act-gedti
Use this command to activate a GEDTI Hub for Eagle Eyes. The state of the GEDTI Hub is changed from DACT(Deactivated) to ACT(Active).
The GEDTI hub must be Deactived on the specified card before the command can be executed. If the card boots, then the status of the GEDTI Hub will be reset to DACT.
Parameters
loc (mandatory)
The card location as stenciled on the shelf of the system.
Range:
1101 - 1108, 1111 - 1112, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 - 6118
Example
act-gedti:loc=1102
Dependencies
The value specified for the loc parameter must refer to an equipped card location.
The card at the specified location must be configured as GEDTI Hub.
Activating the state of GEDTI Hub that is already activated has no effect.
The card at the specified location must not be a reserved location.
Notes
None.
Output
act-gedti:loc=1101
Command Accepted - Processing
tekelecstp 11-08-16 18:35:44 MST EAGLE 46.0.0 act-gedti:loc=1101
Command entered at terminal #1.;
UNKNOWN EAGLE 46.0.0 Activate GEDTI Hub message sent to card.;
Command Completed.;
