dact-lg-engine
Use this command to deactivate LG event generation/reception for a given engine on a LG engine. The command class is TKLC_INTERNAL inheriting properties of DEBUG class. The Load Generator is supported on IPSG, IPLHC, IPGHC and SS7HC GPLs.
Parameters
dir (optional)
Traffic Direction.
Range:
Rx
 Receive Direction
Tx
 Transmit Direction
All
Both in Tx and Rx directions
Default:
All
engine (optional)
Range: ayyyyyyyyy
Up to 10 alphanumeric characters; the first character must be a letter.
loc (optional)
The card location as stenciled on the shelf of the system.
Range:
1101 - 1108, 1111 - 1112, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 - 6118
Example
dact-lg-engine:loc=1301
dact-lg-engine:loc=1301:dir=tx
dact-lg-engine:engine=txengine1
Dependencies
The engine name specified must pre-exist in the LG Engine table.
The loc and engine parameters cannot be specified together in the command.
The card location specified in the loc parameter must be of a provisioned LG card.
The loc parameter must be specified before the dir parameter can be specified.
Activating the state of an LG object that is already activated or deactivating the state of an LG object that is already deactivated has no effect.
Output
