dlt-lg-engine
Use this command to delete an LG engine.
The command class is TKLC_INTERNAL inheriting properties of DEBUG class. The Load Generator is supported on IPSG, IPLHC, IPGHC and SS7HC GPLs.
Parameters
engine (mandatory)
Range:
ayyyyyyyyy
Up to 10 alphanumeric characters; the first character must be a letter.
Example
dlt-lg-engine:engine=txengine1
Dependencies
The LG Engine table is corrupt or cannot be found.
The engine name specified must pre-exist in the LG Engine table.
Engine must be deactivated before it can be deleted.
Rx engine must be removed or disassociated from the Tx engine.
Output
