rept-stat-mux
Use this command to list all the MUX cards and the location and status of the cards.
Parameters
This command has no parameters.
Example
rept-stat-mux
Dependencies
None
Notes
None
Output
rept-stat-mux
tekelecstp 10-02-21 11:19:03 EST EAGLE 42.0.0
CARD TYPE PST SST AST BITRATE BITRATE BERT
(OPER) (ACT) STATUS
1109 HIPR2 IS-NR Active ----- HIGH LOW PASS
1110 HIPR2 IS-NR Active ----- HIGH LOW UNKNOWN
1209 HIPR2 IS-NR Active ----- HIGH LOW FAIL
1210 HIPR2 IS-NR Active ----- HIGH LOW PASS
Command Completed.
Legend
- CARD—MUX card location
- TYPE—Type of card
- PST—Primary state of the card. Possible values are described in Possible Values for PST/SST/AST in Appendix A.
- SST—Secondary state of the card. Possible values are described in Possible Values for PST/SST/AST in Appendix A.
- AST—Associated state of the card. Possible values are described in Possible Values for PST/SST/AST in Appendix A.
- BITRATE(OPER)—Maximum operational bit rate that the Fibre-Channel ring is capable of. If the operational bit rate is HIGH, the Fibre-Channel ring can be switched between the HIGH rate and the LOW rate.
- BITRATE(ACT)—Bit rate currently used by the Fibre-Channel ring. This rate is determined by various parameters such as the operational bit rate of the other bus, availability of a High Rate Feature Access Key, etc.
- BERT STATUS—BERT (Bit Error Rate Test) status of the MUX card. BERT is a diagnostic test that is initiated by the MUX cards on the IMT Bus during Bus alignment. Possible values are:
- PASS—BERT passed for the MUX card
- FAIL—BERT failed for the MUX card
- UNKNOWN— This value should not be seen. If it is observed, please contact My Oracle Support (MOS).
Related Topics
