 8
xxxx.0081 *C CARD 1103 LIMT1 Shelf FAN bit is ON Alarm Level: Normal
Recovery
This message indicates that the feature previously was OFF and now has been turned ON.
3.2.62 0082 - Alarm in Fuse Panel
A blown fuse has been detected in the fuse panel located on top of the designated frame.
** 0100.0082 ** FUSE PANEL 11xx Alarm in Fuse panel
Alarm Level: Major
Recovery
3.2.63 0083 - Fuse Panel alarm has cleared
This indicates that the fuse alarm has been cleared.
0100.0083 FUSE PANEL 11xx Fuse Panel alarm has cleared Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.64 0084 - IP Connection Unavailable
The TCP/IP and SIGTRAN protocols both have an IP layer. This UAM indicates that either a TCP/IP socket or an SCTP/IP (SIGTRAN) association is unavailable.
RLGHNCXA03W 09-11-06 16:28:08 EST EAGLE5 41.1.0
** 1234.0084 ** IP7CONN LONGSOCKETNAME1 IP Connection Unavailable
Alarm Level: Major
Recovery
There are six recovery procedures for this UAM. The first two procedures are for TCP/IP socket problems; the third procedure is for SCTP/IP (SIGTRAN) problems. Read the UAM to see which entity has been affected, then refer to the following scenarios to help determine which procedure to use:
Use the Recovery Procedure for EDCMs running STC GPLwhen an IP application socket is out of service due to an IP link down (Ethernet problem) or due to the STC card.
Use the Recovery Procedure for DSM with EPAP or ELAP when an IP link is down. The link may be a DSM (Database Service Module) to MPS link.
Use the Recovery Procedure for IPLMx, IPGWx, and IPSG when failure at the IP level is affecting associations used for SS7-over-IP (SIGTRAN) links.
Use the Recovery Procedure for MCP or MCPHCwhen UAM 0084 says that the problem is MCP or MCPHC.
- Use the Recovery Procedure for OAMHCwhen UAM 0084 says that the problem is OAMHC.
- Use the Recovery Procedure for SNMP when UAM 0084 says that the problem is SNMP.
3.2.64.1 Recovery Procedure for EDCMs running STC GPL
3.2.64.2 Recovery Procedure for DSM with EPAP or ELAP
IP Connection Available message.
UAM:
1481.0085 DSM A 1101 IP Connection Available
1482.0085 DSM B 1101 IP Connection Available
3.2.64.4 Recovery Procedure for MCP or MCPHC
3.2.64.5 Recovery Procedure for OAMHC
3.2.64.5.1 Recovery Procedure for Integrated Measurements
3.2.65 0085 - IP connection available
IP system: This message indicates that for an IPLIM, MCP, MCPHC, OAMHC, or SS7IPGW link, one or more connections have been opened for SS7 traffic. IPLIM hosts multiple links, and each link corresponds to exactly one connection. SS7IPGW also hosts multiple links, but each link may have more than one corresponding connection.
EAGLE 5 ISS system: This indicates that a previously broken link with either the far end (external customer link) or between the SIGRAN card and the far end now exists and is functioning properly. This UAM is also used to indicate that a previously broken link between the EPAP and DSM card is now functioning properly.
station1234 09-11-06 16:28:08 EST EAGLE5 41.1.0
1234.0085 IP7CONN LONGSOCKETNAME1 IP Connection Available
Recovery
3.2.66 0086 - IP Connection Congested
This message indicates that an IP application socket or association is congested. The card's memory has been exceeded, so the card cannot process all of the MSUs being received.
In addition to the basic number of MSUs the card is rated to handle, other factors that affect the card's capacity such as the number of connections sharing the card. Network conditions can cause extra memory to be consumed as the card stores MSUs while waiting for acknowledgments from the far end.
IP Connection UAMs 0086 (Congested), 0535 (Restricted), and 0536 (Excess Retransmits) conditions can occur simultaneously. However, only one alarm per device can be displayed at a time. If two or more are present, the display of these alarms is prioritized as follows:- 0086 - IP Connection Congested (MSUs are being dropped)
- 0536 - IP Connection Excess Retransmits (MSUs may be dropped. The EAGLE 5 ISS sustains a certain rate of dropped MSUs without triggering this alarm, then issues UIM 0536 when that rate is exceeded.)
- 0535 - IP Connection Restricted (MSUs are being transmitted at reduced rate. A path of a multi-homed association has failed. )
RLGHNCXA03W 99-04-10 16:28:08 EST EAGLE5 41.1.0
0046.0086 * IP7CONN LONGSOCKETNAME1 IP Connection Congested
Alarm Level: Minor
Recovery
3.2.67 0087 - IP Connection manually removed
This message indicates that an IP application socket has been manually removed from the system.
RLGHNCXA03W 99-04-10 16:28:08 EST EAGLE 35.0.0.0
0046.0087 IP7 LONGSOCKETNAME1 IP Connection manually removed
Recovery
3.2.68 0088 - Clocks A and B TSCs are Out of Sync
It was detected by the OAM that clocks A and B have been out of synch for a excessive period of time. This alarm indicates the clock sources being used for TSCSYNC feature have failed or a hardware failure in the OAM card. This may impact the EAGLE Integrated Monitoring Support feature functionality.
** 0014.0088 ** CARD 1113 EOAM Clocks A and B are out of sync
Alarm Level: Major
Recovery
3.2.69 0089 - Clocks A and B TSCs are resynchronized
A previous GPSM-II card fault is cleared.
0014.0089 CARD 1113 EOAM Clocks A and B TSCs are resynchronized
Recovery
3.2.70 0092 - MDAL Not Responding
This message indicates a problem with the maintenance disk and alarm card (MDAL).
*C 0014.0092 *C CARD 1117 MDAL MDAL not responding
Recovery
3.2.71 0093 - MDAL alarm cleared
A previous maintenance disk and alarm card (MDAL) card fault is cleared.
0014.0093 CARD 1117 MDAL MDAL alarm cleared
Recovery
3.2.72 0096 - Card has been Reloaded
The indicated card has been reinitialized and reloaded with the appropriate data. This occurs as a result of a manual reset or software maintenance intervention.
0014.0096 CARD 1218 SS7ANSI Card has been reloaded
Recovery
Look for other reports associated with the indicated card.
If an obituary report exists, the card malfunctioned. If this happens continuously, replace the defective card. If this is only an occasional condition, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA. Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.73 0097 - IMT allowed
The IMT bus has been returned to service.
0100.0097 IMT SYSTEM IMT allowed
Card 1101, 1102, 1107, 1108
Recovery
This message indicates a previous fault has been corrected. No further action is necessary
3.2.74 0098 - IMT inhibited
The IMT bus has been removed from service by using the
rmv-imt:bus=x
command. The bus is no longer available to carry traffic.
0100.0098 IMT SYSTEM IMT inhibited
Recovery
3.2.75 0099 - Incompatible HW for Provisioned Slot
An MPL card is in a slot provisioned for a different card type and application. The card is automatically inhibited.
** 0100.0099 ** CARD 1201 SS7ANSI Incompatible HW for provisioned slot
Alarm Level: Major
Recovery
- If this message contains the optional line HW
VERIFICATION CODE: xxx:
- If this message does not contain the optional line
‘HWVERIFICATIONCODE: xxx’, perform either of the following steps:
3.2.76 0102 - Motherboard BIP Invalid
The motherboard in the location indicated has an invalid Board ID Prom (BIP).
* 0014.0102 * CARD 1201 SS7ANSI Motherboard BIP invalid
Alarm Level: Minor
Recovery
3.2.77 0103 - Motherboard BIP Valid
The Board ID Prom (BIP) for the specified motherboard is correctly programmed.
0014.0103 CARD 1201 SS7ANSI Motherboard BIP valid
Recovery
3.2.78 0106 - IMT Bus Alarm Cleared
The specified IMT bus has recovered from a fault.
0014.0106 IMT BUS A IMT Bus alarm cleared
Recovery
3.2.79 0107 - Minor IMT Failure Detected
A minor fault has been detected on one of the IMT buses. A minor fault consists of at least one card fault but no more than two card faults.
* 0100.0107 * IMT BUS A Minor IMT failure detected
Card 1101, 1102
Alarm Level: Minor
Recovery
3.2.80 0108 - Major IMT Failure Detected
A major fault has been detected on one of the IMT buses. A major fault consists of three or more faults on the IMT bus.
** 0100.0108 ** IMTBUS A Major IMT failure detected
Alarm Level: Major
Recovery
3.2.81 0109 - All IMT System Level Alarms Cleared
Both IMT busses are functioning.
0100.0109 IMT SYSTEM All IMT System level alarms cleared
Recovery
3.2.82 0110 - Failure Detected on One IMT bus
A fault has been detected on one IMT bus.
* 0100.0110 * IMT SYSTEM Failure detected on one IMT bus
Alarm Level: Minor
Recovery
3.2.83 0111 - Failure on Both IMT A and IMT B
A major fault occurred on one IMT bus and a minor fault has occurred on the other. Or, there is a minor fault on both IMT buses. A minor fault occurs when one or two cards are disconnected from the IMT bus. A major fault occurs when three or more cards are disconnected from the IMT bus.
** 0100.0111 ** IMT SYSTEM Failure on both IMT A and IMT B
Alarm Level: Major
Recovery
Check the status of the IMTs by entering the
rept-stat-imt command.
Contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.2.84 0112 - Major Failures Detected on Both IMTs
Major faults have been detected on both IMT buses.
* C0100.0112 *C IMT SYSTEM Major failures detected on both IMTs
Recovery
3.2.85 0113 - Clock alarm(s) Cleared
All primary and secondary clock sources are functioning.
0100.0113 CLOCK SYSTEM Clock alarm(s) cleared
Recovery
3.2.86 0115 - Linkset IP TPS Threshold Exceeded
This message indicates that the actual linkset transaction rate exceeds the provisioned linkset IPSG TPS.
This message indicates that the actual linkset transaction rate exceeds the linkset capacity alarm threshold defined by lsusealm, tpsalmtype, slktps (rsvdslktps or maxslktps based on tpsalmtype) parameters and the number of links in the linkset.
** 0014.0115 ** LSN lsgw1103 Linkset IP TPS threshold exceeded
Alarm Level: Major
Recovery
3.2.87 0116 - Link Expected IP TPS Threshold Exceeded
This message indicates that the actual link transaction rate is approaching the link's fair share of provisioned linkset capacity.
This message indicates that the actual link transaction rate exceeds the link capacity alarm threshold defined by slkusealm, tpsalmtype and slktps (rsvdslktps or maxslktps based on tpsalmtype) parameters.
RLGHNCXA21W 00-12-07 12:01:43 EST EAGLE 35.0.0
* 0014.0116 * SLK 1104,A LSA01 Link expected IP TPS threshold exceeded
SLC=01 FECLLI=A1234567890
Alarm Level: Minor
Recovery
3.2.88 0118 - Linkset IP TPS Normal
This message indicates the total usage for the linkset TPS rate has fallen below the configured linkset TPS rate.
This message indicates that the actual linkset transaction rate has fallen below the linkset capacity alarm threshold defined by lsusealm, tpsalmtype, slktps (rsvdslktps or maxslktps based on tpsalmtype) parameters and the number of links in the linkset.
0014.0118 LSN lsgw1103 Linkset IP TPS normal
Recovery
3.2.89 0119 - Link IP TPS Normal
This message indicates the total usage for the linkset exceeds the linkset threshold for the linkset’s IP TPS.
This message indicates that the actual link transaction has fallen below the link capacity alarm threshold defined by slkusealm, tpsalmtype and slktps (rsvdslktps or maxslktps based on tpsalmtype) parameters.
0014.0119 SLK 1104,A LSA01 Link IP TPS normal
Recovery
3.2.90 0120 - ENUM SYSTEM is not available
This message indicates none of the ENUM cards is Active/IS-NR.
*C 0002.0120 *C ENUM SYSTEM ENUM SYSTEM is not available
Alarm Level: Critical.
Recovery
Activate (Active/IS-NR) any one of the ENUM cards in the system.
3.2.91 0121 - ENUM SYSTEM is available
This message indicates half or more of the configured ENUM cards are in IS-NR state.
0002.0121 ENUM SYSTEM ENUM SYSTEM is available
Alarm Level: None. The message is informational only.
Recovery
No further action necessary.
3.2.92 0122 - ENUM SYSTEM normal, card(s) abnormal
This message indicates the Active/IS-NR number of ENUM cards is less than half of the configured ENUM cards.
** 0002.0122 ** ENUM SYSTEM ENUM SYSTEM normal, card(s) abnormal
Alarm Level: Major.
Recovery
Activate (Active/IS-NR) half or more ENUM cards in the system.
3.2.93 0123 - ENUM SYSTEM is removed
This message indicates all the ENUM cards are deleted from the system.
0002.0123 ENUM SYSTEM ENUM SYSTEM is removed
Recovery
3.2.94 0124 - ENUM Threshold -Level1 exceeded
This message indicates the card TPS exceeds the configured level-1 value in ENUMOPTS.
* 0002.0124 * CARD xxxx ENUMHC ENUM Threshold -Level1 exceeded
Alarm Level: Minor.
Recovery
Reduce the card TPS below the configured level-1 value in ENUMOPTS.
3.2.95 0125 - ENUM Threshold -Level 2 exceeded
This message indicates the card TPS exceeds the configured level-2 value in ENUMOPTS.
** 0002.0125 ** CARD xxxx ENUMHC ENUM Threshold –Level 2 exceeded
Alarm Level: Major.
Recovery
Reduce the card TPS below the configured level-2 value in ENUMOPTS.
3.2.96 0126 - ENUM Threshold Condition cleared
This message indicates the card TPS has been reduced to below the configured level-1 value in ENUMOPTS.
0002.0126 CARD xxxx ENUMHC ENUM Threshold Condition cleared
Recovery
3.2.97 0127 - ENUM card capacity exceeded
This message indicates the card TPS exceeds the maximum allowable TPS (4000) on a single ENUM card.
*C 0002.0127 *C CARD xxxx ENUMHC ENUM card capacity exceeded
Alarm Level:Critical
Recovery
Reduce the card TPS below the maximum allowed card TPS.
3.2.98 0128 - All Clocks Have Failed
A fault has been detected on all system clocks.
RLGHNCXA21W 00-12-07 11:02:30 EST EAGLE 35.0.0
*C 0100.0128 *C CLOCK SYSTEM All clocks have failed
Recovery
3.2.99 0129 - ENUM Card TPS is normal
This message indicates the card TPS is normal.
0002.0129 CARD xxxx ENUMHC ENUM Card TPS is normal
Recovery
3.2.100 0130 - Card successfully loaded with data
The indicated card has been reloaded by the system with the appropriate GPL and tables.
0014.0130 CARD 1304 SCCP Card successfully loaded with data
Recovery
3.2.101 0132 - Loading Failed: Table Not Found
This indicates an error in an upgrade procedure. Either an incorrect file or table was entered. This message could also indicate the file or table being loaded is corrupted and is not recognized by the system.
** 0014.0132 ** CARD 1304 SCCP Loading failed: table not found
Alarm Level: Major
Recovery
3.2.102 0133 - Loading Failed: Data Read Error
An error occurred on the active MASP while data tables were loaded.
** 0014.0133 ** CARD 1304 SCCP Loading failed: data read error
Alarm Level: Major
Recovery
3.2.103 0134 - Loading Failed: Bad Checksum Returned
The GPL checksum, which is used to verify the data, indicates an error during file transfer. The file (GPL) needs to be downloaded again.
** 0014.0134 ** CARD 1304 SCCP Loading failed: bad checksum returned
Alarm Level: Major
Recovery
3.2.104 0135 - Loading failed: GPL load timeout
There was a timeout caused by the loading process.
** 0014.0135 ** CARD 1304 SCCP Loading failed: GPL load timeout Alarm Level: Major
Recovery
3.2.105 0136 - Loading Failed: Data Load Timeout
The download process timed out on the MASP. This could be caused by an improperly programmed BIP on the daughterboard of the card being loaded.
** 0014.0136 ** CARD 1304 SCCP Loading failed: data load timeout
Alarm Level: Major
Recovery
3.2.106 0137 - Loading Failed: Invalid GPL
This message indicates the GPL file is corrupt or there was a failure in the IMT bus.
** 0014.0137 ** CARD 1304 SCCP Loading failed: invalid GPL
Alarm Level: Major
Recovery
- This problem should correct itself.
- If the problem still exists, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.2.107 0138 - Loading failed: GPL format error
This message indicates a corrupted GPL file.
** 0014.0138 ** CARD 1304 SCCP Loading failed: GPL format error
Alarm Level: Major
Recovery
3.2.108 0139 - Loading Failed: Disk Read Prep Error
This message indicates the GPL version is not current, and incompatible with the system load.
** 0014.0139 ** CARD 1304 SCCP Loading failed: disk read prep error
Alarm Level: Major
Recovery
Refer to the upgrade procedure sent with the software.
If this procedure was followed correctly, and the problem still exists, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.2.109 0140 - Loading Failed: Disk Read Response Error
This message indicates there was an error in reading the fixed disk.
** 0014.0140 ** CARD 1304 SCCP Loading failed:disk read response error
Alarm Level: Major
Recovery
- If the disk was just installed in the system, try the load again.
- If the problem occurs again, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.2.110 0141 - Loading Failed: Disk Read Failed
This message indicates there was a failure while reading the fixed disk on the active TDM.
** 0014.0141 ** CARD 1304 SCCP Loading failed: disk read failed
Alarm Level: Major
Recovery
3.2.111 0142 - System release alarm cleared
The SYSREL.SYS file has been installed on the active fixed disk and the alarm has been cleared.
0014.0142 GPL SYSTEM OAM System release alarm clea Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.112 0143 - System release GPL(s) not approved
This message indicates that one or more approved GPLs do not match the version specified in the SYSREL.SYS file.
* 0014.0143 * GPL SYSTEM OAM System release GPL(s) not approved
Alarm Level: Minor
Recovery
3.2.113 0144 - System Release Version Unknown
This message indicates that a failure has occurred while accessing the SYSREL.SYS file. Either the SYSREL.SYS file could not be found on the active fixed disk or has become corrupted and is not accessible.
* 0014.0144 * GPL SYSTEM OAM System release version unknown
Alarm Level: Minor
Recovery
3.2.114 0145 - HS Clock A for Card Failed, B Normal
This indicates that the High Speed clock A signal for the indicated card is not present.
station1234 99-03-05 16:28:08 EST EAGLE 31.6.0
* 0053.0145 * CARD 1115 OAM HS Clock A for card failed, B normal
Alarm Level: Minor
Recovery
3.2.115 0146 - HS Clock B for Card Failed, A Normal
This indicates the High Speed clock B signal for the indicated card is not present.
* 0053.0146 * CARD 1115 OAM HS Clock B for card failed, A normal
Alarm Level: Minor
Recovery
3.2.116 0147 - High Speed Clocks A and B for Card Failed
The High Speed A and B clock sources for the indicated card are not present.
* 0053.0147 * CARD 1115 OAM High Speed Clocks A and B for card failed
Alarm Level: Minor
Recovery
3.2.117 0148 - High Speed Clock A for card normal
This indicates that the High Speed clock A signal for the indicated card has returned to a normal, functional state.
0053.0148 CARD 1115 OAM High Speed Clock A for card normal Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.118 0149 - High Speed Clock B for card normal
This indicates that the High Speed clock B signal for the indicated card has returned to a normal, functional state.
station1234 99-03-05 16:28:08 EST EAGLE 35.0.0
0053.0149 CARD 1115 OAM High Speed Clock B for card normal Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.119 0157 - OA&M IP Security feature risk detected
This UAM indicates the OA&M IP Security feature is currently ON, and there is 1 or more FTP Servers not using a secure FTP or Telnet terminals not using SSH.
The EAGLE OA&M IP Security feature entry is used to control only the alarming if the SSH for terminals or Security of FTP Server entries is OFF. SSH for terminals and Security of FTP Server entries are controlled via the SECU-DFLT:SSH parameter and SECUIRTY parameter against the FTP servers entries, respectively.
eagle11 17-12-07 09:22:34 EST EAGLE 46.5.0.0.0-0.0.0
* 1988.0157 * SECURITY SYSTEM OA&M IP Security feature risk detected
Recovery
- To clear this alarm, either turn ON the SSH for terminals and security for all FTP sever entries, or turn the EAGLE OA&M IP Security feature OFF.
- Run the
rtrv-secu-dfltandchg-secu-dfltcommands to view and modify the SSH parameter value. - Run
rtrv-ftp-servandchg-ftp-servcommands to view and modify the SECURITY parameter values for the FTP servers entries. - Run the
rtrv-ctrl-featandchg-ctrl-featcommands to view and modify the EAGLE OA&M IP Security feature status.
3.2.120 0158 - OA&M IP Security feature risk cleared
This UAM indicates the OA&M IP Security feature risk alarm has been cleared.
eagle11 17-12-07 09:22:48 EST EAGLE 46.5.0.0.0-0.0.0
1991.0158 SECURITY SYSTEM OA&M IP Security feature risk cleared
Recovery
3.2.121 0159 - High Speed Clocks A and B for card normal
The High Speed A and B clock sources for the indicated card are now functioning normally.
0053.0159 CARD 1115 OAM High Speed Clocks A and B for card normal Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.122 0160 - 1116-S Clock Failed
This message indicates the secondary BITS clock failed on the TDM card in slot 1116.
* 0014.0160 * CLOCK SYSTEM 1116-S clock failed
Alarm Level: Minor
Recovery
3.2.123 0161 - 1116-P Clock Failed
This message indicates that the primary clock on the TDM card in slot 1116 failed.
* 0014.0161 * CLOCK SYSTEM 1116-P clock failed
Alarm Level: Minor
Recovery
3.2.124 0162 - 1116-P, 1116-S Clocks Failed
This message indicates that both BITS clocks have failed on the TDM card located in slot 1116.
** 0014.0162 ** CLOCK SYSTEM 1116-P, 1116-S clocks failed
Alarm Level: Major
Recovery
3.2.125 0163 - 1114-S Clock Failed
This message indicates the secondary BITS clock for the TDM card in slot 1114 has failed.
* 0014.0163 * CLOCK SYSTEM 1114-S clock failed
Alarm Level: Minor
Recovery
3.2.126 0164 - 1114-S, 1116-S Clocks Failed
This message indicates the secondary BITS clock source has failed on both the active and standby TDM cards.
** 0014.0164 ** CLOCK SYSTEM 1114-S, 1116-S clocks failed
Alarm Level: Major
Recovery
3.2.127 0165 - 1114-S, 1116-P Clocks Failed
This message indicates the secondary BITS clock on the TDM card in slot 1114, and the primary BITS clock on the TDM card in slot 1116 have failed.
* 0014.0165 * CLOCK SYSTEM 1114-S, 1116-P clocks failed
Alarm Level: Minor
Recovery
3.2.128 0166 - 1114-S, 1116-P, 1116-S Clocks Failed
This message indicates the following clocks failed:
The secondary clock on the TDM card in slot 1114.
The primary clock on the TDM card in slot 1116.
The secondary clock on the TDM card in slot 1116.
** 0014.0166 ** CLOCK SYSTEM 1114-S, 1116-P, 1116-S clocks failed
Alarm Level: Major
Recovery
3.2.129 0167 - 1114-P Clock Failed
This message indicates the primary BITS clock on the TDM card in slot 1114 has failed.
* 0014.0167 * CLOCK SYSTEM 1114-P clock failed
Alarm Level: Minor
Recovery
3.2.130 0168 - 1114-P, 1116-S Clocks Failed
This message indicates the primary BITS clock on the TDM card in slot 1114, and the secondary BITS clock on the TDM card in slot 1116 have failed.
* 0014.0168 * CLOCK SYSTEM 1114-P, 1116-S clocks failed
Alarm Level: Minor
Recovery
3.2.131 0169 - 1114-P, 1116-P Clocks Failed
This message indicates the primary BITS clock on the TDM cards in slots 1114 and slot 1116 have failed.
** 0014.0169 ** CLOCK SYSTEM 1114-P, 1116-P clocks failed
Alarm Level: Major
Recovery
3.2.132 0170 - 1114-P, 1116-P, 1116-S Clocks Failed
The primary clock on the TDM card in slot 1114.
** 0014.0170 ** CLOCK SYSTEM 1114-P, 1116-P, 1116-S clocks failed
Alarm Level: Major
Recovery
3.2.133 0171 - 1114-P, 1114-S Clocks Failed
This message indicates the primary and secondary BITS clocks on the TDM card in slot 1114 have failed.
** 0014.0171 ** CLOCK SYSTEM 1114-P, 1114-S clocks failed
Alarm Level: Major
Recovery
3.2.134 0172 - 1114-P, 1114-S, 1116-S Clocks Failed
** 0014.0172 ** CLOCK SYSTEM 1114-P, 1114-S, 1116-S clocks failed
Alarm Level: Major
Recovery
3.2.135 0173 - 1114-P, 1114-S, 1116-P clocks failed
** 0014.0173 ** CLOCK SYSTEM 1114-P, 1114-S, 1116-P clocks failed
Alarm Level: Major
Recovery
3.2.136 0174 - %-Full Threshold Reached-Upload Required
This alarm is part of the Security Logging feature. When
the security log reaches a threshold (administered by the
chg-attr-seculog command), this alarm
is raised. If the system detects that the percent full condition of new entries
has reached the threshold, this alarm is raised to alert the system
administrator that the security log must be uploaded to avoid an overflow
condition. If the log is not uploaded before the log is completely full,
entries will be lost. When the security log is uploaded, the alarm is lowered.
RLGHNCXA21W 00-12-07 12:01:43 EST EAGLE 46.3.0.0
* 0047.0174 *SECULOG 1114 %-Full level reached-upload required
Alarm Level: Minor
Recovery
This alarm appears only on the security administrator terminal.3.2.137 0175 - LOGBUFROVFL-SECULOG - Upload Required
chg-attr-seculog command) UAM 174 is
raised. When the log fills completely, new entries are lost and this alarm is
raised. When the security log is uploaded, this alarm is lowered.
* 0014.0175 *SECULOG 1114 LOGBUFROVFL-SECULOG - upload required
Alarm Level: Minor
Recovery
This alarm appears only on the security administrator terminal.3.2.138 0176 - Stdby Security Log - Upload Required
This alarm is part of the Security Logging feature. All of the security log entries should be written to the active MASP and none to the standby MASP. However, should a problem occur and the standby MASP switches to active, the security logs are split between the two MASPs. If there are any new log entries on the standby MASP, the standby log should be uploaded.
* 0014.0176 *SECULOG 1116 Stdby security log - upload required
Alarm Level: Minor
Recovery
This alarm appears only on the security administrator terminal.Enter this command to clear the alarm and copy the
security log to the file transfer area (FTA) in the system:
copy-seculog:slog=stb
3.2.139 0177 - Security Log Exception Cleared
This alarm is part of the Security Logging feature and indicates that a previous alarm has been cleared by doing one of the following:
Upload the security log to the file transfer area.
Turn off the security logging feature.
Raise the threshold for the number of log entries that will generate UAM 174.
0014.0177 SECULOG 1114 Security log exception cleared
Recovery
This alarm appears only on the security administrator terminal.This message indicates a previous fault has been corrected.
3.2.140 0178 - Security log failed
This alarm is part of the Security Logging feature and indicates that a command could not be recorded in the security log.
0014.0178 SECULOG 1114 Security log failed Alarm Level: No alarm condition. The message is informational only.
Recovery
This alarm appears only on the security administrator terminal.This message indicates a logging failure has occurred.
If the problem persists, check for other alarms, such as a disk failure, and troubleshoot that alarm.
3.2.141 0183 - 1116-SHS Clock Failed
This message indicates that the secondary E1/T1 High Speed clock has failed for the TDM card located in slot 1116.
* 0052.0183 * HS CLOCK SYSTEM 1116-SHS clock failed
Alarm Level: Minor
Recovery
3.2.142 0184 - 1116-PHS Clock Failed
This message indicates that the primary E1/T1 High Speed clock has failed for the TDM card located in slot 1116.
* 0052.0184 * HS CLOCK SYSTEM 1116-PHS clock failed
Alarm Level: Minor
Recovery
3.2.143 0185 - 1116-PHS, 1116-SHS Clocks Failed
This message indicates that both E1/T1 High Speed clocks have failed for the TDM card located in slot 1116.
** 0052.0185 ** HS CLOCK SYSTEM 1116-PHS, 1116-SHS clocks failed
Alarm Level: Major
Recovery
3.2.144 0186 - 1114-SHS Clock Failed
This message indicates that the secondary E1/T1 High Speed clock has failed for the TDM card located in slot 1114.
* 0052.0186 * HS CLOCK SYSTEM 1114-SHS clock failed
Alarm Level: Minor
Recovery
3.2.145 0187 - 1114-SHS, 1116-SHS Clocks Failed
This message indicates the secondary E1/T1 High Speed clock source has failed for both the active and standby TDM cards.
** 0052.0187 ** HS CLOCK SYSTEM 1114-SHS, 1116-SHS clocks failed
Alarm Level: Major
Recovery
3.2.146 0188 - 1114-SHS, 1116-PHS Clocks Failed
This message indicates the following High Speed clocks failed:
The secondary High Speed clock for the TDM card in slot 1114.
The primary High Speed clock for the TDM card in slot 1116.
* 0052.0188 * HS CLOCK SYSTEM 1114-SHS, 1116-PHS clocks failed
Alarm Level: Minor
Recovery
3.2.147 0189 - 1114-SHS, 1116-PHS, 1116-SHS Clocks Failed
The secondary High Speed clock for the TDM card in slot 1116
** 0052.0189 ** HS CLOCK SYSTEM 1114-SHS, 1116-PHS,1116-SHS clocks failed
Alarm Level: Major
Recovery
3.2.148 0190 - 1114-PHS Clock Failed
This message indicates the primary High Speed clock for the TDM card in slot 1114 has failed.
* 0052.0190 ** HS CLOCK SYSTEM 1114-PHS clock failed
Alarm Level: Minor
Recovery
3.2.149 0191 - 1114-PHS, 1116-SHS Clocks Failed
The primary High Speed clock for the TDM card in slot 1114
* 0052.0191 * HS CLOCK SYSTEM 1114-PHS, 1116-SHS clocks failed
Alarm Level: Minor
Recovery
3.2.150 0192 - 1114-PHS, 1116-PHS Clocks Failed
This message indicates the primary E1/T1 High Speed clocks for the TDM cards in slots 1114 and 1116 have failed.
** 0052.0192 ** HS CLOCK SYSTEM 1114-PHS, 1116-PHS clocks failed
Alarm Level: Major
Recovery
3.2.151 0193 - 1114-PHS, 1116-PHS, 1116-SHS clks Failed
** 0052.0193 ** HS CLOCK SYSTEM 1114-PHS, 1116-PHS,1116-SHS clks failed
Alarm Level: Major
Recovery
3.2.152 0194 - 1114-PHS, 1114-SHS Clocks Failed
This message indicates the primary and secondary E1/T1 High Speed clocks for the TDM card in slot 1114 have failed.
** 0052.0194 ** HS CLOCK SYSTEM 1114-PHS, 1114-SHS clocks failed
Alarm Level: Major
Recovery
3.2.153 0195 - 1114-PHS, 1114-SHS, 1116-SHS clks Failed
Alarm Level: Major
Recovery
3.2.154 0196 - 1114-PHS, 1114-SHS, 1116-PHS clks Failed
** 0052.0196 ** HS CLOCK SYSTEM 1114-PHS, 1114-SHS,1116-PHS clks failed
Alarm Level: Major
Recovery
3.2.155 0197 - All High Speed Clocks Have Failed
A fault has been detected on all high speed system clocks.
RLGHNCXA21W 00-12-07 11:02:30 EST EAGLE 31.6.0
*C 0100.0197 *C HS CLOCK SYSTEM All high speed clocks have failed
Recovery
3.2.156 0198 - High speed clock alarm(s) cleared
All primary and secondary high speed clock sources are functioning.
0100.0198 HS CLOCK SYSTEM High speed clock alarm(s) cleared Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.157 0199 - OA&M IP Security feature disabled
The Eagle OA&M IP Security Enhancements Feature is not operational. This UAM is issued because the temporary key for the QA&M IP Security feature has expired.
With this feature disabled, you do not have the tools to securely pass data across an otherwise non-secure network. Until the Eagle OA&M IP Security Enhancements Feature is restored, the Eagle cannot provide secure connections from approved clients, and does not protect sensitive passwords and information while in transit between the Eagle and a host.
RLGHNCXA21W 03-03-03 12:01:43 EST EAGLE 35.0.0
0047.0199 SECURITY SYSTEM OA&M IP Security feature disabled
Recovery
3.2.158 0200 - RCVRY-LKF: Link Available
The link has become available for SS7 signaling traffic. SS7 traffic has been restored to the link.
0014.0200 SLK 1202,A nc00027 RCVRY-LKF: link available
SLC=01 FECLLI=A1234567890 CLASS=MTP2
The Class parameter in the example is optional. SS7IPGW and IPLIM links are considered high-speed links by the EAGLE 5 ISS. They are reported as CLASS=SAAL.Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.159 0201 - REPT-LKF: Remote NE Loopback
This message indicates the link is in loopback. This alarm is repeated every 15 minutes until the loopback is deactivated.
** 0014.0201 ** SLK 1205,A nc00027 REPT-LKF:remote NE loopback
The Class parameter in the example is optional.Alarm Level: Major
Recovery
If the loopback was established in error, enter the following command, specifying the location and port from the output message:
dact-lbp:loc=xxxx:port=y
where xxxx = the card location from the outputy = the port A or B from the output.
3.2.160 0202 - REPT-LKF: HWP - too many link interrupts
This message indicates the link has had numerous interruptions.
** 0014.202 ** SLK 1205,A nc00027 REPT-LKF:HWP - too many link interrupts
SLC=01 FECLLI=A1234567890 CLASS=SAAL Note:
Recovery
3.2.161 0203 - REPT-LKF: lost data
The signaling link has lost data.
** 0014.0203 ** SLK 1205,A nc00027 REPT-LKF:lost data
SLC=03 FECLLI=testclli CLASS=MTP2
Recovery
3.2.162 0204 - REPT-LKF: XER - ERM threshold exceeded
The signal unit error rate monitor (ERM) has exceeded the threshold because there are too many errors on the link.
** 0014.0204 ** SLK 1205,A nc00027 REPT-LKF:XER-ERM threshold exceeded
SLC=01 FECLLI=A1234567890 CLASS=SAAL Alarm Level: Major
Recovery
Follow local procedures to test the link facilities.
3.2.163 0205 - REPT-LKF: APF - lvl-2 T1 expd (ready)
The signaling link did not receive a fill-in or message signal unit after the proving period.
** 0313.0205 ** SLK 1205,A nc00027 REPT-LKF:APF-lvl-2 T1 expd (ready)
SLC=03 FECLLI=testclli CLASS=MTP2 Note:
Recovery
If the problem persists, follow local procedures to determine why the far-end is not responding correctly.
3.2.164 0206 - REPT-LKF: APF - lvl-2 T1 expd (not ready)
** 0313.0206 ** SLK 1205,A nc00027 REPT-LKF:APF - lvl-2 T1 expd (not ready)
Recovery
- If the problem persists, follow local procedures to determine why the far-end is not responding correctly.
3.2.165 0207 - REPT-LKF: APF - lvl-2 T3 expired
The link did not receive an SIN or an SIE before the T3 timer expired.
** 0014.0207 ** SLK 1205,A nc00027 REPT-LKF:APF - lvl-2 T3 expired
Recovery
3.2.166 0208 - REPT-LKF: APF - lvl-2 T2 expired
The link did not receive an SIN, SIE, or SIOS.
** 0014.0208 ** SLK 1205,A nc00027 REPT-LKF:APF - lvl-2 T2 expired
SLC=03 FECLLI=testclli CLASS=SAAL Note:
Recovery
3.2.167 0209 - REPT-LKF: APF - failed proving period
The signaling link has failed the proving period.
** 0014.0209 ** SLK 1205,A nc00027 REPT-LKF: APF - failed proving period
Recovery
3.2.168 0210 - REPT-LKF: OSA - received SIO
The signaling terminal has received the status indication Out of Alignment from the far end.
** 0014.0210 ** SLK 1205,A nc00027 REPT-LKF: OSA - received SIO
Recovery
3.2.169 0211 - REPT-LKF: OSA - received SIN
The signaling terminal has received the status indication normal proving from the far end.
** 0014.0211 ** SLK 1205,A nc00027 REPT-LKF: OSA - received SIN
Recovery
3.2.170 0212 - REPT-LKF: OSA - received SIE
The signaling terminal has received the status indication emergency alignment, from the far end.
** 0014.0212 ** SLK 1205,A nc00027 REPT-LKF: OSA - received SIE
Recovery
3.2.171 0213 - REPT-LKF: OSA - received SIOS
The signaling link has received the status indication out of service from the far end.
** 0014.0213 ** SLK 1205,A nc00027 REPT-LKF: OSA - received SIOS
Recovery
3.2.172 0214 - REPT-LKF: ABN - rcvd 2 of 3 invalid BSN
The link has received 2 out of 3 invalid backward sequence numbers (BSNs) from the far end.
** 0014.0214 ** SLK 1205,A nc00027 REPT-LKF: ABN - rcvd 2 of 3 invalid BSN
Recovery
3.2.173 0215 - REPT-LKF: ABN - rcvd 2 of 3 invalid FIB
The signaling link has received 2 out of 3 invalid forward indicator bits (FIB) from the far end.
** 0014.0215 ** SLK 1205,A nc00027 REPT-LKF: ABN-rcvd 2 of 3 invalid FIB
Recovery
3.2.174 0216 - REPT-LKF: remote congestion timeout
The remote node has been in congestion too long. The T6 timer has timed out.
** 0014.0216 ** SLK 1205,A nc00027 REPT-LKF:remote congestion timeout
Recovery
If the problem persists, follow local procedures to determine why the far end is not responding correctly.
3.2.175 0217 - REPT-LKF: XDA - excess acknowledge delay
The T7 timer has timed out. Either there is too much incoming traffic on M2PA signaling links, or the far end node is taking too long to acknowledge the messages sent to it by the signaling terminal.
** 0014.0217 ** SLK 1205,A nc00027 REPT-LKF: XDA-excess acknowledge delay
Recovery
- Enter
rept-stat-card:mode=full:loc=xxxxto determine if the signaling link is M2PA. If so, continue to 2. If not, skip to 3. - If this alarm is raised for M2PA signaling links, do the following:
- Enter the
rept-stat-iptpsandmsucount –lcommands to determine how much traffic is received and transmitted on the M2PA links. - Enter the
rtrv-lscommand to determine the amount of rsvdslktps and maxslktps traffic that the M2PA signaling link can receive based on what is provisioned. (The rsvdslktps is the reserved-per-signaling-link TPS for IPSG linkset; this indicates the minimum guaranteed capacity for each link in the linkset. The maxslktps is the maximum-per-signaling-link TPS; this indicates the maximum traffic permitted when sufficient unused capacity is present on the host card.) - If the value is incorrect to handle the incoming traffic rate, enter the
chg-lscommand to increase or decrease the minimum and maximum TPS for the M2PA signaling link.
- Enter the
- If the problem persists, follow local procedures to determine why the far end is not responding correctly.
3.2.176 0218 - REPT-LKF: COO - rcvd changeover order
The signaling link has received a changeover order from the far end.
** 0014.0218 ** SLK 1205,A nc00027 REPT-LKF:COO-rcvd changeover order
Recovery
3.2.177 0219 - REPT-LKF: False Congestion Restart
This message indicates the signaling link has entered a congestion state even though the traffic on the linkset is not high enough to cause congestion. For example, if the link has a high number of re-transmissions, the throughput on the link could drop enough to cause congestion on the link. A T31 timer has started. If the link stays in congestion for a specified period, the link is restarted.
** 0014.0219 ** SLK 1205,A nc00027 REPT-LKF:false congestion restart
Recovery
3.2.178 0220 - REPT-LKF: MTP Link Restart Delayed
This message indicates that a link has gone in and out-of-service. To avoid links going in and out-of-service repeatedly, the EAGLE system uses level 3 T32 timer procedure, which delays restarting a link if the link has an unstable history.
** 0014.0220 ** SLK 1205,A nc00027 REPT-LKF:MTP link restart delayed
The Class parameter in the example is optional. SS7IPGW and IPLIM links are considered high-speed links by the EAGLE 5 ISS system. They are reported as CLASS=SAAL.Alarm Level: Major
Recovery
The link should become available.
If the problem persists, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.2.179 0222 - REPT-LKF: remote FE loopback
This message indicates that the specified link has been looped back from the far-end.
** 0014.0222 ** SLK 1205,A nc00027 REPT-LKF:remote FE loopback
Recovery
If you wish to stop the loopback testing, notify the far-end to stop the testing.
3.2.180 0223 - REPT-LKF: remote NE loopback cleared
This message indicates the link was in loopback and now the loopback has been deactivated.
0014.0223 SLK 1205,A nc00027 REPT-LKF:remote NE loopback cleared
The Class parameter in the example is optional.Alarm Level: No alarm condition. The message is informational only.
Recovery
No further action is necessary.
3.2.181 0224 - REPT-LKF: link test failed
This message indicates that the specified link was automatically removed from service (OOS) because of a failed signaling link test.
** 0014.0224 ** SLK 1205,A nc00027 REPT-LKF:link test failed
Recovery
3.2.182 0225 - CARD running outdated Flash GPL
This message indicates an OAM/MCP/IPS card is running a GPL with VxWorks6.4 version or Service Module card is running 32-bit SM GPLs (SCCPHC, DEIRHC, SIPHC, ENUMHC). EAGLE release 46.6 is going to be the last release in which 32-bit SM GPLs (SCCPHC, DEIRHC, SIPHC, ENUMHC) is available. EAGLE running/getting upgraded to release 46.6 generates UAM 0225, "CARD running outdated Flash GPL", if there are SM cards running 32-bit GPLs. All SM cards should be converted to run 64-bit GPLs to clear the alarm. SM cards can be converted to 64-bit during the upgrade maintenance window or during next available maintenance window.
1 2 3 4 5 6 7 8
** 5019.0225 ** CARD 1101 MCPHC CARD running outdated Flash GPL
HW VERIFICATION CODE: 182
Alarm Level: Major
Recovery
- Upgrade the OAM/MCP/IPS card to VXworks6.9.
- Upgrade the SM card to 64 bit GPL.
3.2.183 0230 - REPT-LKF: Local Blocked - Thermal
All links to the HC MIM are blocked because the temperature of the HC MIM is above operational limits.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 35.0.0
** 0014.0230 ** SLK 1205,A nc00027 REPT-LKF: local blocked - thermal
Alarm Level: Major
Recovery
Review the output.
Correct the associated alarms to clear this alarm.
3.2.184 0232 - REPT-LKF: remote blocked
The link is blocked due to an event at the far-end.
** 0014.0232 ** SLK 1205,A nc00027 REPT-LKF: remote blocked
Recovery
Contact the far-end office to verify a processor outage and correct.
3.2.185 0233 - REPT-LINK-MANUAV: local blocked
A local technician has put the signaling link in processor outage.
** 0014.0233 ** SLK 1205,A nc00027 REPT-LINK-MANUAV: local blocked
Recovery
3.2.186 0234 - REPT-LKF: RMI remote inhibited
The link has been remotely inhibited by a technician at the far-end office.
** 0014.0234 ** SLK 1205,A nc00027 REPT-LKF: RMI remote inhibited
Recovery
Contact the far-end office to verify the reason for inhibiting the link.
3.2.187 0235 - REPT-LINK-MGTINH: local inhibited
The link has been inhibited locally by a technician.
** 0014.0235 ** SLK 1205,A nc00027 REPT-LINK-MGTINH: local inhibited
Recovery
3.2.188 0236 - REPT-LKF: Not Aligned
The signaling link has lost alignment. It can no longer carry traffic.
** 0014.0236 ** SLK 1205,A nc00027 REPT-LKF: not aligned
Recovery
3.2.189 0237 - REPT-LKF: LM Timer NO-CREDIT expired
The remote node has held the local node in a no-credit state for too long.
** 0014.0237 ** SLK 1205,A nc00027 REPT-LKF: LM Timer NO-CREDIT expired
Recovery
Contact the far-end office to test and correct the link congestion problem.
3.2.190 0238 - REPT-LKF: XDA-Timer NO-RESPONSE expired
The far end is not responding to the outgoing POLL messages.
** 0014.0238 ** SLK 1205,A nc00027 REPT-LKF: Timer NO-RESPONSE expired
Recovery
Contact the far-end office to determine why no STAT messages are being sent.
3.2.191 0239 - REPT-LKF:MBL - Local Processor Outage
Indicates a spontaneous or management-initiated processor outage.
** 0014.0239 ** SLK 1205,A nc00027 REPT-LKF:MBL - local processor outage
Recovery
3.2.192 0240 - REPT-LKF: rcvd remote processor outage
The far end sent an END processor outage protocol data unit (PDU).
** 0014.0240 ** SLK 1205,A nc00027 REPT-LKF: rcvd remote processor outage
Recovery
Contact the far-end office to verify a processor outage and the cause.
3.2.193 0241 - REPT-LKF: rcvd remote out of service
The far end sent an END out of service protocol data unit (PDU).
** 0014.0241 ** SLK 1205,A nc00027 REPT-LKF: rcvd remote out of service
Recovery
Contact the far-end office to correct the problem.
3.2.194 0242 - REPT-LKF:rcvd remote protocol error
A protocol error has occurred on the far end.
** 0014.0242 ** SLK 1205,A nc00027 REPT-LKF:rcvd remote protocol error
Recovery
Contact the far-end office to test and correct the problem.
3.2.195 0243 - REPT-LKF:rcvd Remote mgmt Inititated
The MAAL layer (not a user) on the far end released a link.
** 0014.0243 ** SLK 1205,A nc00027 REPT-LKF:rcvd remote mgmt inititated
Recovery
Contact the far-end office for the details about releasing the link.
3.2.196 0244 - REPT-LKF: FAC – DS1/E1 LOS failure
A level 1 facility outage: loss of signal.
** 0014.0244 ** SLK 1205,A nc00027 REPT-LKF: FAC – DS1/E1 LOS failure
Recovery
3.2.197 0245 - REPT-LKF: FAC – DS1/E1 LOF failure
A level 1 facility outage: loss of frame.
** 0014.0245 ** SLK 1205,A nc00027 REPT-LKF: FAC – DS1/E1 LOF failure
Recovery
3.2.198 0246 - REPT-LKF: FAC – DS1/E1 LCD failure
A level 1 facility outage: loss of cell delineation.
** 0014.0246 ** SLK 1205,A nc00027 REPT-LKF: FAC – DS1/E1 LCD failure
Recovery
3.2.199 0247 - REPT-LKF: XER - ISERM threshold exceeded
The in-service error rate monitor (ISERM) maintains a counter to estimate the PDU error rate. The ISERM counter exceeded the estimated threshold.
** 0014.0247 ** SLK 1205,A nc00027 REPT-LKF:XER - ISERM threshold exceeded
SLC=03 FECLLI=testclli CLASS=MTP Note:
Recovery
Contact the far-end office to determine why the error rate is so high.
3.2.200 0248 - DDL Unstable
This alarm indicates the DDL unstable has been detected.
** 0002.0248 ** Card 1212 DDL Unstable
Alarm Level: Major
Recovery
3.2.201 0249 - DDL Stable
This indicates the DDL is no longer unstable.
0002.0249 * Card 1212 DDL Stable
Alarm Level: None
3.2.202 0250 - MPS Available
This indicates that a previous MPS platform association loss has been reestablished and is currently functioning properly.
station1234 99-03-30 16:28:08 EST EAGLE 35.0.0
3535.0250 MPS A MPS available
Recovery
3.2.203 0261 - MPS Unavailable
This message indicates that the EAGLE 5 ISS system is unable to communicate with the MPS or the MPS has an internal failure.
*C 3535.0261 *C MPS A MPS unavailable
Recovery
3.2.204 0262 - GTT Duplicate Actn processing stopped
The Service Module card received too many MSUs requiring GTT Duplicate Actions at one time. As a result, the Service Module card was generating more duplicate MSUs than the card could handle. To prevent the number of duplicates from overwhelming the Service Module card, the card stopped processing GTT Duplicate Actions.
** 0002.0262 ** SCCP SYSTEM GTT Duplicate Actn processing stopped
Service: GTT Alarm Level: Major
Recovery
The Service Module card will begin processing GTT Duplicate Actions again with no further action. To prevent the problem from occurring again, do the following:
- Run the
rept-stat-sccpcommand to see the location of the Service Module cards that are not processing GTT Duplicate Actions. Note that this command does not display the GTT Actions that resulted in the disabling of GTT Duplicate Actions. - To reduce the chance of the overwhelming the Service Module card, do one of the following:
- Provision fewer GTT Duplicate Actions so that the Service Module card does not generate excess duplicate messages.
- Rearrange the location of LIM and Service Module cards so that the traffic is evenly distributed among the Service Module cards.
3.2.205 0263 - GTT Duplicate Actn processing resumed
The Service Module card stopped GTT Duplicate Action processing temporarily, because the number of duplicate MSUs was more than the card could handle. This UAM is issued when GTT Duplicate Action processing resumes.
0002.0263 SCCP SYSTEM GTT Duplicate Actn processing resumed
Service: GTTAlarm Level: No alarm condition. The message is informational only.
Recovery
3.2.206 0264 - REPT-LINK-CGST: Congestion Level 0 to 1
The amount of MSU traffic on the link has reached a congestion level 1.
0014.0264 SLK 1205,A nc00027 REPT-LINK-CGST: congestion level 0 to 1
Recovery
3.2.207 0265 - REPT-LINK-CGST: Congestion Level 1 to 2
The amount of MSU traffic on the link has reached a congestion level 2.
0014.0265 SLK 1205,A nc00027 REPT-LINK-CGST: congestion level 1 to 2
Recovery
3.2.208 0266 - REPT-LINK-CGST: Congestion level 2 to 3
The congestion on a link has risen to level 3. That is, the amount of MSU traffic on the signaling link has reached the onset level defined for congestion level 3. This usually indicates the node is under provisioned.
0014.0266 SLK 1205,A nc00027 REPT-LINK-CGST: congestion level 2 to 3
Recovery
3.2.209 0267 - RCVRY-LINK-CGST:Congestion Level 3 to 2
The congestion on a link has fallen to level 2. That is, the amount of MSU traffic on the signaling link has reached the abatement level defined for congestion level 3. This indicates congestion is clearing.
0014.0267 SLK 1205,A nc00027 RCVRY-LINK-CGST:congestion level 3 to 2
Recovery
Since congestion usually peaks and subsides quickly, a measurements report should be printed to understand what SS7 events took place.
rept-meas to obtain a report.
The measurements collection must first be turned on so measurements can be collected. If measurements are not turned on, no report will be available. Refer to the Measurements Manual for traffic measurements information.3.2.210 0268 - RCVRY-LINK-CGST:Congestion Level 2 to 1
The congestion on a link has fallen to level 1. That is, the amount of MSU traffic on the signaling link has reached the abatement level defined for congestion level 2. This indicates congestion is clearing.
0014.0268 SLK 1205,A nc00027 RCVRY-LINK-CGST:congestion level 2 to 1
Recovery
The measurements collection must first be turned on so measurements can be collected. If measurements are not turned on, no report will be available. Refer to the Measurements Manual for traffic measurements information.3.2.211 0269 - RCVRY-LINK-CGST: congestion has cleared
This message is generated when the congested state of a link has been removed.
0014.0269 SLK 1205,A nc00027 RCVRY-LINK-CGST: congestion has cleared
Recovery
3.2.212 0270 - REPT-LINK-CGST: Discard Level 0 to 1
The amount of MSU traffic on the link has reached an overflow level 1. Messages with an SIO priority of 0 are being discarded.
0014.0270 SLK 1205,A nc00027 REPT-LINK-CGST: discard level 0 to 1
Recovery
3.2.213 0271 - REPT-LINK-CGST: Discard Level 1 to 2
The link has reached an overflow level 2. The percentage of MSU traffic on the signaling link has exceeded the discard/overflow level defined for level 2. Messages with SIO priority of 0 or 1 are being discarded.
0014.0271 SLK 1205,A nc00027 REPT-LINK-CGST: discard level 1 to 2
Recovery
3.2.214 0272 - REPT-LINK-CGST: Discard Level 2 to 3
The amount of MSU traffic on the link has reached an overflow level 3. Messages with an SIO priority of 0, 1, or 2 are being discarded.
0014.0272 SLK 1205,A nc00027 REPT-LINK-CGST: discard level 2 to 3
Recovery
3.2.215 0273 - RCVRY-LINK-CGST: Discard Level 3 to 2
The amount of MSU traffic on the link has reached an overflow level 2 and congestion is clearing. Messages with an SIO priority of 0 or 1 are being discarded.
0014.0273 SLK 1205,A nc00027 RCVRY-LINK-CGST: discard level 3 to 2
Recovery
Since overflow conditions usually peak and subside quickly, a measurements report should be printed to understand what SS7 events took place.
The measurements collection must first be turned on so measurements can be collected. If measurements are not turned on, no report will be available. Refer to the Measurements Manual for traffic measurements information.3.2.216 0274 - RCVRY-LINK-CGST: Discard Level 2 to 1
The amount of MSU traffic on the link has decreased to an overflow level 1 and congestion is clearing. Messages with an SIO priority of 0 are being discarded.
0014.0274 SLK 1205,A nc00027 RCVRY-LINK-CGST: discard level 2 to 1
Recovery
The measurements collection must first be turned on so measurements can be collected. If measurements are not turned on, no report will be available. Refer to the Measurements Manual for traffic measurements information.3.2.217 0275 - RCVRY-LINK-CGST: discard has cleared
The overflow level of the link has reached level 0. No messages are being discarded.
0014.0275 SLK 1205,A nc00027 RCVRY-LINK-CGST: discard has cleared
Recovery
3.2.218 0276 - Insufficient HW for IP7 Provisioning
The DCM or EDCM does not have enough memory to provision for sockets and associations.
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 35.0.0
** 0100.0276 ** CARD 1115 DCM Insufficient HW for IP7 provisioning
HW VERIFICATION CODE: xxx
Alarm Level: Major
Recovery
3.2.219 0277 - AS Unavailable
This Application Server (AS) is not available to carry service traffic. All ASPs in this AS are not available to carry service traffic.
** 0014.0277 ** IP7 as3 AS Unavailable
Alarm Level: Major
Recovery
- If the connection is in service, enter this command
to generate a report of the AS association status:
rept-stat-as:asname="application_server_name" - If the connection is not in service, there is nothing more you can do to fix the problem without further information from the far end, because the far end node is in control of this state.
3.2.220 0278 - AS Available
The Application Server (AS) is now available to carrying traffic.
0014.0278 IP7 as2 AS Available
Recovery
3.2.221 0279 - AS Restricted
At least half of the paths are not working, so the traffic is considered restricted. The Application Server (AS) is carrying traffic, but one of the Application Server Processes (ASPs) is not functioning properly.
RLGHNCXA21W 00-12-07 12:01:43 EST EAGLE 28.1.0
* 0014.0279 * IP7 as2 AS Restricted
Alarm Level: Minor
Recovery
3.2.222 0280 - AS Unrestricted
The Application Server (AS) is carrying traffic. A previous restriction has been cleared.
0014.0280 IP7 as2 AS Unrestricted
Recovery
3.2.223 0283 - LNP Ported LRNs approaching Feat. Cap.
The number of LNP ported LRNs is greater than the capacity this feature supports.
This UAM appears when the DSMV SCCP cards are cold-restarted after the ELAP RTDBs were pre-populated offline with LRN totals that exceed the LRN Quantity Feature keys capacities that are currently configured for the EAGLE 5 ISS.
RLGHNCXA21W 03-02-07 11:02:30 EST EAGLE 35.0.0
** 0100.0283 ** CARD 1115 DCM LNP Ported LRNs approaching Feat. Cap.
Alarm Level: Major
Recovery
3.2.224 0284 - LNP Ported LRNs Capacity Normal
This UAM is a clearing message that appears when the operator enables the LRN feature key quantities on the Eagle that exceed the quantities currently populated in the ELAP RTDBs.
** 0100.0284 CARD 1115 DCM LNP Ported LRNs Capacity Normal
Recovery
3.2.225 0285 - LNP Ported NPAs Approaching Feat. Cap.
The number of LNP ported NPANXXs is greater than the capacity this feature supports.
This UAM appears when the DSMVSCCP cards are cold-restarted after the ELAPRTDBs were pre-populated offline with NPANXX totals that exceed the NPANXX Quantity Feature keys capacities that are currently configured for the EAGLE 5 ISS.
** 0100.0285 ** CARD 1115 DCM LNP Ported NPAs approaching Feat. Cap.
Alarm Level: Major
Recovery
3.2.226 0286 - LNP Ported NPAs Capacity Normal
This UAM is a clearing message that appears when the operator enables the NPANXX feature key quantities on the Eagle that exceed the quantities currently populated in the ELAP RTDBs.
** 0100.0286 CARD 1115 DCM LNP Ported NPAs Capacity Normal
Recovery
3.2.227 0287 - RTDB Table Level 2 FAK Cap Exceeded
This UAM warns the customer that the total TNs in the LNP database has reached 95% of the LNP database Feature Access Key (FAK) capacity.
*C 0100.0287 *C LNP 1115 DCM RTDB Table Level 2 FAK Cap Exceeded
TABLE: TN Threshold Value: 95%
Exceeds 88320000 of 96000000
Recovery
3.2.228 0288 - RTDB Table Level 1 FAK Cap Exceeded
This UAM warns the customer that the total TNs in the LNP database has reached 80% of the LNP database Feature Access Key (FAK) capacity.
RLGHNCXA21W 03-02-07 11:02:30 ESTEAGLE 35.0.0
** 0100.0288 ** LNP 1115 DCM RTDB Table Level 1 FAK Cap Exceeded
TABLE: TN Threshold Value: 80%
Exceeds 76800000 of 96000000
Alarm Level: Major
Recovery
3.2.229 0289 - RTDB Table FAK Capacity Normal
This UAM appears when the LNP FAK alarm condition no longer exists.
0100.0289 LNP 1115 DCM RTDB Table FAK Capacity Normal
Recovery
This message indicates a previous condition has been corrected.
3.2.230 0290 - GLS is Available
The TSM cards configured as generic loader services (GLS) are functioning. These cards are used to download gateway screening (GWS) data to the LIMs.
0100.0290 GLS SYSTEM GLS is available
Recovery
3.2.231 0291 - GLS is at Minimum Service Limit
Only one TSM configured for generic loader services (GLS) is in service. When this module fails, GLS is unavailable.
Generic loader services (GLS) are used to download gateway screening data to the LIMs. GLS consists of TSM cards configured with GLS software. They are only needed when LIMs or TSMs must be reloaded.
** 0100.0291 ** GLS SYSTEM GLS is at minimum service limit
Alarm Level: Major
Recovery
3.2.232 0292 - GLS is Not Available
Generic loading services (GLS) is not able to function; the EAGLE 5 ISS may not be performing gateway screening (GWS).
At least one card should be returned to IS-NR status. This makes GLS available and changes the alarm level to major (0291 - GLS is at Minimum Service Limit). The alarm clears after two TSM cards have returned to IS-NR.
*C 0100 0292 *C GLS SYSTEM GLS is not available
Recovery
3.2.233 0293 - GLS Have Been Removed From The System
Generic loading services (GLS) has been removed from the system, because all TSMs configured for GLS have been deleted through database administration commands.
0100.0293 GLS SYSTEM GLS have been removed from the system
Recovery
This message alerts the user that all TSMs configured for GLS have been deleted from the system.
No action is necessary unless gateway screening is required.
3.2.234 0294 - REPT-ALMINH: Alarm Output PERM Inhibit
This message indicates that alarms for the indicated device are permanently inhibited at the indicated level.
6277.0294 RTXA 001-101-001 REPT-ALMINH: alarm output PERM Inhibit
OPCA= 004-004-004
ALARM INHIBIT LEVEL: MAJR
The output can vary significantly. Alarm Inhibit alarms are generic and the output varies depending on which alarm/device is inhibited. This example utilizes the CARD format.Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.235 0295 - REPT-ALMINH: Alarm Output Enabled
This message indicates the restoration of the reporting of alarms for the indicated device at the indicated level.
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 31.5.0
0100.0295 CARD 1101 SCCP REPT-ALMINH: alarm output enabled
The output can vary significantly. Alarm Inhibit alarms are generic and the output varies depending on which alarm/device is inhibited.Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.236 0296 - REPT-ALMINH: Alarm Output TEMP Inhibit
This message indicates that alarms for the indicated device are temporarily inhibited at the indicated level.
tekelecstp 09-11-06 14:56:48 EST EAGLE 41.1.0
0045.0296 IP7CONN applsock1 REPT-ALMINH: alarm output TEMP Inhibit ALARM INHIBIT LEVEL: MAJR
Recovery
3.2.237 0297 - Incorrect Port Configuration
This message indicates that a MPL card with more than ports A and B provisioned has been replaced with a 2 port DS0-A LIM card. This alarm is also generated if an MPL card is placed in a LIM slot which has either port A or port B provisioned as non-56K bps link speed.
** 0100.0297 ** CARD 1108 SS7ML Incorrect LIM port configuration
Alarm Level: Major
Recovery
3.2.238 0298 - Card Not Using config. SCTP csum Method
The IPLIMx/IPGWx card issues this UAM alarm when the card's active SCTP checksum algorithm does not match the configured SCTP checksum algorithm in the IP OPTIONS table.
* 0100.0298 * CARD 1115 DCM Card not using config. SCTP csum method
Alarm Level: Minor
Recovery
3.2.239 0299 - Config. SCTP csum Method Alarm Cleared
The SCTP checksum UAM alarm is cleared when the card's active SCTP checksum algorithm matches the configured SCTP checksum algorithm.
0100.0299 CARD 1115 DCM Config. SCTP csum method alarm cleared
Recovery
3.2.240 0300 - TVG Grant Failure
This message indicates that for some card in the system, the grant mechanism (as part of the Multicast Capacity Feature) failed for at least 60 seconds, or more than one time for a 15-second period. A TVG granter failure is defined as a TVG request that completes with a time-out (hardware or software) and/or a status value where the Granter Present bit is not set.
RLGHNCXA21W 09-04-06 11:55:14 EST EAGLE5 40.3.0-62.15.21
** 0016.0300 ** CARD 1203 SS7ML TVG Grant Failure
INFO: SCCP --N---
Alarm Level: Major
Recovery
3.2.241 0301 - TVG Grant Recovery
This message indicates the Multicast Capacity Feature for handling SNM or SCCP traffic is functioning, and a previous problem has cleared.
0100.0301 CARD 1201 OAM TVG Grant Recovery
Recovery
3.2.242 0302 - Cooling Fan Failure
The cooling fan hardware is not working.
* 0100.0302 * SYSTEM Cooling fan failure
Alarm Level: Minor
Recovery
3.2.243 0303 - Cooling Fans Normal
The cooling fan hardware has returned to service.
0100.0303 SYSTEM Cooling Fans Normal Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.244 0304 - REPT-NMTSK-DSCD: SNM Discard Onset
This message indicates that the number of system network messages has exceeded the threshold and messages are being discarded.
* 0100.0304 * CARD 1113 OAM REPT-NMTSK-DSCD: SNM Discard Onset Alarm Level: Minor
Recovery
Check for problems in the network that would cause excessive network management messages to be broadcast.
3.2.245 0305 - RECVY-NMTSK-DSCD: SNM Discard Abated
This message indicates that network messages are no longer being discarded.
0100.0305 CARD 1113 OAM REPT-NMTSK-DSCD: SNM Discard Abated Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.246 0306 - SNM Overload Onset
This message indicates that network management messages are approaching the threshold where they will be discarded.
* 0100.0306 * CARD 1113 OAM SNM Overload Onset Alarm Level: Minor.
Recovery
3.2.247 0307 - SNM Overload Abated
This message indicates that the threat of network messages being discarded no longer exists.
0100.0307 CARD 1113 OAM SNM Overload Abated Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.248 0308 - Node Isolated Due to SLK Failures
The EAGLE 5 ISS is isolated from other signaling points. All system links are down. Possible causes are as follows:
Primary and secondary clock sources have failed.
Signaling links have been manually cancelled.
All cards have been manually inhibited.
Both IMT busses have failed.
*C 0100.0308 *C SYSTEM Node isolated due to SLK failures
Recovery
3.2.249 0309 - Node is no longer isolated
This message occurs when the node has been in node isolation due to signaling link failures. Enough links have recovered so that the node is no longer isolated and signaling can occur.
0100.0309 SYSTEM Node is no longer isolated Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.250 0311 - DPC is allowed
A previous fault is corrected and the EAGLE 5 ISS system can send traffic to a specified point code.
0014.0311 DPC 144-201-001 DPC is allowed
LSN=nc00027
Prohibited SS 1, 5, 18
Allowed SS 3, 6
Blocked SS 100, 103
Unblocked SS 2, 102, 221 Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.251 0312 - DPC is Restricted
A transfer-restricted message has been received concerning the DPC. Possible causes:
One or more routes to this DPC are unavailable.
A low priority route is carrying the traffic. The primary and combined routes are not available for traffic to the given DPC.
* 0014.0312 * DPC 144-201-001 DPC is restricted
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Alarm Level: Minor
Recovery
- Enter the
rept-stat-rtecommand using the DPC specified from the output message to determine which linkset has a problem. - Enter the
rept-stat-lsusing the linkset name specified from the output of Step 1 to determine which link(s) could have a problem. - Use local procedures to test the link facilities.
3.2.252 0313 - DPC is prohibited
Traffic to the DPC is prohibited. Possible causes:
All routes to this DPC are unavailable.
Adjacent point code link failures or nonadjacent failure in the route.
12345678901234567890123456789012345678901234567890123456789012345678901234567890
** 0044.0313 *C DPCN24 001-001-001 DPC is prohibited
LSN=lsn012345
Prohibited SS 5, 20
Recovery
- Enter the
3.2.253 0314 - Route is Allowed
The primary route to the DPC can carry traffic.
0014.0314 DPC 144-201-001 Route is allowed
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
3.2.254 0315 - Route is Restricted
Traffic in the primary route to the DPC is restricted. This could indicate signaling link failures for a non-adjacent DPC.
0014.0315 DPC 144-201-001 Route is restricted
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
Contact the far-end to test and correct the problem.
3.2.255 0316 - Route is Prohibited
The route to the DPC cannot carry traffic to the DPC. Following are the possible causes:
Local SLK failures
Non-adjacent DPC SLK failures
0014.0316 DPC 144-201-001 Route is prohibited
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
3.2.256 0317 - RCVRY-LKSTO: Link set allowed
The linkset is returned to service.
0014.0317 LSN a24546 RCVRY-LKSTO: Link set allowed Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.257 0318 - REPT-LKSTO: Link Set Prohibited
This message indicates a linkset is out of service.
** 0014.0318 ** LSN a54646 REPT-LKSTO: Link set prohibited
Alarm Level: Major
Recovery
3.2.258 0319 - REPT-MTPLP-DET: Circ rte det(cong)
The system automatically tests for circular routing when congestion occurs on an ANSI signaling link. If the routing data was provisioned incorrectly, or was corrupted, MSUs could be routed in an endless circular route. The incorrect routing data could be on the system or at a remote STP. This message indicates that circular routing has been detected.
*C 0044.0319 *C RTXN24 001-101-001 REPT-MTPLP-DET: Circ rte det(cong)
OPCA= 007-001-000
XMIT LSN=ls04 RC=20
RCV LSN=lsna05
MEMBER=011-210-004
Recovery
3.2.259 0320 - REPT-MTPLP-SUST: Sustained circ rt(cong)
*C 0014.0320 *C DPC 011-210-* REPT-MTPLP-SUST: Sustained circ rt(cong)
XMT LSN=ls01 RC=10
RCV LSN=ls14
MEMBER=011-210-007
Recovery
3.2.260 0321 - X-LIST occupancy threshold exceeded
This message indicates that the number of x-list entries has exceeded a specified threshold.
* 0014.0321 * XLIST X-LIST occupancy threshold exceeded Alarm Level: Minor
Recovery
3.2.261 0322 - X-LIST occupancy below threshold
This message indicates that the number of x-list entries has fallen below a specified threshold.
0014.0322 XLIST X-LIST occupancy below threshold Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.262 0324 - DPC Subsystem is Allowed
All subsystems at the indicated DPC are reachable.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 35.0.0 0014.0324 DPC 144-201-001 DPC subsystem is allowed
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
3.2.263 0325 - DPC Subsystem is Blocked
The DPC subsystem is blocked due to administrative action.
*C 0014.0325 *C DPC 144-201-001 DPC subsystem is blocked
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
Contact the far-end to correct the problem.
3.2.264 0326 - DPC Subsystem is Prohibited
The indicated DPC Subsystem is prohibited.
*C 0014.0326 *C DPC 144-201-001 DPC subsystem is prohibited
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
3.2.265 0327 - DPC Subsystem Has Been Deleted
This indicates a DPC subsystem has been deleted from the system global title translation (GTT) tables.
0014.0327 DPC 144-201-001 DPC subsystem has been deleted
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
This message indicates a previous fault has been corrected by deletion of the entity.
3.2.266 0328 - SCCP is available
The SCCP subsystem was previously unavailable and has returned to service.
0100.0328 SCCP SYSTEM SCCP is available
Recovery
3.2.267 0329 - System SCCP TPS Normal
The SCCP subsystem is operating normally, using the TVG
(Group Ticket Voucher load balancing algorithm) message transport method. The
TPS (Transactions Per Second) rate is below its capacity threshold, as defined
by the
chg-th-alm command.
0100.0329 SCCP SYSTEM SCCP capacity normal, card(s) abnormal
UAM 329 will only be raised only if there is at least one IS-ANR SCCP card in EAGLE.Alarm Level: Minor.
Recovery
3.2.268 0330 - System SCCP TPS Threshold Exceeded
This message indicates EAGLE has exceeded its TPS (Transactions Per Second) message transport rate threshold. For every 30 seconds EAGLE is above the threshold, an ATH (Application Trouble Handler) reports the minimum, maximum and average TPS value seen during the past 30-second period.
** 0100.0330 ** SCCP SYSTEM System SCCP TPS Threshold exceeded
Alarm Level: Major
Recovery
3.2.269 0331 - SCCP is Not Available
The SCCP subsystem is not available to any LIM(s). All TSM/DSM-SCCP cards have failed.
*C 0100.0331 *C SCCP SYSTEM SCCP is not available
Recovery
3.2.270 0332 - DPC Subsystem is prohibited and blocked
A subsystem is both prohibited and blocked as reported by the network.
*C 0014.0332 *C DPC 144-201-001 DPC Subsystem is prohibited and blocked
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Unblocked SS 2, 102, 221 Alarm Level: Critical
Recovery
3.2.271 0333 - DPC Subsystem is Normal
The DPC subsystem indicated in the output message is now allowed.
0014.0333 DPC 144-201-001 DPC Subsystem is Normal
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
3.2.272 0334 - DPC Subsystem is Abnormal
The indicated DPC subsystem is not reachable through the normal route.
*C 0014.0334 *C DPC 144-201-001 DPC Subsystem is Abnormal
LSN=nc00027
Allowed SS 3, 6
Blocked SS 100, 103
Recovery
- Enter the
3.2.273 0335 - SCCP is Removed
All Service Module cards have been deleted from the database; SCCP services are not available to the system. This message is the result of a deliberate action. Removing all Service Module cards from the database may have been an action from another maintenance procedure. If you wish to restore SCCP services to the system, perform the following procedure. For more information about adding a card to the system, refer to the Database Administration Manual - Global Title Translation.
0100.0335 SCCP SYSTEM SCCP is removed
Recovery
3.2.274 0336 - LIM(s) Have Been Denied SCCP Service
Some LIM(s) are using the SCCP subsystem, but others have been denied service. This is due to underprovisioning, and will require more Service Module cards to be added.
* 0100.0336 ** SCCP SYSTEM LIM(s) have been denied SCCP service
Alarm Level: Major
Recovery
3.2.275 0337 - DPC - SS Status Changed
This output is related to other DPC alarm messages. It indicates that one or more subsystems with an existing alarm condition has had a change in status. The message indicates the new status of the subsystem. A previous alarm condition has not cleared.
0100.0337 DPC 001-001-001 DPC-SS status changed
LSN=A1234567
Prohibited SS 5, 20
Recovery
Follow the troubleshooting procedure for the previous alarm.
3.2.276 0338 - X-LIST space full-entry(s) discarded
This message indicates that the total number of dynamic status exception list (x-list) entries for cluster routing has exceeded the maximum number configured. No more entries can be added to the list. This can occur because the maximum number of x-list entries is set too low, the timer that eliminates x-list entries after a specified period is set too long, or the x-list needs to be culled.
* 0100.0338 ** XLIST X-LIST space full-entry(s) discarded Alarm Level: Major
Recovery
3.2.277 0339 - X-LIST space full condition abated
This message indicates the total number of dynamic status exception list (x-list) entries no longer exceeds the maximum allowed.
0100.0339 XLIST X-LIST space full condition abated Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.278 0340 - RCVRY-MTPLP-RST: Circ rte Status Cleared
The system automatically tests for circular routing when congestion occurs on an ANSI signaling link. This message indicates that the circular routing has been cleared.
0100.0340 DPC 001-001-001 RCVRY-MTPLP-RST: Circ rte status cleared
XMIT LSN=A1234567
RCV LSN=ls14
MEMBER=011-210-007
Recovery
3.2.279 0341 - OAP Unavailable
This message indicates that the EAGLE 5 ISS system is unable to communicate with the OAP or the OAP has an internal failure.
** 0100.0341 ** OAP B OAP Unavailable
Alarm Level: Major
Recovery
3.2.280 0342 - SEAS UAL Unavailable
This message indicates the SEAS User Application Layer (UAL) process on the OAP is not running. Layer 4 (UPL) is not available for the specified OAP.
** 0100.0342 ** SEAS OAP B SEAS UAL unavailable
Alarm Level: Major
Recovery
3.2.281 0343 - SEAS X.25 Link Unavailable
This message indicates the X.25 link to the specified OAP is down. Layer 2 is not available for the indicated SEAS X.25 link.
** 0100.0343 ** X25 Link A1 SEAS X.25 Link unavailable
Alarm Level: Major
Recovery
3.2.282 0344 - SEAS PVC Unavailable
This message indicates that the permanent virtual circuit (PVC) connected to the OAP is not available.
* 0100.0344 * SEAS X25 Link A1 SEAS PVC unavailable
Alarm Level: Minor
Recovery
3.2.283 0345 - All SEAS UAL Sessions Unavailable
This message indicates the X.25 User Application Layer (UAL) is not available. If all PVCs for the indicated X.25 link have failed, UAL is no longer available, or all UAL sessions are unavailable.
** 0100.0345 ** SEAS X25 Link B1 All SEAS UAL sessions unavailable
Alarm Level: Major
Recovery
3.2.284 0346 - SEAS UAL Session Unavailable
This message indicates that the SEAS X.25 link UAL session on one PVC is not available.
* 0100.0346 * SEAS X25 Link B1 SEAS UAL session unavailable
Alarm Level: Minor
Recovery
3.2.285 0347 - SEAS X.25 Link is available
This message indicates that a previous problem with the X.25 link has been corrected.
0100.0347 SEAS X.25 Link B1 SEAS X.25 Link is available Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.286 0348 - SEAS is at Min Service Limit
This message indicates that some part of the SEAS subsystem has failed. When there are two OAPs, this could mean that one OAP has failed, or some part of the path to the SEAC for that OAP has failed. When there is only one OAP with two X.25 links to the SEAC and two connections to the TDM serial ports, either one of the X.25 links has failed, or one of the serial port connections to the TDM has failed. One more failure in either case will cause the SEAS subsystem to fail.
** 0100.0348 ** SEAS SYSTEM SEAS is at min service limit
Alarm Level: Major
Recovery
3.2.287 0349 - SEAS Unavailable
This message indicates the EAGLE 5 ISS system is unable to communicate with the SEAS subsystem.
*C 0100.0349 *C SEAS SYSTEM SEAS unavailable
Recovery
3.2.288 0350 - OAP Terminals Inhibited
This message indicates that the OAP terminals are inhibited.
*C 0100.0350 *C SEAS SYSTEM OAP terminals inhibited
Recovery
3.2.289 0351 - SEAS is Available
This message indicates that a problem with SEAS system has been corrected.
0100.0351 SEAS SYSTEM SEAS is available
Recovery
3.2.290 0352 - SEAS is Removed
This message indicates that the SEAS feature has been manually removed by removing both SEAS TDM ports.
0100.0352 SEAS SYSTEM SEAS is removed
Recovery
3.2.291 0353 - OAP is Available
This indicates a previous problem with the OAP has been corrected.
0100.0353 OAP A OAP is available
Recovery
3.2.292 0354 - One OAP Terminal Unavailable
This message indicates that the OAP terminal specified in the output message is not available.
** 0100.0354 ** OAP B One OAP terminal unavailable
Alarm Level: Major
Recovery
3.2.293 0355 - LSMS is Available
All communication paths are complete to the LSMS.
0014.0355 LSMS SYSTEM LSMS is available
Recovery
3.2.294 0356 - LSMS is Unavailable
There are no communication paths available to the LSMS. This condition is reached when all OAP terminals are manually inhibited or all LSMS associations are down.
*C 0014.0356 *C LSMS SYSTEM LSMS is unavailable
Recovery
3.2.295 0357 - All OAP Terminals are Removed
The OAP terminals have been modified to another type using the chg-trm command.
0014.0357 LSMS SYSTEM All OAP terminals are removed
Recovery
3.2.296 0358 - LSMS Connection Unavailable
An LSMS connection is not available.
** 0014.0358 ** LSMS Q.3 Assoc. A1 LSMS connection unavailable
Alarm Level: Major
Recovery
3.2.297 0359 - LSMS connection available
A LSMS connection is available.
0014.0359 LSMS Q.3 Assoc. A1 LSMS connection available
Recovery
3.2.298 0360 - EMS Agent Unavailable
An EMS agent is not available.
** 0100.0360 ** OAP B EMS Agent unavailable
Alarm Level: Major
Recovery
3.2.299 0361 - EMS Agent Available
An EMS agent is available.
0014.0361 OAP A EMS Agent available
Recovery
3.2.300 0362 - LSMS is at min. Service Limit
Only one communication path is available to the LSMS.
** 0014.0362 ** LSMS SYSTEM LSMS is at min. service limit
Alarm Level: Major
Recovery
3.2.301 0363 - OAP Filesystem Full
One of the OAP file systems has exceeded a 95% threshold.
RLGHNCXA21W 94-02-07 12:01:43 EST EAGLE 35.0.0
* 0014.0363 * OAP A OAP filesystem full.
Alarm Level: Minor
Recovery
Contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.2.302 0364 - Config. Data Checksum Mismatch
This indicates the OAP configuration data does not match the OAP configuration data stored in the system database. There is a mismatch between the system and OAP databases.
* 0014.0364 * OAP A Config. Data checksum mismatch
Alarm Level: Minor
Recovery
3.2.303 0365 - Config. Data checksum alarm cleared
This indicates that the system databases once out of sync are now back in sync.
0014.0365 OAP A Config. Data checksum alarm cleared Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.304 0366 - Temp Key(s) Expiration Alarm Cleared
This message indicates that there are no temporary keys currently in the expired state, and the alarm condition, specified by message “0368 - Temp Key(s) have expired,” has been cleared.
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 5.0.0-32.0.0
0100.0366 SYSTEM Temp Key(s) expiration alarm cleared
Recovery
Further access to this controlled feature requires the purchase of a permanent key.3.2.305 0367 - Temp Key(s) Expiring Soon
This alarm indicates that one or more temporary keys used to enable a controlled feature will expire within the next seven days.
** 0100.0367 SYSTEM Temp Key(s) expiring soon
Alarm Level: Major
Recovery
3.2.306 0368 - Temp Key(s) have expired
This alarm indicates that one or more temporary keys used to enable a controlled feature have expired.
*C 0100.0368 SYSTEM Temp Key(s) have expired Alarm Level: Critical
Recovery
3.2.307 0369 - REPT-T1F:FAC-T1 unavailable
There is a problem at the far end and the far end is not communicating with the EAGLE 5 ISS.
RLGHNCXA21W 00-12-07 12:01:43 EST EAGLE 35.0.0
** 0014.0369 ** T1/J1PORT 1201,2 REPT-T1F:FAC-T1 unavailable Alarm Level: Major
Recovery
- Contact the far-end office to determine the cause and to correct the problem.
3.2.308 0370 - Critical Platform Failure(s)
This message indicates the application running in the MPS server has detected a critical platform failure. The Alarm Data in the message contains a 16-character hexadecimal string in the format of h’1xxxxxxxxxxxxxxx’. This alarm will be reset when UAM #250, MPS Available is issued.
station1234 00-09-30 16:28:08 EST EAGLE 35.0.0
*C 0259.0370 *C MPS B Critical Platform Failure(s)
ALARM DATA = h'1000000000000008'
Recovery
- To decode the ALARM DATA included in this alarm, write down the Alarm Data string.
- To decode the alarm and for the correct procedure to solve the problem, refer to the MPS Platform Software and Maintenance Manual.
- This alarm will be reset when the problem is resolved and you receive UIM #250 MPS Available.
3.2.309 0371 - Critical Application Failure(s)
This message indicates the application running in the MPS server has detected a critical application failure. The Alarm Data in the message contains a 16-character hexadecimal string in the format of h’2xxxxxxxxxxxxxxx’. This alarm will be reset when UAM #250, MPS Available is issued.
*C 0259.0371 *C MPS B Critical Application Failure(s)
ALARM DATA = h'2000000000000001'
Recovery
- To decode the ALARMDATA included in this alarm, write down the Alarm Data string.
3.2.310 0372 - Major Platform Failure(s)
This message indicates the application running in the MPS server has detected a major platform failure. The Alarm Data in the message contains a 16-character hexadecimal string in the format of h’3xxxxxxxxxxxxxxx’. This alarm will be reset when UAM #250, MPS Available is issued.
** 0259.0372 ** MPS B Major Platform Failure(s)
ALARM DATA = h'3000000000000002'
Alarm Level: Major
Recovery
3.2.311 0373 - Major Application Failure(s)
This message indicates the application running in the MPS server has detected a major application failure. The Alarm Data in the message contains a 16-character hexadecimal string in the format of h’4xxxxxxxxxxxxxxx’. This alarm will be reset when UAM #250, MPS Available is issued.
** 0259.0373 ** MPS B Major Application Failure(s)
ALARM DATA = h'4000000000000008'
Alarm Level: Major
Recovery
- To decode the Alarm Data included in this alarm, write down the Alarm Data string.
3.2.312 0374 - Minor Platform Failure(s)
This message indicates the application running in the MPS server has detected a minor platform failure. The Alarm Data in the message contains a 16-character hexadecimal string in the format of h’5xxxxxxxxxxxxxxx’. This alarm will be reset when UAM #250, MPS Available is issued.
* 0259.0374 * MPS B Minor Platform Failure(s)
ALARM DATA = h'5000000000000004'
Alarm Level: Minor
Recovery
3.2.313 0375 - Minor Application Failure(s)
This message indicates the application running in the MPS server has detected a minor application failure. The Alarm Data in the message contains a 16-character hexadecimal string in the format of h’6xxxxxxxxxxxxxxx’. This alarm will be reset when UAM #250, MPS Available is issued.
* 0259.0375 * MPS B Minor Application Failure(s)
ALARM DATA = h'6000000000000001'
Alarm Level: Minor
Recovery
3.2.314 0376 - REPT-T1F:FAC-T1 LOS Failure
No signal is being received on the T1 Port.
** 0014.0376 ** T1PORT 1201,2 REPT-T1F:FAC-T1 LOS failure
Alarm Level: Major
Recovery
Check the physical connections.
3.2.315 0377 - REPT-T1F:FAC-T1 LOF failure
The 7-bit frame alignment signal does not match the pattern the EAGLE 5 ISS is expecting.
** 0014.0377 ** T1PORT 1201,2 REPT-T1F:FAC-T1 LOF failure Alarm Level: Major
Recovery
Contact the far-end office to correct their framing problem.
3.2.316 0378 - REPT-T1F:FAC-T1 Remote Alarm
This indicates there is some type of failure on the far end.
** 0014.0378 ** T1PORT 1201,2 REPT-T1F:FAC-T1 Remote Alarm Alarm Level: Major
Recovery
Contact the far-end office to determine the cause and correct the problem.
3.2.317 0379 - REPT-T1F:FAC-T1 Alarm
The far end is transmitting an alarm indication signal (AIS) due to an excessive bit error rate, loss of signal, or loss of frame.
** 0014.0377 ** T1PORT 1201,2 REPT-T1F:FAC-T1 Alarm Alarm Level: Major
Recovery
Contact the far-end office to determine the cause of the AIS and to correct the problem.
3.2.318 0380 - RCVRY-T1F:FAC-T1 Available
The T1 port 1 is back in-service.
RLGHNCXA21W 00-11-07 11:02:30 EST EAGLE 35.0.0
0014.0380 T1PORT 1201,2 RCVRY-T1F:FAC-T1 available
Recovery
3.2.319 0381 - REPT-E1F:FAC-E1 LOS failure
No signal is being received on the signaling link.
** 0014.0381 ** E1PORT 1201,2 REPT-E1F:FAC-E1 LOS failure Alarm Level: Major
Recovery
3.2.320 0382 - REPT-E1F:FAC-E1 LOF failure
** 0014.0382 ** E1PORT 1201,2 REPT-E1F:FAC-E1 LOF failure Alarm Level: Major
Recovery
3.2.321 0383 - REPT-E1F:FAC-E1 AIS detected
** 0014.0383 ** E1PORT 1201,2 REPT-E1F:FAC-E1 AIS detected Alarm Level: Major
Recovery
3.2.322 0384 - REPT-E1F:FAC-E1 Far End Failure
** 0014.0384 ** E1PORT 1201,2 REPT-E1F:FAC-E1 Far End Failure Alarm Level: Major
Recovery
3.2.323 0385 - REPT-E1F:FAC-E1 10E-3 BER failed
A framing bit error rate is maintained for in-service links because the error rate is high.
** 0014.0385 ** E1PORT 1201,2 REPT-E1F:FAC-E1 10E-3 BER failed Alarm Level: Major
Recovery
Contact the far-end office to determine the cause of the high framing bit error rate.
3.2.324 0386 - RCVRY-E1F:FAC-E1 Available
The E1 port 1 is back in-service.
0014.0386 E1PORT 1201,2 RCVRY-E1F:FAC-E1 available
Recovery
3.2.325 0387- REPT-E1F:FAC-E1 unavailable
** 0014.0387 ** E1PORT 1201,2 REPT-E1F:FAC-E1 unavailable Alarm Level: Major
Recovery
3.2.326 0388 - Illegal Address Error has Cleared
This message indicates the clearing of a prior illegal address error. Previously, the HMUX-assigned shelf ID address received from OAM did not match the value read from the Assigned Shelf Address Register, resulting in major alarm UAM #0390. This message shows the previous alarm has cleared.
station1234 00-11-30 16:28:08 EST EAGLE 35.0.0
0012.0388 CARD 1109 HMUX Illegal Address Error has Cleared
Recovery
This message indicates a previous fault, which was indicated by UAM #0390, has been corrected.
3.2.327 0389 - Card Responding Normally
This message indicates the clearing of a prior card problem.
0014.0389 CARD 1201 Card Responding Normally Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.328 0390 - Illegal Address Error
This message indicates an HMUX (High Speed Multiplexer) illegal address error. The ATH (Application Trouble Handler) displays this alarm when an HMUX-assigned shelf ID address, which was received from OAM and written to the Assigned Shelf Address Register, did not match the value read from the Assigned Shelf Address Register. Furthermore, the error was not corrected after an automatic attempt to correct the address discrepancy.
** 0012.0390 ** CARD 1109 HMUX Illegal Address Error
Alarm Level: Major
Recovery
3.2.329 0391 - Card Not Responding Error
This message indicates an HMUX (High Speed Multiplexer)/HIPR (High-Speed IMT Packet Router) is not responding. This alarm is displayed when an HMUX/HIPR in a provisioned shelf card does not respond.
** 0012.0391 ** CARD 1109 HIPR Card not responding Error
Alarm Level: Major
Recovery
3.2.330 0392 - OA&M IP Security Feature is OFF
not turned on. One of the following occurred: and OAM init, or OAM role change,
or the
chg-ctrl-feat command turned the
feature off.
With this feature not operating, you do not have the tools to securely pass data across an otherwise non-secure network. Until the Eagle OA&M IP Security Enhancements Feature is restored, the Eagle cannot provide secure connections from approved clients, and does not protect sensitive passwords and information while in transit between the Eagle and a host.
eagle11 17-12-07 09:23:41 EST EAGLE 46.5.0.0.0-0.0.0
2001.0392 SECURITY SYSTEM OA&M IP Security feature status is OFF
Alarm Level: Major
Recovery
To restore the OA&M IP Security Enhancements feature, you turn it on permanently.
To turn the feature on, use the command.
enable-ctrl-feat
3.2.331 0393 - OA&M IP Security feature is ON
The Eagle OA&M IP Security Enhancements Feature is turned on. This UAM is an informational message that confirms that the feature is restored to operational status.
With this feature operating, you have the tools to securely pass data across an otherwise non-secure network. With the Eagle OA&M IP Security Enhancements Feature operational, the Eagle can provide secure connections from approved clients, and protects sensitive passwords and information while in transit between the Eagle and a host.
0047.0393 SECURITY SYSTEM OA&M IP Security feature status is ON
Recovery
This message indicates that the feature previously was OFF and now has been turned ON.
3.2.332 0394 - INP Subsystem is Available
This message indicates that a problem with the INP subsystem has been corrected.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 39.2.0
0056.0394 INP SYSTEM INP Subsystem is available
Recovery
This message indicates a previous fault has been corrected.
3.2.333 0395 - INP Subsystem is Not Available
The INP subsystem is not available. There are no IS-NR VSCCP cards associated with this INP subsystem. The INP subsystem was not taken off-line via command.
*C 0056.0395 *C INP SYSTEM INP Subsystem is not available
Recovery
3.2.334 0396 - INP Subsystem is disabled
The INP subsystem has been manually disabled using the
inh-map-ss command.
*C 0056.0396 *C INP SYSTEM INP Subsystem is disabled
Recovery
3.2.335 0397 - INP Subsystem is Removed
The INP subsystem is not fully equipped. There are no VSCCP cards configured with this INP subsystem.
0056.0397 INP SYSTEM INP Subsystem is removed
Recovery
Verify the VSCCP hardware.
Configure the INP system with VSCCP cards. Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.336 0398 - INP Subsystem Normal, Card(s) Abnormal
One or more of the VSCCP cards do not have an ACTIVE status.
* 0056.0398 * INP SYSTEM INP Subsystem normal,card(s) abnormal
Alarm Level: Minor
Recovery
3.2.337 0399 - RCVRY-LKSTO:Alarm clr’d by deleting SLK
A signaling link (SLK) that was out of service and had an outstanding alarm has been deleted from the database. The alarm is cleared.
0014.0399 LSN a24546 RCVRY-LKSTO:Alarm clr’d by deleting SLK Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.338 0400 - Alarm cleared by deleting card
A card that was out of service and had an outstanding alarm has been deleted from the system database. The alarm is cleared.
0014.0400 CARD 1202 SCCP Alarm cleared by deleting card Alarm Level: No alarm condition. The message is informational only.
Recovery
This message indicates a previous failure has been corrected.
3.2.339 0401 - Alarm cleared by deleting SLK
0014.0401 SLK 1205,A SS7ANSI Alarm cleared by deleting SLK
SLC=01 FECLLI=A1234567890 Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.340 0402 - Alarm cleared by deleting route
A route that was out of service and had an outstanding alarm has been deleted from the database. The alarm is cleared.
0014.0402 DPC 001-001-001 Alarm cleared by deleting route Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.341 0403 - 1114 E1/T1 Clock Requires TDM-GTI
This message indicates that the high speed clock is provisioned as T1 framed, E1 framed, or E1 unframed. A non TDM-GTI card has been placed in this system where recovered clocks are provisioned. The TDM-GTI version of the TDM card is required.
station1234 99-03-05 16:28:08 EST EAGLE 35.0.0
** 0052.0403 ** HS CLOCK SYSTEM 1114 E1/T1 clock requires TDM-GTI
Alarm Level: Major
Recovery
- Replace the card in location 1114 with a TDM-GTI
card. Refer to the
removal/replacement procedures for the replacement procedure.
OR
Use the
chg-clkoptschg-stpoptscommand to change the hsclksrc parameter to RS422. Refer to the Commands Manual for proper usage of the command.
3.2.342 0404 - 1116 E1/T1 Clock Requires TDM-GTI
This message indicates the high speed clock is provisioned as T1 framed, E1 framed, or E1 unframed. A non TDM-GTI card has been placed in this system where recovered clocks are provisioned. The TDM-GTI version of the TDM card is required.
** 0052.0404 ** HS CLOCK SYSTEM 1116 E1/T1 clock requires TDM-GTI
Alarm Level: Major
Recovery
- Replace the card in location 1116 with a TDM-GTI
card. Refer to the
OR
- Use the
chg-clkoptschg-stpoptscommand to change the HSCLKSRC parameter to RS422. Refer to the Commands Manual for proper usage of the command.
3.2.343 0405 - 1114, 1116 E1/T1 Clock Requires TDM-GTI
This message indicates that the high speed clock is provisioned as T1 framed, E1 framed, or E1 unframed. A non TDM-GTI card has been placed in this system in slots 1114 and 1116 where recovered clocks are provisioned. The TDM-GTI version of the TDM card is required.
** 0052.0405 ** HS CLOCK SYSTEM 1114, 1116 E1/T1 clock requires TDM-GTI
Alarm Level: Major
Recovery
- Replace the cards in locations 1114 and 1116 with a
TDM-GTI card. Refer to the
OR
- Use the
3.2.344 0406 - 1114 Clock selection mismatch
This message indicates that the database has been restored and the provisioned clocks do not match what is running on the TDM.
station1234 99-03-05 16:28:08 EST EAGLE 31.6.0
** 0052.0406 ** HS CLOCK SYSTEM 1114 Clock selection mismatch
Alarm Level: Major
Recovery
3.2.345 0407 - 1116 Clock selection mismatch
** 0052.0407 ** HS CLOCK SYSTEM 1116 Clock selection mismatch
Alarm Level: Major
Recovery
3.2.346 0408 - 1114, 1116 Clock selection mismatch
** 0052.0408 ** HS CLOCK SYSTEM 1114, 1116 Clock selection mismatch
Alarm Level: Major
Recovery
3.2.347 0409 - Clock configuration corrected
This message indicates that a problem with the high speed clock configuration database has been corrected.
0052.0409 HS CLOCK SYSTEM Clock configuration corrected Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.348 0422 - Insufficient Extended Memory
At least one SCCP card does not have enough memory for the LNP application. Loading of the SCCP card is automatically inhibited.
** 0100.0422 ** CARD 1113 SCCP Insufficient extended memory
Alarm Level: Major
Recovery
3.2.349 0423 - Card Reload Attempted
Card loading is no longer inhibited. The once inhibited card is now attempting to load.
0100.0423 CARD 1108 SCCP Card reload attempted
Recovery
3.2.350 0424 - LNP Subsystem is Not Available
The LNP subsystem is not available. There are no IS-NR SCCP cards associated with this LNP subsystem. The LNP subsystem was not taken off-line via command.
*C 0056.0424 *C LNP SYSTEM LNP Subsystem is not available
Recovery
3.2.351 0425 - LNP Subsystem Normal, Card(s) Abnormal
One or more of the SCCP cards do not have an ACTIVE status.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 46.0.0
* 0056.0425 * LNP SYSTEM LNP Subsystem normal, card(s) abnormal
Alarm Level: Minor.
Recovery
3.2.352 0426 - LNP Subsystem is Available
This message indicates that a problem with LNP system has been corrected.
0056.0426 LNP SYSTEM LNP Subsystem is available
Recovery
3.2.353 0427 - LNP Subsystem degraded, card(s) abnormal
One or more LNP cards goes out of service in (N or N+1) configuration or not IS-NR.
** 0056.0427 ** LNP SYSTEM LNP Subsystem degraded, card(s) abnormal Alarm Level: Major.
Recovery
- Restore the one or more LNP out of service cards in (N or N+1) configuration or not IS-NR.
3.2.354 0428 - INP Subsystem degraded, card(s) abnormal
One or more INP cards goes out of service in (N or N+1) configuration or not IS-NR.
0056.0428 INP SYSTEM INP Subsystem degraded, card(s) abnormal Alarm Level: Major.
Recovery
- Restore the one or more INP out of service cards in (N or N+1) configuration or not IS-NR.
3.2.355 0429 - ATINPQ Subsystem degraded, card(s) abnormal
One or more ATINPQ cards goes out of service in (N or N+1) configuration or not IS-NR.
0056.0429 ATINPQ SYSTEM ATINPQ Subsystem degraded, card(s) abnormal Alarm Level: Major.
Recovery
- Restore the one or more ATINPQ out of service cards in (N or N+1) configuration or not IS-NR.
3.2.356 0434 - LNP Subsystem is Removed
The LNP subsystem is not fully equipped. There are no SCCP cards configured with this LNP subsystem.
0056.0434 LNP SYSTEM LNP Subsystem is removed
Recovery
Verify the SCCP hardware.
Configure the LNP system with SCCP cards. Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.357 0435 - LNP Subsystem is Disabled
The LNP subsystem has been manually disabled using the
inh-map-ss command.
*C 0056.0435 *C LNP SYSTEM LNP Subsystem is disabled
Recovery
3.2.358 0436 - LNP ACG node overload
This message indicates that the number of LNP subsystem queries has exceeded the supported level.
station1234 94-03-30 16:28:08 EST EAGLE 35.0.0
** 0056.0436 ** LNP SYSTEM LNP ACG node overload
Alarm Level: Major
Recovery
3.2.359 0437 - System SCCP TPS Capacity Exceeded
This message indicates the Eagle has exceeded its TPS (Transactions Per Second) message transport rate. The alarm will not stop until the TPS rate is below its rated TPS for the system for a period of 30 seconds. The alarm is cleared by the UIM #329 “SCCP capacity normal, card(s) abnormal”.
*C 0100.0437 *C SYSTEM System SCCP TPS Capacity Exceeded
Recovery
3.2.360 0438 - Degraded Mode, Invalid OAM HW Config
This UAM alarm occurs when the system does not have the
required baseline hardware. Baseline hardware required includes TDM-10 or
greater. The alarm recurs every minute. Also, the
act_upgrade command is rejected if
alarm is present.
RLGHNCXA21W 02-12-07 12:01:43 EST EAGLE 35.0.0
*C 0014.0438 *C SECULOG 1114 Degraded Mode, Invalid OAM HW config
Recovery
Ensure that the Eagle has the required hardware baseline, that is, the TDM-10 or greater is installed.
3.2.361 0439 - Exiting Degraded Mode
The Degraded Mode due to a invalid OAM hardware configuration has been cleared, and the mode has been exited. The HMUX is restored to its full operating capacity.
0014.0439 SECULOG 1114 Exiting Degraded Mode
Recovery
3.2.362 0441 - Incorrect MBD - CPU
An SM card does not have the required hardware configuration for the application.
eagle11 18-10-30 09:58:56 MST EAGLE 46.7.0.0.0-75.27.0
** 5881.0441 ** CARD 1215 SCCP64 Incorrect MBD - CPU
HW VERIFICATION CODE: 180
Alarm Level: Major
Recovery
3.2.363 0442 - RTDB Database Capacity is 90% Full
EPAP database capacity alarms are triggered by allocated capacity, whereas EAGLE alarms are triggered by provisioned capacity.
Allocated Capacity refers to the amount of memory that is currently dedicated to storing each RTDB entity-type. For instance when the very first DN is added to the EPAP RTDB, the EPAP allocates a block of memory large enough to store 6 million DNs. Although most of this memory is not in-use (provisioned) it has been demarcated for future use and cannot be utilized to store other non-DN entities (such as IMSIs or DN-Blocks, etc).
Provisioned Capacity refers to the provisioned RTDB entries versus the max RTDB entries allowed on an EAGLE SM card by the EPAP/ELAP related quantity features activated on EAGLE. EAGLE RTDB capacity alarms are triggered when the provisioned capacity passes the 80% and 90% levels. Furthermore, if the EAGLE RTDB provisioned capacity is below 80% and the allocation of the next memory block by EPAP would cause overallocation of the DSM Memory on an EPAP SM card, the EAGLE will report the 80% capacity alarm for that card.
RLGHNCXA21W 14-05-07 11:02:30 EST EAGLE 46.0.0
0100.0442 *C CARD 1108 VSCCP RTDB database capacity is 90% full
Alarm Level:Critical
Recovery
- For ELAP, perform the following:
- For EPAP, perform the following:
3.2.364 0443 - RTDB Database Corrupted
A RTDB database is corrupt. The calculated checksum did not match the checksum value stored for one or more records.
* 0100.0443 * CARD 1108 VSCCP RTDB database corrupted
Alarm Level: Minor
Recovery
3.2.365 0444 - RTDB Database is Inconsistent
One or more DSM card’s real time database is not identical to the current real time database on the active EPAP fixed disks.
* 0100.0444 * CARD 1108 VSCCP RTDB database is inconsistent
Alarm Level: Minor
Recovery
3.2.366 0445 - RTDB Database Has Been Corrected
This message indicates that a problem with the RTDB has been corrected.
0100.0445 CARD 1108 VSCCP RTDB database has been corrected
Recovery
3.2.367 0446 - RTDB Satabase Capacity is 80% Full
Allocated Capacity refers to the amount of memory that is currently dedicated to storing each RTDB entity-type. For instance when the very first DN is added to the EPAP RTDB, the EPAP allocates a block of memory large enough to store 6 million DNs. Although most of this memory is not in-use (provisioned) it has been demarcated for future use and cannot be utilized to store other non-DN entities (such as IMSIs or DN-Blocks, etc.).
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 35.0.0.0
* 0100.0446 * CARD 1108 VSCCP RTDB database capacity is 80% full
Alarm Level: Minor
Recovery
- For ELAP, perform the following from the EAGLE STP:
3.2.368 0447 - RTDB Database Capacity Alarm Cleared
This message indicates that a problem with the RTDB memory has been corrected.
When the TN, LRN, or NPA control features are involved, this UAM message indicates either the feature key quantity has been increased or the RTDB database size has been reduced to clear the condition.
0100.0447 CARD 1108 VSCCP RTDB database capacity alarm cleared
Recovery
3.2.369 0448 - RTDB Database Incoherent
This message indicates that the RTDB database download is in-process or that the update failed.
* 0100.0448 * CARD 1108 VSCCP RTDB database incoherent
Alarm Level: Minor
Recovery
3.2.370 0449 - RTDB Resynchronization in Progress
This message indicates the MPS database resynchronization is in process.
** 0100.0449 ** CARD 1108 VSCCP RTDB resynchronization in progress
Alarm Level: Major
Recovery
message is displayed.
0445 - RTDB database has been corrected
No further action is necessary
If the MPS has been inhibited, the generic clearing
alarm
0500 is displayed. Otherwise, when the
resynchronization is complete, the
corrected message is displayed.
3.2.371 0450 - Invalid HW for Integrated GLS
The Integrated GLS Feature requires E5-based control cards. This UAM is generated when legacy control cards are installed in the standby MASP location after the Integrated GLS feature is turned on. This action changes the GLS subsystem state to IS-ANR.
* 0002.0450 * GLS System Invalid HW for Integrated GLS Alarm Level: Major
Recovery
Replace the legacy control cards (labeled GPSM-II and TDM on the cards) with E5-based control cards (labeled E5-MASP) when enabling the Integrated GLS Feature.
3.2.372 0451 - RTDB Reload Required
The RTDB database on the DSM card needs to be reloaded because the resynch log does not contain all of the required updates.
** 0100.0451 ** CARD 1108 VSCCP RTDB reload required
Alarm Level: Major
Recovery
3.2.373 0452 - Exceeded Service Error Threshold Lvl 1
UAM 527 is also expected when the errors exceed the threshold level (UAM452/453). These alarms are auto-cleared when the error condition abates (below threshold level1 for UAM 452 and level 2 for UAM 453)RLGHNCXA21W 00-11-07 11:02:30 EST EAGLE 35.0.0
** 0014.0452 ** SCCP SYSTEM Exceeded Service Error Threshold Lvl 1
Alarm Level: Major
Recovery
3.2.374 0453 - Exceeded Service Error Threshold Lvl 2
UAM 527 is also expected when the errors exceed the threshold level (UAM 452/453). These alarms are auto-cleared when the error condition abates (below threshold level1 for UAM 452 and level 2 for UAM 453).RLGHNCXA21W 00-11-07 11:02:30 EST EAGLE 35.0.0
*C 0014.0453 *C SCCP SYSTEM Exceeded Service Error Threshold Lvl 2
Recovery
3.2.375 0454 - Service Error Threshold Alarm Cleared
This message is generated when the Service Error Threshold alarm is cleared.
0014.0454 SCCP 1205,Service Error Threshold Cleared Alarm Level: No alarm condition. The message is informational only.
Recovery
No further action is necessary.
3.2.376 0455 - EIR Subsystem is Not Available
The EIR subsystem is not available. No IS-NR VSCCP cards are associated with this EIR subsystem. No VSCCP cards have an Active EIR status; all are either out-of service (OOS) or loading. The EIR subsystem was not taken off-line via command.
RLGHNCXA21W 03-08-18 12:01:43 EST EAGLE 35.0.0
*C 0056.0455 *C EIR SYSTEM EIR Subsystem is not available
Recovery
3.2.377 0456 - EIR Subsystem is Disabled
The EIR subsystem has been manually disabled with the
inh-map-ss command. All IS-NR (in
service normal) cards have EIR status of Offline, with at least one card IS-NR.
*C 0056.0456 *C EIR SYSTEM EIR Subsystem is disabled
Recovery
3.2.378 0457 - EIR Subsystem Normal, Card(s) Abnormal
One or more of the VSCCP cards do not have an Active status.
*C 0056.0457 EIR SYSTEM EIR Subsystem normal, card(s) abnormal
Alarm Level: Minor
Recovery
3.2.379 0458 - EIR Subsystem is Available
This message indicates that a problem with the EIR subsystem has been corrected. All VSCCP cards are IS-NR and have an EIR status of Active.
0056.0458 EIR SYSTEM EIR Subsystem is available
Recovery
3.2.380 0459 - EIR Subsystem is Removed
The EIR subsystem is not equipped. No VSCCP cards are configured with the EIR subsystem.
0056.0459 EIR SYSTEM EIR Subsystem is removed
Recovery
Configure the EIR system with VSCCP cards. Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.381 0460 - EIR Subsystem degraded, card(s) abnormal
One or more EIR cards goes out of service in (N or N+1) configuration or not IS-NR.
0056.0460 EIR SYSTEM EIR Subsystem degraded, card(s) abnormal Alarm Level: Major.
Recovery
- Restore the one or more EIR out of service cards in (N or N+1) configuration or not IS-NR.
3.2.382 0466 - STC Network Unavailable
This indicates the network connected to the STC (port A/B) is inaccessible.
** 0014.0466 ** CARD 1201 STC STC Network Unavailable
Alarm Level: Major
Recovery
Re-association should take place automatically.
If it does not, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.2.383 0467 - STC Network Available
This indicates the network connected to the STC (port A/B) is now accessible.
0014.0467 CARD 1201 STC STC Network Available
Recovery
3.2.384 0468 - All STC Networks Unavailable
All connections off all the STC cards (port A/B) are inaccessible.
*C 0014.0468 *C EROUTE System All STC Networks Unavailable
Recovery
3.2.385 0469 - All STC Cards Unavailable
All the STC cards are not accessible.
*C 0014.0469 *C EROUTE System All STC Cards unavailable
Recovery
3.2.386 0470 - EROUTE is Removed
All the STC cards have been deleted.
0014.0470 EROUTE System EROUTE is Removed
Recovery
No action is necessary.
3.2.387 0471 - EROUTE System is Available
This message indicates that the EROUTE system is available and fully functional.
0014.0471 EROUTE System EROUTE System is Available
Recovery
3.2.388 0472 - EROUTE System Threshold Exceeded
The EROUTE system has reached a rate higher than its threshold of 80% capacity.
* 0014.0472 * EROUTE System EROUTE System Threshold Exceeded
Alarm Level: Minor
Recovery
- Decrease the number of links being monitored until more STC cards are added to the System.
- Refer to the Database Administration Manual - Features for the correct procedure on adding STC cards.
3.2.389 0473 - EROUTE System Capacity Exceeded
The EROUTE system has reached a rate higher than its capacity. There is the possibility of a loss of traffic monitoring.
** 0014.0473 ** EROUTE System EROUTE System Capacity Exceeded
Alarm Level: Major
Recovery
3.2.390 0474 - EROUTE Capacity Normal, Card(s) Abnormal
The EROUTE system is operating normally even though one or more card(s) is OOS-MT.
0014.0474 EROUTE System EROUTE capacity normal, card(s) abnormal
Recovery
3.2.391 0475 - NTP Time Unavailable
The STC cards are not able to get NTP time from the ESP.
* 0014.0475 * EROUTE System NTP Time Unavailable
Alarm Level: Minor
Recovery
Have the far-end (Sentinel) to verify the status of the time process.
For the complete list of cards supported by EAGLE Release 47.0, see Hardware Reference Guide.3.2.392 0476 - NTP Time Available
The STC cards are now able to get NTP time from the ESP.
0014.0476 EROUTE System NTP Time Available
Recovery
3.2.393 0477 - Congestion: Copy Function De-activated
The Copy Function on the SS7 cards have been de-activated.
* 0014.0477 * SLK 1205,A nc00027 Congestion: Copy Function De-activated
SLC=03 FECLLI=testclli CLASS=SAAL
The Class parameter in the example is optional.Alarm Level: Minor
Recovery
3.2.394 0478 - Copy Function Activated
The congestion has cleared and the copy function on the SS7 cards have been re-activated.
0014.0478 SLK 1205,A nc00027 Copy Function Activated
The Class parameter in the example is optional.Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.395 0479 - Link Not Monitored
This is a possible clearing condition for UAM 477,
Congestion: Copy Function Deactivated
or
Sentinel Socket Inactive. This implies
that the Link's attempt to establish monitoring session is not successful,
hence, not being monitored. Therefore any monitoring alarms should be cleared.
0014.0479 SLK 1205,A nc00027 Link not Monitored
Recovery
3.2.396 0480 - Timestamp Invalid
This indicates that the LIM card timestamp is invalid.
* 0014.0480 * CARD 1201 STC Timestamp Invalid
Alarm Level: Minor
Recovery
This alarm should clear automatically.
3.2.397 0481 - Timestamp Valid
This indicates that the LIM card timestamp is valid.
Recovery
3.2.398 0482 - Card(s) Have Been Denied EROUTE Service
EROUTE service is being denied service because there is a shortage of STC cards.
** 0014.0482 ** EROUTE System Card(s) have been denied EROUTE service
Alarm Level: Major
Recovery
- Enter the following command to determine the cards
that are denied EROUTE service:
rept-stat-mon - Refer to the Database Administration Manual - Features for the correct procedure on adding STC cards.
3.2.399 0483 - DEIR System is not available
The S13 Feature is not ON or the System has no S23 card in ACTIVE/IS_NR.
*C 0002.0483 *C DEIR SYSTEM DEIR System is not available
Recovery
- Activate (Active/IS-NR) any of the DEIR cards in the system.
3.2.400 0484 - DEIR System Normal, Card(s) Abnormal
The number of active S13 cards (i.e., in IS-NR state) is less than half the configured S13 cards.
* 0002.0484 * DEIR SYSTEM DEIR System normal, card(s) abnormal
Alarm Level: Major
Recovery
- Activate (Active/IS-NR) half or more DEIR cards in the system.
3.2.401 0485 - DEIR System is available
The number of active (Active/IS-NR) S13 cards is equal to or more than half of the configured S13 cards.
0003.0485 DEIR SYSTEM DEIR System is available
Alarm Level: None
Recovery
No further action necessary.
3.2.402 0486 - DEIR Threshold - Level1 exceeded
The DEIR Card TPS has exceeded configured level-1 value in DEIROPTS.
* 0002.0486 * DEIR SYSTEM DEIR Threshold - Level1 exceeded
Alarm Level: Minor
Recovery
- Reduce the card TPS below configured level-1 value in DEIROPTS.
3.2.403 0487 - DEIR System Threshold - Level2 exceeded
The DEIR Card TPS has exceeded configured level-2 value in DEIROPTS.
** 0002.0487 ** DEIR SYSTEM DEIR System Threshold - Level2 exceeded
Alarm Level: Major
Recovery
- Reduce Card TPS below configured level-2 value in DEIROPTS.
3.2.404 0488 - DEIR Threshold Condition Cleared
The DEIR Card TPS is below configured level-1 value in DEIROPTS..
0002.0488 DEIR SYSTEM DEIR Threshold Condition Cleared
Alarm Level: None
Recovery
3.2.405 0489 - DEIR capacity exceeded
The DEIR Card TPS has exceeded the maximum allowable cards TPS (8000).
*C 0002.0489 *C DEIR SYSTEM DEIR capacity exceeded
Recovery
- Reduce the card TPS below the overall cards TPS.
3.2.406 0490 - DEIR normal
The S13 card capacity has returned to normal.
0002.0490 DEIR SYSTEM DEIR normal
Alarm Level: None
Recovery
3.2.407 0491 - Connection TPS exceeded
The connection present on the DEIR Card has exceeded the maximum allowable connection TPS (MaxTPS) configured in the DCONN table.
** 0002.0491 ** DEIR SYSTEM Connection TPS exceeded
Alarm Level: Major
Recovery
- Reduce the connection TPS to below the configured MaxTPS for that connection in the DCONN table.
3.2.408 0492 - Connection TPS normal
The TPS on a connection present DEIR card is below or equal to the maximum allowed TPS (MaxTPS) configured in the DCONN table.
0002.0492 DEIR SYSTEM Connection TPS normal
Alarm Level: None
Recovery
3.2.409 0493 - Diameter Connection Down
The SCTP association is Open (open=yes) and the Diameter connection status is down.
** 0004.0493 ** DCONN DCNAME1 Diameter Connection Down
Alarm Level: Major
Recovery
- Get the diameter connection UP.
3.2.410 0494 - Diameter Connection UP
The SCTP association is Open (open=yes) and the Diameter connection status is UP.
0003.0494 DEIR SYSTEM Diameter Connection UP
Alarm Level: None
Recovery
3.2.411 0495 - Diameter Connection Closed
The Diameter connection or SCTP association for a diameter connection is closed.
0002.0495 DEIR SYSTEM Diameter Connection Closed
Alarm Level: None
Recovery
3.2.412 0496 - DEIR System is removed
The last S13 card has been deleted from the system.
0002.0496 DEIR SYSTEM DEIR System is removed
Alarm Level: None.
Recovery
3.2.413 0497 - REPT-J1F:FAC-J1 LOS failure
This alarm is present when no signal is being received on the signaling link.
1 2 3 4 5 6 7 8
** 0123.0497 ** J1PORT 1103,2 REPT-J1F:FAC-J1 LOS failure
Alarm Level: Major
Recovery
3.2.414 0498 - REPT-J1F:FAC-J1 LOF failure
The 7-bit frame alignment signal does not match the pattern the EAGLE is expecting.
1 2 3 4 5 6 7 8
** 0124.0498 ** J1PORT 1103,2 REPT-J1F:FAC-J1 LOF failure
Alarm Level: Major
Recovery
3.2.415 0499 - REPT-J1F:FAC-J1 Remote Alarm
This alarm is present when there is some type of failure on the far end.
1 2 3 4 5 6 7 8
** 0125.0499 ** J1PORT 1103,2 REPT-J1F:FAC-J1 Remote Alarm
Alarm Level: Major
Recovery
3.2.416 0500 - Alarm for This Entity is Being Cleared
This is a generic alarm clearing output that applies to all setting alarms (Critical, Major, or Minor). The alarm for the indicated device is being cleared.
tekelecstp 99-01-19 14:56:48 EST EAGLE 31.5.0
0045.0500 DLK 1104,A1 Alarm for this entity is being cleared
The output can vary significantly. The output varies depending on which device the alarm is being cleared. In this example the alarm is being cleared for a Data Link.Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.417 0501 - OAM ITT Sample Minor Alarm
This is an alarm clearing output that applies to Minor setting alarms. The alarm for the indicated device is being cleared.
tekelecstp 01-01-19 14:56:48 EST EAGLE 34.0
0045.0501 DLK 1104,A1 Alarm for this entity is being cleared
Recovery
3.2.418 0502 - OAM ITT Sample Minor Alarm
This is an alarm clearing output that applies to Minor alarms. The alarm for the indicated device is being cleared.
0045.0502 DLK 1104,A1 Alarm for this entity is being cleared
Recovery
3.2.419 0503 - OAM ITT sample Critical Alarm
This is an alarm clearing output that applies to Major alarms. The alarm for the indicated device is being cleared.
0045.0503 DLK 1104,A1 Alarm for this entity is being cleared
Recovery
3.2.420 0504 - REPT-J1F:FAC-J1 Alarm
This alarm is present when the J1 port becomes unavailable.
1 2 3 4 5 6 7 8
** 0126.0504 ** J1PORT 1103,2 REPT-J1F:FAC-J1 Alarm
Alarm Level: Major
Recovery
3.2.421 0505 - RRCVRY-J1F:FAC-J1 available
This alarm is present when the J1 port is back in-service.
1 2 3 4 5 6 7 8
0127.0505 J1PORT 1103,2 REPT-J1F::FAC-J1 available
Alarm Level: Normal
Recovery
None.
3.2.422 0506 - REPT-J1F:FAC-J1 unavailable
This alarm is present when the J1 port goes down.
1 2 3 4 5 6 7 8
** 0128.0506 ** T1/J1PORT 1103,2 REPT-J1F::FAC-J1 unavailable
Alarm Level: Major
Recovery
When the J1 port becomes available.
3.2.423 0514 - Standby MASP Inhibited
This message indicates that the standby OAM is inhibited. Database updates will be rejected until the standby OAM is allowed.
RLGHNCXA3W 00-11-06 10:55:49 EST EAGLE 35.0.0
** 0076.0514 ** CARD 1115 OAM Standby MASP inhibited
Alarm Level: Major
Recovery
3.2.424 0515 - Standby MASP Allowed
This message indicates that the inhibited standby OAM has been restored.
0076.0515 CARD 1115 OAM Standby MASP allowed
Recovery
3.2.425 0516 - Degraded Mode - 1 Card Failed
Measurements are degraded because a card is out of service:
If the E5-OAM Integrated Measurements feature is in use, the problem is that one E5-MCAP card is out of service.
If the Measurements Platform is in use, the problem is that one MCPM card is out of service.
The E5-OAM Integrated Measurements feature or the Measurements Platform (depending on which is in use) can successfully complete all of its work, but with no spare E5-MCAP card or no spare MCPM card.
* 0100.0516 * MEAS SYSTEM Degraded Mode - 1 card failed
Alarm Level: Minor
Recovery
3.2.426 0517 - Degraded Mode - Multiple Cards Failed
The Measurements Platform subsystem is degraded because more than one MCPM card is out of service. The Measurements Platform subsystem can successfully complete all of its work, but may have no spare MCPM.
** 0100.0517 ** MEAS SYSTEM Degraded Mode - multiple cards failed
Alarm Level: Major
Recovery
3.2.427 0518 - Measurements Subsystem Unavailable
The Measurements Platform subsystem is not available. All MCPM cards are out of service.
*C 0100.0518 *C MEAS SYSTEM Measurements subsystem unavailable
Recovery
3.2.428 0519 - Measurements subsystem available
This message indicates that the Measurements subsystem has been restored to service.
0076.0519 MEAS SYSTEM Measurements subsystem available Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.429 0520 - Frame Power Usage Reached LVL3
Frame power usage reached 98% of threshold value.
*C 0002.0520 *C FRAME CF01 Frame power usage reached LVL3
Recovery
3.2.430 0521 - Frame Power Usage Reached LVL2
Frame power usage reached 95% but is below 98% of threshold value.
** 0002.0521 ** FRAME CF01 Frame power usage reached LVL2
Alarm Level: Major
Recovery
3.2.431 0522 - Frame Power Usage Reached LVL1
Frame power usage reached 90% but is below 95% of threshold value.
* 0002.0521 * FRAME CF01 Frame power usage reached LVL1
Alarm Level: Minor
Recovery
3.2.432 0523 - Frame power usage normal
Frame power usage is normal.
0002.0521 FRAME CF01 Frame power usage normal Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.433 0524 - REPT-ALMINH: alarm output TIMED inhibit
A device’s alarm is Timed inhibited using the inh-alm command.
6277.0524 RTXA 001-101-001 REPT-ALMINH: alarm output TIMED inhibit
OPCA= 004-004-004
ALARM INHIBIT LEVEL: MINR Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.434 0525 - Timed alm inh rdy to expire
Timed inhibition on a device is about to expire in the next 12 hours.
6277.0525 RTXA 001-101-001 REPT-ALMINH:Timed alm inh rdy to expire
OPCA= 004-004-004
ALARM INHIBIT LEVEL: MINR Expires: 05/05/20 16:00
Recovery
3.2.435 0526 - Service is Available
A problem with the specified SCCP service has been corrected. All SCCP cards are IS-NR and have a service status of Active.
RLGHNCXA3W 00-11-06 10:55:49 EST EAGLE 34.3.0
0056.0526 GFLEX SERVICE Service is available
Recovery
3.2.436 0527 - Service Abnormal
If UAM 527 is subsequent to UAM 452 or 453, then UAM 527 is auto cleared when the error condition abates (below threshold level 1 for UAM 452 and level 2 for UAM 453).
* 0056.0527 * GFLEX SERVICE Service abnormal
Alarm Level: Minor
Recovery
3.2.437 0528 - Service is Not Available
The specified SCCP service is not available. No IS-NRSCCP cards are associated with this specified SCCP service. No SCCP cards providing the specified service have a service status of Active.
*C 0056.0528 *C GFLEX SERVICE Service is not available
Recovery
3.2.438 0529 - Service is Disabled
The specified SCCP service has been manually disabled
with the
chg-sccp-serv command. All IS-NR cards
providing the service have service status of Offline.
*C 0056.0529 *C GFLEX SERVICE Service is disabled
Recovery
3.2.439 0530 - Service is Removed
The specified SCCP service is not equipped. No SCCP cards are configured with the service.
0056.0530 GFLEX SERVICE Service is removed
Recovery
Refer to the Maintenance Manual for card removal/replacement procedures. for card replacement procedures.3.2.440 0531 - Insufficient HW Copy Function Inhibited
HIPR cards must be installed in the same shelf as the IPLIMx and IPGWx card if their links are monitored. Therefore, monitoring will be inhibited on links on IPLIMx or IPGWx cards if a HIPR card is not installed in the same shelf. This is accomplished by ignoring an EMP service accept message after a service request is sent when HPIR cards are not installed. In addition, any active EMP TCP connections on an IPLIM or IPGW link is disconnected if both HIPR cards in the same shelf are removed. A new minor link alarm is implemented to report when monitoring on a link has been inhibited in this manner.
*0 044.0531 *SLK 1201,A lsnabcde Insufficient HW Copy Function Inhibited
Alarm Level: Minor
Recovery
Refer to the Maintenance Manual for card removal/replacement procedures. for card replacement procedures.3.2.441 0532 - RTX is Allowed
A previous fault is corrected and the EAGLE 5 ISS system can send traffic to the specified DPC using the exception route set identified by the specified class and criterion.
0044.0532 RTX 001-101-001 RTX is allowed
ILSN=lsn012345
Recovery
3.2.442 0533 - RTX is Restricted
A transfer-restricted message has been received concerning the exception route set. Possible causes are as follows:
One or more routes in this exception route set are unavailable.
A low priority route is carrying the traffic. The primary and combined routes are not available for traffic in this exception route set.
* 0044.0533 * RTX 001-101-001 RTX is restricted
ILSN=lsn012345
Alarm Level: Minor
Recovery
3.2.443 0534 - RTX is Prohibited
Traffic to the DPC through this exception route set is prohibited. Possible causes are as follows:
All routes in this exception route set are unavailable.
Adjacent point code link failures or non-adjacent failure exist in the route.
*C 0044.0534 *C RTXN24 001-101-001 RTX is prohibited
ILSN=lsn012345
Recovery
3.2.444 0535 - IP Connection Restricted
Although an IP connection has failed, some traffic is still flowing through an alternate SIGTRAN (SS7-over-IP) link.
The following two scenarios exist:
The SCTP association is established and the SCTP far-end is multi-homed and the Eagle determines one or more far-end IP destinations for the association are unreachable.
The SCTP association is established and the SCTP far-end is uni-homed and the SCTP near_end has an LHOST and an ALHOST configured.
IP Connection UAMs 0086 (Congested), 0535 (Restricted), and 0536 (Excess Retransmits) conditions can occur simultaneously. However, only one alarm per device can be displayed at a time. If two or more are present, the display of these alarms is prioritized as follows:- 0086 - IP Connection Congested (MSUs are being dropped)
- 0536 - IP Connection Excess Retransmits (MSUs may be dropped. The EAGLE 5 ISS sustains a certain rate of dropped MSUs without triggering this alarm, then issues UIM 0536 when that rate is exceeded.)
- 0535 - IP Connection Restricted (MSUs are being transmitted at reduced rate. A path of a multi-homed association has failed. )
RLGHNCXA21W 00-12-07 12:01:43 EST EAGLE 31.3.0
* 0014.0535 * IP7 assoc1 IP Connection Restricted
Alarm Level: Minor
Recovery
3.2.445 0536 - IP Connection Excess Retransmits
An SCTP association has excessive retransmissions. The retransmission errors may cause a connection to congest and fail in the presence of a sufficiently high load.
RLGHNCXA21W 06-12-07 12:01:43 EST EAGLE 35.6.0
* 1111.0536 * IP7 assoc1234567890 IP Connection Excess RetransmitsAlarm Level: Minor
Recovery
Misconfiguration or improper tuning of SCTP attributes to match the network conditions and traffic volumes
Packet loss
Excessive round-trip times
The receive buffer of the SCTP peer being full for extended periods (probes by Eagle SCTP to update window size may result in discards by the peer)
Timer settings that are too close in value
3.2.446 0537 - Ethernet error threshold exceeded
Too much data received on the port.
An Ethernet interface experiences excessive errors at the physical layer, such as CRC or framing errors. This error is issued when the Ethernet statistics indicate errors occurring in any 15-second window. The alarm will clear when no errors have occurred in the previous 15 second window. In full-duplex mode, collisions will not be ignored but when configured for half-duplex mode, they will be ignored, since collisions are expected in half-duplex mode. When collisions occur repeatedly for the same packet more than 16 times then the “excess collisions” error count is pegged.
** 2315.0537 ** ENET 1201,B Ethernet error threshold exceededAlarm Level: Major
Recovery
- Too much incoming data for the port to handle.
- Faulty hardware; an EAGLE card, cable, or immediate IP switch/router.
- Configuration mismatch problems; the following items should match on both ends:
- Duplex
- Speed
- Ethernet type
- Autonegotiate used on EAGLE or immediate IP switch/router (it is recommended to lock down your IP connection and do not use AUTONEGOTIATE)
3.2.447 0538 - Ethernet error threshold cleared
A problem with the Ethernet error threshold has been corrected.
2359.0538 ENET 1201,B Ethernet error threshold clearedAlarm Level: No alarm condition. The message is informational.
Recovery
This message indicates that a problem with the Ethernet error threshold has been cleared.
3.2.448 0539 - Ethernet Interface Down
An Ethernet interface is reporting that it is down.
RLGHNCXA21W 06-12-09 12:01:43 EST EAGLE 40.1
** 2315.0539 ** DLK 1201,B1 IPSG Ethernet Interface DownAlarm Level: Major
Recovery
An Ethernet interface is provisioned (rtrv-ip-lnk reports a non-zero IP address and the card on which the Ethernet resides is in service), but the interface is reporting that it is down.
If this UAM comes from the E5-OAM card and rept-stat-meas command output shows this E5-OAM card as Primary, a loss of reports on the measurement server is possible and MASP swap must be done manually.
If this UAM comes from the E5-OAM card, rept-stat-card shows this card is active, and rtrv-ctrl-feat command output shows the SNMP feature is activated, a loss of SNMP traps is possible. MASP swap must be done manually.
3.2.449 0540 - Ethernet Interface Up
A problem with the Ethernet interface has been corrected.
2359.0540 DLK 1201,B1 IPSG Ethernet Interface UpAlarm Level: No alarm condition. The message is informational.
Recovery
This message indicates that a problem with the Ethernet interface has been cleared.
3.2.450 0541 - MSU cksum Error Threshold Exceeded
One or more MSU checksum validation errors have been reported by a LIM or SCCP card during internal card integrity checks.
A LIM or SCCP card has reported a checksum validation failure for a MSU received from another card. The failure may be due to a hardware problem or other issue affecting the data transfer path on a particular card. It may indicate a problem with data corruption in an MSU sent to or received from another card.
The alarm is raised when a checksum validation failure occurs during internal card integrity checks. It remains active in the system until the Run-Time Diagnostic subsystem (RTD) statistics are reset and no further indications of MSU checksum validation failures are reported.
*C 2315.0541 *C RTD SYSTEM MSU cksum error threshold exceeded
Recovery
3.2.451 0542 - MSU cksum error threshold cleared
The MSU checksum threshold exceeded alarm has been corrected.
2359.054238 RTD SYSTEM MSU Cksum error threshold clearedAlarm Level: No alarm condition. The message is informational.
Recovery
This message indicates that the MSU checksum threshold exceeded alarm has been cleared.
3.2.452 0543 - VLR Dynamic Learning is suspended
This alarm occurs if only one SFAPP card is present in the system and the mode parameter "is not set to OFF" in the SFAPPOPTS table.
Example
1 2 3 4 5 6 7 8
12345678901234567890123456789012345678901234567890123456789012345678901234567890
yyyy.0543 SFAPP SYSTEM VLR Dynamic Learning is suspended
Recovery
- Place more than one SFAPP card IS-NR.
3.2.453 0544 - VLR Dynamic Learning Started
This alarm occurs if more than one SFAPP card is present in the system and the mode parameter "is not set to OFF" in the SFAPPOPTS table.
Example
1 2 3 4 5 6 7 8
yyyy.0544 SFAPP SYSTEM VLR Dynamic Learning Started
Alarm Level: Normal.
Recovery
None. This alarm is a corrective alarm.
3.2.454 0545 - SEAS Terminal Available
This message indicates a problem with SEAS system has been corrected.
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 37.5.0
* 0043.0545 ** TERMINAL 17 SEAS Terminal Available
Recovery
3.2.455 0546 - SEAS Terminal Unavailable
This message indicates that the EAGLE 5 ISS system is unable to communicate with the SEAS subsystem.
* 0043.0546 ** TERMINAL 17 SEAS Terminal Unavailable
Alarm Level: Major
Recovery
3.2.456 0547 - Service degraded
One or more SS cards goes out of service in (N or N+1) configuration or not IS-NR.
0056.0547 APSS Service degradedAlarm Level: Major.
Recovery
- Restore the one or more SS out of service cards in (N or N+1) configuration or not IS-NR.
3.2.457 0548 - GTT HexTree DB corrupted. TPS derated
This message indicates there is a memory corruption in the HexTree DB that is affecting the lookup of GTT translations.
** 0002.0548 ** CARD 1203 GTT HexTree DB corrupted. TPS derated Alarm Level: No alarm condition. The message is informational only.
Recovery
Reboot the card or turn OFF GTTHITPS.
3.2.458 0549 - GTT HexTree DB incoherent. TPS derated
This message indicates the HexTree DB could not be updated successfully on the RADB command and the DB is incoherent..
** 0002.0549 ** CARD 1203 GTT HexTree DB incoherent. TPS derated Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.459 0550 - GTT HexTree DB alarm cleared
This message indicates the HexTree DB error has been cleared.
0002.0550 CARD 1203 GTT HexTree DB alarm cleared Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.460 0551 - V-Flex Subsystem is not available
No SCCP cards have a V-Flex status of Active. (All SCCP cards are OOS or loading)
RLGHNCXA21W 00-12-07 12:01:43 EST EAGLE 37.6.0
*C 0056.0551 *C VFLEX SYSTEM VFLEX Subsystem is not available Alarm Level: Critical.
Recovery
- The V-Flex feature must be turned on and activated.
3.2.461 0552 - V-Flex Subsystem is disabled
All IS-NR SCCP cards have V-Flex status of Offline (with at least 1 card IS-NR). INH-MAP-SS command has been executed.
*C 0056.0552 *C VFLEX SYSTEM VFLEX Subsystem is disabledAlarm Level: Critical.
Recovery
- The V-Flex feature must be enabled and turned on.
3.2.462 0553 - VFLX Subsystem normal, card(s) abnormal
One Service Module card has V-Flex status of Active and there are 1 or more cards with an V-Flex status other than Active (a status not equal to OOS (out of service), loading or Offline).
*C 0056.0553 *C VFLEX SYSTEM VFLX Subsystem normal, card(s) abnormalAlarm Level: Minor.
Recovery
- No action necessary.
3.2.463 0554 - V-Flex Subsystem is available
All Service Module cards are IS-NR and have an V-Flex status of Active.
*C 0056.0554 *C VFLEX SYSTEM VFLEX VFLEX Subsystem is availableAlarm Level: No alarm condition. The message is informational only.
Recovery
3.2.464 0555 - V-Flex Subsystem is removed
Last Service Module card was deleted.
*C 0056.0555 *C VFLEX SYSTEM VFLEX Subsystem is removedAlarm Level: No alarm condition. The message is informational only.
Recovery
3.2.465 0556 - V-Flex Subsystem degraded, card(s) abnormal
One or more V-Flex cards goes out of service in (N or N+1) configuration or not IS-NR.
0056.0556 VFLEX Subsystem VFLX Subsystem degraded, cards abnormalAlarm Level: Major.
Recovery
- Restore the one or more V-Flex out of service cards in (N or N+1) configuration or not IS-NR.
3.2.466 0560 - REPT-LKSTO: Link Set Restricted
This message indicates a linkset has been restricted.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 38.0.0
* 0014.0560 * LSN a54646 REPT-LKSTO: link set restricted
Alarm Level: Minor
Recovery
3.2.467 0561 - Can't Establish Hi Bit Rate; All HW OK
This message is issued if the system cannot establish high bit rate operation when it is equipped with HIPR2 cards at all MUX locations and the HIPR2 High Rate Mode feature is ON.
This UAM might appear during transition phase when the HIPR2 High Rate Mode feature status has changed, but eventually it will be cleared if high bit rate is established on both IMT buses.RLGHNCXA21W 09-02-07 12:01:43 EST EAGLE 41.1.0
*C 5025.0561 *C SYSTEM Can't establish Hi Bit rate;All HW OK
Recovery
3.2.468 0562 - High Bit rate established
This message indicates that the alarm condition specified by the previous alarm has been cleared.
0590.0562 SYSTEM High Bit rate established Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.469 0563 - IMT Bit rate mismatch detected
This message indicates that the the IMT Bus A and B are operating at different bit rates. This can occur if the BERT Test fails for only one bus, or if some of the HIPR2 cards have been replaced with HMUX/HIPR cards after the HIPR2 High Rate Mode feature was turned ON.
** 0590.0563 ** IMT SYSTEM IMT Bit rate mismatch detected Alarm Level: Major
Recovery
3.2.470 0564 - IMT Bit rate mismatch cleared
0014.0564 IMT SYSTEM IMT Bit rate mismatch cleared Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.471 0565 - ATINPQ Subsystem is Not Available
The ATINP subsystem is not available. There are no IS-NR SCCP cards associated with this ATINP subsystem. The ATINP subsystem was not taken off-line via command.
*C 0056.0565 *C ATINP SYSTEM ATINPQ Subsystem is not available
Recovery
3.2.472 0566 - ATINPQ Subsystem is disabled
The ATINP subsystem has been manually disabled using the inh-map-ss command.
*C 0056.0566 *C ATINP SYSTEM ATINPQ Subsystem is disabled Alarm Level: Critical
Recovery
3.2.473 0567 - ATINPQ Subsystem Normal, Card(s) Abnorml
One SCCP card has ATINP status of Active and there are one or more cards with an ATINP status other than Active.
* 0056.0567 * ATINP SYSTEM ATINPQ Subsystm normal, card(s) abnorml
Alarm Level: Minor
Recovery
3.2.474 0568 - ATINPQ Subsystem is available
This message indicates that a problem with the ATINP subsystem has been corrected.
0056.0568 ATINP SYSTEM ATINPQ Subsystem is available Alarm Level: No alarm condition. The message is informational only.
Recovery
3.2.475 0569 - ATINPQ Subsystem is Removed
The ATINP subsystem is not fully equipped. There are no SCCP cards configured with this ATINP subsystem.
0056.0569 ATINP SYSTEM ATINPQ Subsystem is removed
Recovery
Configure the ATINP system with SCCP cards. Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.476 0570 - Incompatible Flash Image for sys rel
The new card inserted into system with a flash image is not compatible with the system release. The card is auto-inhibited. A manual flash download is required.
isht01 09-07-21 09:19:16 EST EAGLE5 41.1
ALARM STATUS = ** 0570 Incompatible flash image for sys rel
99 Inserted H/W is not compatible with the provisioned slot
HW VERIFICATION CODE: 98
Alarm Level: Major
Recovery
3.2.477 0571 - Sentinel Socket is Inactive
- Turned off scopy bit through
chg-eiscopycommand if it is already on - Lost connection with Sentinel/IMF server
- Link being monitored is deleted
- Adaptor type is changed to non-M2PA on the IPLIM
card connected to IMF/sentinel server using
chg-assoc/chg-appl-sock - Internal problem occured at the LIM card hosting the corresponding link
RLGHNCXA21W 00-12-07 12:01:43 EST EAGLE 38.0.0
* 0100.0571 * SLK 1201,A lsn123 Sentinel Socket is inactive
Alarm Level: Minor
Recovery
3.2.478 0572 - Sentinel socket is active
A problem with the EAGLE 5 ISS - Sentinel socket has been corrected and the socket is active.
0100.0572 SLK 1201,A lsn123 Sentinel Socket is active
Recovery
- No action neccessary
3.2.479 0573 - BERT Test Failed
This message is displayed when the BERT diagnostic test, which is initiated by the HIPR2 card as a part of the IMT bus alignment process, has failed. This message may indicate that a HIPR2 card has failed; it may also indicate that there is a bad high rate Fibre-Channel cable, or that the high rate Fibre-Channel cables have not been installed.
** 0590.0573 ** Card 1109 BERT Test Failed
Alarm Level: Major
Recovery
3.2.480 0574 - BERT Test failure cleared
This message indicates that the alarm condition specified by the UAM 0573 (BERT Test Failed) has been cleared.
0590.0574 Card 1109 BERT Test failure cleared
Recovery
3.2.481 0575 - Card type not HIPR2
This message is displayed when the HIPR2 High Rate Mode feature is ON and a non-HIPR2 card has replaced the HIPR2 card.
** 0590.0575 ** Card 1309 Card type not HIPR2
Alarm Level: Major
Recovery
- The HIPR/HMUX card is replaced with a HIPR2 card.
- The HIPR2 High Rate Mode feature is turned OFF.
3.2.482 0576 - All FC Network Unavailable
This indicates that the FC Network is down on all FC enabled cards.
RLGHNCXA21W 00-12-09 12:01:43 EST EAGLE 40.1
** 0100.0576 ** FCS All FC Network Unavailable
Alarm Level: Major
Recovery
3.2.483 0577 - All FC cards removed
This indicates that all Fast Copy enabled cards have been deleted from the system.
0101.0577 FCS All FC cards removed Alarm Level: None
Recovery
3.2.484 0578 - FC System is Available
This indicates that the FC Network is available on any of the FC enabled cards.
0101.0578 FCS FC System is Available Alarm Level: None
Recovery
3.2.485 0579 - FC Network Unavailable
This indicates the FC enabled card is unable to reach any XMF server.
* 0107.0579 * Card 1104 FC Network Unavailable
Alarm Level: Minor
Recovery
3.2.486 0580 - FC Network Available
This indicates that FC enabled card is able to reach any XMF server.
0108.0580 Card 1104 FC Network Available Alarm Level: None
Recovery
3.2.487 0581 - Loss of heartbeat
This indicates that an FC enabled card did not receive a heartbeat message from XMF server before the expiry of RCV heartbeat timer.
* 0108.0581 * Card 1104 Loss of heartbeat Alarm Level: Minor
Recovery
- Inspect the backplane for loose dongle cables (P/N 830-1343-0X).
- Verify the RJ45 cables are connected completely on the backplane.
3.2.488 0582 - Heartbeat Available
This indicates that FC enabled card receives heartbeat from the XMF.
0107.0582 Card 1104 Heartbeat Available Alarm Level: None
Recovery
3.2.489 0583 - Unexpected SAM Received
This indicates that an FC enabled card received an erroneous SAM from IMF.
* 0102.0583 * SLK 1201,A lsnabcde Unexpected SAM Received
REASON: Mismatched Fast Copy Network Addresses Alarm Level: Minor
Recovery
3.2.490 0584 - Expected SAM Received
This indicates that FC enabled card received a valid SAM on a link from DAS.
0102.0584 SLK 1201,A lsnabcde Expected SAM Received Alarm Level: None
Recovery
3.2.491 0588 - FC Port De-activated
This indicates that FC enabled Card CPU Idle reached Threshold level 1 and deactivated the FCS IP port (see Example 1) or if negotiation for data rate and traffic flow do not result in 100 Mbps and full duplex mode for the FC port (see Example 2).
** 0705.0588 ** DLK 1106,B1 IPSG FC Port De-activated
REASON: Onset of CPU Congestion Example 2 RLGHNCXA21W 00-12-09 12:01:43 EST EAGLE 40.1
** 0772.0588 ** DLK 1106,B1 IPSG FC Port De-activated
REASON: Auto-Neg FailsAlarm Level: Major
Recovery - Onset of CPU Congestion
Recovery - Auto-Negotiation Fails
Corrective action needs to be taken at the switch to auto-negotiate successfully with Fast Copy Ports, for data rate and traffic as 100 Mbps/Full Duplex.
3.2.492 0589 - FC Port Activated
This indicates that FCS IP Port on FC Enabled card CPU Idle reached the Abatement Level.
2359.0589 DLK 1201,B1 IPSG FC Port Activated
Alarm Level: None
Recovery
3.2.493 0590 - Fast Copy Application De-activated
- Fast Copy CPU Load Shedding condition or Auto-Negotiation failure on both the FC Ports
- One FC port is down due to network failure and another one is down either due to CPU load-shedding or Auto-Negotiation failure
- Fast Copy CPU Load Shedding condition on one FC Port and Auto-Negotiation failure on another FC Port
* 0642.0590 * CARD 1105 IPSG Fast Copy Application De-activated
REASON: CPU Threshold Exceeded
* 0587.0590 * CARD 1106 IPSG Fast Copy Application De-activated
Alarm Level: Minor
Recovery - CPU Threshold Exceeded
3.2.494 0591 - Fast Copy Application Activated
This indicates that FC enabled Card CPU Idle reached abatement level and activated the Fact Copy application.
0107.0591 Card 1104 Fast Copy Application Activated Alarm Level: None
Recovery
3.2.495 0592 - AIQ Subsystem is Not Available
The AIQ subsystem is not available. There are no IS-NR SCCP cards associated with this AIQ subsystem. The AIQ subsystem was not taken off-line via command.
RLGHNCXA21W 00-02-10 12:01:43 EST EAGLE 42.0.0
*C 0135.0592 *C LSS AIQ Subsystem is not available
Recovery
3.2.496 0593 - AIQ: Subsystem is Disabled
The AIQ subsystem has been manually disabled using the
inh-map-ss command.
*C 1571.0593 *C LSS AIQ Subsystem is disabled
Recovery
3.2.497 0594 - AIQ: Subsystem Normal, Card(s) Abnormal
* 0212.0594 * LSS AIQ Subsystem normal, card(s) abnormal
Alarm Level: Minor
Recovery
3.2.498 0595 - AIQ: Subsystem is available
This message indicates that a problem with AIQ system has been corrected.
0144.0595 LSS AIQ Subsystem is available
;Alarm Level: No alarm condition. The message is informational only.
Recovery
This message indicates a previous fault has been corrected. No further action is necessary.
3.2.499 0596 - AIQ: Subsystem is Removed
The AIQ subsystem is not fully equipped. There are no SCCP cards configured with this AIQ subsystem.
0144.0595 LSS AIQ Subsystem is removed
Recovery
- Verify the SCCP hardware.
- Configure the AIQ system with SCCP cards. Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.500 0597 - FC System is Deactivated
This alarm indicates that the Fast Copy application is de-activated on all FC Capable cards.
RLGHNCXA21W 09-08-19 12:01:43 EST EAGLE 41.1
* 0302.0597 * FCS FC System is Deactivated
Alarm Level: Minor
Recovery
3.2.501 0598 - Subsystem degraded, card(s) abnormal
0056.0598 Subsystem Subsystem degraded, cards abnormalAlarm Level: Major.
Recovery
3.2.502 0599 - RW Time Mismatch
This alarm indicates that there is a mismatch of RW Timing.
tklc1170501 22-03-25 03:09:33 EST EAGLE 47.0.0.0.0-78.38.0
* 0277.0599 * CARD 2307 SS7HC69 RW Time Mismatch
Alarm Level: Minor
Recovery
Remove the alarm from the system, when the time between EAGLE and IMF synchronizes.
3.2.503 0619 - SIP SYSTEM is Not Available
This alarm indicates SIP feature is not ON and System has no SIP card that is Active/IS-NR.
1 2 3 4 5 6 7 8
*C 0002.0619 *C SIP SYSTEM SIP System is not available
Recovery
- Enter the following command to verify the status and
location of the SIP card:
rept-stat-sip. - Enter the following command to move the SIP card to
an ACTIVE status if loading is successful:
rst-card:loc=xxxwhere xxxx is the location of the SIP card identified in 1. - Enter the following command to verify the status and
rept-stat-sip. - Verify the SIP card reset in 2 are ACTIVE/IS-NR.
- If the SIP card remains INACTIVE, replace the card. Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.504 0620 - SIP SYSTEM is available
This message indicates that at least one SIP card is ACTIVE/IS-NR.
1 2 3 4 5 6 7 8
0002.0620 SIP SYSTEM SIP SYSTEM is available
Recovery
3.2.505 0622 - SIP Threshold - Level 1
This UAM is generated when the EAGLE detects SIP Congestion Level 1 based on the threshold set in TH-ALM table for the SIP card.
1 2 3 4 5 6 7 8
0002.0622 SIP SYSTEM SIP Threshold - Level1
Alarm Level: Minor
Recovery
- Use
rept-stat-sipcommand to determine the status of the SIP SYSTEM. If the TPS is beyond the allowed limit, decrease the TPS. - Follow the procedures to add more SIP cards to handle the increased SIP traffic.
3.2.506 0623 - SIP Threshold - Level2
This UAM is generated when the EAGLE 5 detects SIP Congestion Level 2 based on the threshold set in TH-ALM table for the SIP card.
1 2 3 4 5 6 7 8
0002.0623 SIP SYSTEM SIP Threshold - Level2
Alarm Level: Major
Recovery
- Use
3.2.507 0624 - SIP Threshold Condition Cleared
This UAM is generated when the SIP Threshold congestion is cleared.
1 2 3 4 5 6 7 8
0002.0624 SIP SYSTEM SIP Threshold Condition Cleared
Alarm Level: No Alarm Condition.
Recovery
This alarm indicates a previous fault has been corrected.
3.2.508 0625 - SIP SYSTEM Normal, Card(s) Abnormal
This message indicates that the number of active SIP cards (i.e., in IS-NR state) is less than half of the configured SIP cards.
1 2 3 4 5 6 7 8
0002.0625 SIP SYSTEM SIP SYSTEM normal, card(s) abnormal
Alarm Level: NO alarm condition. The message is informational only.
Recovery
- Enter the following command to determine which SIP
cards are out of service:
rept-stat-sip. - Use the
init-cardcommand to reinitialize any SIP cards OOS-MT. - Use the
rept-stat-sipcommand again to determine if the card(s) have returned to IS-NR. If not, reseat the card(s). - If the SIP card remains OOS-MT, replace the card(s). Refer to the Maintenance Manual for card removal/replacement procedures.
3.2.509 0626 - SIP Threshold Level Critical
This message indicates that there is a Congestion Level of Critical based on the threshold set in TH-ALM table for the SIP card.
1 2 3 4 5 6 7 8
0002.0626 SIP SYSTEM SIP Threshold Level Critical
Recovery
- Use
3.2.510 0627 - SFLOG SYSTEM is not available
This message indicates the system has no SFLOG card that is Active/IS_NR status.
*C yyyy.0627 *C SFLOG SYSTEM SFLOG SYSTEM is not available
Recovery
Activate (Active/IS-NR) any one of the SFLOG card in the system.
3.2.511 0628 - SFLOG SYSTEM is available
This message indicates the system has at least one SFLOG card that is Active/IS_NR status.
yyyy.0628 SFLOG SYSTEM SFLOG SYSTEM is available
Recovery
3.2.512 0629 - SFLOG SYSTEM is removed
This message indicates that all SFLOG cards are deleted from the system.
yyyy.0629 SFLOG SYSTEM SFLOG SYSTEM is removed
Recovery
3.2.513 0630 - Throttle Threshold - exceeded
This message indicates the Throttle threshold for a particular Throttling GTT Action has exceeded. Any new messages hitting this Throttling Action will be discarded for the remaining duration of the current 30-second window. This alarm is issued for each Throttling Action for which the threshold has exceeded.
** yyyy.0630 ** TA – abc Throttle Threshold – exceeded
Alarm Level: Major.
Recovery
Review and modify the throttle threshold for the Throttle GTT action if it is not currently set appropriately to handle the desired traffic volume.
- Use the
rept-stat-sfthrotcommand to verify the Throttle Action status. - Use the
rtrv-gttactandchg-gttactcommands to review and modify the Throttle Action settings.
3.2.514 0631 - Throttle Threshold - cleared
This message indicates the Throttle threshold for a particular Throttling GTT Action, or alarm threshold for UAM 0632, has cleared.
yyyy.0631 TA – abc Throttle Threshold - cleared
Recovery
3.2.515 0632 - Alarm Threshold - exceeded
This message indicates the system wide alarm threshold for the throttling GTT Action has exceeded.
* yyyy.0632 * SCCP SYSTEM Alarm Threshold – exceeded
Alarm Level: Minor.
Recovery
3.2.516 0633 - Alarm Threshold - cleared
This message indicates the system wide alarm threshold has cleared.
yyyy.0633 SCCP SYSTEM Alarm Threshold - cleared
Recovery
3.2.517 0634 - SFAPP is available
This message indicates all the SFAPP cards are IS-NR in the system.
yyyy.0634 SFAPP SYSTEM SFAPP is available
Recovery
- Alarm itself is a corrective alarm.
3.2.518 0635 - SFAPP is not available
This message indicates all the SFAPP cards are isolated from the system.
yyyy.0635 SFAPP SYSTEM SFAPP is not available
Recovery
- Check if the SFAPP card is faulty or inhibited.
3.2.519 0636 - SFAPP is removed
This message indicates the last SFAPP card is deleted from the system.
yyyy.0636 SFAPP SYSTEM SFAPP is removed
Recovery
- Check if the SFAPP card is removed.
3.2.520 0637 - SFAPP Threshold Level1 Exceeded
This message indicates the SFAPP traffic is above the SFAPP Congestion Alarm Lvl 1 threshold.
yyyy.0637 SFAPP SYSTEM SFAPP Threshold Level1 Exceeded
Alarm Level: Minor.
Recovery
- Reduce the TPS of the card below the configured threshold level 1 value.
3.2.521 0638 - SFAPP Threshold Level2 Exceeded
This message indicates the SFAPP traffic is above the SFAPP Congestion Alarm Lvl 2 threshold.
yyyy.0638 SFAPP SYSTEM SFAPP Threshold Level2 Exceeded
Alarm Level: Major.
Recovery
- Reduce the TPS of the card below the configured threshold level 2 value.
3.2.522 0639 - SFAPP Threshold Level Critical
This message indicates the SFAPP traffic is above the system supported traffic limit.
yyyy.0639 SFAPP SYSTEM SFAPP Threshold Level Critical
Recovery
- Reduce the TPS of the card below the system maximum limit.
3.2.523 0640 - SFAPP Threshold Condition Cleared
This message indicates the SFAPP traffic is below the SFAPP Congestion Alarm Lvl 1 threshold.
yyyy.0640 SFAPP SYSTEM SFAPP Threshold Condition Cleared
Recovery
- Alarm itself is a corrective alarm..
3.2.524 0641 - SFAPP Capacity normal, card(s) abnormal
This message indicates that any provisioned SFAPP card is isolated from the system.
yyyy.0641 SFAPP SYSTEM SFAPP Capacity normal, card(s) abnormal
Alarm Level: Minor.
Recovery
3.2.525 0642 - System SFAPP TPS normal
This message indicates the isolated SFAPP card comes in service.
yyyy.0642 SFAPP SYSTEM System SFAPP TPS normal
Recovery
3.2.526 0643 - System SFAPP Threshold Exceeded
This message indicates the SFAPP TPS is above the SFAPP
TPS Threshold Lvl (rtrv-th-alm).
yyyy.0643 SFAPP SYSTEM System SFAPP Threshold Execeeded
Alarm Level: Major.
Recovery
- Reduce the overall TPS of the SFAPP subsystem below the SFAPP TPS threshold Lvl.
3.2.527 0644 - System SFAPP capacity exceeded
This message indicates the SFAPP capacity exceeds the maximum system limit.
yyyy.0644 SFAPP SYSTEM System SFAPP Capacity Exceeded
Recovery
- Reduce the overall TPS of the SFAPP subsystem below the Maximum system capacity.
3.2.528 0645 - LIM/SCCP card(s) denied SFAPP service
e1061501 17-12-22 11:03:03 EST EAGLE 46.5.1.5.0-73.10.0
** 0141.0645 ** SFAPP SYSTEM LIM/SCCP card(s) denied SFAPP service
Alarm Level: Major.
Recovery
- Configure the LIM/SCCP card for SFAPP service.
3.2.529 0646 - SFAPP Dynamic Learning Alarm Cleared
This occurs if alarm 0543 (VLR Dynamic Learning is suspended) is raised and changed the value of the mode parameter of the SFAPPOPTS table to OFF.
1 2 3 4 5 6 7 8
yyyy.0646 SFAPP SYSTEM SFAPP Dynamic Learning Alarm Cleared
Recovery
None. This alarm is a clearing alarm.
3.2.530 0647 - EEDB Connectivity Down
This occurs when connectivity between the EAGLE and its EEDB has been lost.
1 2 3 4 5 6 7 8
yyyy.0647 SYSTEM EEDB Connectivity Down
Alarm Level: Major.
Recovery
- Check the connectivity between the EAGLE and its EEDB.
3.2.531 0648 - EEDB Connectivity Up
This occurs when connectivity between the EAGLE and its EEDB has been restored.
1 2 3 4 5 6 7 8
yyyy.0648 SYSTEM EEDB Connectivity Up
Recovery
3.2.532 0649 - Card is Non-responsive
This alarm indicates that a specific card is non-responsive due to some software or hardware issue.
Example
tklc1111101 23-04-28 08:20:50 EST EAGLE 47.0.0.1.0-79.13.12
** 0621.0649 ** CARD 1108 IPSG69 CARD is non-responsiveAlarm
Level: Major
Recovery:
Reseat the card again.
3.2.533 0650 - MTP3 MFC Discard
This alarm indicates that MTP3 routed messages are getting discarded on the card.
Example
** 0621.0650 ** CARD 1108 IPSG69 MTP3 MFC Discard
Alarm Level: Major
Recovery:
This issue will be resolved automatically within a few seconds. However, the alarm will be cleared if there is no MTP3 MFC discard for five minutes. If the issue is not auto-corrected, then reseat the card again along with the corresponding destination cards.
3.2.534 0901 - Card DB Load Timeout, Check GLS SS
This message indicates that the database of a card or subsystem has been in a transition for 9 minutes. This alarm shows the unavailability of the GLS subsystem. If the Integrated GLS feature is OFF or not yet enabled, this alarm shows that no TSM/E5-TSM is in IS-NR state or no TSM/E5-TSM card is responding to GWS requests. If the Integrated GLS feature is ON, this alarm shows that the E5-OAM cards are not performing the GLS functionality properly.
tekelecstp 02-09-21 17:09:58 EST EAGLE5 42.0.2-63.38.33
** 0076.0901 ** CARD 1201 SS7ANSI Card DB load timeout, check GLS SS
Alarm Level: Major
Recovery
3.2.535 0902 - Card DB is stable
This message indicates that the database of a card was in transition but has recovered.
RLGHNCXA3W 99-12-06 10:56:18 EST EAGLE 35.0.0
0104.0902 CARD 1201 SS7ANSI Card DB is stable Alarm Level: No alarm condition. The message is informational only.
Recovery
No action is needed.
3.2.536 0903 - IP Link A is Down
This message indicates that an IP application socket is out of service due to a IP link down (ethernet problem) or due to the signaling link being deactivated.
RLGHNCXA03W 01-01-10 16:28:08 EST EAGLE 35.0.0
** 0046.0903 ** CARD 1111 EBDADCM IP Link A is down
Alarm Level: Major
Recovery
3.2.537 0904 - IP Link A is Up
This indicates that a previously broken link between the DCM card and the OAP now exists and is functioning properly.
0046.0904 CARD 1111 EBDADCM IP Link A is up
Recovery
3.2.538 0905 - IP Link B is Down
** 0046.0905 ** CARD 1111 EBDADCM IP Link B is down
Alarm Level: Major
Recovery
3.2.539 0906 - IP Link B is Up
0046.0906 CARD 1111 EBDADCM IP Link B is up
Recovery
3.2.540 0907 - HW limiting TPS Rate Alarm Cleared
This message indicates that the alarm condition, specified by message “0908 - HW cannot support purchased TPS rate,” has been cleared.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 5.0.0-32.0.0
0100.0907 CARD 1101 SS7IPGW HW limiting TPS rate alarm cleared
ASSY SN: 102199815a1234
Recovery
3.2.541 0908 - HW Cannot Support Purchased TPS Rate
This message indicates that the purchased transactions per second (TPS) rate running on the DCM(s) is higher than can be supported by you current hardware.
** 0100.0908 ** CARD 1101 SS7IPGW HW cannot support purchased TPS rate
Alarm Level: Major
Recovery
3.2.542 0911 - Dynamic Database is Inconsistent
The dynamic database (DDB) audit (whether running automatically or on-demand) has detected that checksums are inconsistent. This means that one or more cards do not concur with the current network configuration. (The UIM lists a maximum of four affected cards.)
The dynamic database audit looks for checksum errors in dynamic database tables on LIM and Service Module cards. The fixed database, which is entered via the OAM card, includes all provisionable tables and options. The dynamic database has information about the state of those static-database entries (for example, which links are actually available). Each LIM and Service Module card has a copy of the fixed database and the dynamic database. The entries in the tables in the dynamic database on each card change as network conditions change. Cards calculate and record dynamic database checksums in real time as updates are applied.
If the dynamic database is being updated during the dynamic database audit, then the inconsistent checksums might not indicate a true problem. To ensure that all dynamic database changes have been received and applied, the OAM processes audit replies after a required quiet period.
You can use the “DDBAUDTIMER” SS7OPTS option to enable and disable the background audit.Typically, when the dynamic database copies are consistent among all the cards except one, then there is a problem on that one card. It is possible, however, for one card to have the correct information when the other cards do not (for example, a card might have a link on it that is actually available when the other cards incorrectly show the link as unavailable). When this alarm occurs, further troubleshooting is necessary to determine the actual status of the routes, links, linksets, and subsystems.
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 41.0
** 0100.0911 ** SYSTEM Dynamic database is inconsistent
Card 1101, 1102, 1107, 1108, ... (3 others)
Alarm Level: Major
Recovery
The Eagle cannot automatically determine which cards are inconsistent. Do the following to address a dynamic-database inconsistency alarm:
3.2.543 0912 - Dynamic database is now consistent
The dynamic database audit has run and determined that the checksums are consistent.
0100.0912 SYSTEM Dynamic database is now consistent Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3 UIMs
The following are UIMs that may be displayed.
3.3.1 1000 - MTP rcvd UPU - User Part is not SCCP
The system forwarded a unit data (UDT) message to a distant node that does not support SCCP. In response, the distant node sent back a user part unavailable (UPU) message.
The message provides the affected point code (which sent the UPU), as well as the service information octet (SIO) field of the message and the cause code.
All fields are in decimal values. The SIO field values applicable to this message are:
03 – SCCP
04 – Telephone User Part (TUP)
05 – ISDN User Part (ISUP)
06 – Data User Part (call and circuit related messages)
07 – Data User Part (facility registration and cancellation)
08 – MTP Testing User Part
The message also provides the value for the User Part that was unavailable (UPU=). The values shown above apply to this field as well.
The Cause Codes (Unavail Cause =) applicable to this message are:
000 – Unknown
001 – Unequipped Remote User
002 – Inaccessible User Part
Unequipped remote user indicates the distant node is not equipped for SCCP. Inaccessible user part indicates that the distant node is equipped with SCCP capability, but there has been a failure in SCCP making it impossible to handle messages sent to it by MTP.
0100.1000 CARD 1201,A INFO MTP rcvd UPU - user part is not SCCP
SIO=03 OPC=003-232-000 DPC=001-004-000
AFTPC=004-000-001 UPU=03 UNAVAIL CAUSE=001
LSN=A1234567
Recovery
3.3.2 1001 - MTP rcvd Transfer Controlled (TFC)
The system is generating traffic for a remote node that is congested. The distant node sent a transfer controlled (TFC) message in response.
0100.1001 CARD 1201,A INFO MTP rcvd Transfer Controlled (TFC)
SIO=0a OPC=003-232-000 DPC=000-000-000
AFTPC=004-000-000 CONG STATUS=000
LSN=A1234567
Recovery
3.3.3 1002 - MTP rcvd invalid TFC - status 0
The EAGLE 5 ISS system received a transfer controlled (TFC) message with a status of 0 (protocol violation). No action on the part of the EAGLE 5 ISS system has been taken.
0100.1002 CARD 1205,B INFO MTP rcvd invalid TFC - status 0
SIO=0a OPC=003-234-000 DPC=000-024-000
AFTPC=055-000-046 CONG STATUS=000
LSN=A1234567
Recovery
3.3.4 1003 - MTP rcvd invalid H0/H1 code
SS7 received a level 3 message with an unrecognized H0H1 code.
0100.1003 CARD 1205,B INFO MTP rcvd invalid H0/H1 code
SIO=0a OPC=003-235-000 DPC=000-024-000
H0H1=43
LSN=A1234567
Recovery
3.3.5 1004 - MTP rcvd unknown DPC
The EAGLE 5 ISS system received an MSU with a DPC that is not in the routing table.
0100.1004 CARD 1205,B INFO MTP rcvd unknown DPC
SIO=0a OPC=003-236-000 DPC=000-071-000
LSN=A1234567
Recovery
- If the EAGLE 5 ISS system should be able to route to
the DPC (indicated in the message output), add the DPC to the EAGLE 5 ISS
system routing table using the
ent-rteandent-dstncommands. - If the DPC is not one that the EAGLE 5 ISS system should be able to route to, no action is necessary.
3.3.6 1005 - GWS rcvd OPC that is not allowed
This message indicates the EAGLE 5 ISS received an MSU with an origination point code (OPC) that is not allowed in gateway screening (GWS).
0100.1005 CARD 1205,A INFO GWS rcvd OPC that is not allowed
SIO=b2 OPC=003-237-000 DPC=003-003-003
H0H1=32 AFTPC=03-03-03
SR=osp3 LSN=A1234567
Four outputs are possible. The Legend includes abbreviations found in all variations.
- ADDR
- Address
- AFTPC
- Affected point code (for SCCP messages)
- AFTSS
- Affected subsystem (identifies the subsystem that failed)
- AI
- Address Indicator
- CDPA
- Called party address
- CGPA
- Calling party address
- DATA
- Information from the upper layers of SCCP management
- DPC
- Destination point code
- H0H1
- H0/H1 heading code
- LSN
- Linkset name. The name must be unique.
- MULT
- SCCP management message multiplicity indicator
- OPC
- Origination point code
- PC
- Point code for the SS7 end user (OPC).
- SCCP MT
- SCCP message type
- SCMG
- SIO
- Service information octet
- SR
- Screening reference name
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
- SCCP management message type
Recovery
3.3.7 1006 - GWS rcvd DPC that is not allowed
This message indicates the EAGLE 5 ISS received an MSU with a destination point code (DPC) that is not allowed in gateway screening (GWS).
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 35.0.0
0100.1006 CARD 1205,A INFO GWS rcvd DPC that is not allowed
H0H1=23 AFTPC=03-03-03
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.8 1007 - GWS rcvd OPC That is Blocked
This message indicates the EAGLE 5 ISS received an MSU from an origination point code (OPC) that is blocked from this network by gateway screening (GWS).
0100.1007 CARD 1205,A INFO GWS rcvd OPC that is blocked
SIO=93 OPC=001-001-004 DPC=003-003-003
H0H1=31 AFTPC=03-03-03
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
- If this origination point code (OPC) should be
allowed to send messages through the network, use the command
dlt-scr-blkopcto delete the OPC from the blocked OPC screen set assigned to this link. - If this OPC should be blocked from entering this network, no further action is necessary.
3.3.9 1008 - GWS rcvd DPC that is blocked
This message indicates the EAGLE 5 ISS received an MSU from a destination point code (DPC) that is blocked from this network by gateway screening (GWS).
0100.1008 CARD 1205,A INFO GWS rcvd DPC that is blocked
SIO=b2 OPC=007-008-000 DPC=003-003-003
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
- If this destination point code (DPC) should be
dlt-scr-blkdpcto delete the DPC from the blocked DPC screen set assigned to this link. - If this DPC should be blocked from entering this network, no further action is necessary.
3.3.10 1009 - GWS rcvd SIO that is not allowed
This message indicates that gateway screening (GWS) has discarded an MSU that is not allowed in the network.
0100.1009 CARD 1205,B INFO GWS rcvd SIO that is not allowed
H0H1=33 AFTPC=03-03-03
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.11 1010 - GWS rcvd a priority that is not allowed
This message indicates gateway screening (GWS) has discarded an MSU because the priority is listed as one that is not allowed in this network.
0100.1010 CARD 1205,A INFO GWS rcvd a priority that is not allowed
SIO=0a OPC=003-242-000 DPC=000-071-000
H0H1=54 AFTPC=03-03-03
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H11
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.12 1011 - GWS rcvd TFC, AFTPC not in routing tbl
This indicates that a transfer controlled message was received by a gateway link and failed screening because of an affected point code value in the message.
0100.1011 CARD 1105,B INFO GWS rcvd TFC, AFTPC not in routing tbl SIO=0a OPC=003-243-000 DPC=000-024-000
H0H1=35 AFTPC=099-099-003
Recovery
- Verify the affected point code in the message, and verify whether the affected point code is required to be in the EAGLE 5 ISS routing tables.
- If the affected point code is not required to be in the EAGLE 5 ISS routing tables, no further action is necessary.
- If the affected point code is required to be in the
EAGLE 5 ISS routing table, use the
ent-dstncommand to add the affected point code to the EAGLE 5 ISS routing tables.
3.3.13 1012 - GWS rcvd Clg Party That is Not Allowed
This indicates an MSU was received on a gateway link but failed screening because of the SCCP calling party address.
RLGHNCXA21W 00-04-18 18:59:23 EST EAGLE 31.3.0
0101.1012 CARD 1205,B1 INFO GWS rcvd Clg Party that is not allowed SIO=0a OPC=003-244-000 DPC=000-071-000
SCCP MT= 18
CDPA: AI=10 PC=003-003-003 SSN=005 TT=250
ADDR=ABCDEF1234567890ABCDE
CGPA: AI=10 PC=004-004-004 SSN=005 TT=251
SR=scrb LSN=A1234567
RLGHNCXA21W 00-04-18 18:59:30 EST EAGLE 31.3.0
0102.1012 CARD 1205,B1 INFO GWS rcvd Clg Party that is not allowed SIO=03 OPC=003-245-000 DPC=001-004-000
SCMG: TYPE=000 AFTPC=003-003-003
MULT=000 AFTSS=005
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.14 1013 - GWS rcvd Cld Party that is not allowed
This indicates an MSU was received on a gateway link but failed screening because of the called party value in the SCCP called party address field.
Example
RLGHNCXA21W 00-04-18 18:59:30 EST EAGLE 35.0.0
0102.1013 CARD 1205,B INFO GWS rcvd Cld Party that is not allowed
MULT=000 AFTSS=005
Report Date:06-09-13 Time:00:13:22
0185.1005 CARD 1101,A2 INFO GWS rcvd OPC that is not allowed
SIO=03 OPC=007-021-067 DPC=005-022-019
SCCP MT=018
CDPA: AI=05 PC=005-006-007 SSN=006 TT=007
ADDR=0
CGPA: AI=14 PC=015-016-017 SSN=022 TT=023
ADDR=9194603655
SR=scr1 LSN=ABCD123
Report Date:02-07-21 Time:16:20:19
- AFTPC
- AFTSS
- DPC
- LSN
- MULT
- OPC
- SCMG
- SIO
- SR
- TYPE
Recovery
3.3.15 1014 - GWS rcvd Translation Type not allowed
This indicates an MSU requiring global title was received on a gateway link but failed screening because of the translation type indicated in the message.
0101.1014 CARD 1205,B INFO GWS rcvd Translation Type not allowed
SCCP MT= 18
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DPC
- LSN
- OPC
- PC
- SCCP MT
- SCCP message type
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.16 1015 - GWS rcvd SCMG with not allowed AFTPC
This message indicates that an SCCP management message (SCMG) was received on a gateway link and failed gateway screening because of the affected point code.
0102.1015 CARD 1205,B INFO GWS rcvd Cld Party that is not allowed
MULT=000 AFTSS=005
- AFTPC
- AFTSS
- DPC
- LSN
- MULT
- OPC
- SCMG
- SIO
- SR
- TYPE
Recovery
3.3.17 1016 - MTP Adj PC not in routing table
This message indicates that an MSU was received with an adjacent point code not found in the EAGLE 5 ISS routing table.
RLGHNCXA21W 00-11-18 19:12:00 EST EAGLE 35.0.0
0147.1016 CARD 1201,A INFO MTP Adj PC not in routing table
OPC=001-001-001 CPC=002-002-002
LSN=lsn01a
Recovery
3.3.18 1018 - REPT-MTPERR: MTP rcvd invalid SIO
A MSU is discarded when the EAGLE 5 ISS is unable to perform MTP-level routing.
RLGHNCXA21W 00-04-18 19:09:14 EST EAGLE 31.3.0
0140.1018 CARD 1201,A INFOREPT-MTPERR: MTP rcvd invalid SIO
SIO=07 OPC=001-001-001 DPC=002-002-002
LSN=A1234567
Recovery
3.3.19 1019 - SCCP rcvd invalid UDTS/XUDTS msg
SCCP received a user data service (UDTS)/extended user data service (XUDTS) message from the network that was discarded because of an invalid message type indicator.
RLGHNCXA21W 00-04-18 19:00:05 EST EAGLE 31.3.0
0106.1019 CARD 1103,A INFO SCCP rcvd invalid UDTS/XUDTS msg
SIO=03 OPC=003-251-000 DPC=001-004-000
CDPA: SSN=005 TT=250
CGPA: SSN=000 TT=000
RETURN CAUSE=001
DATA=26 80 03 09 0e 06 09 00 fe 08 50 55 05
43 00 00 00 00 00
LSN=A1234567
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- return cause
- Identifies the reason for the returned message (for connectionless protocols)
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
This indicates that SCCP received a UDTS/XUDTS message that was discarded because the message type field contained a value invalid in the system.
- Message type
- Return cause
- Data
3.3.20 1020 - IARCDPN NPP Service is off
This message is issued when the IARCDPN NPP service is called for at run-time, but the service status is currently set to OFF instead of ON.
RLGHNCXA21W 09-07-21 16:20:19 EST EAGLE 41.1.0
0002.1020 CARD 1113 INFO IARCDPN NPP Service is off
Report Date:09-07-21 Time:16:20:19
Recovery
Use the chg-npp-serv command to change the service status to ON. Enter chg-npp-serv:srvn=iarcdpn:status=on.
3.3.21 1021 - IARCGPN NPP Service is off
This message is issued when the IARCGPN NPP service is called for at run-time, but the service status is currently set to OFF instead of ON.
0002.1021 CARD 1113 INFO IARCGPN NPP Service is off
Recovery
Use the chg-npp-serv command to change the service status to ON. Enter chg-npp-serv:srvn=iarcgpn:status=on.
3.3.22 1022 - System Meas. Limit Exceeded for LSONISMT
This UIM alarm is issued when the either of these limits is exceeded:
Maximum of 3000 LSONISMT measurements, or
Maximum of 100 ISUP message type measurements per linkset.
0140.1022 SYSTEM INFO System Meas. limit exceeded for LSONISMT
Recovery
3.3.23 1023 - SCCP rcvd unknown msg type
This UIM may indicate that the SCCP received a message from the network that was discarded because of an unknown message type indicator. The generation of this UIM does not necessarily mean that an MSU has been discarded, however. This UIM can indicate that some feature did not handle an MSU due to its package type. (For example, features such as PPSMS or MO SMS NP/NPP feature that do not handle some SCCP MSU types.) In this case, the feature issues this UIM and passes the MSU to GTT to process.
RLGHNCXA21W 00-04-18 19:01:09 EST EAGLE 31.3.0
0109.1023 CARD 1103,A INFO SCCP rcvd unknown msg type
SIO=0a OPC=003-255-000 DPC=000-024-000
43 00 00 00 00 00
LSN=A1234567
Recovery
No action is necessary.
3.3.24 1024 - SCCP rcvd inv msg length
The SCCP received a message from the network that was discarded because of an invalid message length.
RLGHNCXA21W 00-04-18 19:01:15 EST EAGLE 31.3.0
0110.1024 CARD 1103,A INFO SCCP rcvd inv msg length
SIO=0a OPC=004-000-000 DPC=000-071-000
43 00 00 00 00 00
LSN=A1234567
Recovery
The SCCP received a message that was discarded because the message length field contained an invalid field for the system.
3.3.25 1025 - SCCP rcvd inv msg class
The SCCP received a message from the network that was discarded because of an invalid message class.
RLGHNCXA21W 00-04-18 19:01:40 EST EAGLE 31.3.0
0111.1025 CARD 1103,A INFO SCCP rcvd inv msg class
SIO=0a OPC=004-001-000 DPC=000-071-000
CDPA SS=000 CDPA TT=000
CGPA SS=00 CGPA TT=000
CLASS=000 MSG TYPE=00
LSN=A1234567
Recovery
The SCCP received a message that was discarded because the message class field contained an invalid value for the system.
3.3.26 1026 - System Meas Limit exceeded for LSORIGNI
This gateway related data has exceeded its threshold for the accumulation interval.
RLGHNCXA21W 00-04-18 19:05:43 EST EAGLE 31.3.0
0128.1026 CARD 1105 INFO System Meas Limit exceeded for LSORGNIAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.27 1027 - System Meas Limit exceeded for LSDESTNI
0128.1027 CARD 1105 INFO System Meas Limit exceeded for LSDESTNIAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.28 1028 - System Meas. Limit exceeded for ORIGNI/NINC
0128.1028 CARD 1105 INFO System Meas. Limit exceeded for ORIGNI/NINCAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.29 1029 - SCCP rcvd inv Cld Party - bad GT ind
The SCCP received a message from the network that was discarded because of a bad global title indicator in the called party address.
RLGHNCXA21W 00-04-18 19:02:05 EST EAGLE 31.3.0
0112.1029 CARD 1103,A1 INFO SCCP rcvd inv Cld Party - bad GT ind
SIO=03 OPC=001-001-001 DPC=002-002-002
CDPA LENGTH=000 MSG TYPE=04
ADDR=12345678901234567890
DATA=3a e2 38 c7 04 56 04 72 e0 e8 30 e9
2e cf 01 00 d0 02 83 01 f2 25 aa 0b
84 09 01 00 11 0a 19 49
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- Called party address length
- CGPA
- DATA
- Hex dump of TCAP part of MSU
- DPC
- LSN
- MSG TYPE
- Message type
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
The SCCP received a message that was discarded because the global title field in the called party address was invalid in the EAGLE 5 ISS.
3.3.30 1030 - Inh EIR SS request already outstanding
An
inh-map-ss command is already entered
and queued.
For more information about the
inh-map-ss
command, refer to the
Commands Manual.
RLGHNCXA21W 03-08-18 19:09:14 EST EAGLE 31.3.0
0140.1030 CARD 1201 INFO Inh EIR SS request already outstanding
Recovery
3.3.31 1031 - Failure Inhibiting EIR SS
The
inh-map-ss command was unsuccessful in
taking the EIR subsystem off-line. For more information about the
inh-map-ss command, refer to the
Commands Manual.
0140.1031 CARD 1201 INFO Failure Inhibiting EIR SS
Recovery
Enter the
inh-map-ss command specifying the
force=yes parameter.
3.3.32 1032 - Set ETS Mismatch
There is a discontinuity between the ETS broadcast and what the card expects. A discontinuity can occur when both OAM cards are booted at the same time and ETS gets reset to zero.
0140.1032 CARD 1201 INFO Set ETS Mismatch
Recovery
The affected LIM/ATM/STC card recalibrates to the new ETS value and should continue to operate correctly.
If not, this is a reference point for possible invalid timestamps to Sentinel.
3.3.33 1033 - SCCP rcvd inv Cld Party - bad network
The SCCP received a message from the network that it could not route and was discarded because of an invalid network indicator in the called party address.
RLGHNCXA21W 00-04-18 19:02:12 EST EAGLE 31.3.0
0113.1033 CARD 1103,A1 INFO SCCP rcvd inv Cld Party - bad network
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- CGPA
- DPC
- LSN
- MSG TYPE
- Message type
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
This indicates that SCCP discarded a message because the network indicator (national or international) provided in the called party address is invalid in the EAGLE 5 ISS.
3.3.34 1034 - SCCP rcvd inv Cld Party - no SSN
The SCCP received a message from the network that it could not route and was discarded because no subsystem number was present in the called party address.
RLGHNCXA21W 00-04-18 19:02:41 EST EAGLE 31.3.0
0114.1034 CARD 1201,A INFO SCCP rcvd inv Cld Party - no SSN
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- CGPA
- DPC
- LSN
- MSG TYPE
- Message type
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
The sender of the discarded message is using an invalid message format.
If there is only one occurrence, no action is necessary. However, if the condition continues, there may be a problem at the node that is sending the invalid message. Contact that node and inform them of the problem.
3.3.35 1035 - SCCP rsp did not route - invalid GTI
This message indicates the SCCP response did not route because of an invalid GTI in the calling party of the query.
Example
RLGHNCXA21W 02-07-21 16:20:19 EST EAGLE 37.5.0
0018.1035 CARD 1103,A INFO SCCP rsp did not route - invalid GTI
SCCP MSG TYPE=04
CDPA: NI=1 RI=0 GTI=04 SSNI=0 PCI=1
TT=250 NP=04 NAI=010 ADDR=123456789012345678901
CGPA: NI=1 RI=0 GTI=04 SSNI=0 PCI=1
TT=100 NP=07 NAI=012 ADDR=012345678901234567890
PC=001-001-001 SSN=004
LSN=ABCD123 GTTSET=3 203 46
Report Date:02-07-21 Time:16:20:19This alternate output includes the redirected destination and is
used when a redirected MSU encounters an error.
SCCP MSG TYPE=04
GTT on CdPA used MOSMSGTA=9193802053
- ADDR
- Address
- CDPA
- CGPA
- GTI
- Global title indicator
- LSN
- MSG TYPE
- Message type
- NAI
- Nature of address indicator
- NI
- Network indicator value
- NP
- Numbering plan
- OPC
- PC
- PCI
- Protocol control information
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- Subsystem number indicator
- TT
- Translation type
Recovery
Change the message to include a valid GTI in the CGPA part of the query.
Specify GTI=2 for ANSI, and specify GTI=2 or GTI=4, as appropriate for ITU.
3.3.36 1036 - SCCP rsp did not route - invalid TT
This message indicates the SCCP response did not route because of an invalid TT in the calling party of the query.
Example
0018.1036 CARD 1103,A INFO SCCP rsp did not route - invalid TT
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Provision the CGPA TT in the GTT TT table using the
ent-tt command.
3.3.37 1037 - SCCP rsp did not route - bad Xlation
This message indicates the SCCP response did not route because of an invalid translation in the calling party of the query.
Example
0018.1037 CARD 1103,A INFO SCCP rsp did not route - bad Xlation
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Provision the CGPA GTA address in the GTT database using
the
ent-gtt command.
3.3.38 1038 - SCCP rsp did not route -SSP not True PC
This message indicates the SCCP response did not route because the SSP (OPC or CGPA Point Code) is not the True Point Code.
Example
0018.1038 CARD 1103,A INFO SCCP rsp did not route -SSP not True PC
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
The True Point Code is the primary PC of the route, not an ALIAS PC.3.3.39 1039 - SCCP rsp did not route - bad Selectors
This message indicates the SCCP response did not route because of invalid selectors (e.g., GTI, TT, NP, NAI) in the calling party of the query.
Example
0018.1039 CARD 1103,A INFO SCCP rsp did not route - bad Selectors
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Provision the CGPAGTI, TT, NP, and NAI in the EGTT
selector table using the commands
ent-gttsel (to assign global title
selectors to a GTT set for EGTT) and
ent-gttset (to specify the attributes
for a new GTT set).
3.3.40 1040 - ITU <-> ANSI translation not supported
This message indicates an invalid translation PC type in attempting to cross the ANSI to ITU domain.
Example
0018.1040 CARD 1103,A INFO ITU <-> ANSI translation not supported
TRANSLATED PC=003-003-003 TRANSLATED SS=005
LSN=ABCD123 GTTSET=3 (8)
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TRANSLATED PC
- Translated point code
- TRANSLATED SS
- Translated subsystem
- TT
- Translation type
Recovery
Change the translation PC type to not cross the domain (ANSI <-> ITU), by using the appropriate GTT/GTA commands.
Refer to the EPAP Administration Manual.
3.3.41 1041 - SCCP did not route -no SSN in msg or DB
This message indicates the SCCP message did not route because the SSN was not found in the message or translation data.
Example
0018.1041 CARD 1103,A INFO SCCP did not route -no SSN in msg or DB
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Change the message to include the CDPASSN in the message or provision the SSN in the translation table.
You can change the translation table by using the
appropriate GTT (ent-gtt or
ent-gta) or the EPAP commands.
Refer to the Commands Manual or the EPAP Administration Manual, respectively for details.
3.3.42 1042 - SCCP rcvd inv GT - bad Translation Type
The SCCP received a message from the network requiring global title translation but the message was discarded because the system did not recognize the translation type.
Example
0018.1042 CARD 1103,A INFO SCCP rcvd inv GT - bad Translation Type
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- CGPA
- DATA
- DPC
- LSN
- MSG TYPE
- Message type
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.43 1043 - SCCP did not route - bad translation
The SCCP did not route a message because it could not translate the global title. The message was discarded.
Example
0241.1043 CARD 1101,A1 INFO SCCP did not route - bad translation
SIO=03 OPC=1-200-2 DPC=3-054-4
CDPA LENGTH=019 MSG TYPE=04
CDPA: AI=05 PC=1-050-1 SSN=006 TT=007
ADDR=ABCDEF0123456789ABCDE
LSN=ABCD123
LSN=ABCD123
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- CGPA
- DPC
- LSN
- MSG TYPE
- Message type
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
The SCCP received a message with a global title translation it could not interpret.
The message was discarded. Check translations on the originating switch to determine the trouble.
3.3.44 1044 - SCCP did not route - DPC OOS
The SCCP did not route a message because the destination point code (DPC) was out-of-service (OOS). The message was discarded.
Example
0246.1044 CARD 1101,A1 INFO SCCP did not route - DPC OOS
OPC=1-200-2
TRANSLATED PC=5-038-6 TRANSLATED SS=202
LSN=ABCD123
OPC=1-200-2
LSN=ABCD123
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- CGPA
- DATA
- DPC
- LSN
- MSG TYPE
- Message type
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.45 1045 - SCCP did not route - DPC congested
The SCCP did not route a message because the destination point code (DPC) was congested. The message was discarded.
Example
0246.1045 CARD 1101,A1 INFO SCCP did not route - DPC congested
OPC=1-200-2
LSN=ABCD123
OPC=1-200-2
LSN=ABCD123
Recovery
A transfer controlled (TFC) should have been received on the link to indicate congestion to this node. When the congestion status changes, the congestion status indicator in the flow control messages indicates what message type priorities can be transmitted to the distant node. If the condition persists, follow normal company procedures in dealing with congestion at distant nodes.
3.3.46 1046 - SCCP didn't route - PC/SSN not in MAP tbl
SCCP did not route a message because the destination point code was not in the mated application (MAP) table. The message was discarded.
Example
0018.1046 CARD 1103,A INFO SCCP didn't route - PC/SSN not in MAP tbl
0018.1046 CARD 1103,A INFO SCCP did not route - DPC not in MAP tbl
Recovery
- If the DPC indicated in the message should not be routed to, no further action is necessary.
- If the DPC should be routed to from the EAGLE 5 ISS,
use the
ent-mapcommand to enter the DPC into the mated application (MAP) table.
3.3.47 1047 - SCCP did not route - SS OOS
The SCCP did not route a message because the destination subsystem (SSN) was Out-of -Service. The message was discarded.
Example
0246.1047 CARD 1101,A1 INFO SCCP did not route - SS OOS
OPC=1-200-2
LSN=ABCD123
OPC=1-200-2
LSN=ABCD123
Recovery
This indicates that an SCCP was discarded because the DPC SSN to which it was addressed to is out-of-service (OOS).
Contact the distant end node that this message refers to and verify that action is being taken to bring the SCCP back into service.
3.3.48 1048 - SCCP did not Route - SS Congested
The SCCP did not route a message because the subsystem was congested. The message was discarded.
Example
0246.1048 CARD 1101,A1 INFO SCCP did not route - SS congested
OPC=1-200-2
LSN=ABCD123
OPC=1-200-2
LSN=ABCD123
Recovery
An SCCP message was discarded due to congestion at a subsystem.
Maintenance personnel should monitor the network and verify the subsystems congestion status changes to zero (no congestion).
3.3.49 1049 - SCCP did not route - SS not in MAP tbl
The SCCP did not route a message because the destination subsystem was not in the Mated Application (MAP) table. The message was discarded.
Example
0246.1049 CARD 1101,A1 INFO SCCP did not route - SS not in MAP tbl
OPC=1-200-2
LSN=ABCD123
OPC=1-200-2
LSN=ABCD123
Recovery
- If the subsystem indicated in the message is not a mated application to the EAGLE 5 ISS, no further action is necessary.
- If the SCCP message should have been routed, use the
ent-mapcommand to add the subsystem number to the mated application (MAP) table.
3.3.50 1050 - SCCP-CNV: Unable to convert ANSI CDPA GT
This message indicates that a SCCP MSU contained an undefined CDPA PC. The GTCNVDFLT STP Option is not enabled.
5054.1050 CARD 1105 INFO SCCP-CNV: Unable to convert ANSI CDPA GT
SIO=83 OPC= 001-011-001 DPC= 001-001-001
SCCP MSG TYPE=09 GTCNV:Cld ANSI->ITU fail
CDPA: NI=1 RI=0 GTI=02 SSNI=1 PCI=0
TT=000 NP=-- NAI=--- ADDR=101010
PC=-------------- SSN=024
CGPA: NI=1 RI=0 GTI=02 SSNI=1 PCI=0
TT=001 NP=-- NAI=--- ADDR=654321
PC=-------------- SSN=000
LSN=lsa1111 GTTSET=(2)
Report Date:09-01-05 Time:16:38:41
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG GYPE
- Message type
- optional text field
- Optional text field providing additional
information about the error. Possible text display and definitions may include:
- INV DMA LEN=xxx
- DMA Length too big or too small: After SCCP encoding of translated MSU DMA Length became too big or too small.
- UNSUP Clg GTI=x
- GTT attempted on Unsupported CgPA GTI=x
- UNSUP Cld GTI=x
- GTT attempted on Unsupported CdPA GTI=x
- INV Clg GTI=x
- GTT attempted on INV CgPA GTI=x
- INV Cld GTI=x
- GTT attempted on INV CdPA GTI=x
- GTCNV:Cld ANSI->ITU fail
- Invalid CdPA GTI for ANSI-to-ITU GTCNV table: ANSI MSU is GTT translated to ITU, CdPA GTA record has NGTI as not provisioned, so GTT is using Default GTT (GTCNV table) to convert CdPA, but CdPA GTCNV Selectors (GTI, TT) are not found in GTCNV table
- GTCNV:Clg ANSI->ITU fail
- Invalid CgPA GTI for ANSI-to-ITU GTCNV table: ANSI MSU is GTT translated to ITU, CgPA RI=GT, SCCP Conversion used Default GTT (GTCNV table) to convert CgPA, but CgPA GTCNV Selectors (GTI, TT) are not found in GTCNV table
- GTCNV:Cld ITU->ANSI fail
- Invalid CdPA GTI for ITU-to-ANSI GTCNV table: ITU MSU is GTT translated to ANSI, CdPA GTA record has NGTI as not provisioned, so GTT is using Default GTT (GTCNV table) to convert CdPA, but CdPA GTCNV Selectors (GTI, TT, possibly NP and NAI if GTI=4) are not found in GTCNV table
- GTCNV:Clg ITU->ANSI fail
- Invalid CgPA GTI for ITU-to-ANSI GTCNV table: ITU MSU is GTT translated to ANSI, CgPA RI=GT, SCCP Conversion used Default GTT (GTCNV table) to convert CgPA, but CgPA GTCNV Selectors (GTI, TT, possibly NP and NAI if GTI=4) are not found in GTCNV table
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
- Enable the GTCNVDFLTSTP Option, which would cause a
default GT conversion to occur.
Refer to the Database Administration Manual - Global Title Translation for details.
- Add the proper ANSI to ITU entry (matching TT) into
the Default GT Conversion Table.
- Add a wildcard ANSI to ITU entry into the Default GT
Conversion Table.
3.3.51 1051 - SCCP-CNV: Unable to convert ANSI CGPA GT
This message indicates that a SCCP MSU contained an undefined CGPA PC. The GTCNVDFLT STP Option is not enabled.
tekelecstp 09-01-05 16:41:51 EDT RAGLE 41.0
5058.1051 CARD 1105 INFO SCCP-CNV: Unable to convert ANSI CGPA GT
SCCP MSG TYPE=09 GTCNV:Clg ANSI->ITU fail
Report Date:09-01-05 Time:16:41:51
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- INV DMA LEN=xxx
- UNSUP Clg GTI=x
- UNSUP Cld GTI=x
- INV Clg GTI=x
- INV Cld GTI=x
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TRANSLATED PC
- TRANSLATED SS
- TT
- Translation type
Recovery
OR
OR
Conversion Table.
3.3.52 1052 - SCCP-CNV: Unable to convert ITU CDPA GT
tekelecstp 09-01-05 16:22:30 EDT EAGLE 41.0
5038.1052 CARD 1105 INFO SCCP-CNV: Unable to convert ITU CDPA GT
SIO=b3 OPC= 2-011-1 DPC= 1-001-1
SCCP MSG TYPE=09 GTCNV:Cld ITU->ANSI fail
CDPA: NI=0 RI=0 GTI=02 SSNI=0 PCI=1
TT=000 NP=-- NAI=--- ADDR=111111
PC= 1-001-1 SSN=---
CGPA: NI=0 RI=0 GTI=02 SSNI=0 PCI=1
TT=000 NP=-- NAI=--- ADDR=654321
PC= 2-011-1 SSN=---
LSN=lsn2111 GTTSET=(1)
Report Date:09-01-05 Time:16:22:30
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- INV DMA LEN=xxx
- UNSUP Clg GTI=x
- UNSUP Cld GTI=x
- INV Clg GTI=x
- INV Cld GTI=x
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
- Enable the GTCNVDFLT STP Option, which would cause a
OR
- Add the proper ANSI to ITU entry (matching NP/NAI/TT)
into the Default GT Conversion Table.
OR
- Add a wildcard ITU to ANSI entry into the Default GT
Conversion Table.
3.3.53 1053 - SCCP-CNV: Unable to convert ITU CGPA GT
tekelecstp 08-12-26 15:17:59 EDT EAGLE 41.0
5007.1053 CARD 1105 INFO SCCP-CNV: Unable to convert ITU CGPA GT
SIO=83 OPC= 2-011-1 DPC= 1-001-1
SCCP MSG TYPE=09 INV Clg GTI=1
CDPA: NI=0 RI=0 GTI=02 SSNI=1 PCI=0
TT=000 NP=-- NAI=--- ADDR=123456
PC=-------------- SSN=008
CGPA: NI=0 RI=0 GTI=01 SSNI=1 PCI=1
TT=--- NP=-- NAI=000 ADDR=000000000000000000000
PC= 2-011-1 SSN=008
Report Date:08-12-26 Time:15:17:59
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- INV DMA LEN=xxx
- UNSUP Clg GTI=x
- UNSUP Cld GTI=x
- INV Clg GTI=x
- INV Cld GTI=x
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
OR
OR
Conversion Table.
3.3.54 1054 - SCCP rcvd inv LSS - bad SSN
The SCCP received a message destined to a local subsystem that was discarded because of a bad subsystem number (SSN).
Example
0241.1054 CARD 1101,A1 INFO SCCP rcvd inv LSS - bad SSN
LSN=ABCD123
LSN=ABCD123
- ADDR
- Address
- CDPA
- CGPA
- gti
- LSN
- msg type
- Message type
- nai
- ni
- np
- Numbering plan
- OPC
- PC
- pci
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- ssni
- TT
- Translation type
Recovery
The EAGLE 5 ISS supports only one subsystem.
All other local subsystem numbers are invalid. Check translations on the originating switch to determine the problem.
3.3.55 1055 - SCCP rcvd inv SCMG - bad AFTPC
SCCP received an SCCP management message (SCMG) that was discarded because of a bad affected point code (AFTPC). The point code does not appear in the EAGLE 5 ISS routing tables.
RLGHNCXA21W 00-04-18 19:04:15 EST EAGLE 31.3.0
0124.1055 CARD 1106 INFO SCCP rcvd inv SCMG - bad AFTPC
SIO=0a OPC=004-031-000 DPC=000-071-000
SCMG: MSG TYPE=000 MSG LEN=003
AFTPC=004-219-000 AFTSS=000 MULT=000
LSN=A1234567
- AFTPC
- AFTSS
- DPC
- LSN
- MSG LEN
- Message length
- MSG TYPE
- Message type
- MULT
- OPC
- SCMG
- SIO
Recovery
3.3.56 1056 - SCCP rcvd inv SCMG - bad subsystem
SCCP received an SCCP management message (SCMG) that was discarded because of an invalid subsystem.
0124.1056 CARD 1106 INFO SCCP rcvd inv SCMG - bad subsystem
LSN=A1234567
- AFTPC
- AFTSS
- DPC
- LSN
- MSG LEN
- Message length
- MSG TYPE
- Message type
- MULT
- OPC
- SCMG
- SIO
Recovery
- Verify the point code in the message, and verify the subsystem number as a valid SSN for the network.
- Add the subsystem number to the EAGLE 5 ISS map
tables using the
ent-mapcommand.
3.3.57 1057 - SCCP rcvd inv SCMG - bad length
SCCP received an SCCP management message (SCMG) that was discarded because of an invalid length indicator.
SCCP received an SCCP/Subsystem congested (SSC) SCMG message (MSG TYPE=006) that was discarded because EAGLE does not support SSC procedures. However, for through switched SCMG, EAGLE handles SSC messages, and there should not be an issue.
0124.1057 CARD 1106 INFO SCCP rcvd inv SCMG - bad length
LSN=A1234567
- AFTPC
- AFTSS
- DPC
- LSN
- MSG LEN
- Message length
- MSG TYPE
- Message type
- MULT
- OPC
- SCMG
- SIO
Recovery
This message indicates an SCCP message was discarded due to an invalid length indicator.
3.3.58 1058 - SCCP rcvd inv SCMG - bad msg type
SCCP received an SCCP management message (SCMG) that was discarded because of an invalid message type.
RLGHNCXA21W 00-04-18 19:05:37 EST EAGLE 31.3.0
0128.1058 CARD 1106 INFO SCCP rcvd inv SCMG - bad msg type
SIO=0a OPC=004-034-000 DPC=000-000-000
LSN=A1234567
- AFTPC
- AFTSS
- DPC
- LSN
- MSG LEN
- Message length
- MSG TYPE
- Message type
- MULT
- OPC
- SCMG
- SIO
Recovery
This indicates an SCCP message was discarded due to an invalid message type.
3.3.59 1059 - Telnet terminal connection disconnected
Indicates that an established telnet connection on the EAGLE has disconnected.
RLGHNCXA21W 02-08-08 20:52:04 EST EAGLE 39.0
5024.1059 CARD 1105 INFO Telnet terminal disconnected.
REASON=Remote End Unreachable
RIPADDR=192.168.57.52
RIPORT=2336
LIPADDR=192.168.53.46
LIPORT=23
Report Date:02-08-08 Time:20:52:04
Recovery
No action necessary.
3.3.60 1060 - Map Screening cannot generate ATIER
This message is generated because the MSU passed the SCCP conversion before the MAP screening and is of a different domain than the OPC of the inbound MSU. Therefore, the MSU is discarded and the Any Time Interrogation error (ATIER) is not generated.
RLGHNCXA21W 00-11-18 18:59:23 EST EAGLE 35.0.0
0018.1060 CARD 1103 INFO Map Screening cannot generate ATIER
OPC=001-001-001
Op-Code=61 Forbidden Param=N/A Action=Discard
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- OP-CODE
- Operation Code
- PARAM
- Parameter
- PC
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
The MSU indicated in the message was discarded.
3.3.61 1061 - Meas Sync Not Allowed From Old Version
This UIM is generated when the secondary MCP receives measurements data from a primary MCP that is running an older version of the software. This message indicates that measurements data was discarded by the secondary MCP due to the version mismatch. This problem occurs during a system upgrade to a new release.
RLGHNCXA21W 00-04-18 19:09:14 EST EAGLE 31.4.0
0140.1061 CARD 1201 INFO Meas sync not allowed from old version
Recovery
This UIM should only occur during an upgrade.
Complete the upgrade per approved procedure.
3.3.62 1062 - String Data Dump
A screen set was created with too many rows.
12345678901234567890123456789012345678901234567890123456789012345678901234567890
9912.1062 CARD 1113 INFO a50 too large
Report Date:14-08-01 Time:13:32:14Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.63 1063 - SCCP Screen Set is Too Large
The screen set is too large to fit on a LIM or SCCP card and has failed loading.
5946.1063 CARD 1113 INFO SCCP screen set is too large
Report Date:14-08-02 Time:17:01:45
Recovery
3.3.64 1064 - GWS rcvd TFP, AFTPC not in routing tbl
The EAGLE 5 ISS has received a transfer controlled (TCP) for an affected point code (AFTPC) which does not appear in the EAGLE 5 ISS routing tables. The message was discarded by Gateway Screening (GWS).
RLGHNCXA21W 00-04-18 19:05:52 EST EAGLE 31.3.0
0129.1064 CARD 1105,A INFO GWS rcvd TFP, AFTPC not in routing tbl SIO=b0 OPC=004-040-000 DPC=000-001-000
H0H1=41 AFTPC=099-099-003
Recovery
3.3.65 1065 - GWS rcvd TFR, AFTPC not in Routing tbl
The EAGLE has received a transfer restricted (TFR) for an affected point code (AFTPC) which does not appear in the EAGLE routing tables. The message was discarded by gateway screening (GWS).
RLGHNCXA21W 00-04-18 19:05:57 EST EAGLE 31.3.0
0130.1065 CARD 1201,A INFO GWS rcvd TFR, AFTPC not in routing tbl
SIO=b0 OPC=004-041-000 DPC=001-000-000
H0H1=43 AFTPC=099-099-003
Recovery
3.3.66 1066 - GWS rcvd TFA, AFTPC not in routing tbl
The EAGLE 5 ISS has received a transfer allowed (TFA) for an affected point code (AFTPC) that does not appear in the EAGLE 5 ISS routing tables. The message was discarded by the gateway screening (GWS) feature.
RLGHNCXA21W 00-04-18 19:06:35 EST EAGLE 31.3.0
0131.1066 CARD 1201,A INFO GWS rcvd TFA, AFTPC not in routing tbl
SIO=b0 OPC=004-042-000 DPC=002-000-000
H0H1=45 AFTPC=099-099-003
Legend
- AFTPC
- DPC
- H0H1
- LSN
- OPC
- SIO
- SR
Recovery
3.3.67 1067 - GWS rcvd UPU, AFTPC not in routing tbl
The EAGLE 5 ISS has received a user part unavailable (UPU) for an affected point code (AFTPC) which does not appear in the EAGLE 5 ISS routing tables. The message was discarded by gateway screening (GWS).
RLGHNCXA21W 00-04-18 19:06:42 EST EAGLE 31.3.0
0132.1067 CARD 1201,A INFO GWS rcvd UPU, AFTPC not in routing tblSIO=90 OPC=004-043-000 DPC=002-000-000
H0H1=A1 AFTPC=099-099-003
Recovery
3.3.68 1068 - GWS rcvd RSP, AFTPC not in Routing tbl
The EAGLE 5 ISS has received a signaling route set test prohibited message (RSP) for an affected point code (AFTPC) which does not appear in the EAGLE 5 ISS routing tables. The message was discarded by gateway screening (GWS).
RLGHNCXA21W 00-04-18 19:06:48 EST EAGLE 31.3.0
0133.1068 CARD 1201,A INFO GWS rcvd RSP, AFTPC not in routing tbl SIO=b0 OPC=004-044-000 DPC=008-010-000
H0H1=51 AFTPC=099-099-003
Recovery
3.3.69 1069 - GWS rcvd RSR, AFTPC not in routing table
The EAGLE 5 ISS has received a signaling route test set restricted (RSR) for an affected point code (AFTPC) which does not appear in the EAGLE 5 ISS routing tables. The message was discarded by gateway screening (GWS).
RLGHNCXA21W 00-04-18 19:07:27 EST EAGLE 31.3.0
0134.1069 CARD 1201,A INFO GWS rcvd RSR with AFTPC not in routing tbl
SIO=b0 OPC=004-045-004 DPC=002-072-002
H0H1=52 AFTPC=099-099-003
Recovery
3.3.70 1070 - SLTC failure: invalid Point Code (OPC)
The signaling link test control has reported an invalid point code in the signaling link test message (SLTM) received from the far end. The point code for the adjacent signaling point does not match the point code in the adjacent point code field in the linkset table.
RLGHNCXA21W 00-04-18 19:08:05 EST EAGLE 31.3.0
0135.1070 CARD 1201,A INFO SLTC failure: invalid Point Code (OPC)SIO=0a OPC=003-236-000 DPC=000-071-000
LSN=A1234567
Recovery
3.3.71 1071 - SLTC failure: invalid SLC
The signaling link test control has reported an invalid signaling link code (SLC) in the signaling link test message (SLTM) received from the far end.
RLGHNCXA21W 00-04-18 19:08:13 EST EAGLE 31.3.0
0136.1071 CARD 1201,A INFO SLTC failure: invalid SLC
ADJ PC=004-046-000 SLC=02 LEN=0f
DATA= 01 02 03 04 05 06 07 08 09 11 12 13 14 15
Recovery
Contact the far-end to make sure both ends have provisioned the same SLC for the signaling link.
3.3.72 1072 - SLTC failure: no response
The signaling link test control has reported “No Response” received for a signaling link test message (SLTM) sent to the far end.
tekelecstp 13-07-11 06:06:31 EST EAGLE5 44.0.4-64.34.24
5757.1072 CARD 4205,B1 INFO SLTC failure: no responseAlarm Level: No alarm condition. The message is informational only.
Recovery
Contact the far-end to find out why there is no response to the SLTM.
3.3.73 1073 - SLTC failure: bad data pattern
The signaling link test control has detected an invalid data pattern in the signaling link test message (SLTM) received from the far end.
RLGHNCXA21W 00-04-18 19:08:28 EST EAGLE 31.3.0
0138.1073 CARD 1201,A INFO SLTC failure:bad data pattern
Recovery
Contact the far-end and use your company procedures to test the facilities for the signaling link.
3.3.74 1074 – MSU Arrived on Wrong SM Card
SCCP MSU ended up on an Service Module card, which does not contain the needed RIDB/RTDB table (ELAP, DN, or IMSI).
Format
“MSU for xxxx needs ExAP yyyy data”
where xxxx = Service Name (LNP, INPQ, INPMR, VFLEX, IDPR, IAR, APORT, GPORT, TATI, ATINPQ, SMSMR, GFLEX, EIR), ExAP = ELAP/EPAP, and Yyyy = IMSI/DN
0226.1074 CARD 1101,A1 INFO MSU for INPMR needs EPAP DN data
SIO=05 OPC=1-200-2 DPC=3-054-4
CDPA: AI=05 SSN=006 TT=007
CGPA: AI=14 PC=2-054-2 SSN=022
DATA=3a e2 38 c7 04 e7 04 35 ae e8 30 e9
LSN=ABCD123
Report Date:02-07-21 Time:16:20:19Alarm Level: No alarm condition. The message is only informational and MSU will be discarded.
Recovery: Make sure that the EAGLE has the SM card available for the service for which UIM is generated.
3.3.75 1075 - MTP: Link Bypassed SLT Phase
The link has aligned and may be brought into service without a successful signaling link test (SLT).
0140.1075 CARD 1201,A INFO MTP: link bypassed SLT phase
Recovery
3.3.76 1076 - SLTC Failure: Invalid Point Code (DPC)
The signaling link test control (SLTC) has detected an invalid data pattern in the signaling link test message (SLTM) received from the adjacent point code.
RLGHNCXA21W 00-04-18 19:09:22 EST EAGLE 31.3.0
0141.1076 CARD 1201,A INFO SLTC failure:invalid Point Code (DPC)
Recovery
Contact the far-end and use local procedures to test the facilities for the signaling link.
3.3.77 1077 - GTT Action TCAP ERROR DISCARDED MSU
This UIM indicates that the TCAP Error Action executed and UIMREQD is ON.
- When this GTT Action (DISC, UDTS or TCERR) is provisioned as the main GTT Action for the translation (GTA)
- When this GTT Action (DISC, UDTS or TCERR) is provisioned as the default action (ENT/CHG-GTTACT:DEFACTID) for some other GTT Action (FWD, DUP, SFTHROT or SCPVAL) that is provisioned for the translation (GTA), and this default action is executed when the main GTT Action fails.
When these DISCARD Actions are executed as main GTT Action for the translation, the output will look like the following example:
6053.1077 CARD 1101 INFO GTT Action TCAP ERROR DISCARDED MSU
OPC= 1-001-4 DPC= 1-001-5
CDPA: NI=0 RI=0 GTI=02 SSNI=1 PCI=1
TT=010 NP=-- NAI=--- ADDR=9818316478
PC= 1-001-1 SSN=016
CGPA: NI=0 RI=0 GTI=02 SSNI=1 PCI=1
TT=011 NP=-- NAI=--- ADDR=9910929095
PC= 1-002-3 SSN=049
Op-Code=--- Action Set=tcapset
Report Date:03-01-03 Time:16:45:01
When these DISCARD Actions are executed as the "failure outcome" of the main GTT Action for the translation, this UIM generates an additional line displaying the cause of that main GTT Action failing:
tekelecstp 15-12-08 13:55:11 MST EAGLE5 46.3.0.0.0-66.18.1
Cause: SMRPOA-CGPA Digits Mismatch
PC= 1-001-1 SSN=016
PC= 1-002-3 SSN=049
Report Date:15-12-08 Time:13:55:11
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- OP-CODE
- Operation Code
- PARAM
- Parameter
- PC
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery:
3.3.78 1078 - GTT Action Duplicate Failed
This UIM indicates that the EAGLE 5 ISS failed to route or prepare Duplicate MSU for the reason indicated in the UIM.
6618.1078 CARD 1105 INFO GTT Action DUPLICATE FAILED
OPC= 1-001-4 DPC= 001-001-002
TT=200 NP=-- NAI=--- ADDR=123456
PC=-------------- SSN=005
TT=010 NP=-- NAI=--- ADDR=234567
PC=-------------- SSN=---
Op-Code=--- Action Set=aset1
Cause=CLG PC Conv fail
Report Date:03-04-27 Time:07:42:09
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- OP-CODE
- Operation Code
- PARAM
- Parameter
- PC
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery:
Table 3-7 Error Recovery
| Cause | Recovery |
| CDPA GTMOD Failure |
CdPA GT Modification failed resulting in Forward action failure. Correct the GT Modification data in CDGTMODID associated with the GTT Action. |
| CGPA GTMOD Failure |
CgPA GT Modification failed resulting in Forward action failure. Correct the GT Modification data in CGGTMODID associated with the GTT Action. |
| Encoding Failure |
Encoding of forward MSU failed resulting in Forward action failure. The True PC for the DPC or EAGLE for destination Network must be configured AND/OR The SCCP data (GTI/SSN) must be corrected such that the message length does not exceed the Maximum MSU length limit. |
| MAP Lookup Failure |
Error in MAP load sharing caused Forward action failure. Configure the DPC/SSN displayed in UIM within the MAPSETID associated with GTT Action. OR Configure correct MAP SETID (which contains the DPC/SSN displayed in UIM) in GTT Action entry. |
| Routing Failure |
Error in routing the forward MSU caused Forward action failure. The route for DPC must be provisioned and at least one route to the DPC must be available. |
| DFLT GT Conv Failure |
Default GT conversion failed while creating Forward MSU. Provision correct Default GT Conversion data for successful network conversion of the MSU. |
| CLG PC Conv fail |
Error in conversion of Calling PC. Provision correct Conversion data for Calling PC for successful network conversion of the MSU. |
| Unknown Error |
Error in creating Forward MSU for any other reason. Correct the data associated with Forward GTT Action. |
3.3.79 1079 - GTT Action Forward Failed
This UIM indicates that the EAGLE 5 ISS failed to route or prepare Forward MSU for the reason indicated in the UIM.
6618.1079 CARD 1105 INFO GTT Action FORWARD FAILED
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- OP-CODE
- Operation Code
- PARAM
- Parameter
- PC
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery:
Table 3-8 Error Recovery
| Cause | Recovery |
| Encoding Failure |
| Routing Failure |
| CLG PC Conv fail |
| Unknown Error |
3.3.80 1080 - disk measurement status unreadable
The active MASP could not determine the measurement collection status so that the measurements task could perform routine polling and measurement collection. If the measurement collection status cannot be determined, the routine polling and measurement collection tasks cannot be performed.
RLGHNCXA21W 00-04-18 19:10:54 EST EAGLE 31.3.0
0145.1080 CARD 1116 INFO disk measurement status unreadable
Recovery
3.3.81 1081 - MTP: Changeback T5 Timeout
When a link changes back, the EAGLE 5 ISS sends up to six changeback declaration messages and starts the T4 timer. The EAGLE 5 ISS waits for a changeback acknowledgment message for each of these declarations. If the T4 timer expires before the EAGLE 5 ISS receives an acknowledgment message, the EAGLE 5 ISS sends the changeback declaration message again and starts the T5 timer. If the T5 timer expires before the EAGLE 5 ISS receives an acknowledgment message, this message is generated and the EAGLE 5 ISS restarts traffic on the link.
RLGHNCXA21W 00-04-18 19:11:03 EST EAGLE 31.3.0
0146.1081 CARD 1105, A INFO MTP: Changeback T5 timeout
Recovery
The system restarts traffic and no further action is necessary.
3.3.82 1082 - Amem single bit error report
This message indicates that an SCCP, GLSHC, SIP or S13 (DEIR) card encountered a single bit dynamic ram error. This message gives the user a record of single bit errors for the last 24 hours.
RLGHNCXA21W 14-05-18 19:12:00 EST EAGLE 46.0.0
0147.1082 CARD 1101 INFO Amem single bit error report
Any Errors : YES current hour-------v
24 Hour History : NNNYNN NNNNNN NNNNYN NYNNNYAlarm Level: No alarm condition. The message is informational only.
Recovery
There is no immediate action needed, but the message indicates that the error was encountered and corrected.
If many errors are reported then the card may be beginning to fail and should be targeted for replacement in the future.
3.3.83 1083 - REPT COND: system alive
This message is a periodic system message indicating that the system is alive.
RLGHNCXA21W 00-04-18 19:12:00 EST EAGLE 31.3.0
0147.1083 SYSTEM INFO REPT COND: system aliveAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.84 1084 - GWS MSU discarded by redirect function
This message indicates that an MSU has been discarded rather than redirected to the SCP as part of the Database Transport Access (DTA) feature.
0003.1084 CARD 1205,A INFO GWSMSU discarded by redirect function SIO=01 OPC=003-237-002 DPC=006-006-000
SR=scrb
LSN=A1234567
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TN
- Telephone number
- TYPE
Recovery
3.3.85 1085 - GWS MSU too large to be redirected
This message indicates that the system tried to encapsulate an MSU for redirection to an SCP (as part of the Database Transport Access feature).
The DTA feature encapsulates the entire data packet including level 2 MTP. Because the DTA feature requires approximately 24 octets, the original packet can contain a maximum of about 248 octets of “user data.” If the size of the data is larger, the MSU cannot be redirected and is routed to its original destination.
0003.1085 CARD 1205,A INFO GWSMSU too large to be redirected
SR=scrb
LSN=A1234567
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TN
- Telephone number
- TYPE
Recovery
3.3.86 1086 - LFS Test Aborted with OAM Switch Over
The link fault sectionalization (LFS) test aborted with OAM switch over.
RLGHNCXA21W 14-05-18 19:11:03 EST EAGLE 46.0.0
1111.1086 CARD 1115 LFS test terminated with OAM switch over
Recovery
3.3.87 1087 - MTP RSTRT rcvd Unexpected User Traffic
This message indicates the system encountered traffic during the MTP restart process.
0147.1087 CARD 1101 INFO MTP RSTRT rcvd unexpected user traffic
Report Date:00-03-30 Time: 16:27:19
Recovery
There is no immediate action needed, but the message indicates that the error was encountered.
3.3.88 1088 - REPT-MTP-RSTRT MTP Restart Started
This message indicates that a full MTP Restart has begun.
0147.1088 CARD 1101 INFO REPT-MTP-RSTRT MTP Restart started
Recovery
There is no immediate action needed, but the message indicates that MTP Restart has begun.
3.3.89 1089 - RCVRY-MTP-RSTRT MTP Restart Completed
This message indicates a full MTP Restart is complete.
0147.1089 CARD 1101 INFO RCVRY-MTP-RSTRT MTP Restart completed
Recovery
There is no immediate action needed, but the message indicates that MTP Restart is complete.
3.3.90 1090 - ITU GWY:CPC conversion failure
This message indicates a protocol conversion failure. There are three possible reasons for the conversion failure.
The point code was not in the database.
The appropriate point code type was unavailable. There is no true point code or alias point code that matches the CPC.
The database is corrupted. The master database and the card database must be synchronized.
station5 00-04-18 19:12:00 EST EAGLE 31.3.0
0010.1090 CARD 1205,B INFO ITU GWY: CPC conversion failure
SIO=0a OPC=3-236-1 DPC=1-014-2
CPC=3-095-6
LSN=A1234567890
Recovery
3.3.91 1091 - ITU GWY:OPC conversion failure
The point code is not in the database.
The appropriate point code type was unavailable. There is no true point code or alias point code that matches the OPC.
0010.1091 CARD 1205,B INFO ITU GWY: OPC conversion failure
LSN=A1234567890
Recovery
3.3.92 1092 - ITU GWY:HOH1 conversion failure
This message occurs when there is an ANSI message with no ITU equivalent. Table 3-9 shows the ANSI messages with no ITU equivalent.
Table 3-9 ANSI Messages with No ITU Equivalent
| Message | H0/H1 Code (Hex) |
| Transfer Restricted (TFR) when generated by an ITU National network | 43 |
| Transfer-Cluster Restricted (TCR) | 44 |
| Transfer-Cluster Allowed (TCA) | 46 |
| Transfer-Cluster Prohibit Signal (TCP) | 42 |
0010.1092 CARD 1205,B INFO ITU GWY: H0H1 conversion failure
SIO=08 OPC=003-235-001 DPC=006-006-000
H0H1=42
LSN=A1234567890
Recovery
3.3.93 1093 - ITU GWY:rcvd msg type cannot convert
This message indicates the STP received a message type that has no equivalent in the opposite protocol. Table 3-10 shows the list of message types that have no equivalents and are discarded.
Table 3-10 Message Type with No Opposite Protocol Equivalent
| Message Type | Code |
| Confusion Message (CNF) | 2F |
| Connect Message (CONN) | 07 |
| Continuity Test Message (COT) | 05 |
| Continuity Check Request Message (CCR) | 11 |
| Information Message (INF) | 04 |
| Information Request Message (INR) | 03 |
| Loop Back Acknowledge Message (LPA) | 24 |
| Overload Message (OLM) | 30 |
0110.1093 CARD 1205,B INFO ITU GWY:rcvd msg type cannot convert
SIO=0e OPC=4-013-1 DPC=1-003-0
MSG TYPE=07
LSN=A1234567890
Recovery
3.3.94 1094 - ITU GWY:Invalid ISUP msg structure
This message indicates that an ISUP parameter or pointer to a parameter was invalid.
0110.1094 CARD 1205,B INFO ITU GWY:Invalid ISUP msg structure
MSG TYPE=07
LSN=A1234567890
Recovery
3.3.95 1095 - ITU GWY:GRS Buffer Full
This message indicates the circuit group reset (GRS) buffer is full.
0110.1095 CARD 1205,B INFO ITU GWY:GRS buffer full
Recovery
3.3.96 1096 - ITU GWY:RSC Buffer Full
This message indicates the reset circuit (RSC) buffer is full.
0110.1096 CARD 1205,B INFO ITU GWY: RSC buffer full
Recovery
3.3.97 1097 - ITU GWY:CGB Buffer Full
This message indicates the circuit group blocking (CGB) buffer is full.
0110.1097 CARD 1205,B INFO ITU GWY: CGB buffer full
Recovery
3.3.98 1098 - Unexpected Disk Access Timeout
This message is used to determine whether there are problems with the disk access system.
0110.1098 CARD 1113 INFO Unexpected disk access timeout
Recovery
If the target disk is the same CARD that corresponds to the GPSM-II, there is a software timing issue that needs to be addressed.
If the target disk is the mate GPSM-II/TDM or the removable and access is physically impossible, no action is necessary.
3.3.99 1099 - String Data Dump
This is a generic UIM. The informational message in the UIM varies.
FTP Transfer Failed due to network congestionAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.100 1100 - GWS rcvd H0/H1 that is not allowed
This message indicates the STP has received an H0/H1 that is not allowed.
RLGHNCXA21W 00-04-18 18:59:58 EST EAGLE 31.3.0
0105.1100 CARD 1201,A INFO GWS rcvd H0H1 that is not allowed
SIO=02 OPC=009-009-009 DPC=006-006-006
H0H1=01 AFTPC=255-009-009
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TN
- Telephone number
- TYPE
Recovery
3.3.101 1101 - SDRAM Single Bit Error Report
This message indicates SDRAM memory on HIPR (or IMTPCI) is detecting Single Bit Errors (SBEs). This may be an indication that the card should be replaced (memory becoming faulty) before Multi Bit Errors (MBEs) begin to occur, which results in an OBIT of the card.
RLGHNCXA21W 02-07-21 16:20:19 EST EAGLE 35.0
0024.1101 CARD 1109 INFO SDRAM single bit error report
Any Errors : YES current hour------v
Microengine Count : 12345678
PCI Count : 12345678
StrongARM Count : 12345678
Recovery
The card generating the error may need replacement. Refer to the Maintenance Manual for card removal/replacement procedures. Contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.3.102 1102 - Invalid Length for Map IMEI Parameter
This message indicates that the EIR subsystem received a Check-IMEI message in which the Map IMEI parameter had an invalid length.
RLGHNCXA21W 00-04-18 19:00:11 EST EAGLE 31.3.0
0107.1102 CARD 1103,A1 INFO Invalid Length for Map IMEI Parameter
SIO=03 OPC=003-252-000 DPC=000-071-000
CDPA: AI=10 SSN=05 TT=250
CGPA: AI=12 PC=001-001-001 SSN=002
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.103 1103 - LSS:No Map IMEI Parameter present
This message indicates that the EIR subsystem received a Check-IMEI message in which the Map IMEI parameter is not present.
0107.1103 CARD 1103,A1 INFO LSS:No Map IMEI Parameter present
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.104 1104 - IP Connection Failed
Reports that either an attempt to connect to an IP server failed, or that a client socket failed to establish a connection with the system (IP7 Secure Gateway).
RLGHNCXA03W 99-04-10 16:28:08 EST EAGLE 35.0.0
0003.1104 DCM 1213,A IP Connection Failed
RIPADDR = 123.123.123.123
RPORT = 1314
LIPADDR = 123.123.123.124
LPORT = 1315
SNAME=LONGSOCKETNAME1
Report Date: 02-04-10 Time: 16:27:19
Recovery
pass:loc=xxxx:cmd=”connmgr -l”displays the connection manager event log.pass:loc=xxxx:cmd=”connmgr -c”displays socket client data.pass:loc=xxxx:cmd=”connmgr -s”displays socket server data.
3.3.105 1105 - REPT EVT:IMT GPL Reloading
This message indicates the IMT software download procedure is initiated. This is the first message that the system displays.
0105.1105 SYSTEM INFO REPT EVT:IMT GPL reloading
cards loaded : 1 of 25
Recovery
3.3.106 1106 - REPT COND:IMT GPL Reloading
This message displays the progress of the IMT software downloading procedure.
0105.1106 SYSTEM INFO REPT COND:IMT GPL reloading
cards loaded : 10 of 25
Recovery
3.3.107 1107 - SCCP XUDT (S) msg: Hop Counter violation
This message indicates that the incoming MSU has a Hop counter value of zero or greater than 15 and the F bit in the segmentation parameter is not set. An XUDTS error response is generated and sent to the originating node. The message is discarded.
Example
0018.1107 CARD 1103,A INFO SCCP XUDT (S) msg: Hop Counter violation
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.108 1108 - SCCP XUDT (S) msg: inv opt portion len
This message indicates that the incoming MSU has an invalid length in the optional portion (optional parameter length exceeding the MSU length or no end of optional parameters octet). The message is discarded.
0112.1108 CARD 1103,A1 INFO SCCP XUDT (S) msg: inv opt portion len
SCCP MSG TYPE=04
CDPA: NI=1 RI=0 GTI=04 SSNI=1 PCI=1
CGPA: NI=1 RI=0 GTI=04 SSNI=1 PCI=1
LSN=A1234567
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
This message indicates an SCCP message was discarded due to an invalid length.
No further action is necessary.
3.3.109 1109 - SCCP XUDT(S) msg: inv segmentation parm
This message indicates that the length of the optional segmentation parameter is not equal to 6. The length of the segmentation parameter must be equal to 6. The message is discarded.
0112.1109 CARD 1103,A1 INFO SCCP XUDT(S) msg: inv segmentation parm
SCCP MSG TYPE=04
LSN=A1234567
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
This message indicates an SCCP message was discarded due to an invalid segmentation parameter.
3.3.110 1110 - GWS rcvd AFTPC that is not allowed
This indicates that a message was received by a gateway link and failed DESTFLD screening because of an affected point code value in the message.
0100.1110 CARD 1105,B INFO GWS rcvd AFTPC that is not allowed
SR=osp3 LSN=A1234567
Recovery
3.3.111 1111 - GWS rcvd TCA, AFTPC not in routing tbl
This indicates that a TCA message was received by a gateway link and failed DESTFLD screening because of an affected point code value in the message.
0100.1111 CARD 1105,B INFO GWS rcvd TCA, AFTPC not in routing tbl
H0H1=46 AFTPC=099-099-003
Recovery
3.3.112 1112 - GWS rcvd TCR, AFTPC not in routing tbl
This indicates that a TCR message was received by a gateway link and failed DESTFLD screening because of an affected point code value in the message.
0100.1112 CARD 1105,B INFO GWS rcvd TCR, AFTPC not in routing tbl
H0H1=44 AFTPC=099-099-003
Recovery
3.3.113 1113 - GWS rcvd TCP, AFTPC not in routing tbl
This indicates that a TCP message was received by a gateway link and failed DESTFLD screening because of an affected point code value in the message.
0100.1113 CARD 1105,B INFO GWS rcvd TCP, AFTPC not in routing tbl
H0H1=42 AFTPC=099-099-003
Recovery
3.3.114 1114 - Database BACKUP Started
A local database backup is beginning. This UIM follows
the issue of the
chg-db:action=backup command.
RLGHNCXA21W 00-06-18 19:12:00 EST EAGLE 31.3.0
0147.1114 CARD 1201,A INFO Database BACKUP started
Recovery
3.3.115 1115 - Database RESTORE Started
A local database restore is beginning. This UIM follows
the issue of the
chg-db:action=restore command.
0147.1115 CARD 1201,A INFO Database RESTORE started
Recovery
3.3.116 1116 - Database Action Ended - OK
A local database backup or restore has successfully
completed. This UIM follows the issue of the
chg-db command.
0147.1116 CARD 1201,A INFO Database action ended - OK
Recovery
3.3.117 1117 - Database action ended - FAIL
This error message indicates that one or more cards specified in the init-flash/act-flash command is out of phase with the command.
0147.1117 CARD 1201,A INFO Database action ended - FAILEDAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.118 1118 - TOD change affects MEAS collection
This message indicates that due to a time change, the measurements in a specific period may be inaccurate.
0020.1118 CARD 1106 INFO TOD change affects MEAS collection
Report Date:02-07-21 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.119 1119 - Cards out of phase with flash procedure
This message indicates that the collection sequence has been disrupted and the 60-minute and/or 30-minute data may be inaccurate.
Example
0020.1119 CARD 1115 INFO Cards out of phase with flash procedure
Card List: 1101, 1201, 1302, 2103, 2204, ... (2 others)
Report Date:02-07-21 Time:16:20:19 Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.120 1120 - TRBL Queue is full:elements overwritten
This message indicates that too many UIMs per second are being output. One or more might be lost.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 35.0.0
0014.1120 CARD 1113 INFO RBL Queue is full;elements overwrittenAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.121 1121 - LNP rcvd query from unknown CGPA PC
The LNP query receives a calling party point code that is not in the routing table. The system LNP subsystem normally sends a response back to the calling party PC in the query. The system did not respond to this query.
0107.1121 CARD 1103,A1 INFO LNP rcvd query from unknown CGPA PC
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- CGPA
- Calling party address
- DATA
- DPC
- Destination point code
- LSN
- Linkset name. The name must be unique.
- OPC
- Origination point code
- PC
- Point code for the SS7 end user (OPC).
- SIO
- Service information octet
- SSN
- Subsystem number
- TT
- Translation type
Recovery
Provision a route to the Calling Party Point Code using
the
ent-dstn and
ent-rte commands.
3.3.122 1122 - LNP rcvd query with undefined TT/SERV
The LNP Query Subsystem received a message with an undefined Service. The Called Party Translation type in the incoming message determines the format of the MSU. This UIM can be issued when there is no LNP Service associated with the Translation Type of this MSU.
If the Translation Type of the MSU is provisioned as a Translation Type for LNPQS Service, the Eagle attempts to determine the actual LNP Service for this message by examining the OP CODE value. If the OP CODE does not match any supported by the Eagle Service (IN, AIN, IS-41), this UIM is issued.
This UIM can also be issued as a result of an error response from an end office because the Eagle LNP database response returned an LRN that was not provisioned in the end office.
Trace tools and/or the hex dump in the UIM can be used to determine the TCAP information. Note that the GTT data is not contained in the SCCP layer because the Eagle does not return this information in the LNP response to the end office.
0107.1122 CARD 1103,A1 INFO LNP rcvd query with undefined TT/SERV
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.123 1123 - LNP rcvd query with Message Relay TT
The LNP Query Subsystem received a message with a Translation Type reserved for Message Relay. This happens if another node sent a message to the system for Message Relay with the routing indicator set to rt-on-ssn and ssn set to system’s LNP subsystem.
0107.1123 CARD 1103,A1 INFO LNP rcvd query with Message Relay TT
ADDR=ABCDEF1234567890ABCDE
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
- No further action is necessary.
3.3.124 1124 - SIP: Dgts truncated in 302 response
SIP 302 response shall encode only 30 digits in dialed string/telephone number and 25 digits in RN. The remaining digits shall be truncated.
0014.1124 CARD 1103,B INFO Dgts truncated in 302 response
CNAME= conn1
Branch ID = z9hG4bKnashds8
RURI: INVITE sip:+1 206 555-0146@127.0.0.1:5070;user=phone
Report Date:10-10-12 Time:16:20:19
Recovery
No further action is required.
3.3.125 1125 - GWS rcvd CDPA that could not be RDCTd
This message indicates the EAGLE 5 ISS received an MSU, with a called party address (CDPA) that is not allowed in gateway screening (GWS) and cannot be redirected.
RLGHNCXA21W 00-04-18 18:59:23 EST EAGLE 31.3.0
0101.1125 CARD 1205,B INFO GWS rcvd CDPA that could not be RDCTd
SIO=0a OPC=003-244-000 DPC=000-071-000
SCCP MT= 18
CDPA: AI=10 PC=003-003-003 SSN=005 TT=250
ADDR=123456789012345678909
CGPA: AI=10 PC=004-004-004 SSN=005 TT=251
SR=scrb LSN=A1234567
Four outputs are possible. The Legend includes abbreviations found in all variations.
- ADDR
- Address
- AFTPC
- Affected point code (for SCCP messages)
- AFTSS
- Affected subsystem (identifies the subsystem that failed)
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- Information from the upper layers of SCCP management
- DPC
- H0H1
- H0/H1 heading code
- LSN
- MULT
- SCCP management message multiplicity indicator
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- Screening reference name
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
- SCCP management message type
Recovery
3.3.126 1126 - GWS rcvd CGPA that could not be RDCTd
This message indicates the EAGLE 5 ISS received an MSU, with a calling party address (CGPA) that is not allowed in gateway screening (GWS) and cannot be redirected.
0101.1126 CARD 1205,B INFO GWS rcvd CGPA that could not be RDCTd
SCCP MT= 18
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.127 1127 - GWS rcvd AFTPC that could not be RDCTd
This message indicates the EAGLE 5 ISS received an MSU, with an allowed affected point code (AFTPC) that is not allowed in gateway screening (GWS) and cannot be redirected.
0101.1127 CARD 1205,B INFO GWS rcvd AFTPC that could not be RDCTd
SCCP MT= 18
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.128 1128 - GWS rcvd TT that could not be RDCTd
This message indicates the EAGLE 5 ISS received an MSU, with a translation type (TT) that is not allowed in gateway screening (GWS) and cannot be redirected.
0101.1128 CARD 1205,B INFO GWS rcvd TT that could not be RDCTd
SCCP MT= 18
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.129 1129 - Ported subs SMSC matches Home SMSC Addr
This message indicates that a ported out subscriber is fraudulently attempted to send SMS using the old networks SMSC. An error message was generated and returned to the originating MSC.
Example
0018.1129 CARD 1103,A INFO Ported subs SMSC matches Home SMSC Addr
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.130 1130 - IS412GSM not provisioned
The GSMOPTS: IS412GSM digits have not been provisioned.
To be able to perform the IS-41 GSM Migration feature and to accept LOCREQ Request messages, first specify the IS412GSM prefix in GSMOPTS.
Example
RLGHNCXA21W 08-01-13 16:20:19 EST EAGLE 37.5.0
0712.1130 CARD 1105 INFO IS412GSM not provisioned
SIO=83 OPC= 00100 DPC= 00456
SCCP MSG TYPE=09
CDPA: NI=0 RI=0 GTI=04 SSNI=1 PCI=1
TT=010 NP=01 NAI=004 ADDR=19876543210
PC= 08238 SSN=010
CGPA: NI=0 RI=1 GTI=00 SSNI=0 PCI=0
LSN=ls1
Report Date:08-01-13 Time:23:20:02This alternate output includes the redirected destination and is
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.131 1131 - Invalid Digits in IS41 MAP Digits Parm
A LOC Request message contained invalid data and will be passed to the GTT. G-Port determined a received Location Request message had invalid data in the called party number parameter fields. The verified fields must contain:
Digits: from 5 to 21 digits
Encoding scheme: BCD
Numbering plan: Telephony
0112.1131 CARD 1103,A1 INFO Invalid digits in IS41 MAP Digits parm
SCCP MSG TYPE=04
LSN=A1234567
Legend
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.132 1133 - Diameter msg decode failed
This message indicates that the Diameter message parsing has failed. This may be cause by:
- ECR Message does not have IMEI AVP or a value in IMEI AVP
- CER Message does not have mandatory AVP present
- DPR message received does not have disconnect cause AVP present
xxxx.1133 CARD 1103,B INFO Diameter msg decode failed
DCNAME= dcon1
Command Code=(R) AVP Code=
Origin Host= host1
Error Cause= avp not present Alarm Level: No alarm condition. The message is informational only.
3.3.133 1134 - Diameter msg encode Failed
This message indicates that the Diameter message Encoding has failed.
xxxx.1134 CARD 1101,B INFO Diameter msg encode failed
DCNAME=dcon2
Command Code= (A)
Origin Host=host1
Error Cause=Invalid IMEI digits Alarm Level: No alarm condition. The message is informational only.
3.3.134 1135 - Invalid diameter Msg received
This message indicates that the Diameter message received is not supported by the EAGLE.
xxxx.1135 CARD 1101,B INFO Invalid Diameter Msg received
DCNAME= dcon1
Command Code= 4022 (R)
Origin Host=---
Error Cause=---
3.3.135 1136 - Invalid Diameter Msg length
- The total Diameter message length specified in the diameter header does not match the actual diameter message length.
- The diameter message length is greater than the maximum length of 448 bytes supported by current EIR S13/S13's implementation.
xxxx.1136 CARD 1101,B INFO Invalid Diameter Msg length
DCNAME= dcon1
Command Code= (R)
Origin Host=---
Error Cause=---
3.3.136 1137 - Diameter AVP Decode Fail
This message indicates an invalid length for the IMEI/IMSI AVP has received.
xxxx.1137 CARD 1101,B INFO Diameter AVP Decode Fail
DCNAME= dcon1
Command Code= (R) AVP Code=
Origin Host=---
Error Cause=AVP Decode Error
3.3.137 1138 - Connection Refused
This message indicates that the Origin host and Origin Realm AVPs in the CER message does not match the host and real values provisioned in the IPAPSOCK table. The Source IP Address of the CER does not match the IP Address present in the Host-IP-Address AVP. This may be cause by:
- Origin Host Mismatch
- Origin Realm Mismatch
- IP Address Mismatch
- No common Application
xxxx.1138 CARD 1101,B INFO Connection Refused
DCNAME= dcon1
Command Code= (R)
Origin Realm=aricent.com
Error Cause=Origin Realm Mismatch
3.3.138 1139 - DEIROPTS: DEIR Global Response is ON
This message indicates that the DEIR Global response is ON.
6056.1139 CARD 1115 INFO DEIROPTS: DEIR Global Response is ON
3.3.139 1140 - DEIROPTS: DEIR Global Response is OFF
This message indicates that the DEIR Global response is OFF.
6056.1140 CARD 1115 INFO DEIROPTS: DEIR Global Response is OFF
3.3.140 1141 - AIN INP Qry Rejected: AINPQ is OFF
The EAGLE 5 ISS has rejected an ANSI INP query that is decoded as an AIN query because the appropriate AINPQ (ANSI INP Query) feature key is not on.
6812.1141 CARD 1103 INFO AIN INP Qry rejected: AINPQ is OFF
TRANSLATED PC= 001-001-001 TRANSLATED SS=002
TT=006 NP=-- NAI=--- ADDR=234567
PC= 003-003-001 SSN=002
CGPA: NI=0 RI=1 GTI=00 SSNI=1 PCI=1
PC= 002-002-001 SSN=002
LSN=ls221
Recovery
- If you want to support the AINPQ feature, issue the
following commands to process
ANSIAINqueries:enable-ctrl-feat:partnum:893017801:fak=<ANSI-41 INP Query FAK> - Enter
chg-ctrl-feat:partnum:893017801:status=oncommand. - If you do not want to support the AINPQ feature, ignore this informational message.
- For additional information or assistance about the AINPQ or any feature to purchase, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.3.141 1142 - GWS Strip Stop Action Failed
GWS Strip stop action has failed to de-encapsulate the MSU.
6812.1142 CARD 1103 INFO GWS Strip Stop Action Failed
Report Date:13-10-10 Time:16:20:19
Recovery
- Send the redirected MSU for the STRIP action to be applied.
- Verify that the filtering criteria of the 'STRIP' action matches the parameters encoded by REDIRECT stop action.
3.3.142 1143 - GTT(FLOBR) failure: duplicate settype
This message indicates that any one of the MBR GTT Settypes (IMSI\MSISDN\VLRnb\SMRPOA\SMRPDA) is found twice in the FLOBR search path, and the fallback is set to "NO" in the last matched translation. This results in GTT failure.
0018.1143 CARD 1103 INFO GTT(FLOBR) failure: duplicate settype
SIO=03 OPC=4-123-5 DPC=6-018-7
TT=25 NP=04 NAI=010 ADDR=123456789012345678901
PC=3-026-5 SSN=005
PC=----------- SSN=004
LSN=ls2314n2 GTTSETIDX=211 215
Recovery
- Update the FLOBR GTT search path configuration via the
chg-gtacommand so that the same MBR GTT settype is not encountered in the search path again.
3.3.143 1144 - GTT(FLOBR) warning: duplicate settype
This message indicates that any one of the MBR GTT Settypes (IMSI\MSISDN\VLRnb\SMRPOA\SMRPDA) is found twice in the FLOBR search path, and the fallback is set to "Yes" in the last matched translation. GTT is then performed on the basis of the last matched translation. This is a successful scenario.
0028.1144 CARD 1103 INFO GTT(FLOBR) warning: duplicate settype
CDPA: NI=1 RI=0 GTI=04 SSNI=0 PCI=1
PC=3-026-5 SSN=005
CGPA: NI=1 RI=0 GTI=04 SSNI=0 PCI=1
TT=100 NP=07 NAI=012 ADDR=012345678901234567890
Recovery
3.3.144 1145 - MBR decoding failed
This message indicates that there is a problem with decoding the TCAP portion of the incoming MSU. The UIM information displays the error reason and the parameter value. The GTT will be performed on the basis of the "fallback" value set in the last matched translation.
0018.1145 CARD 1103 INFO MBR decoding failed
Reason= MSISDN decoding failed (Extension bit is zero)
PC=3-026-5 SSN=005
Op-Code=2 PKG-Type= TC BEGIN(0x62)
Comp-Type= Invoke(0xA1)
MAP PARAM: NP=1 NON=1 Ext-Bit=0
MAP Digits=12345678912
Report Date:15-07-21 Time:16:20:19
Recovery
No action is necessary.
3.3.145 1146 - REPT-XLST-TIMO: X-LIST entry expired
This message indicates that the timer has expired for an x-list entry and that entry has been removed.
0147.1146 CARD 1201 INFO REPT-XLST-TIMO:X-LIST entry expired
DPC=001-001-001Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.146 1147 - MTP Invalid TFA received
This message indicates the network elements of an adjacent node have not been configured properly.
0147.1147 CARD 1201,A INFO MTP Invalid TFA received
OPC=001-001-001 CPC=002-002-002
LSN=lsn01a
Recovery
Notify the craftsperson at the adjacent node of this error.
3.3.147 1148 - MTP Invalid TFR received
0147.1148 CARD 1201,A INFO MTP Invalid TFR received
LSN=lsn01a
Recovery
3.3.148 1149 - SLK Level-3 T19 Timer Expired
The link has been down for 5 minutes or the timer T19 has timed out.
0147.1149 CARD 1201,A INFO SLK Level-3 T19 timer expired
Recovery
3.3.149 1150 - SLK Inhibit Denied
The request to inhibit the link has been denied.
The following is an example of an error occurring at the near end.
RLGHNCXA21W 03-12-22 21:49:03 EST EAGLE 40.1 7271.1150 CARD 1202,A INFO SLK Inhibit denied Source: Local Reason: Only one link available in the linkset Report Date:03-12-22 Time:21:49:03 -
The following is an example of an error occurring at the far end.
RLGHNCXA21W 03-12-22 21:49:03 EST EAGLE 40.1 7271.1150 CARD 1202,A INFO SLK Inhibit denied Source: Remote Reason: Unknown Report Date:03-12-22 Time:21:49:03
Recovery
- If denied locally, inhibiting the link would cause the far end to prohibit the point code. If remotely denied, contact the far-end office to determine the cause and to correct the problem.
3.3.150 1151 - SLK Inhibit Response Timeout
The system has sent a link inhibit request, but no inhibit acknowledge was received.
0014.1151 CARD 1205,A nc00027 SLK Inhibit Response TimeoutAlarm Level: No alarm condition. The message is informational only.
Recovery
Try the inhibit command again.
If still unsuccessful, contact the far-end office and verify the status.
3.3.151 1152 - SLK Uninhibit Denied
The far end has denied the craftsperson’s request to uninhibit the link.
0014.1152 CARD 1205,A nc00027 SLK Uninhibit DeniedAlarm Level: No alarm condition. The message is informational only.
Recovery
Contact the far end office to determine why this was denied.
3.3.152 1153 - SLK Uninhibit Response Timeout
An uninhibit request was sent, but an uninhibit acknowledge was not received.
0014.1153 CARD 1205,A nc00027 SLK Uninhibit Response TimeoutAlarm Level: No alarm condition. The message is informational only.
Recovery
Try the uninhibit request again.
If still unsuccessful, contact the far-end.
3.3.153 1154 - MSU received threshold exceeded
This UIM is produced by the OAM. It is produced whenever the cumulative count of MSUs received due to gateway screening on a given linkset exceeds the specified GWS activity threshold (MSU_recvd_threshold) within a specified time period.
0014.1154 SYSTEM INFO MSU-received threshold exceededAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.154 1155 - MSU-rejected threshold exceeded
This UIM is produced by the OAM. It is produced whenever the cumulative count of MSUs discarded due to gateway screening on a given linkset exceeds the specified GWS activity threshold (MSU_reject_threshold) within a specified time period.
0014.1155 SYSTEM INFO MSU-rejected threshold exceededAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.155 1156 - Minor congestion event detected
This message is issued when a HIPR2 card detects a minor congestion event. A congestion event is one 10 millisecond time slice that exceeds the specified bus utilization for that time slice on a segment as detected by the HIPR2.
RLGHNCXA21W 09-02-07 12:01:43 EST EAGLE 41.1.0
0023.1156 CARD 1109 INFO Minor congestion event detected
Report Date:09-02-07 Time:12:01:43
Recovery
Although no action is required, the message can serve as a notification that this particular section of the IMT bus is reaching its saturation.
Contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA for more information.
3.3.156 1157 - Major congestion event detected
This message is issued whenever a HIPR2 card detects a major congestion event. A congestion event is one 10 millisecond time slice that exceeds the specified bus utilization for that time slice on that segment.
0023.1157 CARD 1109 INFO Major congestion event detected
Recovery
3.3.157 1158 - Minor HIPR2 switching capacity reached
This message is issued when the minor switching rate is observed by the HIPR2 card. This rate is a measure of the switching capacity of the HIPR2 card.
0023.1158 CARD 1109 INFO Minor HIPR2 switching capacity reached
Recovery
3.3.158 1159 - Major HIPR2 switching capacity reached
This message is issued when the major switching rate is observed by the HIPR2 card. This rate is a measure of the switching capacity of the HIPR2 card.
0023.1159 CARD 1109 INFO Major HIPR2 switching capacity reached
Recovery
3.3.159 1160 - GWS rcvd ISUP that is not allowed
This message indicates gateway screening (GWS) has discarded an MSU because the ISUP is listed as one that is not allowed in this network.
0105.1160 CARD 1205,A INFO GWS rcvd ISUP that is not allowed
SIO=0a OPC=003-247-000 DPC=002-000-000
DATA=12 34 56 78 90 12 34 56 78 90 12 34
56 78 90 12 34 56 78 90 12 34 56 78
Recovery
3.3.160 1161 - GWS rcvd nonSNM DESTFLD screening msg
This message indicates gateway screening (GWS) received a message that is not a MTP network management message. Affected Destination (DESTFLD) screening makes sense only for MTP Network Management (SNM) messages. When a non-SNM message is screened for Affected Destination, it is forced to pass screening and this message is generated.
0105.1161 CARD 1103,A INFO GWS rcvd ISUP nonSNM DESTFLD screening msg
Recovery
3.3.161 1162 - GWS rcvd nonSCCP CGPA/CDPA Screen Msg
This message indicates that a message that was not a SCCP message passed CGPA/CDPA screening. CDPA orCGPA screening makes sense only for SCCP messages. When a non-SCCP message is screened for CDPA or CGPA, it is forced to pass screening and this message is generated.
0105.1162 CARD 1103,A INFO GWS rcvd nonSCCP CGPA/CDPA screen msg
Recovery
3.3.162 1163 - GWS rcvd invalid GTI in TT screening
This message indicates that a message that was not a SCCP message or an SCCP message that does not contain a TT passed the Allowed TT screening. Allowed TT screening makes sense only for SCCP messages that contain TT. When a non-SCCP message or a SCCP message that does not contain a TT is screened for Allowed TT, it is forced to pass screening and this message is generated.
0105.1163 CARD 1103,A INFO GWS rcvd invalid GTI in TT screening
Recovery
3.3.163 1164 - Inh LNP SS request already outstanding
An inh-map-ss command is already entered and queued.
0014.1164 SYSTEM INFO Inh LNP SS request already outstandingAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.164 1166 - ACG Node Overload Level Change
The SCM has detected that the node overload level for the system has changed.
0014.1166 SYSTEM INFO ACG Node Overload Level Change
OLD ACG LEVEL= 0 NEW ACG LEVEL= 10
Recovery
3.3.165 1167 - SIP connection established
This message indicates that the SIP connection has been established.
0014.1167 CARD 1101 INFO SIP connection established
Connection Name : tcp1101d
Report Date:10-10-12 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.166 1168 - SIP connection terminated
This message indicates that the SIP connection has been terminated.
0014.1168 CARD 1101 INFO SIP connection terminated
Recovery
3.3.167 1169 - SCCP rcvd inv TCAP portion
Table 3-11 Feature Settings
| LNP MR | GSM Map Screening | Description |
| On | Off | SCCP discarded a message. No action is necessary. |
| Off | On | GSM MAP Screening does not discard the MSU. The action provisioned in the GSMDECERR parameter in the STPOPTS table is performed. No action is necessary. |
| On | On | The TCAP Package Type from the DATA portion of the UIM must
be decoded to determine which feature generated the message.
RLGHNCXA21W 00-04-18 19:02:12 EST EAGLE 31.3.0
0113.1169 CARD 1103,A1 INFO SCCP rcvd inv TCAP portion
SIO=0a OPC=004-009-000 DPC=002-000-000
CDPA: AI=10 SSN=005 TT=250
DATA=3a e2 38 c7 04 56 04 72 e0 e8 30 e9
2e cf 01 00 d0 02 83 01 f2 25 aa 0b
84 09 01 00 11 0a 19 49
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- Called party address
- CGPA
- DATA
- Hex dump of TCAP part of MSU
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- SR
- TT
- Translation type
Recovery
3.3.168 1170 - OAMHC Meas transition complete.
The full capabilities of the E5-OAM Integrated Measurements feature are available now. The Measurements Platform, if in use before the transition, has been replaced by the the E5-OAM Integrated Measurements feature.
RLGHNCXA21W 09-11-17 12:01:43 EST EAGLE 42.0.0
yyyy.1170 SYSTEM INFO OAMHC Meas transition complete.
Report Date:09-11-17 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
No action required.
3.3.169 1171 - Schd UI Rpt disbld-link cnt exceeds 700
To prevent sending too much information to the terminal during the time available, the E5-OAM Measurements Interface feature disables UI reports whenever the number of provisioned links is greater than 700 .
RLGHNCXA21W 09-11-17 16:20:19 EST EAGLE 42.0.0
0014.1171 SYSTEM INFO Schd UI Rpt disbld-link cnt exceeds 700
Recovery
No action required.
3.3.170 1172 - REPT-OVSZMSG: MTP MSU Too Large to rte
An oversized MTP MSU was received and discarded.
0056.1172 CARD 1113 INFO REPT-OVSZMSG: SCCP MSU too large to rte
LEN=50
SIO=04 OPC= 016-032-048 DPC= 032-032-048
SCCP MT=012
CDPA: AI=04 PC= 016-032-048 SSN=004 TT=004
ADDR=43210FEDCBA9876543210
CGPA: AI=04 PC= 016-032-048 SSN=004 TT=004
ADDR=0123456789ABCDEF01234
LSN=ls211
Report Date:12-12-15 Time:11:03:31
Recovery
3.3.171 1173 - REPT-OVSZMSG: SCCP MSU Too Large to rte
An oversized SCCP MSU was received and discarded.
0045.1173 CARD 1113 INFO REPT-OVSZMSG: MTP MSU too large to rte
LEN=50
DATA=01 02 03 04 05 06 07 08 09 0a 0b 0c
0d 0e 0f 10 11 12 13 14 15 16 17 18
19 1a 1b 1c
LSN=ls211
Report Date:12-12-15 Time:11:01:20
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- CGPA
- DPC
- LEN
- Data length
- LSN
- OPC
- PC
- Point code
- SCCP MT
- SCCP message type
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.172 1174 - Inh INP SS request alrdy outstanding
0014.1174 SYSTEM INFO Inh INP SS request alrdy outstandingAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.173 1176 - Unexpected DB version - Using UDT
This message indicates that an unexpected DB version was received from the MPS during the database download. As a result, the UDP-based Data Transfer protocol will be used to transfer the database from the MPS to the Eagle 5.
0020.1176 CARD 1113 INFO Unexpected DB version – using UDT
Recovery
3.3.174 1177 - Cnvrsn Discard: SCCP MSU too large
An SCCP MSU received was too large and discarded.
0014.1177 CARD 1103,A2 INFO Cnvrsn Discard: SCCP MSU too large
LEN=279
SIO=03 OPC=002-002-002 DPC=001-001-001
SCCP MT=004
CDPA: AI=8B PC=003-003-003 SSN=005 TT=250
ADDR=ABCDEF0123456789ABCDE
CGPA: AI=8B PC=004-004-004 SSN=006 TT=251
ADDR=919460365512345678912
LSN=A1234657
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- CGPA
- DPC
- LEN
- Data length
- LSN
- OPC
- PC
- Point code
- SCCP MT
- SCCP message type
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.175 1178 - Conversion Discard: Invalid SCCP msg type
0110.1178 CARD 1205,B INFO Conversion Discard: Invalid SCCP msg type
MSG TYPE=004
LSN=A1234657
Recovery
3.3.176 1179 - Cnvrsn Discard: CGPA PC alias undefined
An SCCP MSU contained an undefined CGPA PC and was discarded.
Example
RLGHNCXA21W 02-07-21 16:20:19 EST EAGLE 37.5.0
0018.1042 CARD 1103,A INFO SCCP rcvd inv GT - bad Translation Type
SIO=03 OPC=001-001-001 DPC=002-002-002
SCCP MSG TYPE=04
TT=250 NP=04 NAI=010 ADDR=123456789012345678901
PC=001-001-001 SSN=004
LSN=ABCD123 GTTSET=3 203 46
Report Date:02-07-21 Time:16:20:19This alternate output includes the redirected destination and is
used when a redirected MSU encounters an error.
SCCP MSG TYPE=04
GTT on CdPA used MOSMSGTA=9193802053
- ADDR
- Address
- AI
- Address Indicator
- CDPA
- CGPA
- DPC
- LEN
- Data length
- LSN
- OPC
- PC
- Point code
- SCCP MT
- SCCP message type
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
- Enable the proper Discard CGPA PC STP Option, based
on the network type of the incoming message.
Refer to the Database Administration Manual - Global Title Translation for details.
OR
- Add the proper alias for the Calling Party Point Code
corresponding to the destination network.
3.3.177 1180 - Conversion Discard: Aft. PC alias undefined
An SCCP MSU contained an undefined affected point code alias. The message was discarded.
0124.1180 CARD 1106 INFO Conversion Discard: Aft. PC alias undefined
LSN=A1234567
- AFTPC
- AFTSS
- DPC
- LSN
- MSG LEN
- Message length
- MSG TYPE
- Message type (for example, connection request, connection confirm, connection refused)
- MULT
- OPC
- SCMG
- SIO
Recovery
Add the proper alias for the Affected point code corresponding to the destination network.
3.3.178 1181 - Conversion Discard: Invalid SCMG msg type
An SCCP MSU contained an invalid SCCP management message (SCMG) and was discarded
0124.1181 CARD 1106 INFO Conversion Discard: Invalid SCMG msg type
- AFTPC
- AFTSS
- DPC
- LSN
- MSG LEN
- Message length
- MSG TYPE
- MULT
- OPC
- SCMG
- SIO
Recovery
3.3.179 1182 - Cnvrsn Discard - Invalid TCAP element
An invalid element has been detected.
Station 1234 00-03-30 16:20:08 EST EAGLE 31.3.0
0018.1182 - CARD 1103,A INFO Cnvrsn Discard:Invalid TCAP element
LEN=037 SCCP MT=009
CGPA: AI=C3 PC=004-004-004 SSN=005 TT=053
PKG=E2 CMPNT=EA OFFSET=030 EXPECTED=OA ACTUAL=AO
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CMPNT
- Component
- DPC
- LEN
- Data length
- LSN
- OPC
- PC
- Point code
- PKG
- Package
- SCCP MT
- SCCP message type
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.180 1183 - Cnvrsn Discard - Invalid TCAP elem’t len
An element’s length of contents field has received an element that extends beyond the end of its container element.
0018.1183 CARD 1103,A INFO Cnvrsn Discard: Invalid TCAP elem’t len
LEN=037 SCCP MT=009
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CMPNT
- Component
- DPC
- LEN
- Data length
- LSN
- OPC
- PC
- Point code
- PKG
- Package
- SCCP MT
- SCCP message type
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.181 1184 - Cnvrsn Discard: Invalid SCCP elem’t len
0014.1184 CARD 1103,A2 INFO Cnvrsn Discard: Invalid SCCP elem’t len
LEN=279
SCCP MT=004
LSN=A1234657
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CMPNT
- Component
- DPC
- LEN
- Data length
- LSN
- OPC
- PC
- Point code
- pkg
- Package
- SCCP MT
- SCCP message type
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.182 1185 - GTI input clock anomalies detected
This message indicates additional high speed clock diagnostic data is available although the high speed clocks are valid.
RLGHNCXA21W 03-01-06 13:46:23 EST EAGLE 35.0.0
0379.1185 CARD 1113 INFO GTI input clock anomalies detected
Reporting TDM Location : 1114
GTI Clock Status Register : H'0021
Primary LIU Violation Count : 56
Secondary LIU Violation Count : 129
GTI Status Register : H'0022
Report Date:03-01-05 Time:13:46:25Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.183 1186 - Meas data load failure: old version
This message can be generated if the primary MCP is running an older version of the GPL than the secondary MCP. This could possibly occur in an upgrade failure or upgrade back out procedure.
RLGHNCXA21W 02-07-21 16:20:19 EST EAGLE 31.3.0
0002.1186 CARD 1103 INFO Meas data load failure: old version
Recovery
Boot the primary and/or secondary MCPs with the approved GPL version of the system release.
3.3.184 1187 - Table Checksum Mismatch
This message indicates additional diagnostic information in the event of a GPL or a specific table corruption alarm. Whenever a GPL corruption alarm (UAM 0040) is raised during the GPL Audit or a subset data corruption alarm (UIM 1188) is raised during static data Audit, this UIM 1187 is also output to provide the Table ID, Reference Checksum, and Calculated Checksum of the GPL or the specific tablein question.
RLGHNCXA21W 07-01-06 13:46:23 EST EAGLE 41.0.0
0014.1187 CARD 1113 INFO Table Checksum Mismatch
TBL ID = 136 CALC CHKSUM=H’B7C0 REF CHKSUM=H’4A5F
Recovery
Refer to the recovery procedure for the appropriate UAM that accompanied this alarm.
3.3.185 1188 - DB Subset Checksum Mismatch
This message indicates additional diagnostic information in the event of DB corruption alarm (UAM 35, 38, or 427). Whenever a DB corruption is detected during the DB audit, this UIM 1188 is also output to provide the Table ID, Reference Checksum, and Calculated Checksum of the DB Subset in question.
0008.1188 CARD 1113 INFO DB Subset Checksum Mismatch
SUBSET = 3 CALC CHKSUM = H'abcd REF CHKSUM = H'
Report Date:03-01-06 Time:13:46:25Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.186 1189 - SCCP did not Route - DPC not in RTE Table
SCCP did not route a message because the destination point code (DPC) is not in the route (RTE) table. The message was discarded.
Example
0018.1189 CARD 1103,A INFO SCCP did not Route - DPC not in RTE Table
TRANSLATED PC=003-003-003 TRANSLATED SS=005
LSN=ABCD123 GTTSET=3 (8)
- ADD
- Address
- CDPA
- CGPA
- GTI
- Global title indicator
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- Nature of address indicator
- NI
- Network indicator value
- NP
- Numbering plan
- PC
- Point code
- PCI
- Point code indicator
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- Subsystem number indicator
- TT
- Translation type
- TRANSLATED PC
- Translated point code
- TRANSLATED SS
- Translated subsystem
If Global Title Translation is found, the GTTSET in which the translation is found appears. If Global Title Translation is not found, the GTTSET does not display.
Recovery
Check the absence of the DPC in the Routing table by entering the appropriate DPC type (DPCA, DPCN, DPCN24, whichever is applicable).
rtrv-rte:dpc=<ni-nc-ncm>
- If routing to this destination is required, provision
the Routing table.
See Configuring Destination Tables - Adding a Destination Point Code in the Database Administration Manual - SS7
- If routing to this destination is not required,
remove the destination point code from the Routing table.
See Configuring Destination Tables - Removing a Destination Point Code in the Database Administration Manual - SS7.
3.3.187 1190 - SCCP rcvd inv Clg Party - bad GT ind
The SCCP received a message from the network that was discarded because of a bad global title indicator in the calling party address and that GTT on CGPA is required.
Example
0018.1190 CARD 1103,A INFO SCCP rcvd inv Clg Party - bad GT ind
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADD
- Address
- CDPA
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- Nature of address indictor
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- TRANSLATED SS
Recovery
3.3.188 1191 - SCCP rcvd inv Clg Party - bad Selectors
The SCCP received a message from the network requiring CGPA GTT, but the Enhanced GTT could not find a CGPA GTT set using the CGPA GTT selectors from the message.
Example
0018.1191 CARD 1103,A INFO SCCP rcvd inv Clg Party - bad Selectors
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADD
- Address
- CDPA
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- TRANSLATED SS
Recovery
3.3.189 1192 - GTT Action UDTS DISCARDED MSU
GTT is found with a UDTS action.
Example
8878.1192 CARD 1101 INFO GTT Action UDTS DISCARDED MSU
OPC= 7-112-0 DPC= 1-001-0
CDPA: NI=0 RI=0 GTI=04 SSNI=1 PCI=0
TT=111 NP=01 NAI=002 ADDR=123456
PC=-------------- SSN=006
CGPA: NI=0 RI=1 GTI=02 SSNI=1 PCI=1
TT=017 NP=-- NAI=--- ADDR=999997999999990999999
PC= 7-112-0 SSN=008
SMRPOA: NP=1 NON=5 ADDR=55566677770000
LSN=ls711200 Op-Code= 46 GTT Action Set=scpval1
Report Date:02-12-09 Time:01:22:05
PC= 7-112-0 SSN=008
- ADD
- Address
- CDPA
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- TRANSLATED SS
Recovery
To prevent the MSU from being discarded post-GTT, remove the "UDTS" GTT action associated with the GTT translation. If you want to suppress this UIM, turn off the UIMREQD option for the given "UDTS" GTT action.
3.3.190 1193 - GTT Action DISCARD DISCARDED MSU
GTT is found with a DISCARD action.
Example
8872.1193 CARD 1101 INFO GTT Action DISCARD DISCARDED MSU
OPC= 1-202-1 DPC= 1-202-4
PC= 3-003-3 SSN=241
CGPA: NI=0 RI=1 GTI=04 SSNI=0 PCI=1
TT=000 NP=01 NAI=000 ADDR=00
PC= 1-202-1 SSN=---
Op-Code=--- Action Set=disc1
Report Date:02-12-09 Time:01:20:45
PC= 3-003-3 SSN=241
PC= 1-202-1 SSN=---
- ADD
- Address
- CDPA
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- TRANSLATED SS
Recovery
3.3.191 1194 - IP Connection Refused, RHOST Mismatch
This message indicates that an association in MATCH validation mode cannot be established due to mismatch in configured RHOST or ARHOST with the INIT message contents.
station1234 09-09-21 16:28:08 EST Rel 41.0.0-62.6.0
0003.1194 CARD 1213,A INFO IP Connection Refused, RHOST mismatch
RPORT = 1314
LPORT = 1315
SNAME = LONGSOCKETNAME1
Recovery
Check ARHOST provisioning.
3.3.192 1195 - SCCP did not route - DPC/SS not in mapset
The SCCP did not route a message because the destination point code and destination subsystem was not in the mapset. The message was discarded.
Example
0018.1195 CARD 1103,A INFO SCCP did not route - DPC/SS not in mapset
- ADD
- Address
- CDPA
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- TRANSLATED SS
Recovery
- If the DPC/SS indicated in the message should not be routed to, no further action is necessary.
- If the DPC/SS should be routed to from the EAGLE 5
ISS, use the
ent-mapcommand to enter the DPC/SS into the mapset (obtained as outcome of GT translation, with which load sharing is desired) in the MAP table.
3.3.193 1196 - IP Connection Congestion Timeout
This UIM indicates an M3UA or SUA association on the IPGWx GPL has been congested for 30 seconds. At the end of the 30 second period, the congested association is moved to the out-of-service state. All traffic buffered for the association is discarded, at which time this UIM message is displayed.
To prevent a M3UA or a SUA association from remaining congested forever, a 30 second timer is started when an association becomes congested. A separate timer is started for each association that becomes congested.
Approximately one second after the traffic has been discarded, the association is automatically allowed to accept incoming requests to reestablish the association. The timer is not configurable and is not displayed.
0003.1196 CARD 1213,A INFO IP Connection Congestion Timeout
ANAME = LONGASSOCNAME1
Recovery
This is an informational message. No further action is necessary.
3.3.194 1197 - IP Connection Refused
Reports that an attempt to connect to an IP client was rejected by the client.
0003.1197 DCM 1213,A IP Connection refused
RPORT = 1314
LPORT = 1315
SNAME=Unknown
Recovery
No action necessary.
3.3.195 1198 - IP Connection, Cannot resolve RHOST(S)
Reports that an attempt to connect to an IP client failed because the hostname, RHOST and ARHOST (if configured), could not be found on the IP network.
RLGHNCXA03W 02-07-21 16:20:19 EST EAGLE 41.0.0
0003.1198 CARD 1213,A INFO IP Connection, Cannot resolve RHOST(S)
RIPADDR = Unknown
RPORT = 1314
LPORT = 1315
Recovery
3.3.196 1199 - LNP DTH Measurements Discarded for DPC
Reports that LNP DTH measurements are being discarded because the capacity of the SSP DTH table has been exceeded.
RLGHNCXA03W 00-04-10 16:28:08 EST EAGLE 35.0.0
1234.1199 SYSTEM INFO LNP DTH Measurements Discarded for DPC
DPC=001-001-001
Non-Zero Measurements Discarded: Yes
Recovery
3.3.197 1200 - INW ALT Card as First to be Preloaded
Reports the alternate card the system selected to be loaded with GPLs and data.
0014.1200 SYSTEM INFO INW ALT card as first to be preloaded
CARD=1203 GPL=SS7ANSI
Recovery
3.3.198 1201 - INW MAIN Card as Last to be Reset
Reports the main card the system selected to be loaded with GPLs and data.
0014.1201 SYSTEM INFO INW MAIN card as last to be reset
Recovery
3.3.199 1202 - INW Asserted DDL Inhibition
Reports that card cross loading is inhibited.
0014.1202 SYSTEM INFO INW Asserted DDL inhibition
Recovery
3.3.200 1203 - INW Card reset command issued
Reports that a card reset command has been issued.
0014.1203 SYSTEM INFO INW Card reset command issued
Recovery
3.3.201 1204 - INW Waiting for Card Loading Validation
Reports that INW is waiting for validation of card loading.
0014.1204 SYSTEM INFO INW Waiting for card loading validation
Recovery
3.3.202 1205 - INW Detected Card Loaded
Reports that INW has detected a successful completion of a card loading.
0014.1205 SYSTEM INFO INW Detected card loaded
Recovery
3.3.203 1206 - INW Detected Card Reset or Removed
Reports that INW has detected the reset or removal of a card.
0014.1206 SYSTEM INFO INW Detected card reset or removed
Recovery
3.3.204 1207 - INW Allowed Card to Skip DDL Inhibited
Reports that a card is being allowed to crossload.
0014.1207 SYSTEM INFO INW Allowed card to skip DDL inhibited
Recovery
3.3.205 1208 - INW Removed DDL inhibition
Reports that INW has removed the Dynamic Data Loading (DDL) inhibition on a card.
0014.1208 SYSTEM INFO INW Removed DDL inhibition
CARD=1203 GPL=SS7ANSIAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.206 1209 - INW Need to reset/remove/inhibit card
Reports that card must be manually reset, removed, or inhibited.
0014.1209 SYSTEM INFO INW Need to reset/remove/inhibit card
Recovery
3.3.207 1210 - INW Card failed to reset
Reports that card has failed to reset.
0014.1210 SYSTEM INFO INW Card failed to reset
Recovery
3.3.208 1211 - INW Failed to assert DDL inhibition
Reports that a DDL inhibition has failed.
0014.1211 SYSTEM INFO INW Failed to assert DDL inhibition
Recovery
3.3.209 1212 - INW Failed to remove DDL inhibition
Reports that an attempt to remove DDL inhibition has failed.
0014.1212 SYSTEM INFO INW Failed to remove DDL inhibition
Recovery
3.3.210 1213- INW Card failed to DDL crossload
Reports that a card failed to DDL crossload.
0014. SYSTEM INFO INW Card failed to DDL crossload
Recovery
3.3.211 1214 - INW Allowed card to DDL crossload
Reports that a card was allowed to crossload.
0014.1214 SYSTEM INFO INW Allowed card to DDL crossload
Recovery
3.3.212 1215 - GWS rcvd CDPA That Could Not be CNCFd
This message indicates the EAGLE 5 ISS received an MSU, with a called party address (CDPA) that is not allowed in gateway screening (GWS) and cannot be converted.
0101.1215 CARD 1205,B INFO GWS rcvd CDPA that could not be CNCFd
SCCP MT= 18
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.213 1216 - GWS rcvd CGPA that could not be CNCFd
This message indicates the EAGLE 5 ISS received an MSU, with a calling party address (CGPA) that is not allowed in gateway screening (GWS) and cannot be converted.
0101.1216 CARD 1205,B INFO GWS rcvd CGPA that could not be CNCFd
SCCP MT= 18
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.214 1217 - GWS rcvd AFTPC that could not be CNCFd
This message indicates the EAGLE 5 ISS received an MSU, with an allowed affected point code (AFTPC) that is not allowed in gateway screening (GWS) and cannot be converted.
0101.1217 CARD 1205,B INFO GWS rcvd AFTPC that could not be CNCFd
SCCP MT= 18
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.215 1218 - GWS rcvd TT that could not be CNCFd
This message indicates the EAGLE 5 ISS received an MSU, with a translation type (TT) that is not allowed in gateway screening (GWS) and cannot be converted.
0101.1218 CARD 1205,B INFO GWS rcvd TT that could not be CNCFd
SCCP MT= 18
- ADDR
- Address
- AFTPC
- AFTSS
- AI
- Address Indicator
- CDPA
- CGPA
- DATA
- DPC
- H0H1
- LSN
- MULT
- OPC
- PC
- SCCP MT
- SCCP message type
- SCMG
- SIO
- SR
- SSN
- Subsystem number
- TT
- Translation type
- TYPE
Recovery
3.3.216 1231 - SCCP Encode Failure
This message indicates that there is an SCCP encode failure.
Example
tekelecstp 08-12-26 17:02:48 EDT EAGLE 41.0
5093.1231 CARD 1105 INFO SCCP Encode Failure
SIO=03 OPC= 2-011-1 DPC= 1-001-1
CDPA LENGTH=008 MSG TYPE=09 INV DMA LEN=280
CDPA: AI=0b PC= 1-001-0 SSN=002 TT=000
ADDR=123456
LSN=lsn2111
Report Date:08-12-26 Time:17:02
5133.1231 CARD 1105 INFO SCCP Encode Failure 2
SCCP MSG TYPE=09 INV DMA LEN=280
CDPA: NI=0 RI=0 GTI=02 SSNI=1 PCI=1
TT=000 NP=-- NAI=--- ADDR=123456
PC= 1-001-0 SSN=002
TT=027 NP=-- NAI=--- ADDR=123410
PC= 2-011-1 SSN=002
LSN=lsn2111 GTTSET=(1)
Report Date:08-12-26 Time:17:51:26
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- Called party address length
- CDPA
- CGPA
- DPC
- MSG TYPE
- optional text field
- Optional text field providing additional
information about the error. Possible text display and definitions may include:
- INV DMA LEN=xxx
- DMA Length too big or too small: After SCCP encoding of translated MSU DMA Length became too big or too small.
- UNSUP Clg GTI=x
- GTT attempted on Unsupported CgPA GTI=x
- UNSUP Cld GTI=x
- GTT attempted on Unsupported CdPA GTI=x
- INV Clg GTI=x
- GTT attempted on INV CgPA GTI=x
- INV Cld GTI=x
- GTT attempted on INV CdPA GTI=x
- GTCNV:Cld ANSI->ITU fail
- Invalid CdPA GTI for ANSI-to-ITU GTCNV table: ANSI MSU is GTT translated to ITU, CdPA GTA record has NGTI as not provisioned, so GTT is using Default GTT (GTCNV table) to convert CdPA, but CdPA GTCNV Selectors (GTI, TT) are not found in GTCNV table
- GTCNV:Clg ANSI->ITU fail
- Invalid CgPA GTI for ANSI-to-ITU GTCNV table: ANSI MSU is GTT translated to ITU, CgPA RI=GT, SCCP Conversion used Default GTT (GTCNV table) to convert CgPA, but CgPA GTCNV Selectors (GTI, TT) are not found in GTCNV table
- GTCNV:Cld ITU->ANSI fail
- Invalid CdPA GTI for ITU-to-ANSI GTCNV table: ITU MSU is GTT translated to ANSI, CdPA GTA record has NGTI as not provisioned, so GTT is using Default GTT (GTCNV table) to convert CdPA, but CdPA GTCNV Selectors (GTI, TT, possibly NP and NAI if GTI=4) are not found in GTCNV table
- GTCNV:Clg ITU->ANSI fail
- Invalid CgPA GTI for ITU-to-ANSI GTCNV table: ITU MSU is GTT translated to ANSI, CgPA RI=GT, SCCP Conversion used Default GTT (GTCNV table) to convert CgPA, but CgPA GTCNV Selectors (GTI, TT, possibly NP and NAI if GTI=4) are not found in GTCNV table
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
Contact the distant end node this message refers to and verify action is being taken to correct the SCCP encode failure problem.
3.3.217 1232 - SCCP Encode Failure
This message indicates that there is an SCCP encode failure. This UIM may be triggered by a service when network crossing (ANSI <-> ITU) is attempted, or the problem could originate at the far end.
Example
5093.1232 CARD 1105 INFO SCCP Encode Failure 2
ADDR=123456
LSN=lsn2111
5133.1232 CARD 1105 INFO SCCP Encode Failure 2
PC= 1-001-0 SSN=002
PC= 2-011-1 SSN=002
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- INV DMA LEN=xxx
- UNSUP Clg GTI=x
- UNSUP Cld GTI=x
- INV Clg GTI=x
- INV Cld GTI=x
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code
- PCI
- Protocol control information
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.218 1233 - MTP Invalid ITU TFR RCVD
This message indicates an ITU TFR (Transfer Restricted) procedure was received on a linkset that is not configured to receive these procedures.
RLGHNCXA21W 00-11-18 19:12:00 EST EAGLE 35.0.0
0147.1233 CARD 1201,A INFO MTP Invalid ITU TFR RCVD
LSN=lsn01a
Recovery
3.3.219 1234 - LNP Day Meas. Discarded for NPANXX
This message is indicates the Daily LNP NPANXX measurement counts are incorrect because of discards due to provisioning.
station5 00-04-18 19:12:00 EST EAGLE 31.0
0002.1234 CARD 1201 INFO LNP Day Meas. Discarded for NPANXX
Recovery
Correct counts can be derived via calculation from LNP queries - discards - LRN pegs.
3.3.220 1235 - Unable to connect Primary SFLOG Server
This message indicates the connection to Primary SFLOG server cannot be established.
Example
0002.1235 CARD 1201 INFO Unable to connect Primary SFLOG server
IP: 123.678.123.467 FTP Error: 24
File Name: tekelecstp_sflog_150429_031655.pcap
Report Date: 15-04-30 Time: 16:27:19
Recovery
3.3.221 1236 - Unable to connect both SFLOG Servers
This message indicates the connection to the Primary and Secondary SFLOG servers cannot be established.
Example
0002.1236 CARD 1202 INFO Unable to connect both SFLOG servers
IP: 123.678.123.467 FTP Error: 11
Recovery
3.3.222 1237 - Dynamic database audit not current
The dynamic database audit cannot determine whether the dynamic database is inconsistent because there has not been the required quiet period (500 milliseconds by default) to perform the audit. There are always inconsistencies among the copies of the dynamic database on the LIM and Service Module cards while the networks is updating the cards.
0014.1237 SYSTEM INFO Dynamic database audit not current
Recovery
- Determine whether there are issues with links, point codes, linksets, or SSN that are causing network status changes. If so, use your site's normal procedures to address the problems.
- Contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.3.223 1238 - Full LNP Database Reload Initiated
This message indicates that a cold restart is required for a TSM/BLM card. In this case, the entire LNP database is reloaded to the card.
station1234 96-08-01 16:28:08 EST EAGLE 35.0.0
1234.1238 SYSTEM INFO Full LNP database reload initiated:
CARD=1101 GPL=SCCP CAUSE=<xxxxxxxx>where <xxxxxxxx> is one of the following parameters:
Table 3-12 CAUSE Parameters
| Parameter | Description |
| XILINX | M256 Xilinx version has changed. |
| POWER ON | Power on reset. |
| DB VER | LNP database version has changed. |
| DB LVL | Database level is not supported or difference exceeds incremental loading capability. |
| HW ERR | Hardware error bit checks on the card fail. |
| CHECKSUM | Checksum comparisons of the LNP database fail. |
| NO AUDIT | Unable to perform LNP DB audit. LNP audit not on or excessive number of unknown checksums. |
| USER REQ | User initiated init-card or init-sys command reload type cold. |
| OTHER | Other or unknown. |
Recovery
3.3.224 1239 - Ntwrk Card Reload Failed during Upg
This message indicates the OAM has determined that a card has failed to load.
Example
xxxx.1239 SYSTEM INFO Ntwrk Card Reload Failed during Upg
CARD=1103 GPL=SS7ANSI
Report Date:02-01-08 Time:01:24:34 Alarm Level: No alarm condition. The message is informational only.
Recovery
- Manually download card(s) running non-approved flash.
3.3.225 1240 - MAP SCCP Validation Fail
This message indicates that the MAP and SCCP parameter validation performed by SCPVAL GTT Action has failed. Look for the validation failure reason printed by the UIM.
Example
5072.1240 CARD 1105 INFO GTT Action MAP-SCCP validation FAILED
Cause: SMRPDA-CDPA Digits Mismatch
OPC= 7-101-0 DPC= 1-001-0
CDPA: NI=0 RI=0 GTI=04 SSNI=0 PCI=1
TT=010 NP=01 NAI=004 ADDR=9192051234
PC= 1-001-0 SSN=---
PC= 7-101-0 SSN=008
SMRPDA: NP=1 NON=1 ADDR=9192056000
LSN=ls710100 Op-Code= 46 GTT Action Set=scpval1
Report Date:15-08-01 Time:15:50:30
Recovery
3.3.226 1241 - SCCP/SFAPP Card logging capacity exceeded
This message indicates the SCCP/SFAPP card logging capacity has been exceeded.
Example
XXXX.1241 CARD XXXX INFO SCCP/SFAPP Card logging capacity exceeded
Recovery
Reduce the card logging below the recommended capacity level.
3.3.227 1242 - Conv to intl num - Dflt CC not found
This message indicates that the default country code is not defined.
Example
0018.1242 CARD 1103,A INFO Conv to intl num - Dflt CC not found
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- Global title indicator [/concept/concept/task/taskbody/context/p/dl/dlentry/dt {"acro"}) LSN (dt]
- MSG TYPE
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Define the default CC using the
chg-stpopts:defcc command. Refer to the
Commands Manual for the proper usage.
3.3.228 1243 - Conv to intl num - Dflt NC not found
This message indicates that the default network destination code is not defined.
Example
0018.1243 CARD 1103,A INFO Conv to intl num - Dflt NC not found
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- MSG TYPE
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
chg-stpopts:defndc command. Refer to
the
Commands Manual
3.3.229 1244 - Conv to intl num - Dflt MCC Not Found
This message indicates that the default E212 mobile country code is not defined.
station1234 99-08-30 16:28:08 EST EAGLE 35.0.0
0018.1244 CARD 1103,A INFO Conv to intl num - Dflt MCC not found
SCCP MSG TYPE=04
LSN=A1234567
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
chg-gsmopts:defmcc command. Refer to the
3.3.230 1245 - Conv to intl num - Dflt MNC Not Found
This message indicates that the default E212 mobile network code is not defined.
0018.1245 CARD 1103,A INFO Conv to intl num - Dflt MNC not found
SCCP MSG TYPE=04
LSN=A1234567
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
chg-gsmopts:defmnc command. Refer to
the
3.3.231 1246 - Invalid Length of Conditioned Digits
This message indicates that the length of the conditioned international number is less than 5 or greater than 15 digits.
Example
RLGHNCXA21W 02-07-21 16:20:19 EST EAGLE 46.3.0.0
0018.1246 CARD 1103,A INFO Invalid length of conditioned digits
SCCP MSG TYPE=04
INCM DN: 4605523
COND DN: 19194605523
SCCP MSG TYPE=04
INCM DN: 4605523
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Use an international number that is within the proper range - 5 or greater and 15 or less.
3.3.232 1247 - Conversion of MGT to IMSI not possible
This message indicates that the E212 mobile country code for the E214 mobile network code is not defined.
0018.1247 CARD 1103,A INFO Conversion of MGT to IMSI not possible
SCCP MSG TYPE=04
LSN=A1234567
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Enter the E214 part for the E214 code in the database
using the
chg-gsmopts:ccnc=xxxxxxxx:mccmnc=xxxxxxx command. Refer
to the
3.3.233 1248 - GSM MAP Screening rcvd unknown originator
This message occurs when an MSU arrives with a SSN and MAP Op-Code that exist in the GSM SSN and MAP Op-Code tables, but the CGPA address does not exist in the GSM MAP Screening table or the CgPA address exists in the table but with an incorrect NPV/NAIV. In this case, the default action for the Op-Code applies.
RLGHNCXA21W 00-11-18 18:59:23 EST EAGLE 35.0.0
0018.1248 CARD 1103 INFO GSM MAP Screening rcvd unknown originator
OPC=001-001-001
Op-Code=61 Forbidden Param=N/A Action=Discard
- ADDR
- Address
- CDPA
- CGPA
- DATA
- GTI
- NAI
- NI
- NP
- Numbering plan
- OP-CODE
- Operation Code
- OPC
- PARAM
- Parameter
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.234 1249 - SCCP rcvd GSM MAP Opcode w/forbidden param
This message occurs when an MSU is screened in the GSM MAP Screening table and the MSU was found to contain a forbidden parameter as provisioned in the GSM MAP Screening table. The action that applies is taken from the matching entry in the GSM MAP Screening table.
0018.1249 CARD 1103 INFO SCCP rcvd GSM MAP Op-Code w/forbidden param
OPC=001-001-001
Op-Code=### Forbidden Param=N/A Action=PASS
- ADDR
- Address
- CDPA
- CGPA
- DATA
- GTI
- NAI
- NI
- NP
- Numbering plan
- OP-CODE
- Operation Code
- OPC
- PARAM
- Parameter
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.235 1250 - SCCP rcvd undefined MAP Op-Code
This message occurs when an MSU passes the origination or destination SSN screening process and the MAPOp-Code table is searched, but the Op-Code of the MSU is not found in the MAP Op-Code table. In this case, the default action from the STPOPTS table applies.
0018.1250 CARD 1103 INFO SCCP rcvd undefined MAP Op-Code
OPC=001-001-001
Op-Code=### Forbidden Param=N/A Action=ATIERR
- ADDR
- Address
- CDPA
- CGPA
- DATA
- GTI
- NAI
- NI
- NP
- Numbering plan
- OP-CODE
- Operation Code
- OPC
- param
- Parameter
- PC
- Point code
- pci
- ri
- Routing indicator
- SIO
- SSN
- Subsystem number
- ssni
- TT
- Translation type
Recovery
- The GSM MAP Op-Code table was searched, and the Op-Code of the MSU was not found.
- The GSM MAP Op-Code table has successfully screened an Op-Code that was not included in the GSM MAP Opcode table.
- However, if the Op-Code should not be screened, you can add it into the GSM MAP Op-Code table.
- To alter the screening being performed, change the default action for GSM screening when the Op-Code is not defined with the STPOPTS commands.
3.3.236 1251 - Measurements Data Copy Failure
Measurements data is copied to all MCPM cards after collection. Measurements data copy to a Secondary MCPM failed.
station5 00-04-18 19:12:00 EST EAGLE 31.3.0
0002.1251 CARD 1201 INFO Measurements data copy failure
Recovery
There is no immediate action needed, but the message indicates that the error was encountered.
3.3.237 1252 - Report Generation Failure
This message is generated by the Primary MCPM. The measurement report identified in the output message did not generate.
0002.1252 CARD 1201 INFO Report generation failure
IP:111.111.111.111 FTP Error: XXXX
File Name: tues_serv.csv
Recovery
Enter the
rept-ftp-meas command to manually
initiate the generation and FTP transfer of the indicated measurement report.
Refer to the Commands Manual for the correct usage of this command.
3.3.238 1253 - Report transfer failure FTP Server
This message is generated by the Primary MCPM. The FTP transfer of the indicated report failed.
0002.1253 CARD 1201,A INFO Report transfer failure FTP Server
Recovery
Enter the
Refer to the
Commands Manual
3.3.239 1254 - Scheduled transfer failure
This message is generated by the Primary MCPM. Some of the reports scheduled to be generated and transferred were not transferred.
0002.1254 CARD 1201 INFO Scheduled transfer failure
Recovery
Enter the
initiate the generation and FTP transfer of the affected measurement report.
Refer to the
3.3.240 1255 - IS-41 LNP Qry rejected: WNP is OFF
The EAGLE has rejected an LNPQS query that is decoded as an IS-41 Query because the appropriate WNP (Wireless Number Portability) feature is not on.
RLGHNCXA21W 03-04-18 19:02:05 EST EAGLE 31.3.0
0112.1255 CARD 1103,A1 INFO IS-41 LNP Qry rejected: WNP is OFF
SIO=83 OPC=001-101-001 DPC=001-001-001
CDPA: AI=cb SSN=016 TT=012
ADDR=919380
CGPA: AI=c3 PC=001-101-001 SSN=016
LSN=e1m1s1
- ADDR
- Address
- AI
- Address Indicator
- cdpa length
- CGPA
- DATA
- DPC
- LSN
- MSG TYPE
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
- If you want to support the WNP feature, issue the
chg-feat:wnp=oncommand to process IS-41 LNP queries. - If you do not want to support the WNP feature, ignore this informational message.
- For additional information or assistance about the WNP or any feature to purchase, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.3.241 1256 - NP Circular Route Detected
This message indicates the network has incorrect number portability data for a subscriber.
Example
0018.1256 CARD 1103,A INFO NP Circular Route Detected
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DATA
- GTI
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Verify and update number portability data.
3.3.242 1257 - DB restore has cleared and Disabled PDS
A DB restore has rendered the data on PDS table obsolete. The PDS table will be updated when the OAM is rebooted.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 35.0.0
0014.1257 SYSTEM INFO DB restore has cleared and Disabled PDS
Recovery
3.3.243 1258 - Map Screening cannot Forward MSU
This message occurs when an MSU selected by MAP Screening for the Forward screening action cannot be forwarded.
Additional reasons for this alarm include:- If unsupported domain crossing is occurring (from or to ANSI/ITUN24)
- If Alias PC was not found for CgPA PC
- If there is no space to insert CdPA PC when it was not there in the original MSU
0018.1258 CARD 1103 INFO Map Screening cannot Forward MSU
OPC=001-001-001
- ADDR
- Address
- CDPA
- CGPA
- Calling party address
- DATA
- GTI
- NAI
- NI
- NP
- Numbering plan
- OP-CODE
- Operation Code
- OPC
- Origination point code
- PARAM
- Parameter
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- Service information octet
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
- If the DPC indicated in the message should not be routed to, no further action is necessary.
- If the DPC should be routed to from the EAGLE 5 ISS,
use the
ent-mapcommand to enter the DPC into the mated application (MAP) table. - If the subsystem indicated in the message is not a mated application to the EAGLE 5 ISS, no further action is necessary.
- If the SCCP message should have been routed, use the
ent-mapcommand to add the subsystem number to the mated application (MAP) table.
3.3.244 1259 - Map Screening cannot Duplicate MSU
This message occurs when an MSU selected by MAP Screening for the Duplicate screening action cannot be duplicated and/or routed to the duplicate node.
0018.1259 CARD 1103 INFO Map Screening cannot Duplicate MSU
OPC=001-001-001
- ADDR
- Address
- CDPA
- CGPA
- DATA
- GTI
- NAI
- NI
- NP
- Numbering plan
- OP-CODE
- Operation Code
- OPC
- PARAM
- Parameter
- PC
- Point code
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
use the
3.3.245 1260 - LSS: Unsupported TCAP msg type
This message indicates that the LSS (local subsystem) received an SCCP message containing an unsupported TCAP (transaction capabilities application portion) message type.
RLGHNCXA21W 99-12-18 18:59:23 EST EAGLE 31.3.0
0101.1260 CARD 1103,A1 INFO LSS: Unsupported TCAP msg type
CDPA: AI=52 SSN=005 TT=250
CGPA: AI=43 PC=001-001-001 SSN=002
LSN=A1234567
Recovery
3.3.246 1261 - LSS: Invalid len in transaction portion
This message indicates that the LSS (local subsystem) received a TCAP message containing an invalid length in the transaction portion of the message.
0101.1261 CARD 1103,A1 INFO LSS: Invalid len in transaction portion
ADDR=ABCDEF1234567890ABCDE
LSN=A1234567
Recovery
3.3.247 1262 - LSS: Invalid len in dialogue portion
This message indicates that the LSS (local subsystem) received a TCAP message with an invalid length in the dialogue portion of the message.
0101.1262 CARD 1103,A1 INFO LSS: Invalid len in dialogue portion
LSN=A1234567
Recovery
3.3.248 1263 - LSS: Invalid len in component portion
This message indicates that the LSS (local subsystem) received a TCAP message with an invalid length in the component portion of the message.
0101.1263 CARD 1103,A INFO LSS: Invalid len in component portion
LSN=A1234567
Recovery
3.3.249 1264 - LSS: No originating transaction ID
This message indicates that the LSS (local subsystem) received a TCAP message that does not have an originating transaction ID.
0101.1264 CARD 1103,A1 INFO LSS: No originating transaction ID
LSN=A1234567
Recovery
3.3.250 1265 - LSS: Invalid transaction ID len
This message indicates that the LSS (local subsystem) received a TCAP message containing an invalid transaction ID length.
0101.1265 CARD 1103,A1 INFO LSS: Invalid transaction ID len
LSN=A1234567
Recovery
3.3.251 1266 - LSS: Destination transaction ID in Begin
This message indicates that the LSS (local subsystem) received a Begin TCAP message containing a destination transaction ID. (The Begin message should have an originating transaction ID only. A destination transaction ID is valid only in Abort, Continue, and End TCAP messages.)
0101.1266 CARD 1103,A1 INFO LSS: Destination transaction ID in Begin
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- Destination point code
- LSN
- Linkset name. The name must be unique.
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.252 1267 - LSS: No External element
This message indicates that the LSS (local subsystem) received a TCAP message that does not contain an External element in the dialogue portion of the message.
0101.1267 CARD 1103,A1 INFO LSS: No External element
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.253 1268 - LSS: No External Object Identifier
This message indicates that the LSS (local subsystem) received a TCAP message that does not contain an Object Identifier element in the External element in the dialogue portion of the message.
0101.1268 CARD 1103,A1 INFO LSS: No External Object Identifier
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.254 1269 - LSS: Not Structured Dialogue
This message indicates that the LSS (local subsystem) received a TCAP message with an Object Identifier value in the External element in the dialogue portion that does not indicate a structured dialogue as specified in ITU Q.773.
0101.1269 CARD 1103,A1 INFO LSS: Not Structured Dialogue
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.255 1270 - LSS: No External ASN1-Type
This message indicates that the LSS (local subsystem) received a TCAP message that does not have an ASN1-Type element in the External element in the dialogue portion of the message.
0101.1270 CARD 1103,A1 INFO LSS: No External ANS1-Type
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.256 1271 - LSS: No Dialogue Request
This message indicates that the LSS (local subsystem) received a TCAP message that odes not have a Dialogue Request element in the ASN1-Type element in the dialogue portion of the message.
0101.1271 CARD 1103,A1 INFO LSS: No Dialogue Request
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.257 1272 - LSS: No Application Context Name
This message indicates that the LSS (local subsystem) received a TCAP message that does not have an Application Context Name element in the Dialogue Request element in the dialogue portion of the message.
0101.1272 CARD 1103,A1 INFO LSS: No Application Context Name
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.258 1273 - LSS: No ACN Object Identifier
This message indicates that the LSS (local subsystem) received a TCAP message that does not have an Object Identifier element in the Application Context Name element in the dialogue portion of the message.
0101.1273 CARD 1103,A1 INFO LSS: No ACN Object Identifier
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.259 1274 - LSS: No component portion
This message indicates that the LSS (local subsystem) received a TCAP message that does not contain a component portion tag.
0101.1274 CARD 1103,A1 INFO LSS: No component portion
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.260 1275 - LSS: No Invoke component
This message indicates that the LSS (local subsystem) received a TCAP message that does not contain an Invoke component.
0101.1275 CARD 1103,A1 INFO LSS: No Invoke component
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.261 1276 - LSS: No Invoke ID
This message indicates that the LSS (local subsystem) received a TCAP message that does not contain an Invoke ID within the component.
0101.1276 CARD 1103,A1 INFO LSS: No Invoke ID
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.262 1277 - LSS: No operation code
This message indicates that the LSS (local subsystem) received a TCAP message that does not contain an operation code tag within the component.
0101.1277 CARD 1103,A2 INFO LSS: No operation code
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.263 1278 - LSS: No parameter (set/sequence)
This message indicates that the LSS (local subsystem) received a TCAP message that does not contain a parameter, parameter set, or a parameter sequence within the component.
0101.1278 CARD 1103,A1 INFO LSS: No parameter (set/sequence)
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.264 1279 - LSS: Unsupported network type
This message indicates that the LSS (local subsystem) received an SCCP message of an unsupported network type.
0101.1279 CARD 1103,A INFO LSS: Unsupported network type
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.265 1280 - LSS: Unsupported SCCP msg type
This message indicates that the LSS (local subsystem) received an SCCP message of an unsupported SCCP message type.
Example
0018.1280 CARD 1103,A INFO LSS: Unsupported SCCP msg type
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
Check translations on the originating switch to determine the trouble.
3.3.266 1282 - LSS: Unsupported SCCP CDPA GTI
This message indicates that the LSS (local subsystem) received an SCCP message for which the GTI (Global Title Indicator) value for the called party (CDPA) is unsupported.
0101.1282 CARD 1103,A1 INFO LSS: Unsupported SCCP CDPA GTI
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.267 1283 - LSS: Unsupported SCCP CGPA RI
This message indicates that the LSS (local subsystem) received an SCCP message for which the RI (Routing Indicator) value for the calling party (CGPA) is unsupported.
0101.1283 CARD 1103,A1 INFO LSS: Unsupported SCCP CGPA RI
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.268 1284 - LSS: Unknown SSP PC
This message indicates that the LSS (local subsystem) received an SCCP message that contained an SSP (Service Switching Point) point code (PC) that is not in the Eagle routing table. The SSP PC is the CGPA PC (if it exists) or the OPC, otherwise. In the example below, the SSP PC is 001-001-002.
0101.1284 CARD 1103,A2 INFO LSS: Unknown SSP PC
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.269 1285 - LSS: No SCCP CGPA SSN
This message indicates that the LSS (local subsystem) received an SCCP message in which the subsystem number (SSN) for the calling party (CGPA) is missing.
0101.1285 CARD 1103,A1 INFO LSS: No SCCP CGPA SSN
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.270 1286 - LSS: Invalid INAP/CAMEL digits length
This message indicates that the LSS (local subsystem) received an INAP message in which the Called Party Number parameter length is invalid.
RLGHNCXA21W 07-12-18 18:59:23 EST EAGLE 37.6.0
0101.1286 CARD 1103,A1 INFO LSS: Invalid INAP/CAMEL digits length
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
No action is necessary. The querying node should be modified to generate less than 22 digits in the parameter.
3.3.271 1287 - LSS: Unsupported ACN Object ID len
This message indicates that the LSS (local subsystem) received a TCAP message in which the length of the Application Context Name’s Object Identifier is unsupported.
0101.1287 CARD 1103,A1 INFO LSS: Unsupported ACN Object ID len
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.272 1288 - LSS: Unsupported operation code
This message indicates that the LSS (local subsystem) received a TCAP message in which the operation code is unsupported.
0101.1288 CARD 1103,A1 INFO LSS: Unsupported operation code
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.273 1289 - LSS: No parameter sequence
This message indicates that the LSS (local subsystem) received a TCAP message that has a single parameter or a parameter set instead of the expected parameter sequence.
0101.1289 CARD 1103,A1 INFO LSS: No parameter sequence
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.274 1290 - LSS: No INAP ServiceKey parameter
This message indicates that the LSS (local subsystem) received an INAP message that does not contain the Service Key parameter.
0101.1290 CARD 1103,A1 INFO LSS: No INAP ServiceKey parameter
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.275 1291 - LSS: No INAP/CAP CalledPartyNumber param
This message indicates that the LSS (local subsystem) received an INAP message that does not contain an Called Party Number parameter.
0101.1286 CARD 1103,A1 INFO LSS: No INAP/CAP CalledPartyNumber param
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.276 1292 - LSS: Parameters out of sequence
This message indicates that the LSS (local subsystem) received a TCAP message in which the mandatory and conditional parameters are not in the correct sequence.
0101.1292 CARD 1103,A1 INFO LSS: Parameters out of sequence
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.277 1293 - LSS: Invalid num of digits in INAP CdPN
This message indicates that the LSS (local subsystem) received an INAP message containing an invalid number of digits in the Called Party Number (CdPN) parameter.
0101.1293 CARD 1103,A1 INFO LSS: Invalid num of digits in INAP CdPN
LSN=A1234567
- ADDR
- Address
- AI
- Address Indicator
- CGPA
- CDPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.278 1294 - Invalid digits in MAP MSISDN parameter
This message indicates that no valid digits were found in the MAP MSISDN parameter.
Example
0018.1294 CARD 1103,A INFO Invalid digits in MAP MSISDN parameter
SCCP MSG TYPE=04
CDPA: NI=1 RI=0 GTI=04 SSNI=0 PCI=1
CGPA: NI=1 RI=0 GTI=04 SSNI=0 PCI=1
TT=100 NP=07 NAI=012 ADDR=012345678901234567890
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- gti
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code for the SS7 end user (OPC).
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Change the message to have valid digits (digits length greater than 0) in the MSISDN parameter.
3.3.279 1295 - Translation PC is EAGLE 5 ISS’s
This message indicates that the point code translation is invalid because it is one the EAGLE 5 ISS’s own point codes.
Example
0018.1295 CARD 1103,A INFO Translation PC is EAGLE 5 ISS’s
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- add
- Address
- CDPA
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- TRANSLATED SS
Recovery
Change the translation point code for the entry to a non-Eagle’s point code.
Provision the entity data from the EPAP/ELAP. Refer to the EPAP Administration Manual or the ELAP Administration and LNP Feature Actiivation, and see the topic “Manage Network Entities” for details about changing this entity data.
3.3.280 1296 - Translation PC type is ANSI
This message indicates that the point code translation is invalid because it is an ANSI point code.
Example
0018.1296 CARD 1103,A INFO Translation PC type is ANSI
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Change the translation point code type to a non-ANSI type.
Provision the point code type from the EPAP. Refer to the EPAP Administration Manual and see the topic “Manage Network Entities” for details about changing this entity data.
3.3.281 1297 - Invalid prefix/suffix digit length
This message indicates that the attempted digit action of prefixing or suffixing the entity ID is invalid because the combined length of the entity ID and GT digits is greater than 21 digits.
Example
0018.1297 CARD 1103,A INFO Invalid prefix/suffix digit length
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Change the attempted digit action or decrease the length of the entity ID or the GT digits to a length of 21 digits or less.
Provision the digit action or the entity ID length from the EPAP. Refer to the EPAP Administration Manual for details.
3.3.282 1298 - SIP message decode failed
SIP message parsing FAILS. Examples of decoding fail:
- TEL-URI with a Local Number does not contain a "phone-context" parameter
- SIP-URI does not contain "user=phone" parameter
- SIP INVITE does not have E164 num
1 2 3 4 5 6 7 8
12345678901234567890123456789012345678901234567890123456789012345678901234567890
0014.1298 CARD 1103,B INFO SIP msg decode failed
CSeq No: 96781 Cname: tcp1107d
Reason: Incorrect Content-Length Header
Report Date:10-10-12 Time:16:20:19 Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.283 1301 - SECMTPMATE - rcvd mate PC on non C-link
This message indicates the Eagle received a MTP message that failed the mate SID verification. The message was discarded.
RLGHNCXA21W 00-04-18 18:59:58 EST EAGLE 31.3.0
0105.1301 CARD 1205,A INFO SECMTPMATE - rcvd mate PC on non C-link
SIO=0a OPC=003-247-000 DPC=002-000-000
DATA=12 34 56 78 90 12 34 56 78 90 12 34
56 78 90 12 34 56 78 90 12 34 56 78
SR=scrb LSN=A1234567
Recovery
3.3.284 1302 - SECMTPSID - rcvd MSU with OPC = SID
This message indicates the Eagle received a MTP message that failed the self SID verification. The message was discarded.
0105.1302 CARD 1205,A INFO SECMTPSID - rcvd MSU with OPC = SID
Recovery
3.3.285 1303 - SECMTPSNM - no rte to OPC/AFTPC
This message indicates the Eagle received a MTP network management message that failed the MTP Network Management Message OPC Verification. The message was discarded.
RLGHNCXA21W 00-02-07 11:02:30 EST EAGLE 35.0.0
0100.1303 CARD 1105,B INFO SECMTPSNM - no rte to OPC/AFTPC
SIO=0a OPC=003-243-000 DPC=000-024-000
H0H1=41 AFTPC=099-099-003
SR=osp3 LSN=A1234567
Recovery
3.3.286 1304 - SECSCCPSCMG - no rte to AFTPC
This message indicates the Eagle received a MTP network management message that failed the SCMG AFTPC Verification. The message was discarded.
RLGHNCXA21W 00-04-18 18:59:30 EST EAGLE 31.3.0
0102.1304 CARD 1205,B INFO SECSCCPSCMG - no rte to AFTPC
SIO=03 OPC=003-245-000 DPC=001-004-000
SCMG: TYPE=000 AFTPC=003-003-003
MULT=000 AFTSS=005
- AFTPC
- Affected point code (for SCCP messages)
- AFTSS
- Affected subsystem (identifies the subsystem that failed)
- DPC
- LSN
- MULT
- SCCP management message multiplicity indicator
- OPC
- SCMG
- SIO
- SR
- Screening reference name
- TYPE
- SCCP management message type
Recovery
3.3.287 1305 - MTP rcvd UPU - User SCCP, Cause Invalid
This message is generated for a UPU message for a SCCP user when the unavailability cause indicates a SCCP translation exists for a node that does not have a SCCP user part.
0100.1305 CARD 1201,A INFO MTP rcvd UPU - user SCCP, Cause invalid
SIO=03 OPC=003-232-000 DPC=001-004-000
AFTPC=004-000-001 UPU=03 UNAVAIL CAUSE=001
LSN=A1234567
Recovery
3.3.288 1306 - GSMOPTS: EIR Global Response is ON
The EIR Global Response Type is on. The EIR Global
Response Type is set by the
chg-gsmopts command and the
eirgrsp parameter.
The Global Response Type is used to override the response
that is returned to the MSC (Mobile Switching Center). The default value is
OFF. When this parameter to OFF, the normal list logic is applied to the IMEI.
If the Global Response Type is set to a value other than OFF, there is no list
logic processing, and the response corresponding to the
eirgrsp value is sent to the MSC.
For more information about
eirgrsp, refer to the
chg-gsmopts command in the
Commands Manual.
RLGHNCXA21W 03-08-18 19:09:14 EST EAGLE 31.3.0
0140.1306 CARD 1201 INFO GSMOPTS: EIR Global Response is ON
Recovery
No corrective action is required.
3.3.289 1307 - GSMOPTS: EIR Global Response is OFF
The EIR Global Response Type is off. The EIR Global
chg-gsmopts
command and the
eirgrspparameter.
Commands Manual.
0140.1307 CARD 1201 INFO GSMOPTS: EIR Global Response is OFF
Recovery
3.3.290 1308 - Updates inhibited: Target-Cell CRC Fail
This message appears if the new source-cell and the target-cell checksums do not match. This message, similar to UIM 1239, but including the table id, shall be issued by the Eagle User Interface (UI) for each event.
station1234 96-08-01 16:28:08 EST EAGLE 34.0.0
1234.1308 SYSTEM INFO Updates inhibited:Target-Cell CRC Fail
CARD=1107 TABLE=50 OFFSET=XXXX TRGT CRC=1423697Alarm Level: No alarm condition. The message is informational only.
Recovery
This is an automatic process and no action is necessary.
3.3.291 1309 - Updates inhibited: Source-Cell CRC Fail
If the source cell fails validation this message, similar to UIM 1239, but including the table ID, shall be issued by the Eagle User Interface (UI) for each event.
1234.1309 SYSTEM INFO Updates inhibited:Source-Cell CRC Fail
CARD=1107 TABLE=50 OFFSET=XXXXAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.292 1310 - System Meas. Limit Exceeded for LRN
This UIM is issued if the Measurements Platform is not enabled and if the number of provisioned LRNs exceeds 100,000. When the limit of 100,000 is exceeded, this UIM is notification that the LNP LRN measurements report will be truncated, and additional LRN measurements will not be collected or reported.
RLGHNCXA21W 00-04-18 19:09:14 EST EAGLE 31.3.0
0140.1310 CARD 1201 INFO System Meas. Limit exceeded for LRN
Recovery
- Install the Measurements Platform to increase the reporting limits, or
- If you have any unused LRN entries, you can remove them such that the number of provisioned LRNs does not exceed the limit of 100,000.
3.3.293 1311 - System Meas. Limit exceeded for NPANXX
This UIM is issued if the Measurements Platform is not enabled and if the number of provisioned NPANXXs exceeds 150,000. When the limit of 150,000 is exceeded, this UIM is notification that the LNP NPANXX measurements report will be truncated, and additional NPANXX measurements will not be collected or reported.
0140.1311 CARD 1201 INFO System Meas. limit exceeded for NPANXX
Recovery
- If you have any unused NPANXX entries, you can remove them such that the number of provisioned NPANXXs does not exceed the limit of 150,000.
3.3.294 1312 - Dynamic VLR Profile Table Full
This UIM occurs when the VLR profile table is full.
1 2 3 4 5 6 7 8
0002.1312 SYSTEM INFO Dynamic VLR profile table full
Report Date:28-06-18 Time:16:20:19
Recovery
Delete entries in the VLR profile table.
3.3.295 1313 - Dynamic VLR Roaming Table Full
This UIM occurs when the VLR roaming table is full.
1 2 3 4 5 6 7 8
0002.1313 SYSTEM INFO Dynamic VLR roaming table full
Recovery
Delete entries in the VLR roaming table.
3.3.296 1314 - IPS TCP Connection Established
This UIM occurs when any IPS TCP connection is established.
6731.1314 CARD 1112 INFO IPS TCP connection established
Connection Name : ipstcp
Report Date:18-09-21 Time:16:38:33
Recovery
3.3.297 1315 - IPS TCP connection terminated
This UIM occurs when any IPS TCP connection is terminated.
6730.1315 CARD 1112 INFO IPS TCP connection terminated
Recovery
- Check that the network cable is properly inserted for this card.
- Check the remote host to determine if the connection is pingable or not.
- Execute the
chg-ip-conn:cname=<>:opencommand.
3.3.298 1316 - SFAPP(P) to OAM Sync Started
This UIM occurs when an SFAPP(P) to OAM Sync has started.
RLGHNC12345678901234567890123456789012345678901234567890123456789012345678901234567890
0007.1316 SYSTEM INFO SFAPP(P) to OAM Sync started
Report Date:18-09-25 Time:16:20:19
Recovery
3.3.299 1317 - SFAPP(P) to OAM Sync Completed
This UIM occurs when the SFAPP(P) to OAM Sync is complete.
0007.1317 SYSTEM INFO SFAPP(P) to OAM Sync Completed
Recovery
3.3.300 1318 - ICNP: OPC/DPC Correlation Problem
This UIM occurs when the DPC of the IAM is not the True or Secondary Point Code assigned to the OPC in the routing table.
RLGHNCXA21W 00-04-18 19:09:14 EST EAGLE 33.2.0
0140.1318 CARD 1201 INFO ICNP: OPC/DPC correlation problem
Recovery
Make sure that the OPC is using the True or Secondary Point code assigned to it in the routing table as the DPC of the IAM.
3.3.301 1319 - ICNP: IDCA Not Reachable
This UIM when the required IDCA application is not currently reachable.
0140.1319 CARD 1201 INFO ICNP: IDCA is not reachable
Recovery
- Bring the IDCA application online.
- Verify the connection between the EAGLE and IDCA.
3.3.302 1320 - FPT value Unprovisioned for Frame
This UIM is periodically raised at hourly intervals, starting at the system initialization time, for all the provisioned frames if the Frame Power Threshold value is not provisioned for that frame.
RLGHNCXA21W 00-04-18 19:05:43 EST EAGLE 35.0
0021.1320 CARD 1113 INFO FTP value unprovisioned for frame CF00
Recovery
3.3.303 1321 - Eagle RTDB Birthdate Mismatch
This message appears if the EAGLE 5 ISS connects to an ELAP and the birthdates do not match between the RTDB on the ELAP and the RTDB on the EAGLE 5 ISS.
RLGHNCXA21W 00-04-18 19:09:14 EST EAGLE 35.0.0
0008.1321 SYSTEM INFO Eagle RTDB Birthdate Mismatch
Recovery
3.3.304 1322 - EAGLE RTDB Levels Invalid
This message appears if the EAGLE 5 ISS connects to an ELAP and the ELAP's RTDB db-level is less-than the EAGLE 5 ISS's RTDB db-level.
0008.1322 SYSTEM INFO Eagle RTDB Levels Invalid
Recovery
3.3.305 1323 - EAGLE/ELAP TN Quantity Mismatch
This message appears if the EAGLE 5 ISS connects to an ELAP that has a greater number of TNs provisioned than the EAGLE 5 ISS's quantity keys allow.
0008.1323 SYSTEM INFO Eagle/Elap TN Quantity Mismatch
Recovery
3.3.306 1324 - Eagle/Elap NPANXX Quantity Mismatch
This message appears if the EAGLE 5 ISS connects to an ELAP that has a greater number of NPANXXs provisioned than the EAGLE 5 ISS's quantity keys allow.
0008.1324 SYSTEM INFO Eagle/Elap NPANXX Quantity Mismatch
Recovery
3.3.307 1325 - EAGLE/ELAP LRN Quantity Mismatch
This message appears if the EAGLE 5 ISS connects to an ELAP that has a greater number of LRN s provisioned than the EAGLE 5 ISS's quantity keys allow.
0008.1325 SYSTEM INFO Eagle/Elap LRN Quantity Mismatch
Recovery
3.3.308 1326 - Eagle RTDB Depth Alert
RTDB data is stored as inverse tree structures the trees have a maximum depth allowed. This alarm indicates that the maximum depth has been reached for a tree. If the alarm was initiated during a data update, the update will continually fail until there is manual intervention.
0008.1326 SYSTEM INFO Eagle RTDB Depth Alert
Recovery
3.3.309 1327 - Mate PC not Found in table
This UIM indicates the Mate Point Code was not found in the table.
Example
1 2 3 4 5 6 7 8
3281.1327 SYSTEM INFO Mate PC not Found in table
Recovery
No further action necessary.
3.3.310 1328 - Incorrect network domain
This UIM indicates the incorrect network domain was entered.
Example
1 2 3 4 5 6 7 8
3281.1328 SYSTEM INFO Incorrect network domain
Recovery
Check the network domain entry.
3.3.311 1330 - Mismatched UA Routing Context
This message is issued in the following scenarios:
If routing context is present in a M3UA Data message received by the EAGLE 5 ISS, and no routing key for the receiving M3UA association contains a matching routing context value.
If routing context is absent in a M3UA Data message received by the EAGLE 5 ISS, and the receiving M3UA association’s application server is referenced by a routing key containing routing context.
If routing context is present in a M3UA ASP-Active or ASP-Inactive or DAUD message received by the EAGLE 5 ISS, and no routing key for the receiving M3UA association contains a matching routing context value, then a UIM will be generated.
If routing context is present in a SUA message received by the EAGLE 5 ISS, and no routing key for the receiving SUA association contains a matching routing context value.
3409.1330 CARD 1305,A INFO Mismatched UA Routing Context
ANAME = m3ua_assoc_0003 M3UA RC=3
Recovery
- The use of Routing Context in the Eagle Routing Key configuration and the use of the Routing Context by the far-end Application Server should be made to match so that they are either both using Routing Context –OR- they are both not using Routing Context.
3.3.312 1331 - IP Route Table Entry Conflict
A conflict exists between user configured static IP routes and dynamically added routes. (The Integrate Message Feeder application monitoring dynamically creates host specific IP routes to an IMF VIP address.) There are two scenarios in which such a conflict can result:
If an Integrated Message Feeder application receives a service accept message and attempts to add a host specific IP route for the IP address received in the service accept message and there is an user configured static IP route (entered by
ent-ip-rteEAGLE 5 ISS command) whose destination is the same IP address, then the route is not added and the UIM is sent indicating the route and result. -
If a user enters a host specific IP route using the
ent-ip-rtecommand and there currently exists a dynamically added route with the same destination IP address, then the dynamic route is deleted, the static route is added, and this UIM indicating the result is generated.
0003.1331 CARD 1213 INFO IP Route Table Entry Conflict
Dynamic IP Route Add Fail
Destination = 172.130.155.110
Gateway = 172.120.154.111
Mask = 255.255.255.255
Report “Date:02-02-21 Time:02:07:19
Recovery
Resolve the IP Address conflict.
One must either change the Integrated Message Feeder application VIP address or delete the static IP address using the following command:
dlt-ip-rte
3.3.313 1332 - Invalid Initial M2PA FSN Received
The Eagle received an initial M2PA DATA message with an invalid FSN (Forward Sequence Number). The expected FSN in M2PA for the first DATA message received after link alignment is 0 for M2PA RFC. Older versions of M2PA (before Draft 9) used an initial FSN of 1. This UIM indicates that the two ends of the link have mismatched configurations.
Eagle versions prior to 34.3 support M2PA Draft 6 but do not support M2PA RFC.
If both ends of the M2PA association are on Eagle release 34.3 or later, verify that both ends have the VER parameter set to match on the M2PA association (VER=D6 or VER=M2PA must be the same on both ends).
If one end of the M2PA association is on an Eagle release prior to 34.3 and the other is 34.3 or greater, verify that the association VER parameter in the later release is set to D6 for backward compatibility.
RLGHNCXA21W 00-04-18 19:09:14 EST EAGLE 34.3.0
5781.1332 CARD 1301,A INFO Invalid Initial M2PA FSN Received
Alarm Level: No alarm condition. The message is informational only. However, the link will not stay aligned and a link alarm will be present.
Recovery
- To change the M2PA version used by the signaling link
at the Eagle perform the following commands:
- Use the
dact-slk:loc=xxxx:link=yycommand to deactivate the signaling link. - Use the
chg-assoc:open=nocommand to close the M2PA association used by the signaling link. - Use the
chg-assoc:ver=<d6/rfc>command to change the M2PA version on the association used by the signaling link to match the configured M2PA version of the M2PA peer. - Use the
chg-assoc:open=yescommand to activate the M2PA association used by the signaling link. - Activate the signaling using the
act-slk:loc=xxxx:link=yycommand.
- Use the
- Otherwise change the M2PA version at the M2PA peer to match the version configured for the signaling link/association at the Eagle.
- If the fault is not cleared, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.3.314 1333 - UA RCVD MSG DISCARDED
When processing a received PDU at the UA L2 layer, various errors can be detected which cause the MSU to be pegged and discarded. The SG responds to a number of these MSU’s with error messages and transmits them to the customer. Some scenarios exist where a received PDU causes an error to be pegged, the message to be discarded, and the SG to not respond with an error message. A new UIM is issued when a PDU excluding UA ERROR messages is received at the UA L2 layer and results in the SG discarding the message plus pegging an error count. The generation of this UIM is paced (every 30 seconds), and in situations where multiple messages are discarded within a 30 second window of time, a UIM is only generated for the first message discarded.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 38.0.0
0003.1333 CARD 1305,A INFO UA RCVD MSG DISCARDED
IP CONNECTION NAME=LONGCONNECTNAME ADPTR=M3UA
REASON=Large MSU for IP Sig Not Supported
SIO=0D OPC=1-1-1 DPC=2-2-2
Report Date:yy-mm-dd Time:hh:mm:ss
Recovery
3.3.315 1334 - UA TX MSG Discarded
The generation of this UIM is paced (every 30 seconds), and in situations where multiple messages are discarded within a 30-second window of time, a UIM is only generated for the first transmitted message that is discarded.
RLGHNCXA21W 00-02-07 12:01:43 EST EAGLE 37.0.0
0003.1334 CARD 1305,A INFO UA TX MSG DISCARDED
REASON=M3UA Conversion Error
Recovery
Correct the problem based on the reason text displayed.
The reasons listed in this UIM cause a discard in the transmit path.
Table 3-14 SG Messages Discarded in the Transmit Path
| UIM Reason Text | UIM Specific Text |
| M3UA Conversion Error | MTP3 to M3UA Conversion Failed |
3.3.316 1335 - Table Information
An update to the SCCP contained an invalid table identifier.
0003.1335 CARD 1105 INFO Table Information
Table 4294967296 Invalid Table ID
Report Date:02-07-21 Time:16:20:19
Recovery
3.3.317 1336 - UA Error Msg Received
This UIM is issued for message discards in the transmit path. The generation of this UIM is paced (every 30 seconds), and in situations where multiple messages are discarded within a 30-second window of time, a UIM is only generated for the first transmitted message that was discarded.
This UIM is being displayed because the customer is sending an error message to the SG. The following is a list of all the possible error codes that can appear in the UIM for received UA ERROR messages. Each one has the error code appended in parenthesis.
Invalid Version (0x01)
Unsupported Message Class (0x03)
Unsupported Message Type (0x04)
Unsupported Traffic Mode (0x05)
Unexpected Message (0x06)
Protocol Error (0x07)
Invalid Stream Identifier (0x09)
Refused Management Blocking (0x0d)
ASP Identifier Required (0x0e)
Invalid ASP Identifier (0x0f)
Invalid Parameter Value (0x11)
Parameter Field Error (0x12)
Unexpected Parameter (0x13)
Destination Status Unknown (0x14)
Invalid Network Appearance (0x15)
Missing Parameter (0x16)
Invalid Routing Context (0x19)
No Configured AS for ASP (0x1a)
Subsystem Status Unknown (0x1b)
Invalid Loadsharing Label (0x1c)
0003.1336 CARD 1305,A INFO UA ERROR MSG RECEIVED
IP CONNECTION NAME=association1 ADPTR=M3UA
ERROR CODE=Missing Parameter (0x16)
Recovery
Contact far end node and investigate reason for error.
3.3.318 1337 - UA HEARTBEAT TIMEOUT
If T(beat ack) expires before a Heartbeat Ack message is received from the customer, the association is torn down. A new UIM is issued when the association is torn down and the existing format I53 is used for this UIM. The generation of this UIM is paced (every 30 seconds).
0003.1337 CARD 1305,A INFO UA HEARTBEAT TIMEOUT
ANAME = LONGASSOCNAME1 M3UA
Recovery
3.3.319 1338 - SCCP did not route - no PC in CgPA
GTT on CgPA PC is required, but CgPA PC is not present in the MSU.
Example
RLGHNCXA21W 02-07-21 16:20:19 EST EAGLE 37.5.0
0018.1338 CARD 1103,A INFO SCCP did not route - no PC in CgPA
SIO=03 OPC=001-001-001 DPC=002-002-002
SCCP MSG TYPE=04
TT=250 NP=04 NAI=010 ADDR=123456789012345678901
PC=003-003-003 SSN=005
PC=001-001-001 SSN=004
LSN=ABCD123 GTTSET=3 203 46
Report Date:02-07-21 Time:16:20:19This alternate output includes the redirected destination and is
used when a redirected MSU encounters an error.
SCCP MSG TYPE=04
GTT on CdPA used MOSMSGTA=9193802053
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- Linkset name
- MSG TYPE
- Message type
- NAI
- Nature of address indicator
- NI
- Network indicator value
- NP
- Numbering plan
- OPC
- Originating point code
- PC
- Point code
- PCI
- Point code indicator
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- Subsystem number indicator
- TT
- Translation type
Recovery
3.3.320 1340 - REPT COND: TRBL Resynch Required
Under conditions of prolonged, high alarm activity the alarm processing capacity of the EAGLE 5 ISS can be reached. In an effort to keep the internal state machine current, alarms normally generated to the UI are discarded.
Under this scenario, when alarm processing recovers sufficiently, this message is generated to indicate to the attached network or element management systems that they should resynchronize with the EAGLE 5 ISS.
The generation of this message is expected to be limited to large configurations during severe outages, and the expected occurrence rate of this message is low; however, it has been added as a precaution. Although alarms may have been discarded, the internal alarm state of the EAGLE 5 ISS has been maintained and is stable.
tekelecstp 99-03-09 12:01:43 EST EAGLE 35.0.0
5061.1340 SYSTEM INFO REPT COND: TRBL resynch required
Recovery
The attached network or element management systems (such as Harris NetBoss) should use this message as an indication that they should perform the following command to synchronize alarm status with the EAGLE 5 ISS:
rept-stat-trbl
Network or element management systems attached
through terminals configured as EMSALM type terminals must not filter this
message. See the
chg-trm command in the
Commands Manual for further details.
3.3.321 1341 - SRI rcvd - GSM2IS41 not provisioned
The system received an SRI Query message for which it attempted to generate a response. However, IS41 GSM Migration(IGM) feature found the GSM to IS-41 Migration prefix (specified by the GSM2IS41 parameter) is not provisioned on this system. With this UIM, IGM is notifying the operator it cannot process the SRI messages and is allowing it to fall through to the GTT for handling.
To be able to perform the IS-41GSM Migration feature and to accept SRI Request messages, you must first specify the GSM2IS41 prefix in GSMOPTS.
Example
0018.1341 CARD 1103,A INFO SRI rcvd - GSM2IS41not provisioned
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADD
- Address
- CDPA
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- Translated point code
- TRANSLATED SS
- Translated subsystem
If Global Title Translation is found, the GTTSET in which the translation is found appears. If Global Title Translation is not found, the GTTSET does not display.
Recovery
3.3.322 1342 - ANSI IS-41 INP Qry rejected: AINPQ is OFF
The EAGLE 5 ISS has rejected an INP query that is decoded as an ANSI-41NPREQ query because the appropriate AINPQ (ANSI-41 INP Query) feature key is not on.
RLGHNCXA21W 03-04-18 19:02:05 EST EAGLE 35.0.0
0112.1342 CARD 1103,A1 INFO ANSI IS-41 INP Qry rejected: AINPQ is OFF
SIO=83 OPC= 001-101-001 DPC= 001-001-001
ADDR=919380
CGPA: AI=c3 PC= 001-101-001 SSN=016
DATA=3a e2 38 c7 04 56 04 72 e0 e8 30 e9
2e cf 01 00 d0 02 83 01 f2 25 aa 0b
84 09 01 00 11 0a 19 49
LSN=e1m1s1
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- CGPA
- DATA
- Hex dump of TCAP part of MSU
- DPC
- LSN
- MSG TYPE
- Message type
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
- If you want to support the AINPQ feature, issue the
chg-ctrl-feat:ainpq=oncommand to process ANSI-41 INP queries. - If you do not want to support the AINPQ feature, ignore this informational message.
- For additional information or assistance about the AINPQ or any feature to purchase, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.3.323 1343 - INAP INP Qry rejected: INPQ is OFF
The EAGLE 5 ISS has rejected an INP query that is decoded as an INAP NPREQ query because the appropriate INPQ (ITU INP Query) feature key is not on.
0112.1343 CARD 1103,A1 INFO INAP INP Qry rejected: INPQ is OFF
ADDR=919380
LSN=e1m1s1
- ADDR
- Address
- AI
- Address Indicator
- CDPA LENGTH
- CGPA
- DATA
- DPC
- LSN
- MSG TYPE
- Message type
- OPC
- PC
- Point code
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
- If you want to support the INPQ feature, issue the
chg-ctrl-feat:ainpq=oncommand to process ITU INP queries. - If you do not want to support the INPQ feature, ignore this informational message.
- For additional information or assistance about the INPQ or any feature to purchase, contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA.
3.3.324 1344 - MSU discarded: In-Service Thresholding
The EAGLE 5 ISS discarded an SCCP message because the MRN or MAP Group selected by GTT does not have enough available weight to satisfy the In-Service threshold.
Example
0018.1344 CARD 1103,A INFO MSU discarded: In-Service Thresholding
TRANSLATED PC=003-003-003 TRANSLATED SS=005
LSN=ABCD123 GTTSET=3 (8)
- ADD
- Address
- CDPA
- Called party address
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- Nature of address indictor
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- TRANSLATED SS
Recovery
3.3.325 1345 - CRD Auto-Clear Sent to All MTP Cards
EAGLE 5 ISS generates this UIM when Circular Route Auto-Recovery procedure clears the Circular Route Detection (CRD) status of a destination that was marked prohibited.
RLGHNCXA21W 03-04-18 19:02:05 EST EAGLE 36.0.0
1234.1345 CARD 1203 INFO CRD Auto-Clear Sent to All MTP Cards
DPC=001-001-001
Report Date:06-06-19 Time:16:20:19
Recovery
3.3.326 1346 - IS-41 Missing Mandatory Parameters
EAGLE 5 ISS has rejected the ANSI IS-41 INP Query message, because the TCAP portion of the message does not contain mandatory parameters (e.g. digits).
tklc1091301 07-01-19 03:47:19 EST EAGLE5 36.0.0-57.9.0
6962.1346 CARD 2113 INFO IS-41 Missing Mandatory Parameters
SIO=83 OPC= 0-000-0-aa DPC= 5-090-5-aa
CDPA: AI=d3 SSN=250 TT=025
ADDR=197055512340
CGPA: AI=c3 PC= 1-137-4-aa SSN=250
DATA=15 e2 13 c7 04 00 00 00 00 e8 0b e9
09 cf 01 00 d1 02 09 3e f2
LSN=ls1102n0
Report Date:07-01-19 Time:03:47:19
- ADD
- Address
- CDPA
- CGPA
- GTI
- GTTSET
- GTT Set Index
- LSN
- Linkset name
- NAI
- NI
- NP
- Numbering plan
- PC
- Point code
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
- TRANSLATED PC
- TRANSLATED SS
Alarm Level: No Alarm condition. Message is for information only.
Recovery
Ensure ANSI IS-41 INP Query message contains mandatory TCAP parameters for valid query processing.
3.3.327 1347 - IS-41 Digits - Bad Encoding Scheme
EAGLE 5 ISS has rejected the ANSI IS 41 INP Query message, because the encoding scheme of the DIGITS parameter of the ANSI IS-41 TCAP portion is invalid.
tklc1091301 07-01-19 03:31:57 EST EAGLE5 36.0.0-57.9.0
6925.1347 CARD 2113 INFO IS-41 Digits - Bad Encoding Scheme
ADDR=197055512340
DATA=23 e2 21 c7 04 00 00 00 00 e8 19 e9
17 cf 01 00 d1 02 09 3e f2 0e 84 0c
01 01 12 0f 76 18 79 70
LSN=ls1102n0
Report Date:07-01-19 Time:03:31:57
Recovery
Ensure ANSI IS 41 INP Query message contains only digits with BCD encoding scheme.
3.3.328 1348 - IS-41 Number of dgts Exceeds the Maximum
EAGLE 5 ISS has rejected the ANSI IS 41 INP Query message; because the number of digits in the DIGITS parameter exceeds 21 digits.
tklc1091301 07-01-19 03:34:40 EST EAGLE5 36.0.0-57.9.0
6936.1348 CARD 2317 INFO IS-41 Num of dgts exceeds the maximum
ADDR=197055512340
DATA=27 e2 25 c7 04 00 00 00 00 e8 1d e9
1b cf 01 00 d1 02 09 3e f2 12 84 10
01 01 11 18 76 18 79 70
LSN=ls1102n0
Report Date:07-01-19 Time:03:34:40
Recovery
Ensure ANSI IS 41 INP Query message’s DIGITS parameter contains less than 21 digits.
3.3.329 1349 - MSU invalid size – discarded
An MSU less than 5 bytes or greater than 279 bytes was detected by the MTP layer 3 software in an ATM card. A four byte MSU may cause the ATM connection to bounce (four byte PDUs are used for SSCF control). MSU length limit is 279 bytes.
2864.1349 CARD 6112,A INFO MSU invalid size - discarded
LEN=114
SIO=93 OPC= 227-040-000 DPC= 209-122-150
DATA=09 81 03 0c 15 09 89 06 0a 21 80 95
97 10 89 09 89 95 0a 21 80 95 89 30
03 44 62 42
LSN=n209068063
Report Date:13-11-09 Time:09:48:33
The length of the MSU (for example, LEN=114) includes the length of the SIF plus some other parameters. The length of these other parameters varies depending on the protocol managed by the LIM card issuing the UIM.Alarm Level: No alarm condition. The message is informational only.
Recovery
No action necessary.
3.3.330 1350 - Discrd Rcvd Lrg MSU CTRL-FEAT Off
IPL receives on a M2PA connection a large MSU greater than 272 bytes and the feature is not enabled.
0047.1350 CARD 1113 INFO Discrd Rcvd Large MSU CTRL-FEAT Off
LEN=50
SIO=04 OPC= 016-032-048 DPC= 032-032-048
DATA=01 02 03 04 05 06 07 08 09 0a 0b 0c
0d 0e 0f 10 11 12 13 14 15 16 17 18
19 1a 1b 1c
LSN=ls211
Report Date:12-12-15 Time:11:01:50
;Note:
The length of the MSU (for example, LEN=50) includes the length of the SIF plus some other parameters. The length of these other parameters varies depending on the protocol managed by the LIM card issuing the UIM.Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.331 1351 - Discrd Trans Lrg MSU Unsupported SLK
An MSU less than 5 bytes or greater than 279 bytes was detected by the MTP layer 3 software in an ATM card. A four-byte MSU may cause the ATM connection to bounce (four byte PDUs are used for SSCF control). The MSU length limit is 279 bytes. IN this case, an SSEDCM-IPLIM SAAL/TALI signaling link receives from IMT a large MSU greater than 272 bytes. The discard occurs on the outbound card.
0003.1351 CARD 1105,B INFO Discrd Trans Lrg MSU Unsupported SLK
LEN=475
SIO=0D OPC=001-001-001 DPC=002-002-002
LSN=ABCD123
Recovery
3.3.332 1352 - Discrd Rcvd Lrg MSU Unsptd Outbnd SLK
An IP7 GPL receives a large MSU greater than 272 bytes, the BICC controlled feature is on, there are available routes for the destination point code, but selected outbound card does not support large MSUs.
0049.1352 CARD 1113 INFO Discrd Rcvd Lrg MSU Unsprtd Outbnd SLK
LEN=50
19 1a 1b 1c
LSN=ls211
Report Date:12-12-15 Time:11:02:11
;Note:
Recovery
3.3.333 1353 - DTA Bypassed for Rcvd Lrg MSU
An IP7 GPL receives a large MSU that triggers DTA processing instead of converting the MSU (the MSU is routed normally, DTA is bypassed).
0050.1353 CARD 1113 INFO DTA Bypassed for Rcvd Large MSU
LEN=50
19 1a 1b 1c
LSN=ls211
Report Date:12-12-15 Time:11:02:21
;Note:
Recovery
3.3.334 1355 - Card Integ Chk: MSU cksum err
An MSU was discarded because a card received an MSU which failed checksum validation.
RLGHNCXA21W 06-09-07 16:20:19 GMT EAGLE5 35.6.0
0008.1355 CARD 1301 INFO Card Integ Chk:MSU cksum err
Source Loc: 1303 Destination loc: 1301
Report Date: 09-07-06 Time:16:20:19
On a LIM card the destination SS7 port is shown after the card address (it is not printed when this UIM is issued on a SCCP card).CARD 1301,a
Recovery
3.3.335 1356 - EXT BERT terminated with OAM switchover
This message is issued when the Extended BERT is aborted due to OAM switchover.
RLGHNCXA21W 09-09-07 16:20:19 EST EAGLE 42.0.0
0023.1356 CARD 1115 INFO EXT BERT terminated with OAM switchover
Report Date:09-09-07 Time:16:20:19
Recovery
3.3.336 1357 - Negotiation at 100Mbps/Full Duplex failed
The negotiation for data rate and traffic flow did not result in 100 Mbps and full duplex mode respectively, for all data links.
0010.1357 CARD 1103 INFO Negotiation at 100Mbps/Full Duplex failed
DLK configuration: SPEED = 100 Mbps, DUPLEX = HALF
Report Date:00-02-07 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
Use a valid combination of speed and duplex parameters on the card and Ethernet switch for configuring a data link. An invalid combination may cause link degradation and unreliable behavior.
3.3.337 1358 - MSU discarded - too big after MTP conv.
When ITUI or ITUN MSU, routed to ANSI or ITUN24 network, with SI less than or equal to 5 is received on any card type where the original MSU is of sufficient size that when the 14-bit point codes are converted to 24-bit point codes the resulting converted MSU will have SIF greater than 272 bytes.
When ITUI or ITUN MSU, routed to ANSI or ITUN24 network, with SI ranging from 6 to 15 is received on any non-IP card type where the original MSU is of sufficient size that when the 14-bit point codes are converted to 24-bit point codes the resulting converted MSU will have SIF greater than 272 bytes. The MSU will be discarded even if the outbound linkset is on IP card type and Large MSU Support is enabled (Large MSU for IP Sig, Feature P/N 893018401) because conversion is performed on the inbound card, so both the inbound and outbound cards must be able to support MSU greater than 272 bytes.
When ITUI or ITUN MSU, routed to ANSI or ITUN24 network, with SI ranging from 6 to 15 is received on any IP card type where the original MSU is of sufficient size that when the 14-bit point codes are converted to 24-bit point codes the resulting converted MSU will have SIF greater than 4095 bytes.
0055.1358 CARD 1113 INFO MSU discarded - too big after MTP conv.
LEN=50
19 1a 1b 1c
LSN=ls211
Report Date:12-12-15 Time:11:03:11
;Note:
Recovery
No action required.
3.3.338 1359 - SCCP Looping Detected
When a SCCP Looping condition is found, the mode of operation of the loopset will be notify or discard (based on provisioning). The mode of operation either only notifies the user (via this UIM), or notifies the user (via this UIM) and discards the MSU. The data shown in the output will be from the original MSU, before any GTT modifications were applied to it.
A hop counter violation message is also sent by EAGLE to the UDTS. The message indicates either ANSI or ITU Networks based on the provisioned GTT Translation point code type.
Example
nbsa01 12-01-23 19:41:10 BRA EAGLE5 41.1.1-62.67.1
0527.1359 CARD 3217 INFO SCCP Looping Detected
SIO=83 OPC= 000-004-666 DPC= 000-006-500
SCCP MSG TYPE=09
CDPA: NI=0 RI=0 GTI=04 SSNI=1 PCI=0
TT=000 NP=01 NAI=004 ADDR=554197388383
PC=-------------- SSN=008
CGPA: NI=0 RI=0 GTI=04 SSNI=1 PCI=0
TT=000 NP=01 NAI=004 ADDR=551181134001
LSN=ylrjo1 GTTSETIDX=(0)
Report Date:12-01-23 Time:19:41:00
Recovery
Analysis of measurements and messages is required to ensure messages are correctly being discarded.
Entering the wrong data in the SCCP Loop Table and/or incorrectly connecting a GTT translation with a particular SCCP Loop Table entry could result in unwanted traffic loss.Refer to the Commands Manual for more information using ENT/CHG/DEL/RTRV-LOOPSET commands.
- Remove invalid or unwanted entries from the SCCP Loop Tables.
- Create a valid SCCP Loop Table entry for a GTT translation if the available tables are valid for other translations, but not the one in error.
- Set the "notify only" mode until confidence is gained in the EAGLE SCCP Loop Tables, this is also the recommended setting for initial provisioning with a subsequent change.
- Periodic auditing of UIMs to ensure that valid messages are not being discarded.
3.3.339 1360 - Inv SR-5129 msg rcvd, Bad Src.
An SR-5129 message was received with a bad source name in the message header.
station1234 06-12-21 16:28:08 EST Rel 37.5.0-58.12.0
0020.1360 SYSTEM INFO Inv SR-5129 msg rcvd, Bad Src.
Terminal = 17
Name = SNAMNJCCSM1YSA701
Report Date:06-12-21 Time:16:20:19
Recovery
3.3.340 1361 - Inv SR-5129 msg rcvd, Bad Dst.
An SR-5129 message was received with a bad destination name in the message header.
0020.1361 SYSTEM INFO Inv SR-5129 msg rcvd, Bad Dst.
Terminal = 17
Report Date:06-12-21 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.341 1362 - Inv SR-5129 msg rcvd, Bad Ver.
An SR-5129 message was received with a bad version in the message header.
0020.1362 SYSTEM INFO Inv SR-5129 msg rcvd, Bad Ver.
Terminal = 17
Ver = xxxx
Recovery
3.3.342 1363 - SR-5129 Err Msg rcvd Err Code 1(Bad Src)
An SR-5129 Error Message received with Error Code as 1 (Bad Source).
0020.1363 SYSTEM INFO Inv SR-5129 Err Msg rcvd Err Code 1(Bad Src)
Terminal = 17
Recovery
3.3.343 1364 - SR-5129 Err Msg rcvd Err Code 2(Bad Dst)
An SR-5129 Error Message received with Error Code as 2 (Bad Destination).
0020.1364 SYSTEM INFO Inv SR-5129 Err Msg rcvd Err Code 2(Bad Dst)
Terminal = 17
Recovery
3.3.344 1365 - SR-5129 Err Msg rcvd Err Code 3(Bad Ver)
An SR-5129 Error Message received with Error Code as 3 (Bad Version).
0020.1365 SYSTEM INFO Inv SR-5129 Err Msg rcvd Err Code 3(Bad Ver)
Terminal = 17
Recovery
3.3.345 1366 - SR-5129 Err Msg rcvd Err Code Other
An SR-5129 Error Message received with Error Code other than 1, 2 and 3.
0020.1366 SYSTEM INFO Inv SR-5129 Err Msg rcvd Err Code Other
Terminal = 17
Recovery
3.3.346 1367 - SOIP connection failed.
Failed to start SOIP connection.
0009.1367 SYSTEM INFO SOIP connection failed.
Terminal=17
IPADDR=192.168.57.52
PORT = 2336
Recovery
3.3.347 1368 - Inv SR-5129 msg rcvd, Other
An SR-5129 Message Received with error other than Bad Source Name, Bad Destination Name and Bad Version in the Message Header.
0020.1368 SYSTEM INFO Inv SR-5129 msg rcvd, Other
Terminal = 17
Recovery
3.3.348 1369 - ISUP IAM decode failed
An ISUP IAM decode failed with error other than Bad Source Name, Bad Destination Name, and Bad Version in the Message Header.
1 2 3 4 5 6 7 8
0020.1369 CARD 1201,A INFO ISUP IAM decode failed
SIO=3 OPC=&&-001-001-001 DPC=&&-002-002-002
DATA=26 80 03 09 0e 06 09 00fe 08 50 55 43
00
LSN=LS0032 Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.349 1370 - ISUP IAM Cld Pty decode failed
An ISUP IAM Cld Pty decode failed with error other than Bad Source Name, Bad Destination Name and Bad Version in the Message Header.
1 2 3 4 5 6 7 8
0020.1370 CARD 1201,A INFO ISUP IAM Cld Pty decode failed
00
Recovery
3.3.350 1371 - ISUP encode Failed
An ISUP encode failed with error other than Bad Source Name, Bad Destination Name and Bad Version in the Message Header.
1 2 3 4 5 6 7 8
0020.1371 CARD 1201,A INFO ISUP encode failed
00
Recovery
3.3.351 1372 - SLTC Failure-SLTM not sent, Invalid SIO
The EAGLE attempted to send SLTM with SIO=2 for ITU APC.
1230.1372 CARD 1201,A INFO SLTC Failure-SLTM not sent, Invalid SIO
ADJ PC=001-001-001 SLC=02 LEN=0f
DATA=01 02 03 04 05 06 07 08 09 10 11 12 13 14 15
Recovery
Special maintenance messages are not supported for ITU PCs.3.3.352 1373 - TFC Generated for Congested Link
Implementation of auto decrementing of congestion abatement is multicast to all MTP cards (SRC and DEST).
In both ANSI and ITU networks, UIM 1373 indicates the level of congestion; for example, CONG STATUS=001 is a lower level of congestion than CONG STATUS=003 (the highest level of congestion).
- In an ANSI network, the value in the SCON always matches the value in UIM 1373.
- In a non-ANSI (ITU) network, SCON messages report only 0 (not congested) or 1 (congested), so the congestion value reported in UIM 1373 can differ from the value in the SCON. For example, if UIM 1373 reports CONG STATUS=002 or CONG STATUS=003, then the value in the related SCON will be 1 (not 2 or 3).
station1234 02-07-21 16:28:08 EST Rel 37.0.0 -46.12.0
8441.1373 CARD 1101,A INFO TFC Generated for Congested Link
DPC= 001-115-000 CPC= 008-001-001
CONG SLK: 1305,A3 CONG STATUS=001
Report Date:07-01-05 Time:16:20:19
Recovery
- Use local troubleshooting procedures to determine the cause for congestion.
3.3.353 1374 - SMS B-Party address decode failed
An error was detected during decode of SMS message destination address.
tekelecstp 02-03-20 07:40:50 EST EAGLE 39.1.0-61.4.0
6815.1374 CARD 1103 INFO SMS B-Party Address decode failed
SIO=83 OPC= 002-002-001 DPC= 009-008-007
CDPA: AI=8b SSN=002 TT=006
ADDR=110000
CGPA: AI=43 PC= 002-002-001 SSN=002
DATA=49 e2 47 c7 04 47 04 25 1e e8 3f e9
3d cf 01 e9 d1 02 09 35 f2 34 9f 69
01 00 9f 74 02 00 00 89
LSN=ls221
Report Date:02-03-20 Time:07:40:50
Recovery
The message should be analyzed to determine the error, and the originating node should be contacted to send corrected message.
- Mandatory SM-RP-UI parameter is absent from the MO ForwardSM message.
- The TPDU type is SMS-SUBMIT and the parameter length is less then 4 + number of digit bytes specified in the number of digit field.
- The TPDU type is SMS-COMMAND and the parameter length is less then 7 + number of digit bytes specified in the number of digit field.
- Number of digits is 0 or greater than 20.
3.3.354 1375 - SMS B-party Failed to modify TCAP MSU
The formatted outbound digit string length generated by SMS NP for encoding the TCAP message exceeded system limits.The formatted outbound digit string length generated by SMS NP or MO SMS B-Party Routing for encoding the TCAP message exceeded system limits.
6815.1375 CARD 1103 INFO SMS B-party Failed to modify TCAP MSU
ADDR=110000
LSN=ls221
Recovery
The message and outbound digits formatting options should be analyzed to determine the error and the originating node or the requested outbound digit formatting option should be modified to correct the encoding error.
- New SM-RP-UI parameter length exceeds 127 digits.
- The length of new parameter sequence, Invoke component, component portion or TCAP package exceeds 127 bytes.
- The SCCP user data length (TCAP payload size) exceeds 255 bytes.
- The MSU length exceeds 279 bytes.
3.3.355 1376 - SMS Failed to modify B-Party digits
During processing of SMS message, the formatted outbound digit string length exceeded limit for number of digits.
For MO SMS B-Party routing, AMGTT data provisioned in the GTT Table entry corresponding to MAP B-Party number is used to modify MAP B-Party digits. If outbound length exceeds 20 or becomes less than 0.
6815.1376 CARD 1103 INFO SMS Failed to modify B-Party digits
ADDR=110000
LSN=ls221
Recovery
The message and the digit format provisioning should be analyzed to determine the error and the originating node or the requested outbound digit formatting option should be modified to correct the encoding error. For MO SMS B-Party Routing, AMGTT data (NSDD/NPDD/NSDS/NPDS) provisioned in GTT entry corresponding to MAP B-Party number should be modified to correct the encoding error.
This UIM is generated when SMS NP or MO SMS B-Party Routing feature generated an outbound digit string for encode in TCAP message, which exceeded 20 digits in length or is less than 0 digits in length forcing SMS NP/MO SMS B-Party Routing to route original MSU.
3.3.356 1377 - SSH session disconnected - server busy
Indicates that an established SSH connection on the EAGLE has disconnected.
RLGHNCXA21W 02-08-08 20:52:04 EST EAGLE 39.0
5024.1377 CARD 1105 INFO SSH session disconnected - server busy
RIPADDR=192.168.57.52
RIPORT=2336
LIPADDR=192.168.53.46
LIPORT=23
Report Date:02-08-08 Time:20:52:04
Recovery
3.3.357 1378 - Inh VFlex SS request already outstanding
A second attempt to inhibit the V-Flex subsystem has been made while the first is still being processed. The second attempt will be ignored.
tekelecstp 07-03-09 12:01:43 EST EAGLE 37.6.0
5061.1378 SYSTEM INFO Inh VFlex SS request already outstandingAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.358 1379 - Failure Inhibiting VFlex SS
The attempted inhibit of the V-Flex subsystem failed. A response SOG was not received from the mate.
5061.1379 SYSTEM INFO Failure Inhibiting VFlex SSAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.359 1380 - VFLEX: No RN digits provisioned
The digits in the VMS at the requested VMRN index were not provisioned. The provisioning information for the VMS ID accessed via the MSU information should be verified.
RLGHNCXA21W 07-07-21 12:01:43 EST EAGLE 37.6.0
0002.1380 SYSTEM INFO VFlex: RN is not provisioned
SCCP MSG TYPE=04
TT=250 NP=04 NAI=010 ADDR=1234567890901
TT=100 NP=07 NAI=012 ADDR=012345677890
Report Date:07-07-21 Time:16:20:19
Recovery
Verify the VMS ID accessed via the MSU information.
3.3.360 1381 - VFlex: CD entry not found
The call decision table entry matching the incoming MSU criteria is not found. Call decision tree provisioning should be updated.
0002.1381 SYSTEM INFO VFlex: CD entry not found
SCCP MSG TYPE=04
Recovery
3.3.361 1382 - Too many digits for DRA parameter
Too many digits in the DRA parameter to encode.
0002.1382 SYSTEM INFO Too many digits for DRA parameter
SCCP MSG TYPE=04
Recovery
Decrease the number of RN digits or modify the querying node to send fewer digits in DN.
3.3.362 1383 - SLTC Failed: No route to APC on linkset
An SLTC message is sent/received for a linkset that is not in the route-set of its APC.
1 2 3 4 5 6 7 8
8606.1383 CARD 1105,B INFO SLTC Failed: No route to APC on linkset
ADJ PC= 002-14-00 SLC=000 LEN=002
DATA=11 77
Report Date:02-04-01 Time:17:40:42
Recovery
3.3.363 1384 - G-Flex MLR: Op without IMSI erroneous
The G-Flex MLR Function encountered a message that did not contain an IMSI parameter.
station1234 06-12-21 16:28:08 EST Rel 38.0.0
0020.1384 CARD 1106 INFO G-Flex MLR: Op without IMSI erroneous
0018.1384 CARD 1103,A INFO G-Flex MLR: Op without IMSI erroneous
ADDR=110000
LSN=ls221
Report Date:10-10-10 Time:07:40:50 Legend
- ADDR
- Address
- CDPA
- CGPA
- Calling party address
- DATA
- Information from the upper layers of SCCP management
- DPC
- Destination point code
- LSN
- Linkset name. The name must be unique.
- OPC
- Origination point code
- PC
- Point code of the SCCP calling party or called party address
- SIO
- Service information octet
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.364 1385 - G-Flex MLR: Op without IMSI skipped
The G-Flex MLR Function encountered a sendParameters operation that did not contain an IMSI parameter.
0020.1385 CARD 1106 INFO G-Flex MLR: Op without IMSI skipped
0018.1385 CARD 1103,A INFO G-Flex MLR: Op without IMSI skipped
ADDR=110000
LSN=ls221
Report Date:10-10-10 Time:07:40:50Legend
- ADDR
- Address
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.365 1386 - G-Flex MLR: Op with bad TCAP skipped
The G-Flex MLR Function encountered problems decoding the TCAP and MAP layers of a message prior to attempting to identify an IMSI parameter.
0020.1386 CARD 1106 INFO G-Flex MLR: Op with bad TCAP skipped
0018.1386 CARD 1103,A INFO G-Flex MLR: Op with bad TCAP skipped
ADDR=110000
LSN=ls221
- ADDR
- Address
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.366 1387 - G-Flex MLR: Op with bad IMSI skipped
The G-Flex MLR Function encountered an IMSI parameter that contains fewer than 5 digits or more than 15 digits.
0020.1386 CARD 1106 INFO G-Flex MLR: Op with bad IMSI skipped
0018.1387 CARD 1103,A INFO G-Flex MLR: Op with bad IMSI skipped
ADDR=110000
LSN=ls221
- ADDR
- Address
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- PC
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
3.3.367 1388 - Invalid prefix/suffix digit len for CdPA
This message indicates that the the length of the prefix/suffix of the CdPA is not valid.
Example
RLGHNCXA21W 02-07-21 16:20:19 EST EAGLE 38.0.0
0018.1388 CARD 1103,A INFO Invalid prefix/suffix digit len for CdPA
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- Global title indicator
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- Protocol control information
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.368 1389 - Invalid prefix/suffix digit len for CgPA
This message indicates that the the length of the prefix/suffix of the CgPA is not valid.
Example
0018.1389 CARD 1103,A INFO Invalid prefix/suffix digit len for CgPA
SCCP MSG TYPE=04
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.369 1390 - EMAP connection established
This message is generated whenever an EMAP connection is established.
Example
1 2 3 4 5 6 7 8
xxxx.1390 CARD xxxx INFO EMAP connection established
Connection Name : emap1101
Report Date:18-06-26 Time:06:50:07
Recovery
3.3.370 1391 - EMAP connection terminated
This message is generated whenever an EMAP connection is terminated.
Example
1 2 3 4 5 6 7 8
xxxx.1391 CARD xxxx INFO EMAP connection terminated
Report Date:18-06-26 Time: 06:50:15
Recovery
3.3.371 1392 - IDPRCDPN(X) NPP SERVICE is OFF
The status of the IDPRCDPN(X) NPP service is OFF while processing an IDP message.
1 2 3 4 5 6 7 8 12345678901234567890123456789012345678901234567890123456789012345678901234567890 tekelecstp 20-12-11 03:56:48 WET UNKNOWN ??.?.?-64.12.0 5090.1392 CARD 1105 INFO IDPRCDPN(X) NPP SERVICE is OFF Report Date:20-12-11 Time:03:56:48
Recovery
3.3.372 1393 - IDPRCGPN NPP SERVICE is OFF
The status of the IDPRCGPN NPPservice is OFF while processing an IDP message.
1 2 3 4 5 6 7 8
tekelecstp 20-12-11 03:56:48 WET UNKNOWN ??.?.?-63.33.0
5090.1392 CARD 1105 INFO IDPRCDPN NPP SERVICE is Off
Recovery
3.3.373 1394 - Flushing undelivered MSUs
The destination EAGLE card for an SS7 message is not reachable by the origination EAGLE card and the dynamic database is not updated to reflect the unreachable status.
tekelecstp 02-01-05 20:39:14 MST EAGLE 41.0
0010.1394 CARD 1108 INFO Flushing undelivered MSUs
Card List: 1101, 1201, 1302, 2103, 2204
LSN=lg1104a0
Report Date:02-01-05 Time:20:39:14
;Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.374 1395 - Inh ATINPQ SS request alrdy outstanding
A second attempt to inhibit the ATINPQ subsystem has been made while the first is still being processed. The second attempt will be ignored.
station1234 06-12-21 16:28:08 EST Rel 39.2.0
0020.1395 CARD 1106 INFO Inh ATINPQ SS request alrdy outstanding
Recovery
3.3.375 1396 - Failure Inhibiting ATINPQ SS
The attempted inhibit of the ATINPQ subsystem failed. A response SOG was not received from the mate.
0020.1396 CARD 1106 INFO Failure Inhibiting ATINPQ SS
Recovery
3.3.376 1397 - LSS: Missing Mandatory Parameter
A required parameter was missing in ATI NP query.
RLGHNCXA21W 07-07-21 12:01:43 EST EAGLE 39.2.0
0002.1397 SYSTEM INFO LSS: Missing Mandatory Parameter
SCCP MSG TYPE=04
re cseCD123 GTTSET=3 203 46
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Verify that incoming ATI NP query has Subscriber Identity and Requested Info parameters.
3.3.377 1398 - ATINPQ: Badly formatted Subs Id
0002.1398 SYSTEM INFO ATINPQ: Badly formatted Subs Id
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Verify that Subscriber Identity parameter length is at least 2 bytes (1 byte length field of MSISDN, 1 byte choice for MSISDN). If greater than 2 bytes, the Subscriber identity length must be equal to 2 + length of MSISDN.
3.3.378 1399 - ATINPQ: Subscriber Identity not MSISDN
0002.1399 SYSTEM INFO ATINPQ: Subscriber Identity not MSISDN
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.379 1400 - LSS: Invalid MSISDN digits length
The MSISDN length in Subscriber Information was 0, or the MSISDN length was 1 ( ‘ /byte) and the MSISDN had only one 0xF (filler) digit.
0002.1400 SYSTEM INFO LSS: Invalid MSISDN digits length
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.380 1401 - LSS: Unsupported numbering plan
The Numbering Plan in MSISDN from Subscriber Identity in the incoming ATI NP query is not supported (not ISDN/Telephony (0x1)).
0002.1401 SYSTEM INFO LSS: Unsupported numbering plan
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.381 1402 - ATINPQ: Invalid Requested Info
The Requested Info parameter in incoming ATI NP query was invalid. Either, length of Requested Info parameter < 2, or the Requested Info parameter does not contain MNP Requested Info, or the parameter is badly formatted.
0002.1402 SYSTEM INFO ATINPQ: Invalid Requested Info
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
3.3.382 1403 - LSS: Dgts truncated in encd parms
One or more encoded digits parameters in ATI ACK response had to be truncated to fit maximum allowed encoded digits.
0002.1403 SYSTEM INFO LSS: Dgts truncated in encd parms
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Verify the expected number of digits in routing Number and MSISDN fields. These depend on combination of requested formatting for routing Number and MSISDN fields (ATINPQOPTS:ATIACKRN and ATIACKMSISDN options), digits in incoming ATI NP query and result of RTDB lookup.
3.3.383 1407 - Unexpected SI in TIF Stop Action
An MSU is received by TIF/TIF2/TIF3 stop action that is not ISUP. MSUs delivered to a TIF stop action that are not ISUP (SI=5) or TUP (SI=4) shall be routed without modification.
RLGHNCXA21W 09-09-21 16:20:19 GMT EAGLE5 39.2.0
0017.1407 CARD 1103,A INFO Unexpected SI in TIF Stop Action
SIO=08 OPC=001-001-001 DPC=s-002-002-002
12 34
SR=scrb LSN=ABCD123
Report Date:09-09-21 Time:16:20:19
Recovery
The TIF Support of TUP feature is not turned on.
3.3.384 1408 - TIF: Modified MSU Too Large to Route
The MSU is too large to transmit after modification (>273 bytes from SIO onward). The original MSU is routed without modification.
0017.1408 CARD 1103,A INFO TIF: Modified MSU too large to route
DATA=26 80 03 09 0e 06 09 00 fe 08 50 55 05
43 00 00 00 00 00
LSN=ABCD123
Recovery
3.3.385 1410 - MOSMS: Migrated Subscriber with No Entity
There is no entity defined in the RTDB for the migrated subscriber. The subscriber is found migrated and the migration prefix has to be the entity resulted from RTDB lookup.
tekelecstp 02-03-20 07:40:50 EST EAGLE 40.1
6815.1410 CARD 1103 INFO MOSMS: Migrated Subscriber with no entity
ADDR=110000
LSN=ls221
Recovery
Ensure the subscriber has an Entity in the Database, or change MOIGMPFX value of IS41SMSOPTS Table.
3.3.386 1411 - TIF CgPN NS Failure: CC mismatch in DN
A CC mismatch in DN occurred during TIF framework conversion. The CgPN will not be modified.
tekelecstp 02-03-20 07:40:50 EST EAGLE 41.0
0226.1411 CARD 1101 INFO TIF CgPN NS Failure: CC mismatch in DN
International CGPN: 911111012345678
EPAP DN : 899111632226337
Report Date:08-09-10 Time:16:20:19
Recovery
Verify the Public and Private DNs CC match. If the CCs do not match, reconcile the issue within the subscriber database.3.3.387 1412 - GTT(FLOBR) failure: max search depth
This message indicates GTT failed when FLOBR encountered a chain longer than maximum depth. The MSU is discarded.
stpa1071501 09-04-24 13:05:10 EDT EAGLE5 41.0.0-62.23.1
9941.1412 CARD 2317 INFO GTT(FLOBR) failure: max search depth
SIO=83 OPC= 14472-aa DPC= 07347-aa
SCCP MSG TYPE=09
CDPA: NI=0 RI=0 GTI=04 SSNI=1 PCI=1
TT=036 NP=01 NAI=004 ADDR=106001000000000000000
PC= 07347-aa SSN=005
CGPA: NI=0 RI=0 GTI=04 SSNI=1 PCI=1
TT=085 NP=07 NAI=003 ADDR=206001000000000000000
PC= 14472-aa SSN=101
LSN=ls2314n2 GTTSETIDX=211 230 231 232
Report Date:09-04-24 Time:13:05:10
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- Linkset name
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- In the CDPA section, PC refers to the Called Party Point Code. In the CGPA section, PC refers to the Calling Party Point Code.
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Verify the provisioning of the GTT information using the
rtrv-gta,
rtrv-gttsel, and
rtrv-gttset commands to determine why
the MSU encountered an excessive search depth.
3.3.388 1413 - GTT(FLOBR) failure: duplicate set name
This message indicates GTT failed when FLOBR encountered a duplicate GTT set name in the GTT search. This UIM is issued when the Fallback option is OFF in GTA entry. The MSU is discarded.
stpa1071501 09-04-24 10:01:40 EDT EAGLE5 41.0.0-62.23.1
7386.1413 CARD 2317 INFO GTT(FLOBR) failure: duplicate set name
SIO=83 OPC= 14504-aa DPC= 07347-aa
SCCP MSG TYPE=09
TT=036 NP=01 NAI=004 ADDR=106005000000000000000
TT=085 NP=07 NAI=003 ADDR=206005000000000000000
LSN=ls2314n2 GTTSETIDX=211 215
Report Date:09-04-24 Time:10:01:40
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- Link set name
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
rtrv-gta,
rtrv-gttsel, and
the MSU encountered a duplicate GTT set name.
3.3.389 1414 - GTT(FLOBR) warning: max search depth
This message indicates GTT succeeded but searched had encountered a chain longer than the maximum depth. The MSU is routed, as indicated by the index value within the parenthesis of the GTTSETIDX string.
5096.1414 CARD 2317 INFO GTT(FLOBR) warning: max search depth
SCCP MSG TYPE=09
LSN=ls2314n2 GTTSETIDX=211 230 231 (232)
Report Date:09-04-24 Time:13:18:22
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- Linkset name
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
rtrv-gta,
rtrv-gttsel, and
3.3.390 1415 - GTT(FLOBR) warning: duplicate set name
This message indicates GTT succeeded, but a duplicate GTT set name was encountered in the GTT Search. This UIM is issued when the Fallback option is ON in GTA entry. The MSU is routed as indicated by the index value within the parenthesis of the GTTSETIDX string.
stpa1071501 09-04-24 09:56:40 EDT EAGLE5 41.0.0-62.23.1
7367.1415 CARD 2317 INFO GTT(FLOBR) warning: duplicate set name
SCCP MSG TYPE=09
LSN=ls2314n2 GTTSETIDX=(211) 215
Report Date:09-04-24 Time:09:56:40
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- Link set name
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
rtrv-gta,
rtrv-gttsel, and
3.3.391 1416 - MAP Missing Mandatory Parameters
MOSMS Feature could not decode the GSM MAP message, since there are missing mandatory parameters in the TCAP portion of the message, e.g., SM-RP-UI or SM-RP-OA.
6815.1416 CARD 1103 INFO MAP Missing Mandatory Parameters
ADDR=110000
LSN=ls221
Recovery
Ensure the message contains all mandatory parameters.
3.3.392 1417 - PublicKey doesn’t match known-host file
This message indicates that the SSH public key that is exchanged between the host and server has changed. This could be due to a legitimate configuration change on the server, or it could be caused by a security breach, such as a man-in-the-middle attack.
If strict-host-key-checking is in effect, the connection will be rejected. Otherwise, the new key will be automatically added to the known-host file
RLGHNCXA21W 13-07-30 21:18:09 EDT EAGLE5 45.0.0-64.70.1
0130.1417 CARD 1113 INFO PublicKey doesnt match known-host file
FTP Server IP Address = xxx.xxx.xxx.xxx
Recovery
Contact the server system administrator to determine if the host key change is legitimate.
3.3.393 1418 - SCCP did not route - no SSN in CgPA
This message indicates the GTT failed because a CgPA SSN Set Type was encountered, but no CgPA SSN in MSU. The MSU is discarded.
9941.1418 CARD 2317 INFO SCCP did not route - no SSN in CgPA
SCCP MSG TYPE=09
CDPA: NI=0 RI=0 GTI=04 SSNI=0 PCI=1
PC= 07347-aa SSN=---
CGPA: NI=0 RI=0 GTI=04 SSNI=0 PCI=1
PC= 14472-aa SSN=---
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- Linkset name
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
rtrv-gta,
rtrv-gttsel, and
rtrv-gttset commands to determine if
the GTT processing path and fallback options are set properly for the incoming
MSU.
3.3.394 1419 - SCCP did not route - no SSN in CdPA
This message indicates the GTT failed because a CdPA SSN Set Type was encountered, but no CdPA SSN in MSU. The MSU is discarded.
9941.1419 CARD 2317 INFO SCCP did not route - no SSN in CdPA
SCCP MSG TYPE=09
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- LSN
- Linkset name.
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
rtrv-gta,
rtrv-gttsel, and
MSU.
3.3.395 1424 - IMT A [B] requested to re-align at LOW [HIGH] Rate
This message is issued when a rate change request is sent by the OAM to the HIPR2 cards on a particular bus (to re-align at the requested rate). The HIPR2 cards will initiate the alignment protocol on receiving the request.
RLGHNCXA21W 09-02-07 12:01:43 EST EAGLE 41.1.0
0023.1424 CARD 1115 INFO IMT A requested to re-align at HIGH Rate
Report Date:09-02-07 Time:12:01:43
Recovery
3.3.396 1425 - SMS A-party Address decode failed
Decoding fields of the SMS_OOA parameter of IS41 SMDPP message failed.
6815.1425 CARD 1103 INFO SMS A-party Address decode failed
ADDR=110000
LSN=ls221
Recovery
Ensure that SMDPP message contains properly formatted SMS_OOA parameter.
3.3.397 1426 - S-Port: Missing GRN for srvc prtd subs
Service Portability required RTDB data “GRN” to format outbound digits, which was not found.
0017.1042 CARD 1103,A INFO S-Port: Missing GRN for srvc prtd subs
INCM DN: 4605500
COND DN: 19194605500
LSN=ABCD123
6850.1426 CARD 1103 INFO S-Port: Missing GRN for srvc prtd subs
ADDR=987654
CGPA: AI=09 PC=-------------- SSN=003
INCM DN: 4605500
LSN=ABCD123
Recovery
Verify that a GRN has been provisioned for the conditioned DN (specified in the COND DN field in the UIM output) in EPAP.
3.3.398 1427 - IAR CdPN parameter invalid or not found
This message is issued when the IAR Base feature cannot find a CdPN parameter within a message, when it cannot decode the parameter after it finds it, or when the parameter does not contain the required information in a usable format.
RLGHNCXA21W 09-07-21 16:20:19 EST EAGLE 41.1.0
0002.1427 CARD 1113 INFO IAR CdPN parameter invalid or not found
Report Date:09-07-21 Time:16:20:19
Recovery
3.3.399 1428 - IAR CgPN parameter invalid or not found
This message is issued when the IAR Base feature cannot find the CgPN parameter within a message, when it cannot decode the parameter after it finds it, or when the parameter does not contain the required information in a usable format.
0002.1428 CARD 1113 INFO IAR CgPN parameter invalid or not found
Recovery
3.3.400 1429 - IAR TRIGTYPE invalid or not found
This message is issued when the IAR Base feature cannot find the TRIGTYPE parameter within a message, when it cannot decode the parameter after it finds it, or when the parameter does not contain the required information in a usable format.
0002.1429 CARD 1113 INFO IAR TRIGTYPE invalid or not found
Recovery
3.3.401 1430 - IAR CdPN parameter encoding failed
This message is issued when the IAR Base feature cannot encode the message after modifying its CdPN parameter. One way that this can occur without invalid data is when a CdPN parameter length increases, and the containing message grows too large.
0002.1430 CARD 1113 INFO IAR CdPN parameter encoding failed
Recovery
3.3.402 1431 - IAR CgPN parameter encoding failed
This message is issued when the IAR Base feature cannot encode the message after modifying its CgPN parameter. One way that this can occur without invalid data is when a CgPN parameter length increases, and the containing message grows too large.
0002.1431 CARD 1113 INFO IAR CgPN parameter encoding failed
Recovery
3.3.403 1432 - IGM Relay Failed - Bad IS41SMSC Xlation
This message indicates that the GTT translation lookup on DEFIS41SMSC digits (within GTTSET specified by IS41SMSCGTTSN) failed.
Example
station1234 09-08-30 16:28:08 EST EAGLE5 41.1.0
1234.1432 CARD 1101 INFO IGM Relay Failed - Bad IS41SMSC Xlation
SIO=03 OPC= 7-001-7 DPC= 1-001-1
SCCP MSG TYPE=09
CDPA: NI=0 RI=0 GTI=02 SSNI=0 PCI=0
TT=010 NP=-- NAI=--- ADDR=9911308117
PC=-------------- SSN=---
CGPA: NI=0 RI=1 GTI=00 SSNI=1 PCI=1
PC= 7-001-7 SSN=010
LSN=lsi1 GTTSETIDX=1
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- Point code for the SS7 end user (OPC).
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
- Provision the translation entry for DEFIS41SMSC
digits within the GTTSET specified by IS41SMSCGTTSN. Use the
rtrv-gttsetcommand to search the GTT set name based on the GTTSET index displayed in the UIM. - Change the IS41SMSCGTTSN option value in the GSMOPTS table to a valid GTT set name that contains translation for DEFIS41SMSC digits.
3.3.404 1433 - AIQ: Inhibit request already pending
An inh-map-ss command is already entered and queued.
Example
RLGHNCXA21W 00-02-10 12:01:43 EST EAGLE 42.0.0
0014.1433 SYSTEM INFO AIQ: Inhibit request already pendingAlarm Level: No alarm condition. The message is informational only.
Recovery
3.3.405 1434 - AIQ: Failure Inhibiting SS
The inh-map-ss command did not take the AIQ subsystem off-line.
Example
0014.1434 SYSTEM INFO AIQ: Failure Inhibiting SSAlarm Level: No alarm condition. The message is informational only.
Recovery
Enter the inh-map-ss command with the force parameter.
3.3.406 1435 - AIQ: TriggerType not provisioned
This message indicates that the AIQ subsystem received an AIQ message where the value of the TriggerType parameter is not provisioned in the AIQOPTS table.
Example
5193.1435 CARD 1105 INFO AIQ: TriggerType not provisioned
SIO=83 OPC= 001-001-001 DPC= 009-008-007
CDPA: AI=cb SSN=014 TT=004
ADDR=9873946354
CGPA: AI=cb PC= 001-001-001 SSN=014
DATA=3f e2 3d c7 04 00 01 02 03 e8 35 e9
33 cf 01 2a d1 02 09 40 f2 29 81 07
00 00 00 00 00 00 00 84
LSN=ls1
Report Date:20-08-29 Time:02:55:22Alarm Level: No alarm condition. The message is informational only.
Recovery
Ensure the AIQ message’s TriggerType parameter value is one of those provisioned in the AIQOPTS table.
3.3.407 1436 - AIQ: Unsupported Digits(Dialed) length
This message indicates that the AIQ subsystem received an AIQ message where the length of the Digits(Dialed) parameter is outside of the range provisioned in the AIQOPTS table.
Example
0643.1436 CARD 1105 INFO AIQ: Unsupported Digits(Dialed) length
ADDR=9873946354
LSN=ls1
Report Date:20-08-29 Time:03:04:25Alarm Level: No alarm condition. The message is informational only.
Recovery
Ensure the AIQ message’s Digits(Dialed) parameter length is within the range provisioned in the AIQOPTS table.
3.3.408 1437 - IMT [A|B]: Rate change not initiated
This message is issued when the IMT Rate change could not proceed due to bus being in alarming state.
0023.1437 CARD 1115 INFO IMT A: Rate change not initiated
Recovery
Although no action is required, this message can serve as a notification to verify status of the IMT bus and to start recovery procedures if needed.
- Enter the
rept-stat-imtcommand to verify the status of the IMT bus. - Replace any faulty cards with a new HIPR2 card.
- Contact unresolvable-reference.html#GUID-6A9FA28A-A250-400D-B162-873CF95A69FA for more information.
3.3.409 1439 - SIP card exceeded threshold TPS
The alarm indicates that the SIP card has reached maximum TPS.
1 2 3 4 5 6 7 8
xxxx.1439 CARD 1106 INFO SIP card exceeded threshold TPS
Report Date:13-09-03 Time:18:57:35
Recovery
Traffic must be reduced to the SIP card. Failure to reduce SIP card traffic may result in traffic or card failure.
3.3.410 1440 - G-Flex MLR: Op with bad MSISDN skipped
The G-Flex MLR Function encountered an MSISDN parameter that contains fewer than 5 digits or more than 15 digits
station1234 06-12-21 16:28:08 EST Rel 42.0.0
0020.1440 CARD 1106 INFO G-Flex MLR: Op with bad MSISDN skipped
Recovery
Abnormal length of the MSISDN indicates a configuration issue on the far-end node, which can be confirmed with a message trace.
3.3.411 1441 - IP Info mismatch, card reset required
The card stated in the message has an IP mismatch and must be reset. This occurs when the database is updated and a manual reset must be performed for the newly provisioned values to be used.
The IP configuration commands support the MCAP locations when OAMHC is running. Usually these commands require the target card to be inhibited, however for MCAP locations, the command is expected to be run while the card is IS-NR. Since these commands result in a database update, they require the MCAP to be IS-NR. Once the database has been modified, manual reset of the card must be performed for the newly provisioned values to be used. A notice is displayed to the user regarding the reset requirement for an MCAP location. If the MCAP location is not reset, then a UIM is displayed once every hour indicating that the card has an IP Mismatch and must be reset.
RLGHNCXA03W 10-01-11 16:20:19 EST EAGLE 42.0.0
0020.1441 CARD 1113 INFO Active OAM IP mismatch, 1113 reset req
Report Date:10-01-11 Time:16:20:19
0020.1441 CARD 1113 INFO Standby OAM IP mismatch, 1115 reset req
Report Date:10-01-11 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
Reset the card in the appropriate slot as specified in the message text.
3.3.412 1442 - Invalid EMP SCR Message Received
This UIM indicates that the EAGLE 5 ISS received and rejected an invalid Service Configuration Request (SCR) EMP message. The UIM includes the IP address where the request originated and the reason the EAGLE 5 ISS rejected the SCR message.
0020.1442 CARD 1106,A INFO Invalid EMP SCR Message Received
MSG Length=6
REQ EMP Version=4 RSP EMP Version=4
REQ Transaction ID=123 RSP Transaction ID=123
IMF IP Address= 172.21.48.15
Reason=Invalid Message Length
Report Date:10-02-21 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
No action is necessary if there is only one occurrence. If the condition continues, use the information provided in the message to debug the problem.
3.3.413 1443 - GTT Action Failed to Send TCAP Error
This UIM indicates that the TCAP error action could not generate a TCAP error response due to any failure in decoding TCAP.
6054.1443 CARD 1101 INFO GTT Action FAILED TO SEND TCAP ERROR
OPC= 1-001-4 DPC= 1-001-5
CDPA: NI=0 RI=0 GTI=02 SSNI=1 PCI=1
TT=010 NP=-- NAI=--- ADDR=9818316478
PC= 1-001-1 SSN=016
CGPA: NI=0 RI=0 GTI=02 SSNI=1 PCI=1
TT=011 NP=-- NAI=--- ADDR=9910929095
PC= 1-002-3 SSN=049
Op-Code=--- Action Set=tcapset
Report Date:03-01-03 Time:16:55:23
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- OP-CODE
- Operation Code
- PARAM
- Parameter
- PC
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery:
Do just one of the following to fix the problem:
- Correct the TCAP Portion.
- Disassociate “TCAP Error” GTT Action from the GTT Translation.
- Change the “TCAP ERROR” action to either “UDTS” or “DISCARD” GTT Action.
3.3.414 1444 - GTT Loadsharing fail: PC not in MRNSET
This UIM indicates that the EAGLE 5 ISS failed to loadshare a MSU, because the translated DPC is not present in the specified non-default MRNSET.
0019.1444 CARD 1104,A INFO GTT Loadsharing fail: PC not in MRNSET
GTT on CdPA used MOSMSGTA= 9193802053
CDPA: NI=1 RI=0 GTI=04 SSNI=0 PCI=1
CGPA: NI=1 RI=0 GTI=04 SSNI=0 PCI=1
TT=100 NP=07 NAI=012 ADDR=012345678901234567890
- ADDR
- Address
- CDPA
- CGPA
- GTI
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- OP-CODE
- Operation Code
- PARAM
- Parameter
- PC
- PCI
- RI
- Routing indicator
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery:
Do one the following to fix the problem:
- Configure the DPC displayed in UIM within the displayed MRNSETID.
- Configure correct MRNSETID (which contains the DPC displayed in the UIM) in associated GTT Translation entry.
- Configure “Default” MRNSETID in the GTT Translation entry.
3.3.415 1445 - LNP Day Meas. Discarded for LRN
This message is indicates that the Daily LNR measurement counts are incorrect because of discards due to provisioning.
0020.1015 CARD 1106 INFO LNP Day Meas. Discarded for LRN
Recovery
No action required.
3.3.416 1446 - XUDT UDT conversion failed
0018.1446 CARD 1103,A INFO XUDT UDT conversion failed
SCCP MSG TYPE=04
Report Date:10-06-14 Time:16:20:19Legend
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- GTTSET
- GTT Set Index
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
- Database Administration Manual - Global Title Translation
- The
ent/chg/rtrv-dstncommands in the Commands Manual
3.3.417 1447 - Cnvrsn Discard: inv segmentation parm
This UIM is issued when the EAGLE 5 ISS receives an XUDT message that has a segmentation parameter that is incorrect for the message undergoing ANSI/ITU SCCP conversion.
0018.1447 CARD 1103,A INFO Cnvrsn Discard: inv segmentation parm
SCCP MSG TYPE=04
- ADDR
- Address
- CDPA
- CGPA
- DPC
- GTI
- GTTSET
- GTT Set Index
- LSN
- MSG TYPE
- Message type
- NAI
- NI
- NP
- Numbering plan
- OPC
- PC
- PCI
- RI
- Routing indicator
- SIO
- SSN
- Subsystem number
- SSNI
- TT
- Translation type
Recovery
Check the incoming XUDT message to find the incorrectly formatted Segmentation parameter. Contact the node that is sending the messages.
3.3.418 1448 - G-Flex MLR: Op w/o IMSI/MSISDN skipped
The G-Flex MAP Layer Routing Function encountered problems because the IMSI or MSISDN parameter is missing. Normal G-Flex processing is applied to the associated message.
0018.1448 CARD 1103,A INFO G-Flex MLR: Op w/o IMSI/MSISDN skipped
ADDR=110000
LSN=ls221
- ADDR
- Address
- CDPA
- CGPA
- DATA
- DPC
- LSN
- OPC
- PC
- Point code for the SS7 calling user (CgPA)
- SIO
- SSN
- Subsystem number
- TT
- Translation type
Recovery
Contact far end note and investigate reason for error.
3.3.419 1449 - Binding Failed for screen set: <screen set name>
This UIM indicates a screen-set binding failure in Gateway Screening (GWS).
0023.1449 CARD 1105 INFO Binding Failed for screen set: ayyy
Report Date:11-05-26 Time:16:20:19 Alarm Level: No alarm condition. The message is informational only.
Recovery
Refer to the UIM for the name of the failed screen set. The LIM or Service Module card regenerates a binding request.
3.3.420 1450 - IDPRCDPN CDPN Encoding Failed
This UIM is raised if IDPRCDPN encoding fails.
1 2 3 4 5 6 7 8
eagle4 02-03-06 14:31:03 MST UNKNOWN ??.?.?-64.19.0
9442.XXXX CARD 1105 INFO IDPR CDPN encoding failed
SIO=03 OPC= 1-010-1 DPC= 1-001-1
CDPA: AI=0b SSN=051 TT=025
ADDR=9900112233
CGPA: AI=4a PC=-------------- SSN=051
INCM DN: 9992222226
COND DN: 9992222226
LSN=itu1
Report Date:02-03-06 Time:14:31:03
Recovery
One or more of following actions must be taken:
- The Formatting Action list in the NPP Action Set that processed the IDP Query must be corrected.
- The data associated with DN in the RTDB must be corrected.
- The message must have enough space for the CDPN parameter expansion.
3.3.421 1451 - IDPRCGPN CGPN Encoding Failed
This UIM is raised if IDPRCGPN encoding fails.
9452.1451 CARD 1105 INFO IDPR CGPN encoding failed
ADDR=9900112233
INCM DN: 9992222227
COND DN: 9992222227
LSN=itu1
Report Date:02-03-06 Time:14:37:31
Recovery
- The message must have enough space for the CGPN parameter expansion.
3.3.422 1452 - Invalid IP Address from SCTP Heartbeat Response
This UIM indicates an SCTP layer received a Heartbeat Response (HB) with a source IP address that did not match the IP address from where the original HB message was sent.
1 2 3 4 5 6 7 8
0388.1452 CARD 1308,A INFO SCTP HB ACK from unexpected IP address
HB RESP IPADDR = 10.254.111.21
HB RESP PORT = 4002
HB INFO IPADDR = 10.254.111.21
HB INFO PORT = 4002
SNAME = sg1308b
Report Date:12-07-10 Time:13:45:24
Recovery
Correct the IP network setup for the SCTP association.
3.3.423 1453 - EE Collection started
This UIM indicates collection has started on a network card when Eagle Eyes proper is in Active state.
1 2 3 4 5 6 7 8
0023.1453 CARD 1105 INFO Collection started on card
Recovery
None.
3.3.424 1454 - EE Collection end
EAGLE may not output this UIM when Eagle Eye Collection termination is initiated by the system based on the set capture limit (SECLIM, PKTLIM, and KBLIM). 1 2 3 4 5 6 7 8
0023.1454 CARD 1105 INFO EE Collection end
Recovery
None.
3.3.425 1455 - EE Queue full, Packets Dropped
This UIM indicates the message queue on the GEDTI card is full; no more packets can be enqueued..
1 2 3 4 5 6 7 8
0023.1455 CARD 1105 INFO EE Queue Full Packets Dropped
Recovery
None.
3.3.426 1456 - Hub Congested, Packets Dropped
This UIM indicates the message queue between the GEDTI and EEPC is full.
1 2 3 4 5 6 7 8
0023.1456 CARD 1105 INFO Hub Congested Packets Dropped
Recovery
None.
3.3.427 1457 - GEDTI Port Enabled
This UIM indicates the GEDTI port is enabled on the IPSM card.
1 2 3 4 5 6 7 8
9671.1457 CARD 1112 INFO GEDTI Port Enable
PORT = 5555
Recovery
None.
3.3.428 1458 - GEDTI Port Disabled
This UIM indicates the GEDTI port is disabled on the IPSM card.
1 2 3 4 5 6 7 8
9642.1458 CARD 1112 INFO GEDTI Port Disabled
PORT = 5555
Recovery
When the GEDTI port is enabled.
3.3.429 1459 - TCP Connection lost b/w IPSM and EEPC
This UIM indicates the TCP Connection between the IPSM card and network card has been lost.
1 2 3 4 5 6 7 8
0023.1459 CARD 1105 INFO TCP Connection lost b/w IPSM and EEPC
SESSION ID = 1
Recovery
When the TCP Connection is re-established.
3.3.430 1460 - GWS Duplicate Stop Action Failed
This message indicates the gateway screening (GWS) Duplicate and Route stop action failed to duplicate an incoming MSU.
5347.1460 CARD 1103 INFO GWS Duplicate Stop Action Failed
Report Date:13-10-10 Time:16:20:19
Recovery
No further action is required.
3.3.431 1461 - Link status on card needs re-sync
This message indicates the Link status on the card needs to be re-synched and the system has initiated a re-synchronization.
0020.1461 CARD 1106 INFO Link status on card needs re-sync
Card=xxxx Port=xxx
3.3.432 1462 - EE not Configured
This message indicates the EE capture does not start when the network card under capture is not configured as Eagle Eyes Proper.
0023.1462 CARD 1105 INFO EE not ConfiguredAlarm Level: No alarm condition. The message is informational only.
Recovery
No action is necessary.
3.3.433 1463 - ENUM connection established
This message indicates the ENUM connection has come into IS-NR state.
xxxx.1463 CARD 1463 INFO ENUM connection established
Connection Name : enum1101
Report Date: 06-05-14 Time:16:20:19
Recovery
3.3.434 1464 - ENUM connection terminated
This message indicates the ENUM connection has gone down.
xxxx.1464 CARD 1464 INFO ENUM connection terminated
Report Date:06-05-14 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.435 1466 - ENUM Dflt Prof & query type mismatch
The Default ENUM Profile response type and incoming query type do not match.
xxxx.1466 CARD 1466 INFO ENUM Dflt Prof & query type mismatch
Report Date: 06-05-14 Time:18:57:35
Recovery
3.3.436 1467 - ENUM msg decode failed
This message indicates an ENUM message validation has FAILED.
xxxx.1467 CARD 1467,B INFO ENUM msg decode failed
Reason: Response Recieved
Header: QR(1)
Domain: ----
IP : 10.248.13.3
QType : ----
Entity ID: ----
Recovery
3.3.437 1468 - ENUM rcvd invalid msg
This message indicates the ENUM has received a query with unsupported field values.
xxxx.1468 CARD 1468,B INFO ENUM rcvd invalid msg
Reason: Invalid Domain
Header: QR(0)
Domain: e164.abcd
IP : 10.248.13.3
QType : NAPTR(35)
Entity ID: ----
Recovery
3.3.438 1469 - ENUM request rejected
This message indicates an ENUM request rejected is coming from invalid IP addresses.
xxxx.1469 CARD 1469,B INFO ENUM request rejected
Reason: Unauthorized ENUM Client
Header: ----
Domain: ----
IP : 10.248.13.9
QType : ----
Entity ID: ----
Recovery
3.3.439 1471 - ENUM matching prof for qry not found
This message indicates the ENUM Profile Table is missing an entry of a matching ENUM query type.
xxxx.1471 CARD 1471,B INFO ENUM matching prof for qry not found
Reason: Queried Response type not found
Header: QR(0)
Domain: e164.arpa
IP : 10.248.13.3
QType : NAPTR(35)
Entity ID: 123456
Report Date: 06-05-14 Time:16:20:19Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.440 1472 - SCTP Buffer full timer expired, Restart
This message indicates the SCTP Buffer full timer has expired and requires a restart.
xxxx.1472 CARD 1104 INFO SCTP Buffer full timer expired, Restart
Recovery
3.3.441 1473 - Unable to connect to socket
This message indicates the EAGLE is unable to connect to the EAGLE Application Processor. Verify the IP configuration for connectivity to the far end.
0002.1473 CARD 1113 INFO Unable to connect to socket
Report Date:02-07-21 Time:16:20:19
Recovery
3.3.442 1475 - TOBR Multiple Comp: Translation found
This message indicates a translation has been found for more than one component even if its priority numbers are lower than the first component.
5902.1475 CARD 1101 INFO TOBR Multiple Comp: Translation found
SIO=03 OPC= 6-006-1 DPC= 7-007-7
SCCP MSG TYPE=09
CDPA: NI=0 RI=0 GTI=00 SSNI=0 PCI=1
PC= 3-132-5 SSN=---
PC= 0-141-7 SSN=146
LSN=ls661 GTTSETIDX=2
Report Date:16-12-07 Time:11:20:32
Recovery
3.3.443 1476 - TCAPMulComp: Dup Opcode MSU discarded
This message indicates the duplicate in a TCAP Message with the same Opcode in more than one component has been discarded.
5902.1476 CARD 1101 INFO TCAPMulComp: Dup Opcode MSU discarded
SCCP MSG TYPE=09
PC= 3-132-5 SSN=---
PC= 0-141-7 SSN=146
Recovery
3.3.444 1477 - SFAPP Validation Response Timeout Error
This message indicates an SFAPP validation response timeout error.
0156.1477 CARD 1103 INFO SFAPP Validation Response Timeout Error
Reason: ----
OPC= 001-001-001 DPC= 003-003-001
CDPA: NI=1 RI=0 GTI=02 SSNI=1 PCI=1
TT=010 NP=-- NAI=--- ADDR=9999
PC= 003-003-001 SSN=009
CGPA: NI=1 RI=0 GTI=02 SSNI=1 PCI=1
TT=034 NP=-- NAI=--- ADDR=131313
ACN=4-0-0-1-0-18-2 PKG-Type=TC BEGIN(0x62)
MSISDN: NP=1 NON=1 ADDR=123456
LSN=ls331 Op-Code= 12 GTT Action Set=sfapp1
Report Date:17-12-14 Time:17:26:35
Recovery
3.3.445 1478 - SFAPP Validation Encoding Error
This message indicates an SFAPP validation encoding error.
1053.1478 CARD 1107 INFO SFAPP Validation Encoding Error
Reason: INVALID ACN
OPC= 003-003-001 DPC= 001-001-001
PC= 003-003-001 SSN=008
TT=011 NP=-- NAI=--- ADDR=131313
PC= 001-001-001 SSN=009
ACN=--- PKG-Type=TC BEGIN(0x62)
--- : NP=--- NON=--- ADDR=-----
LSN=ls331 Op-Code= 0 GTT Action Set=
Report Date:17-12-15 Time:19:47:46
Recovery
3.3.446 1479 - SFAPP Validation Matching State not fnd
This message indicates the SFAPP validation matching state was not found.
7604.1479 CARD 1107 INFO SFAPP Validation Matching State not fnd
Reason: TID NOT FOUND
OPC= 3-003-1 DPC= 1-001-1
CDPA: NI=0 RI=1 GTI=00 SSNI=1 PCI=1
PC= 1-001-1 SSN=005
PC= 3-003-1 SSN=005
ACN=--- PKG-Type=TC END(0x64)
IMSI : NP=--- NON=--- ADDR=-----
LSN=ls331 Op-Code=--- GTT Action Set=-----
Report Date:17-12-18 Time:15:59:17
Recovery
3.3.447 1480 - SFAPP Validation Error
This message indicates an SFAPP validation error.
1053.1480 CARD 1107 INFO SFAPP Validation Error
Reason: INVALID ACN
Recovery
3.3.448 1481 - SFAPP Validation Velocity Chk Failed
This message indicates the SFAPP validation velocity check has failed.
5184.1481 CARD 1107 INFO SFAPP Validation Velocity Chk Failed
Reason: THRESHOLD EXCEEDED
OPC= 1-001-1 LSN= ls331 GTT Action=sfapp1
CGPA: NI=0 RI=0 GTI=02 SSNI=1 PCI=0
TT=017 NP=-- NAI=--- ADDR=12345678
PC=-------------- SSN=000
PKGTYPE=TC BEGIN(0x62) ACN= 4-0-0-1-0-32-3 OpCode=23
Loc from HLR : NP= 1 NoN= 1 ADDR=121212
AgeOfLocation : 257
Threshold : 999
SubscriberState : SFAPP_NOT_PROVIDED_BY_VLR_SGSN
Report Date:17-12-14 Time:13:46:15
Recovery
3.3.449 1482 - SFAPP Validation Failed
This message indicates the SFAPP validation has failed.
7735.1482 CARD 1107 INFO SFAPP Validation Failed
Reason: VLR MISMATCH
PKGTYPE=TC BEGIN(0x62) ACN= 4-0-0-1-0-18-3 OpCode=12
Loc from HLR : NP= 1 NoN= 1 ADDR=123456
AgeOfLocation : 28784
Threshold : ----
SubscriberState : SFAPP_CS_ASSUME_IDLE
Report Date:17-12-18 Time:16:35:10
Recovery
3.3.450 1483 - SFAPP VLR Status Changed
This message indicates the SFAPP VLR status has changed.
1 2 3 4 5 6 7 8
5105.1483 CARD 1101 INFO SFAPP VLR Status Changed
VLR=727272 : PREV STATUS=GrayList
CURR STATUS=Whitelist : Updated DB=No
Report Date:18-05-21 Time:15:37:11
Recovery
3.3.451 1484 - SFAPP New VLR Created
This message indicates a new SFAPP VLR has been created.
1 2 3 4 5 6 7 8
5039.1484 CARD 1101 INFO SFAPP New VLR Created
VLR=727272 : STATUS=Graylist
Report Date:18-05-21 Time:15:32:00;
Recovery
3.3.452 1485 - SFAPP New Roaming Entry Created
This message indicates a new SFAPP roaming entry has been created.
1 2 3 4 5 6 7 8
5039.1485 CARD 1101 INFO SFAPP New Roaming Entry Created
OLD_VLR=727272 : NEW_VLR=999999
THRESHOLD=999
Recovery
3.3.453 1486 - SFAPP New Primary Card Chosen
This message indicates a new primary SFAPP card has been chosen.
1 2 3 4 5 6 7 8
5016.1486 CARD 1101 INFO SFAPP New Primary Card Chosen
PRIMARY_SFAPP: LOC=1101
Report Date:18-05-21 Time:15:24:13
Recovery
3.3.454 1487 - SFAPP Dyn VLR ROAM Entry Deleted
This message indicates an SFAPP Dynamic VLR Roaming entry has been deleted.
1 2 3 4 5 6 7 8
5039.1487 CARD 1101 INFO SFAPP Dyn VLR ROAM Entry Deleted
THRESHOLD=999
Recovery
3.3.455 1488 - SFAPP Velocity Threshold Crossed
This message indicates the SFAPP velocity threshold has been crossed.
1 2 3 4 5 6 7 8
5039.1488 CARD 1101 INFO SFAPP Velocity Threshold Crossed
THRESHOLD=999
Recovery
3.3.456 1489 - SFAPP Dyn VLR Prof Entry deleted
This message indicates an SFAPP Dynamic VLR Profile entry has been deleted.
1 2 3 4 5 6 7 8
5039.1489 CARD 1101 INFO SFAPP Dyn VLR Prof Entry deleted
Recovery
3.3.457 1490 - Telnet terminal connection successful
Indicates that a telnet connection has been established with the EAGLE from the specified location, but no terminal has yet been selected.
RLGHNCXA21W 00-04-18 18:59:30 EST EAGLE 39.0
0010.1490 CARD 1105 INFO Telnet terminal connection successful.
RIPADDR=192.168.210.48
RIPORT=3805
LIPADDR=192.168.63.116
LIPORT=23
Report Date:03-01-01 Time:12:41:11
Recovery
3.3.458 1491 - Terminal enabled
This message indicates that the specified telnet terminal has been successfully selected by a user via telnet.
Example
RLGHNCXA21W 00-04-18 18:59:30 EST EAGLE 31.3.0
0105.1491 SYSTEM INFO Terminal enabled.
TERMINAL 20 Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.459 1492 - Terminal failed
This message indicates that the specified telnet terminal has been disconnected.
0105.1492 SYSTEM INFO Terminal failed.
TERMINAL 20Alarm Level: No alarm condition. The message is informational only.
Recovery
3.3.460 1493 - SSH Host Keys Regenerated
This message indicates that the OA&M IP Security Enhancements feature has successfully generated new host pubic/private key pairs. This occurs during cold restarts of an IPSM card. During initialization, this UIM displays the new key.
This UIM indicates a new public/private key is in effect. The old key is now invalid. The new key must be installed on SSH clients (on the FTRA) before any connections are permitted.
RLGHNCXA21W 03-08-18 18:59:30 EST EAGLE 30.2.0
0105.1493 SYSTEM INFO SSH Host Keys Regenerated
DSA Server Host Key FTRA-formatted Fingerprint=
xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
Recovery
3.3.461 1494 - SSH Host Keys Loaded
This message indicates that the OA&M IP Security Enhancements feature has successfully preserved existing host pubic/private key pairs. This occurs during reloads, init-card, and alw-card operations. During initialization, this UIM shows the state of the existing host key.
0105.1494 SYSTEM INFO SSH Host Keys Loaded
Recovery
No action necessary.
3.3.462 1495 - TCP IPS Message Failure
This UIM occurs when a TCP IPS message Failure has occurred.
6729.1495 CARD 1112 INFO TCP IPS Message Failure
Reason: INCORRECT CHECKSUM
Connection Name : ipstcp
Report Date:18-09-21 Time:16:38:33
Recovery
- Executing the
rtrv-ip-conn:opencommand should display open=yes. If not, execute thechg-ip-conncommand and set open=yes. - Execute the
rept-stat-ipconncommand and check if the connection is down. Ping the EEDB server, which is added as RHOST for this connection. If the ping response is not received, check the network connection. - Check the error cause to
determine why the error occurred; some errors are autocorrected. If not
autocorrected, execute the following commands:
chg-ip-conn:cname=<>:open=noandchg-ip-conn:cname=<>:open=yes
3.3.463 1496 - EAGLE EEDB Message Failure
This UIM occurs when an EAGLE EEDB Message Failure has occurred.
7643.1496 CARD 1101 INFO EAGLE EEDB Message Failure
Reason: EEDB RESPONSE TIMEOUT
VLR=7171 : STATUS=Whitelist
IMSI=69980645
Report Date:18-09-21 Time:17:45:33
Recovery
- Executing the
chg-ip-conn:cname=<>:open=noandchg-ip-conn:cname=<>:open=yes - check if the maximum TPS limit is exceeded. If so, stop the traffic.
3.3.464 1501 - Visualization connection terminated
This UIM occurs when visualization TCP connection goes down.
tklc1111101 20-07-08 05:58:08 MST EAGLE 46.9.0.0.0-76.22.0
6924.1502 CARD 1111 INFO Visualization connection terminated
Connection Name : conn7
Report Date:20-07-08 Time:05:58:08Alarm Level: No alarm condition. The message is informational only.
Recovery
Verify the remote end (visualization server) availability. However, connection will be established automatically if the remote end is available. Therefore, no action is necessary.
3.3.465 1502 - Visualization connection established
This UIM occurs when visualization TCP connection is established.
tklc1111101 20-07-08 05:58:00 MST EAGLE 46.9.0.0.0-76.22.0
6922.1501 CARD 1211 INFO Visualization connection established
Report Date:20-07-08 Time:05:58:00Alarm Level: No alarm condition. The message is informational only.
Recovery
