4.13 act-lg-sys
Use this command to activate the LG event generation/reception on all LG cards configured in the system.
The command class is TKLC_INTERNAL inheriting properties of DEBUG class. The Load Generator is supported on IPSG, IPLHC, IPGHC and SS7HC GPLs.Parameters
Example
act-lg-sys:dir=tx
act-lg-sys:dir=rx
act-lg-sys:dir=all
Dependencies
The LG System table is corrupt or cannot be found.
dir is mandatory
Activating the state of an LG object that is already activated or deactivating the state of an LG object that is already deactivated has no effect.
Output
None.
