act-ip-lnk
Use this command to activate an IP link and put the link into service. The state of the link is changed from OOS-MT-DSBLD (Out-Of-Service-Maintenance-Disabled) to OOS-MT (Out-Of-Service-Maintenance), IS-ANR (In-Service-Abnormal) or IS-NR (In-Service-Normal).
The specified card must be Active before the command can be executed. If the card boots, then the status of the IP link will be reset.Parameters
- loc (mandatory)
- The card location as stenciled on the shelf of the
system.
- Range:
- 1101 - 1108, 1111 - 1112, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 - 6118, 1113, 1115
Example
act-ip-lnk:loc=1102:port=a
act-ip-lnk:loc=1203:port=fca
act-ip-lnk:loc=1103:port=c
act-ip-lnk:loc=1202:port=d
Dependencies
The value specified for the loc parameter must refer to one of the following cards, and the referenced card must be equipped:
- E5-ENET-B card running the EROUTE, IPGWx, IPLIMx, or IPSG application
- IPSM card
- E5-SM4G or E5-SM8G-B card running the VSCCP application
- E5-OAM card running the OAMHC application
- E5-MCPM-B
- SLIC card
A valid value must be specified for the loc parameter.
- port A - E5-OAM card running OAMHC application, IPSM card, E5-MCPM-B card
- port A, B - E5-ENET-B card running the EROUTE or IPLIMx application, E5-SM4G or E5-SM8G-B card running the VSCCP application
- port A, B, FCA, FCB - E5-ENET-B card running the IPGWx or IPSG application
- port A, B, C and D are valid for SIP/ENUM/DEIR application running on SLIC card.
The card at the specified location must be configured.
The card in the specified location must be Active before this command can be executed.
Notes
The act-ip-lnk/dact-ip-lnk commands were created as debug means - aids to turn off or disable the IP interface to troubleshoot network problems, specifically to allow the operator to troubleshoot IP network flooding issues that can cause EAGLE cards to boot repeatedly while trying to come up. These commands should NOT be used for general maintenance actions since they have not been rigorously tested and their usage should be limited to situations like described above.
Interface A/D is used for ExAP connectivity and interface B/C is used for the signaling network on the SLIC card running the SIP/ENUM/DEIR application.
Output
act-ip-lnk:loc=1101:port=a
Command Accepted - Processing
tekelecstp 11-08-16 19:52:01 MST EAGLE 44.0.0
Command entered at terminal #1.
Activate IP link message sent to card.
Command Completed.
tekelecstp 16-05-25 03:48:33 MST EAGLE 46.4.0.0.0-69.1.0
Command entered at terminal #18.
Command Completed.
