rept-stat-card
Use this command to display the card status and maintenance activity states. The output includes card location, the GPL version being used by the card, device type, device primary state, device secondary state, and device associated state.
Parameters
- appl (optional)
- Application. The status of cards running the
specified application.
- Range:
- xyyyyyy
1 alphabetic character followed by up to 6 alphanumeric characters. Valid applications are:
atmansi —Used by E5-ATM-B cards to support ATM high-speed signaling links and T1 functions.
atmitu —Used by E5-ATM-B cards to support E1 high-speed signaling links and E1 functions.
ccs7itu —Used by E5-E1T1-B cards for ITU MTP functions.
deirhc —Used by E5-SM8G-B and SLIC cards to support the DEIR application.
elap —Used by E5-APP-B cards to support the ELAP application.
enumhc —Used by E5-SM8G-B cards to support the ENUM Mobile Number Portability and Tier One Address Resolution application.
epap —Used by E5-APP-B cards to support the EPAP application.
eroute —Used by STC cards and E5-STC cards for the EAGLE 5 Integrated Monitoring Support functions
gls —Used by E5-TSM cards for downloading gateway screening to LIM and Service Module cards
ipgwi —Used by E5-ENET-B cards for point-to-multipoint IP connectivity for ITU point codes. A maximum of 125 cards can be assigned the IPGWI application.
iplimi —Used by E5-ENET-B cards for point-to-point IP connectivity for ITU point codes
ips —Used by E5-IPSM and E5-ENET-B cards for the IP User Interface feature.
ipsg —Used by E5-ENET-B, and SLIC cards to support the combined functionality of IPLIMx M2PA and IPGWx M3UA
lsms - Used by E5-APP-B cards to support LSMS application.
mcp —Used by E5-MCPM-B cards for the Measurements Platform feature.
nas - Used by E5-APP-B cards to support the NAS application.
siphc — Used by E5-SM8G-B cards to support the SIP application.
ss7ansi —Used by E5-E1T1-B cards for ANSI MTP functions
ss7ipgw —Used by E5-ENET-B cards for point-to-multipoint IP connectivity. The system allows a maximum of 125 cards to be assigned the SS7IPGW application.
switch - Used by Telco switch to add power consumed by Telco Switch to Frame Power Budget. This is not an application gpl.
vsccp —Used by Service Module cards to support EPAP-based features and the LNP ELAP Configuration features. If no EPAP-based or LNP ELAP Configuration feature is turned on, and a Service Module card is present, then normal GTT traffic is processed.
- data (optional)
- Data filter specification. The status of cards
running the specified application with specified data.
The data parameter is valid for IPSG and VSCCP applications only. If the data parameter is not specified, then both types of IPSG (GTT disabled and GTT enabled) cards will be displayed under appl=ipsg.
- links (optional)
- Filter specification. Report the maximum number of links, only equipped links, or only unequipped links on the card in the specified card location (loc).
Example
rept-stat-card
rept-stat-card:loc=1201
rept-stat-card:loc=1201:mode=full
rept-stat-card:stat=alminh
rept-stat-card:appl=ss7ansi
rept-stat-card:appl=siphc
rept-stat-card:loc=1205:links=equip:mode=full
rept-stat-card:appl=epap
rept-stat-card:appl=switch
rept-stat-card:appl=elap
rept-stat-card:appl=lsms
rept-stat-card:appl=nas
rept-stat-card:appl=enumhc
rept-stat-card:appl=ipsg:data=gtt
rept-stat-card:appl=ipsg:data=nosccp
Dependencies
No other command can be in progress when this command is entered.
The mode parameter can be specified only when the loc parameter is specified.
Only one of the loc or stat parameters can be specified in the command.
Unless the appl=vcssp/ipsg, no other parameter can be specified with the appl parameter.
The shelf and card must be equipped.
The card location (loc) must be within the allowed range.
A valid value must be specified for the appl parameter.
The card location specified by the loc parameter must be equipped.
The data parameter is not valid with an APPL other than IPSG/VSCCP.
The data parameter can take nosccp as a value only when the APPL specified is IPSG.
Notes
LIM cards show MFC results for SNM, SCCP, EROUTE, INM and MTP3. SCCP cards show MFC results for SNM, INM and MTP3 when the mode=full and loc parameters are specified.
The status displayed is for the previous 5 minutes and the previous 24 hours.
The following MFC status codes are used: G to indicate service request GRANTED, D to indicate service request DENIED, and N to indicate NO OPERATIONAL SERVERS AVAILABLE.
This command can be canceled using the
F9 function key
or the
canc-cmd command. See
canc-cmd
for more information.
The mode=full parameter gives more information than the summary report.
A plus (+) symbol in the output indicates that the
flash GPL currently being run has not yet been activated on the card. See the
act/init-flash command for a list of
flash GPLs.
E1 alarms are displayed in the alarm status field. When the mode=full parameter is specified, separate fields display status information from the UAM for each E1 interface on the card. For each E1 interface, the display shows the highest priority E1 failure that exists on that E1 card. When no E1 errors exist, the clearing E1 UAM text is displayed. When an E1 interface is not assigned to the card, no output is generated for that E1 position.
T1 alarms are displayed in the alarm status field. When the mode=full parameter is specified, separate fields display status information from the UAM for each T1 interface on the card. For each T1 interface, the display shows the highest priority T1 failure that exists on that T1 card. When no T1 errors exist, the clearing T1 UAM text is displayed. When an T1 interface is not assigned to the card, no output is generated for that T1 position.
If the links=all parameter is specified, then the maximum number of supported SS7 links on the card is displayed as shown. If the links=unequip parameter is specified, then the number of links displayed is equal to the maximum supported links minus the provisioned links. If the links=equip parameter is specified, then only the provisioned links are displayed.
Multiple cards of the same card type but different
capacity can be installed into a slot configured with the
ent-card command. The number of links
supported cannot be determined until the card is physically installed into the
configured slot.
Table 4-50 Maximum Supported Links based on Card Type and GPL
| GPL with Card Type | Maximum Supported Links | |
| Card Hardware Verified | Card Hardware Unknown | |
| ATMHC on E5-ATM-B | 3 | 3 |
| SS7HC on E5-E1T1-B | 64 | 64 |
| IPLHC on E5-ENET-B | 16 | 16 |
| IPGHC on E5-ENET-B | 1 | 1 |
| IPSG on E5-ENET-B/SLIC | 32 | 32 |
| IPSG on SLIC | 128 | 128 |
| SIPHC on E5-SM8G-B/SLIC | 17 (16 TCP & 1 UDP) | 17 (16 TCP & 1 UDP) |
| ENUMHC on E5-SM8G-B/SLIC | 1 (UDP) | 1 (UDP) |
| DEIRHC on E5-SM8G-B/SLIC | 32 | 32 |
The CARD WARNING field in the command output indicates a specific condition that can hinder the normal functioning of a card. For E5-E1T1-B cards, the "Obsolete Framer" warning indicates that a port configured on the card may get stuck in a Loss of Frame (LOF) state. If an E5-E1T1-B card displaying this warning is reloaded, and one of the ports on the card is reporting LOF, then the OAM reboots the card up to 5 times to attempt to clear the LOF condition when the card changes state from IS-ANR to IS-NR.
GTT-enabled IPSG cards have the IPSG application running on SLIC hardware, which is capable of SCCP (GTT) processing. GTT-disabled IPSG cards also have IPSG application running on E5-ENET-B or SLIC hardware, but they do not have SCCP (GTT) processing capability. To sort one from the other, the data parameter is used. The data parameter cannot be used with any application other than IPSG/VSCCP.
Interface A/D will be used for ExAP connectivity running SIP/ENUM application and interface B/C used for signaling network on the SLIC card running the DEIR/SIP/ENUM application.
Fast Copy Cards
E5-ENET-B, or SLIC cards running the IPSG or E5-ENET-B cards running the IPGHC GPL are considered to be FC- capable. A card running the IPGHC GPL must be in the IS-NR State before the card can be considered FC- capable. This restriction does not apply to cards running the IPSG GPL. An FC- capable card is considered FC- enabled when Fast Copy monitoring is enabled for the respective GPL.
Output
The clock status fields are reported when the mode=full report is selected. The clock status report includes a CLOCK A, CLOCK B, and CLOCK I status. The High Speed clock status report (displayed for ATM, E1 and T1 cards) includes HS CLOCK A, HS CLOCK B, and HS CLOCK I. The valid values for each clock status are Idle, Active, and Fault. The meanings of these values are:
- Idle —Clock is available but is not being used by the card
- Active —Clock is available and is being used by the card
- Fault —Clock is unavailable
Idle and Active are shown when the CLK or HS CLK distribution to the card is
good. The Active value does not denote that the
card is actually using the clock source for link alignment. Use the rtrv-slk, rtrv-e1,
and rtrv-t1 commands to determine what clock
source each card is using for link alignment.
If the mode=full parameter is
specified for an FC-enabled card, and Fast Copy functionality has been provisioned
for the GPL (see the chg-eisopts command), then
Fast Copy status and FC Link status is shown. For an E5-ENET-B or SLIC card running
the IPGHC GPL, Fast Copy and Fast Copy link status is shown only when the card is in
IS-NR state.
Abbreviated output is indicated by 3 vertical dots as shown:
The E5-MCPM-B card is an MCPM card. The Type field displays MCPM.
rept-stat-card
rlghncxa03w 12-03-09 16:35:57 IST EAGLE 45.0.0
CARD VERSION TYPE GPL PST SST AST
1102 128-002-000 LIMATM ATMHC IS-NR Active -----
1103 125-020-000 DSM SCCPHC IS-NR Active -----
1105 125-020-000 DSM SCCPHC IS-NR Active -----
1106 130-001-000 TSM GLSHC IS-NR Active -----
1107 125-020-000 STC EROUTE IS-NR Active -----
1108 134-000-000 MCPM MCPHC IS-NR Active -----
1109 125-020-000 HIPR2 HIPR2 IS-NR Active -----
1110 125-020-000 HIPR2 HIPR2 IS-NR Active -----
1111 125-020-000 IPSM IPS IS-NR Active -----
1113 070-019-002 E5MCAP OAMHC IS-NR Standby -----
1114 ----------- E5TDM IS-NR Active -----
1115 070-019-002 E5MCAP OAMHC IS-NR Active -----
1116 ----------- E5TDM IS-NR Active -----
1117 ----------- MDAL IS-NR Active -----
1201 138-008-000 SLIC IPSG IS-NR Active -----
1206 134-060-000 DSM DEIRHC IS-NR Active -----
1209 125-020-000 HIPR2 HIPR2 IS-NR Active -----
1210 125-020-000 HIPR2 HIPR2 IS-NR Active -----
1112 138-008-000 SLIC IPSG IS-NR Active -----
1309 125-017-000 HIPR2 HIPR2 IS-NR Active -----
1310 125-017-000 HIPR2 HIPR2 IS-NR Active -----
1311 125-020-000 STC EROUTE IS-NR Active -----
2103 128-018-000 DCM IPLHC IS-NR Active -----
2109 128-022-000 HIPR2 HIPR2 IS-NR Active -----
2110 128-022-000 HIPR2 HIPR2 IS-NR Active -----
2111 128-018-000 STC ERTHC IS-NR Active -----
1213 053-000-058 E5ENET IPSG IS-NR Active -----
Command Completed.
This example shows the card status for the OAMHC of MASP A located in slot 1113, which is currently active.
This example also shows a Hardware Verification Code. The HW VERIFICATION CODE field is shown only in the mode=full report. "-----" is shown for cards with valid hardware. A numerical value is shown when invalid hardware is detected. All such cards will be auto-inhibited. The numerical values are listed in Table 4-51. The E5-MDAL and MUX cards do not display the field in mode=full reports on their locations.
rept-stat-card:loc=1113:mode=full
tekelecstp 02-01-08 04:34:09 EST EAGLE 46.0.0
1113 134-068-000 E5MCAP OAMHC IS-NR Active -----
ALARM STATUS = No Alarms
BLMCAP GPL version = 134-054-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Fault
CLOCK B = Active
CLOCK I = Idle
MBD BIP STATUS = Valid
MOTHER BOARD ID = E5-MCAP
DBD STATUS = Valid
DBD TYPE = 1G ENET
DBD MEMORY SIZE = 4096M
HW VERIFICATION CODE = ----
CURRENT TEMPERATURE = 32C ( 90F)
PEAK TEMPERATURE: = 32C ( 90F) [02-01-08 04:31]
TROUBLE TEXT VER. = Rev 134.10.2
APPLICATION SERVICING
TVG MFC TVG MFC
IPLNK STATUS
IPLNK IPADDR STATUS PST
A --------------- ---- ----
Command Completed.
This example shows all cards that have alarms inhibited in the system:
rlghncxa03w 04-02-04 12:57:21 EST EAGLE 31.6.0
CARD VERSION TYPE APPL PST SST AST
1211 023-001-000 LIMATM ATMANSI IS-NR Active ALMINH
Command Completed.
This example shows a full report for a specified HIPR2 card:
rept-stat-card:loc=1109:mode=full
tekelecstp 02-01-08 04:45:17 EST EAGLE 46.0.0
1109 134-046-000 HIPR2 HIPR2 IS-NR Active -----
ALARM STATUS = No Alarms.
TRIAL VERSION = HIPR2 134-069-000
FPGA VERSION = HIPR2 008-002-005-009
CURRENT TEMPERATURE = NA
PEAK TEMPERATURE: = NA
Command Completed.
This example shows output for an STC card used by the E5IS feature:
rept-stat-card:loc=1107
rlghncxa03w 10-01-09 16:35:57 IST EAGLE 42.0.0
1107 128-015-000 STC EROUTE IS-NR Active -----
BPDCM GPL version = 128-108-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
MOTHER BOARD ID = Invalid
DBD STATUS = Valid
DBD TYPE = Invalid
DBD MEMORY SIZE = 512M
EROUTE % OCCUP = 0%
NTP broadcast = VALID
Command Completed.
This example shows a full report for an STC card:
rept-stat-card:loc=1107:mode=full
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = Invalid
EROUTE % OCCUP = 0%
IPLNK STATUS
A --------------- DOWN OOS-MT
B 192.168.63.45 UP IS-NR
STC IP CONNECTION
PORT PST SST
A OOS-MT Unavail
B IS-NR Active
This example shows output for an MCPM card used by the Measurements Platform feature:
rept-stat-card:loc=1105
rlghncxa03w 11-05-04 15:10:19 EST EAGLE 44.0.0
1105 128-001-000 MCPM MCP IS-NR Idle -----
BPDCM GPL VERSION = 128-001-000
IMT BUS A = Conn
IMT BUS B = Conn
Command Completed.
This example shows output for an E5-SM4G card:
rept-stat-card:loc=6111
tklc1110501 10-12-09 17:26:29 EST EAGLE5 43.0.0
6111 128-015-000 DSM SCCPHC IS-NR Active -----
BLIXP GPL version = 133-044-000
IMT BUS A = Conn
IMT BUS B = Conn
CURRENT TEMPERATURE = 31C ( 88F)
PEAK TEMPERATURE: = 32C ( 90F) [07-04-12 15:55]
SCCP % OCCUP = 1%
Command Completed.
This example shows a full report for an E5-SM4G card. The MFC option is ON.
rept-stat-card:loc=6111:mode=full
rlghncxa03w 11-02-09 16:35:57 IST EAGLE 44.0.0
6111 134-000-000 DSM SCCPHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
MOTHER BOARD ID = SMXG A
DBD STATUS = Valid
DBD TYPE = 1G ENET
SCCP % OCCUP = 1%
TVG MFC TVG MFC
SNM REQ STATUS = 24 hr: ------ ---, 5 min: ------ ---
INM REQ STATUS = 24 hr: ------ ---, 5 min: ------ ---
MTP3 REQ STATUS = 24 hr: ---, 5 min: ---
IPLNK STATUS
A 10.220.9.9 UP IS-NR
B 10.220.9.8 UP IS-NR
DSM IP CONNECTION
PORT PST SST
A OOS-MT Unavail
B OOS-MT Unavail
Command Completed.
This example shows the output for all cards running the VSCCP application:
rept-stat-card:appl=vsccp
tklc1110501 07-04-12 17:28:02 EST EAGLE5 46.0.0
1107 128-015-000 DSM SCCPHC IS-NR Active -----
1317 ----------- DSM SCCPHC OOS-MT Isolated -----
2217 128-015-000 DSM SCCPHC IS-NR Active -----
2317 ----------- DSM SCCPHC OOS-MT Isolated -----
3103 ----------- DSM SCCPHC OOS-MT-DSBLD Manual -----
3201 128-015-000 DSM SCCPHC IS-NR Active -----
3203 128-015-000 DSM SCCPHC IS-NR Active -----
3205 128-015-000 DSM SCCPHC IS-NR Active -----
3207 128-015-000 DSM SCCPHC IS-NR Active -----
3211 128-015-000 DSM SCCPHC IS-NR Active -----
3213 128-015-000 DSM SCCPHC IS-NR Active -----
3215 128-015-000 DSM SCCPHC IS-NR Active -----
3217 128-015-000 DSM SCCPHC IS-NR Active -----
5317 128-015-000 DSM SCCPHC IS-NR Active -----
6101 128-015-000 DSM SCCPHC IS-NR Active -----
6103 128-015-000 DSM SCCPHC IS-NR Active -----
6105 128-015-000 DSM SCCPHC IS-NR Active -----
6107 128-015-000 DSM SCCPHC IS-NR Active -----
6113 128-015-000 DSM SCCPHC IS-NR Active -----
6115 128-015-000 DSM SCCPHC IS-NR Active -----
6117 128-015-000 DSM SCCPHC IS-NR Active -----
Command Completed.
This example shows a full report for a HIPR2 card:
rept-stat-card:loc=2109:mode=full
rlghncxa03w 09-06-04 15:10:19 EST EAGLE 5 41.1.0
TRIAL VERSION = HIPR2 023-099-008
FPGA VERSION = HIPR2 008-001-003-002
CURRENT TEMPERATURE = 73C (164F)
PEAK TEMPERATURE: = 73C (164F) [02-01-05 10:12]
Command Completed.
This example shows a full report for a card running the IPSG GPL. Fast Copy functionality has been provisioned for the IPSG GPL.
rept-stat-card:loc=1102:mode=full
stpc9070501 11-05-04 17:43:56 EDT EAGLE5 44.0.0
1102 009-054-000 E5ENET IPSG IS-NR Active -----
BLIXP GPL version = 009-054-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Idle
CLOCK B = Active
CLOCK I = Idle
MOTHER BOARD ID = EPM A
DBD STATUS = Valid
DBD TYPE = 1G ENET
CURRENT TEMPERATURE = 42C (108F)
PEAK TEMPERATURE: = 43C (110F) [11-05-04 13:55]
SIGNALING LINK STATUS
SLK PST LS CLLI E5IS
A IS-NR stpa113n stpa113n INACTIVE
B IS-NR sc2a115n sc2a115n INACTIVE
A1 IS-NR stpa113n stpa113n INACTIVE
B1 IS-NR sc2a115n sc2a115n INACTIVE
A4 IS-NR sp2a115n sp2a115n INACTIVE
B4 IS-NR sp3a116n sp3a116n INACTIVE
A5 IS-NR sp2a115n sp2a115n INACTIVE
B5 IS-NR sp3a116n sp3a116n INACTIVE
IPLNK STATUS
A 10.251.100.166 UP IS-NR
B 10.251.102.27 UP IS-NR
FCLNK STATUS
A1 172.21.48.242 UP IS-NR
B1 172.22.48.242 UP IS-NR
FASTCOPY STATUS
ONLINE
ASSOCIATION STATUS
ANAME PST SST
ipn1102am2pa IS-NR ESTABLISHED
ipn1102a1m2pa IS-NR ESTABLISHED
gwn1102bm3ua IS-NR ESTABLISHED
gwn1102b1m3ua IS-NR ESTABLISHED
ipns1102a4m2pa IS-NR ESTABLISHED
ipns1102a5m2pa IS-NR ESTABLISHED
gwns1102b4m3ua IS-NR ESTABLISHED
gwns1102b5m3ua IS-NR ESTABLISHED
TVG MFC TVG MFC
SCCP REQ STATUS = 24 hr: ------ ---, 5 min: ------ ---
EROUTE REQ STATUS = 24 hr: ------ G--, 5 min: ------ G--
INM REQ STATUS = 24 hr: ------ G--, 5 min: ------ ---
MTP3 REQ STATUS = 24 hr: G--, 5 min: G--
Command Completed.
This example shows a full report for a card running the IPSG application and receiving pure MTP routed traffic. The MFC option and E5IS feature are ON.
rept-stat-card:loc=1105:mode=full
e1080403 11-03-10 14:46:53 EST EAGLE 44.0.0
1105 134-000-000 E5ENETB IPSG IS-NR Active -----
BLMCAP GPL version = 056-042-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = 1G ENET
CURRENT TEMPERATURE = 43C (110F)
PEAK TEMPERATURE: = 45C (113F) [11-03-08 10:18]
B2 IS-NR ipsg1105b2 ----------- INACTIVE
IPLNK STATUS
A 10.254.101.121 UP IS-NR
B 10.254.100.4 UP IS-NR
ASSOCIATION STATUS
ANAME PST SST
m3ua1105b2 IS-NR ESTABLISHED
TVG MFC TVG MFC
SNM REQ STATUS = 24 hr: GDNHSI ---, 5 min: GD---- ---
EROUTE REQ STATUS = 24 hr: ------ GDN, 5 min: ------ G--
INM REQ STATUS = 24 hr: G----- ---, 5 min: G----- ---
Command Completed.
This example shows a full report for an E5-TSM card:
rept-stat-card:loc=1106:mode=full
tekelecstp 10-12-09 19:15:28 EST EAGLE 43.0.0
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
CURRENT TEMPERATURE = 44C (112F)
PEAK TEMPERATURE: = 44C (112F) [10-10-05 19:10]
Command Completed.
This example shows the output when E5-MCAP, E5-TDM, and E5-MDAL cards are used:
rept-stat-card
e5oam 14-12-01 15:38:32 EST EAGLE 46.2.0
1109 030-009-000 HIPR2 HIPR2 IS-NR Active -----
1110 030-009-000 HIPR2 HIPR2 IS-NR Active -----
1113 030-010-008 E5MCAP OAMHC IS-NR Standby -----
1115 030-010-008 E5MCAP OAMHC IS-NR Active -----
1117 ----------- E5MDAL OOS-MT Isolated -----
Command Completed.
This example shows the output for a HIPR2 card, which does not support thermal monitoring:
Command Completed.
This example shows the output for a HIPR2 card when the card is not in-service:
1209 ----------- HIPR2 HIPR2 OOS-MT Isolated -----
FPGA VERSION = HIPR2 ---------------
CURRENT TEMPERATURE = ----
PEAK TEMPERATURE: = ----
Command Completed.
This example shows the output for an E5-OAM card when the Integrated Measurements feature is turned on:
tekelecstp 02-01-08 04:50:35 EST EAGLE 46.0.0
IMT BUS A = Conn
IMT BUS B = Conn
Command Completed.
This example shows a full report for the E5-MASP of MASP A located in slot 1113, which is currently active:
tekelecstp 10-01-07 09:37:39 EST EAGLE 42.0.0
1113 030-002-022 E5MCAP OAMHC IS-NR Active -----
BLMCAP GPL version = 030-004-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = 1G ENET
DBD MEMORY SIZE = 2048M
CURRENT TEMPERATURE = 0C ( 32F)
PEAK TEMPERATURE: = 0C ( 32F) [00-00-00 00:00]
TROUBLE TEXT VER. = Rev 133.1.2
TVG STATUS
IPLNK STATUS
A 192.168.1.1 UP IS-NR
This example shows a full report for an E5-MASP card when an IP mismatch condition exists:
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = 1G ENET
TVG STATUS
IPLNK STATUS
IP Mismatch exists, reset required
This example shows a full report for an E5-ENET-B used as an STC card:
rlghncxa03w 11-03-09 16:35:57 EST EAGLE 44.0.0
1102 134-000-000 STC ERTHC IS-NR Active -----
BLMCAP GPL version = 032-000-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Fault
CLOCK B = Fault
CLOCK I = Idle
MOTHER BOARD ID = EPM B
DBD STATUS = Valid
DBD TYPE = 1G ENET
CURRENT TEMPERATURE = 62C (144F)
PEAK TEMPERATURE: = 63C (146F) [02-04-18 19:53]
EROUTE % OCCUP = 0%
SOCKET = INACTIVE
IPLNK STATUS
A 192.168.210.166 UP IS-NR
B --------------- DOWN OOS-MT
STC IP CONNECTION
PORT PST SST
A IS-NR Active
B OOS-MT Unavail
Command Completed.
This example shows a full report for an E5-ATM-B card.
rlghncxa03w 11-03-10 14:00:53 EST EAGLE5 44.0.0
1107 134-000-000 LIMATM ATMHC IS-NR Active -----
ALARM STATUS = * 0022 Clock B for card failed, Clock A normal
BLMCAP GPL version = 023-000-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Fault
CLOCK I = Idle
HS CLOCK A = Active
HS CLOCK B = Fault
HS CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = ATM
CURRENT TEMPERATURE = 54C (130F)
PEAK TEMPERATURE: = 55C (131F) [20-12-22 10:55]
SLK PST LS CLLI
A IS-NR lsatm11 -----------
B IS-NR lsatm11 -----------
A1 IS-NR lsatm12 -----------
MFC MFC
SNM REQ STATUS = 24 hr: ---, 5 min: ---
SCCP REQ STATUS = 24 hr: ---, 5 min: ---
INM REQ STATUS = 24 hr: G--, 5 min: G--
Command Completed.
This example shows the output for an E5-ENET-B card used as an IPSM card:
rept-stat-card:loc=1103:mode=full
rlghncxa03w 11-03-09 16:35:57 IST EAGLE 44.0.0
1103 134-000-000 IPSM IPSHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = 1G ENET
PEAK TEMPERATURE: = 63C (146F) [02-09-14 14:49]
SFLOG = NO
Command Completed.
This example shows the output for an E5-MCPM-B card:
rept-stat-card:loc=1108
tekelecstp 11-04-25 19:44:35 EST EAGLE5 44.0.0
BLMCAP GPL version = 134-000-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = 1G ENET
PEAK TEMPERATURE: = 42C (108F) [11-04-24 04:32]
IPLNK STATUS
A 10.250.37.176 UP IS-NR
MCP IP CONNECTION
PORT PST SST
A IS-NR Active
Command Completed.
This example shows a full report for an E5-MCPM-B card:
rept-stat-card:loc=1108:mode=full
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = 1G ENET
IPLNK STATUS
MCP IP CONNECTION
PORT PST SST
A IS-NR Active
Command Completed.
This example shows the output for an E5-ENET-B card used as an IPSG card:
rept-stat-card:loc=1111:mode=full
stpc9070501 11-05-23 15:30:39 EDT EAGLE5 44.0.0
1111 009-003-000 E5ENETB IPSG IS-NR Active -----
BLMCAP GPL version = 009-003-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Idle
CLOCK B = Active
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = 1G ENET
CURRENT TEMPERATURE = 46C (115F)
PEAK TEMPERATURE: = 46C (115F) [11-05-23 15:09]
A OOS-MT ls1111n00 tklcc1111n0 INACTIVE
A4 OOS-MT lr1111n08 tkc1111n8 INACTIVE
IPLNK STATUS
A 10.251.105.68 UP IS-NR
B --------------- ---- ----
ASSOCIATION STATUS
ANAME PST SST
egwn1111am3ua OOS-MT CONNECTING
egwns1111a4m3ua OOS-MT CONNECTING
TVG MFC TVG MFC
Command Completed.
This example shows a full report when the EPAP Data Split feature is enabled:
epap240m 12-01-29 11:53:07 CST EAGLE 45.0.0
1201 074-012-005 LIME1 SS7HC IS-NR Active -----
BPMPL GPL version = 134-015-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Idle
CLOCK B = Active
CLOCK I = Idle
MOTHER BOARD ID = MPL
DBD STATUS = Valid
DBD TYPE = None
DBD MEMORY SIZE = 0M
SLK PST LS CLLI
A OOS-MT-DSBLD lsa1 -----------
TVG MFC TVG MFC
SCPDN REQ STATUS = 24 hr: ---, 5 min: ---
SCPIMSI REQ STATUS = 24 hr: ---, 5 min: ---
Command Completed.
This example shows a full report when the Dual ExAP Config feature is enabled:
1201 074-012-005 LIMDS0 SS7ML IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Idle
CLOCK B = Active
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
SLK PST LS CLLI
TVG MFC TVG MFC
SCPEPAP REQ STATUS = 24 hr: ---, 5 min: ---
SCPELAP REQ STSTUS = 24 hr: ---, 5 min: ---
Command Completed.
This example shows a full report when both EPAP Data Split feature and Dual ExAP Config features are enabled:
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Idle
CLOCK B = Active
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
SLK PST LS CLLI
TVG MFC TVG MFC
SCPDN REQ STATUS = 25 hr: ---, 5 min: ---
SCPIMSI REQ STATUS = 25 hr: ---, 5 min: ---
SEPELAP REQ STATUS = 25 hr: ---, 5 min: ---
Command Completed.
This example shows output for an E5-SM8G-B card running the SIP application:
tekelecstp 12-06-29 15:03:34 EST EAGLE 45.0.0
1205 134-045-000 DSM SIPHC IS-NR Active -----
BLIXP GPL version = 134-045-000
IMT BUS A = Conn
IMT BUS B = Conn
Command Completed.
This example shows output for an E5-SM8G-B card running the SIP application with mode=full:
rept-stat-card:loc=1101:mode=full
Command entered at terminal #18.
Command Accepted - Processing
1101 029-042-007 DSM SIPHC IS-NR Active -----
BLIXP GPL version = 059-042-000
IMT BUS A = Conn
IMT BUS B = Disc
CLOCK A = Active
CLOCK B = Fault
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
PEAK TEMPERATURE: = 46C (115F) [02-13-06 17:11]
IPLNK STATUS
A 192.168.120.132 UP IS-NR
DSM IP CONNECTION
PORT PST SST
A IS-NR Active
SIP CONNECTION STATUS
CNAME PROT PST OPEN
conn1 TCP IS-NR YES
conn2 UDP IS-NR YES
Command Completed.
This example shows output for an E5-SM8G-B card running the ENUM application:
tekelecstp 14-05-26 15:03:34 EST EAGLE 46.1.0
1205 135-016-000 DSM ENUMHC IS-NR Active -----
BLIXP GPL version = 135-016-000
IMT BUS A = Conn
IMT BUS B = Conn
Command Completed.
This example shows the output when E5-APP-B cards exist in the system:
rept-stat-card
tekelecstp 12-14-13 11:48:18 EST 46.1.0-0.0.0
rept-stat-card
Command entered at terminal #4.
1105 ----------- E5APPB EPAP RSRVD Avail -----
1107 ----------- E5APPB ELAP RSRVD Avail -----
1109 000-000-000 HIPR2 HIPR2 IS-NR Active -----
1110 000-000-000 HIPR2 HIPR2 IS-NR Active -----
1113 255-255-255 GPSM EOAM IS-NR Active -----
1115 255-255-255 GPSM EOAM IS-NR Standby -----
1116 ----------- TDM IS-NR Active -----
1117 ----------- E5MDAL IS-NR Active -----
6202 ----------- TELCO SWITCH RSRVD Avail -----
6203 ----------- TELCO SWITCH RSRVD Avail -----
Command Completed.
This example shows the report for a card location equipped with an E5-APP-B card:
tekelecstp 12-07-13 11:49:35 EST 45.0.0-64.37.0
Command Completed.
These examples show the report for E5-APP-B application cards:
tekelecstp 12-07-13 11:52:44 EST 45.0.0-64.37.0
Command Completed.
;rept-stat-card:appl=elap
tekelecstp 12-07-13 11:54:41 EST 45.0.0-64.37.0
Command Completed.
1103 ----------- E5APPB LSMS RSRVD Avail -----
Command Completed.
1101 ----------- E5APPB NAS RSRVD Avail -----
Command Completed.
This example shows the report for a card location equipped with a Telco Switch:
rept-stat-card:loc=6202
tekelecstp 12-09-06 11:43:37 EST 45.0.0
6202 ------- TELCO SWITCH RSRVD Avail -----
Command Completed.
This example shows the report for Telco Switches with parameter appl=switch:
tekelecstp 12-09-06 11:44:19 EST 45.0.0
6201 ------- TELCO SWITCH RSRVD Avail ----
Command Completed.
This example shows output for a SLIC card running the DEIRHC GPL: rept-stat-card:loc=1101
tklc1161001 23-02-01 15:31:30 EST EAGLE 47.1.0.0.0-79.16.0
Command entered at terminal #2
1101 001-016-000 SLIC DEIR64 IS-NR Active -----
BLSLC64 GPL version = 007-014-008
IMT BUS A = Conn
IMT BUS B = Conn
CURRENT TEMPERATURE = 49C (121F)
PEAK TEMPERATURE: = 51C (124F) [23-02-01 11:11]
Command Completed.
This example shows output for the DEIR application with mode=full:
tklc1161001 23-02-01 15:31:38 EST EAGLE 47.1.0.0.0-79.16.0
Command entered at terminal #2.
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
MOTHER BOARD ID = SLIC
DBD STATUS = Valid
DBD TYPE = None
DBD MEMORY SIZE = 16384M
HW VERIFICATION CODE= ----
FPGA VERSION = 3c8
BIOS VERSION = 006
PSOC VERSION = 1.0
Bootloader VERSION = 2
IPLNK STATUS
B 10.254.102.131 UP IS-NR
C --------------- ---- ----
D --------------- ---- ----
DEIR CONNECTION STATUS
DCNAME STATUS ANAME STATUS
dconn1 DOWN assoc1 OOS-MT
dcon2 DOWN assoc2 OOS-MT
dcon3 DOWN assoc3 OOS-MT
dcon4 DOWN assoc4 OOS-MT
MFC MFC
DEIRSCCP REQ STATUS = 24 hr: ---, 5 min: ---
Command Completed.
This example shows the full report when an IPS card is provisioned as an SFLOG card:
tekelecstp 15-05-27 15:43:58 EST EAGLE 46.3.0
1107 131-010-000 IPSM IPSHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Fault
CLOCK B = Active
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = 1G ENET
CURRENT TEMPERATURE = 45C (113F)
PEAK TEMPERATURE: = 45C (113F) [15-05-27 15:43]
SFLOG = YES
IPLNK STATUS
Command Completed.
This example shows the full report for an SCCP card with the SFLOG MFC service:
tekelecstp 15-07-07 07:02:54 EST EAGLE5 46.3.0
1101 017-001-013 DSM SCCPHC IS-NR Active -----
BLIXP GPL version = 021-001-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
PEAK TEMPERATURE: = 46C (115F) [15-07-07 07:02]
SCCP % OCCUP = 1%
TVG MFC TVG MFC
MTP3 REQ STATUS = 24 hr: G--, 5 min: ---
SFLOG REQ STATUS = 24 hr: ---, 5 min: ---
IPLNK STATUS
DSM IP CONNECTION
PORT PST SST
A OOS-MA Ueq
B OOS-MA Ueq
Command Completed.
This example shows output for a SLIC card running the IPSG GPL with mode=full:
rept-stat-card:loc=1203:mode=full
stpa1090701 16-04-1624 11:09:37 EST EAGLE5 46.3.0.0.0-68.18.0
stpa1090701 16-04-16 11:09:37 EST EAGLE5 46.3.0.0.0-68.18.0
1203 138-018-000 SLIC IPSG IS-NR Active -----
BLSLC32 GPL version = 138-018-000
Idle
Valid
DBD STATUS = Valid
DBD TYPE = None
39C (103F)
PEAK TEMPERATURE: = 43C (110F) [16-04-12 06:24]
SLK PST LS CLLI
A IS-NR sd1c114a -----------
A1 IS-NR sd2c114a -----------
A2 IS-NR sd3c114a -----------
A3 IS-NR sd4c114a -----------
A4 IS-NR sd5c114a -----------
IPLNK 103.50 UP IS-NR
eipa1203am2pa IS-NR ESTABLISHED
eipi1203a1m2pa IS-NR ESTABLISHED
eipis1203a2m2pa IS-NR ESTABLISHED
eipn1203a3m2pa IS-NR ESTABLISHED
eipc1203a4m2pa IS-NR ESTABLISHED
MFC MFC
SNM REQ STATUS = 24 hr: G--, 5 min: ---
INM REQ STATUS = 24 hr: G--, 5 min: ---
SCPELAP REQ STATUS = 24 hr: ---, 5 min: ---
rept-stat-card
tekelecstp 16-05-25 12:38:37 EST EAGLE 46.4.0.0.0-69.3.1
rept-stat-card
Command entered at terminal #3.
tekelecstp 16-05-25 12:38:38 EST EAGLE 46.4.0.0.0-69.3.1
1101 ----------- SLIC GLSHC OOS-MT-DSBLD MEA ----- 1105 139-003-000 TSM GLSHC IS-NR Active -----
1106 ----------- SLIC GLSHC OOS-MT-DSBLD MEA -----
1109 139-003-000 HIPR2 HIPR2 IS-NR Active -----
1110 139-003-000 HIPR2 HIPR2 IS-NR Active -----
1112 139-003-000 SLIC IPSG IS-NR Active -----
1113 030-003-001 E5MCAP OAMHC IS-NR Active -----
1115 030-003-001 E5MCAP OAMHC IS-NR Standby -----
Command Completed.
This example shows output for a SLIC card running the ENUMHC GPL with mode=full:
tekelecstp 16-06-22 03:19:34 EST EAGLE 46.4.0.0.0-69.3.1
1103 139-002-000 SLIC ENUMHC IS-NR Active -----
BLSLC32 GPL version = 139-002-000
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
PEAK TEMPERATURE: = 73C (164F) [16-06-22 00:30]
IPLNK STATUS
B 10.248.13.81 UP IS-NR
DSM IP CONNECTION
PORT PST SST
A IS-NR Active
ENUM CONNECTION STATUS
CNAME PROT PST OPEN
conn1 UDP IS-NR YES
Command Completed.
This example shows output for a SLIC card running the SIPHC GPL with mode=full:
tekelecstp 16-06-21 02:40:34 EST EAGLE 46.4.0.0.0-69.3.1
rept-stat-card:loc=1101:mode=fullentered at terminal #18.
1101 139-002-000 SLIC SIPHC IS-NR Active -----
SLIC
None
PEAK TEMPERATURE: = 73C (164F) [16-06-21 02:40]
IPLNK STATUS
A 192.168.120.131 UP IS-NR
B 10.248.13.76 UP IS-NR
DSM IP CONNECTION
A IS-NR Active
This example shows output for a SLIC card running the ERTHC GPL with mode=full:
rept-stat-card:mode=full:loc=1107
tekelecstp 16-07-14 05:52:22 EST EAGLE 46.4.0.0.0-69.3.1
1107 139-002-000 SLIC ERTHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
PEAK TEMPERATURE: = 73C (164F) [16-07-14 05:50]
EROUTE % OCCUP = 0%
IPLNK STATUS
STC IP CONNECTION
PORT PST SST
A OOS-MT Unavail
B OOS-MT Unavail
Command Completed.
Command Executed
This example shows output for a SLIC card running the MCPHC GPL with mode=full:
tekelecstp 16-07-14 06:09:15 EST EAGLE 46.4.0.0.0-69.3.1
1107 139-002-000 SLIC MCPHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
PEAK TEMPERATURE: = 74C (166F) [16-07-14 06:06]
IPLNK STATUS
A 10.248.13.93 ACTIVE IS-NR MCP IP CONNECTION
PORT PST SST
A OOS-MT Unavail
Command Completed.
Command Executed
This example shows output for a SLIC card running the SCCPHC GPL with mode=full:
tekelecstp 16-07-14 06:37:51 EST EAGLE 46.4.0.0.0-69.3.1
1107 139-002-000 SLIC SCCPHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CLOCK A = Active
CLOCK B = Idle
CLOCK I = Idle
DBD STATUS = Valid
DBD TYPE = None
CURRENT TEMPERATURE = 72C (162F)
PEAK TEMPERATURE: = 73C (164F) [16-07-14 06:24]
SCCP % OCCUP = 0%
MFC MFC
INM REQ STATUS = 24 hr: ---, 5 min: ---
IPLNK STATUS
DSM IP CONNECTION
PORT PST SST
A OOS-MA Ueq
B OOS-MA Ueq
Command Completed.
Command Executed
Legend
- CARD—Location of the card
- VERSION—Version number of
the application loaded on the card. Dashes (- - - - -) in the version column
indicate one of the following conditions about the card:
- The card is configured but is not physically present in the system.
- The card does not run a GPL, such as TDM or MDAL cards.
- The card is IS-ANR or is in the process of being loaded.
- TYPE—Card type entered in the database.
- APPL—Application loaded on the card
- PST—Primary state of the card. See Possible Values for PST/SST/AST .
- SST—Secondary state of the card. See Possible Values for PST/SST/AST .
- AST—Associated state of the card. See Possible Values for PST/SST/AST .
Message Flow Control status is displayed in these fields: SNM REQ STATUS (SNM messages), SCCP REQ STATUS (SCCP messages), EROUTE REQ STATUS (EROUTE messages), INM REQ STATUS (INM messages), MTP3 REQ STATUS (MTP3 messages), and SFLOG REQ STATUS.
For card type STC (EROUTE application), the MFC status is not displayed.
Message Flow Control status output is displayed as a series of these letters:
- G—MFC found a service with available capacity. Indicates normal system behavior.
- D—Servers were present in the system, but no server had available capacity. Indicates an overload, but MFC is working correctly.
- N—No operational server cards were available in the system for use by this card over the corresponding interval.
The HW VERIFICATION CODE field is shown only in the mode=full report. ----- is shown in the HW VERIFICATION CODE field for cards with valid hardware detected. One of the following numerical values is shown when invalid hardware is detected, and all such cards will be auto-inhibited.
* It is possible that the card will continually boot in these cases, before the alarm is ever displayed.
Table 4-51 Auto-Inhibit Hardware Verification Codes
| HW Verification Code | Card or Application Code | Description | Associated UAM Code |
058 |
SS7IPGW, IPGWI, IPLIMI |
E5-ENET-B does not support > 16 associations (IPLIMx). E5-ENET-B does not support > 50 associations (IPGWx). |
422 |
059 |
VSCCP |
MPS database has been detected to exceed capacity of Service Module extended memory (only for GPORT, GFLEX, INP, EIR features). UAMs 281, 283, and 285 are used for LNP and LNP ELAP Configuration features. |
422 |
090 |
Various |
Flash image on the card is incompatible with the current release of the EAGLE |
570 |
099 |
E5-TSM |
E5-TSM card equipped has one or more daughterboard. |
99 |
102* |
SS7IPGW, IPGWI |
Non-DCM detected in slot. |
99 |
103 |
E5-ENET-B does not support >16 associations (IPLIMx). E5-ENET-B does not support >50 associations (IPGWx). |
276 |
103 |
IPSG |
E5-ENET-B does not support >32 associations (IPSG). |
276 |
104 |
SS7IPGW, IPGWI, |
E5-ENET-B does not support >0 sockets (IPLIMx). E5-ENET-B does not support >0 sockets (IPGWx). |
276 |
105 |
E5-ENET-B does not support > 0 (sockets + associations) (IPLIMx). E5-ENET-B does not support > 50 (sockets + associations) (IPGWx). |
276 |
106 |
E5-ENET-B does not support >3200Kb SCTP buffers (IPLIMx). E5-ENET-B does not support >3200Kb SCTP buffers (IPGWx). |
276 |
132 |
IPLIMI |
The actual card in the slot must be a high capacity MIM or LIME1 if card is provisioned as a LIME1 card. |
99 |
136 |
E5-ATM-B |
E5-ATM-B is provisioned |
297 |
140 |
MCPHC |
MCP card not running with D2G memory |
422 |
141 |
IPS |
E5-IPSM card not running with D2G memory. |
422 |
142 |
MCP |
E5-MCPM-B card not running with D4G memory. |
422 |
150 |
various |
Card is obsolete. |
47 |
165 |
VSCCP |
Hardware configuration does not support configured feature set. |
99 |
170 |
EROUTE |
Non-E5-ENET-B card detected in slot provisioned for eroute with card type STC. |
99 |
172 |
IPSG |
Non-SLIC card detected in slot provisioned for IPSG and card type is SLIC with data=gtt. |
99 |
174 |
IPSG |
SLIC hardware detected having 32-bit flash GPL (BLSLC32) in a slot provisioned for IPSG and card type is SLIC with data=gtt. |
99 |
179 |
E5-ATM-B, E5-ENET-B, E5-E1T1-B |
EPM-B based card detected and MFC is OFF. |
99 |
180 |
SCCP, SS7ANSI |
SCCP card equipped with DCM with MOBR on. |
441 |
DEIR, ENUM, SIP |
If ports C and D are configured, the card location must be populated with SLIC cards only. |
