chg-lg-engine
Use this command to modify an LG engine. The command class is TKLC_INTERNAL inheriting properties of DEBUG class. The Load Generator is supported on IPSG, IPLHC, IPGHC and SS7HC GPLs.
Parameters
- port (optional)
- The signaling link on the card specified in the loc parameter.
- Synonym:
- link
- Range:
- a, b, a1 - a31, b1 - b31
Not all card types support all link parameter values.
See Table A-1 for valid link parameter range values for each type of card that can have a location specified in the loc parameter.
Example
chg-lg-engine:engine=txengine1:txrate=100
chg-lg-engine:engine=txengine1:port=b
Dependencies
The engine name specified must pre-exist in the LG Engine table.
The LG Engine table is corrupt or cannot be found.
The number of events associated with a engine should not exceed the max limit.
The txrate parameter cannot be specified with the event parameter of Rx type.
The action=pbk parameter can only be assigned to Tx event direction.
The action parameter of type snk, ret, retl2, cong, or cap can only be assigned to RX event direction.
The port specified in the command must be provisioned.
The rxengine parameter can only be specified with the action=pbk parameter.
The LG Card and Event specified in the command must belong to same network
SIF Size > 272 not supported on ss7hc
The Rx Event can not be associated to more than one Engine on the same LG card
Event dir and Action cannot be changed if engine is of Rx type and associated with the Tx engine.
The LG Event name specified in the command must exist in the table
The specified Rx engine parameter value must be associated with the card.
The port parameter cannot be specified with the event parameter of Rx type.
Engine specified in RxEngine parameter must of Rx Type.
The Rxengine specified must pre-exist in the LG Engine table.
Output
Related Topics
