4.15 act-slk
Use this command to change the link from OOS-MT-DSBLD (Out-of-Service-Maintenance-Disabled) to IS-NR (In-Service-Normal).
The signaling link’s activated status is preserved across a card reboot.
Parameters
link (mandatory)
The signaling link on the card specified in the loc parameter. The links can be specified in any sequence or pattern.
Synonym:
port
Range:
a, b, a1 - a31, b - b31
Not all card types support all link parameter values.
See Table A-1  for valid link parameter range values for each type of card that can have a location specified in the loc parameter.
loc (mandatory)
The card location as stenciled on the shelf of the system.
Range:
1101 - 1108, 1111 - 1112, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 - 6118
Example
act-slk:loc=1301:link=a
Dependencies
The value specified for the loc parameter must refer to one of the following cards, and the referenced card must be equipped:
  • E5-E1T1-B, card running the SS7ANSI or CCS7ITU application
  • E5-ATM-B card running the ATMANSI or ATMITU application
  • E5-ENET-B card running the IPGWI, IPLIMI, IPSG, or SS7IPGW application
  • E5-ENET-B or SLIC card running the IPSG application
This command cannot be entered while the tst-slk command is in progress.
A card location that is defined in the database must be specified.
The card must contain signaling links.
No other action command can be in progress when this command is entered.
The specified signaling link must be provisioned in the database.
An appropriate value must be specified for the link parameter when an ATM card is used:
  • a-a1, b— E5-ATM-B card running the ATMANSI or ATMITU application
A link cannot be activated if the tst-j1 command is in progress on the same port on which the particular link being activated is configured.
This command is not valid for IPSG-M3UA signaling links.
Notes
Installation Guide provides an illustration of card locations.
If Port A32-A63 and B32-B63 is configured when card is not in IS-NR state, then the card won't come up if it's NON-SLIC card.
Output
    tekelecstp 05-01-21 17:00:36 EST  EAGLE5 33.0.0
    Activate Link message sent to card
