4.14 act-lpo
Use this command to force a processor outage on the specified link. The system begins sending link status signal units (LSSUs) with a status of SIPO to the adjacent signaling point. Level 2 status remains in service, except when the link is an ATM high-speed signaling link.
The signaling link’s blocked status is not preserved across a LIM reboot.
Parameters
link (mandatory)
The signaling link on the card specified in the loc parameter. The links can be specified in any sequence or pattern.
Synonym:
port
Range:
a, b, a1 - a63, b1 - b63
Not all card types support all link parameter values.
See Table A-1 for valid link parameter range values for each type of card that can have assigned signaling links.
loc (mandatory)
The card location as stenciled on the shelf of the system.
Range:
1101 - 1108, 1111 - 1112, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 - 6118
Example
act-lpo:loc=1101:link=a
act-lpo:loc=1102:link=a40
Dependencies
A card location that is valid and defined in the database must be specified.
No other action command can be in progress when this command is entered.
This command is not valid for cards running the IPGHC GPL.
The card must contain signaling links.
The signaling link must be equipped in the database.
This command is not valid for links belonging to proxy linksets.
The value specified for the loc parameter must refer to one of the following cards, and the referenced card must be equipped:
  • E5-E1T1-B card running the SS7ANSI or CCS7ITU application
  • E5-ATM-B card running the ATMANSI or ATMITU application
  • E5-ENET-B card running the IPLHC or IPSG application
An appropriate value must be specified for the link parameter when an ATM card is used:
  • a-a1, b—E5-ATM-B card running the ATMANSI or ATMITU application
The act-lpo command is not supported for ITU-N16 links.
This command is not valid for IPSG-M3UA signaling links.
Notes
The function of this command is the same as the blk-slk command.
This command generates an alarm.
If this command is followed by the init-card command, the local processor outage is not preserved after the init-card command completes.
The Installation Guide provides an illustration of card locations.
If the blk-slk or act-lpo command is issued for an IPSG signaling link, then an MTP3 local processor outage is initiated.
Output
    tekelecstp 05-01-21 17:00:36 EST  EAGLE5 33.0.0
    Local processor outage being set.
    * 0014.0208 * SLK 1101,A nc00027 slk local blocked
tekelecstp 16-05-27 17:00:36 EST  EAGLE 69.1.0
    * 0014.0208 * SLK 1101,A40 lsna40 slk local blocked
