3 GPL Management Procedures
Chapter 3, GPL Management Procedures, describes the procedures used for managing the system data (GPLs) on the EAGLE.
Introduction
A GPL is the software that is loaded onto a card that allows the various features in the EAGLE to work. The EAGLE currently uses the following GPLs:
  • ATMHC– The application GPL used for high-speed ANSI and E1 ATM signaling links that are assigned to E5-ATM-B cards.
  • BLDC32–A flash GPL containing a tar image with all code required on E5-MCAP cards to support VxWorks6.9 32-bit application, as in OAMHC69, E5-ENET-B for running IPSHC69, and E5-MCPM-B for running MCPHC69.
  • BLDC64–A flash GPL containing a tar image of 64-bit code required on E5-SM8GB cards for SCCP64, ENUM64, SIP64 and DEIR64 applications.
  • BLMCAP–A flash GPL containing a tar image of 32-bit code for the following cards: E5-MCAP, E5-E1T1-B, E5-ENET-B, E5-ATM-B, E5-MCPMB, and SM8GB.
  • BLSLC32– A flash GPL containing a tar image of 32-bit code required on SLIC cards for 32-bit applications.
  • BLSLC64–A flash GPL containing a tar image of 64-bit code required on SLIC cards for 64-bit applications, as in SCCP64, ENUM64, SIP64, and DEIR64.
  • BLSL932–A flash GPL containing a tar image with all code required on SLIC card for 32-bit application on VxWorks6.9, as in IPSHC69 and MCPHC69.
  • DEIR64–The 64-bit application GPL used on the E5-SM8G-B and SLIC cards to support the S13/S13' EIR feature.
  • ENUM64–The 64-bit application GPL used on the E5-SM8G-B and SLIC cards for the ENUM Mobile Number Portability and Tier One Address Resolution feature.
  • ERTHC–The application GPL used on E5-ENET-B cards for the EAGLE 5 Integrated Monitoring Support feature.
  • HIPR2 –The communication GPL used on the High-Speed IMT Packet Router (HIPR2) card.
  • IPSG –The application GPL used for the IP Signaling Gateway M2PA and M3UA signaling links.
  • IPSG32–The 32-bit application GPL used on SLIC cards that combines GTT and IPSG capabilities.
  • IPSHC –The application GPL used on E5-ENET-B or SLIC cards for the IP User Interface and FTP Retrieve and Replace features.
  • IPSHC69–Used by E5-ENET-B and SLIC cards to support the IPS application when running on VxWorks69.
  • MCPHC– The application GPL used on the E5-MCPM-B (Measurement Collection & Polling Module) and SLIC cards for the Measurements Platform feature.
  • MCPHC69– Used by E5-MCPM-B and SLIC cards for the Measurements Platform feature when running on VxWorks69.
  • OAMHC–The application GPL used by the E5-MCAP card for enhanced OAM functions.
  • OAMHC69–Used by E5-MCAP cards for enhanced OAM functions, when running on VxWorks 69
  • SCCP64–The 64-bit application GPL used on E5-SM8G-B and SLIC cards to support EPAP-based features and the LNP ELAP Configuration feature. If no EPAP-based or LNP ELAP Configuration feature is turned on and an E5-SM8G-B card is present, then the GPL processes normal global title translation traffic.
  • SFAPP–Used by SLIC cards to support Stateful Firewall Application.
  • SIP64–The 64-bit application GPL used on the E5-SM8G-B and SLIC cards to support a SIP stack of TCP.
  • SS7HC– The application GPL used by E5-E1T1-B and SLIC cards to support E1 and T1 signaling links.
Managing GPLs
Managing these GPLs consists of loading them onto the EAGLE from a removable media, downloading these GPLs to the appropriate cards in the EAGLE, then allowing the cards to run these GPLs. The GPLs can be in one of two states, trial and approved.
Refer to the Maintenance and Administration Subsystem section for more information about the control cards.
The approved GPL is the GPL that has been approved for use and the EAGLE should be running, unless otherwise advised by Oracle technical support. The approved GPL version number matches the version number of the GPL contained in the system release ID table.
A trial GPL is usually a duplicate of the approved GPL; it can also be a GPL that has not been approved for use and does not match with the version number in the system release ID table. The trial GPL is a GPL that the EAGLE should normally not be running.
The system release ID table contains the version numbers of the approved GPLs that the EAGLE should be running. The system release ID table is contained on the E5-TDMs (Terminal Disk Modules) and on the removable media containing the GPLs that are being loaded onto the EAGLE. The GPLs are loaded onto the EAGLE from a removable media. To get the GPLs from the removable media onto the EAGLE in the approved state, two commands are used, chg-gpl and act-gpl.
CHG-GPL Command
The chg-gpl command copies a GPL from the removable media to the E5-TDMs. The new GPL becomes the trial version on each of the E5-TDMs. This command also copies the system release ID table from the removable media to the E5-TDMs. The chg-gpl command uses these parameters.
gpl – the GPL being loaded onto the EAGLE
ver – the version number of the GPL
audit – Specifies whether the active MASP system release version is to be audited every 90 seconds.
src – Specifies the source drive containing the GPL that is being copied. This parameter has two values.
  • remove – the removable media flash drive on the E5-MCAP card.
  • usb – This parameter is to be used by Oracle personnel only and cannot be used with the chg-gpl command.
If you are loading a GPL onto the EAGLE, the gpl and ver parameters must be specified with the chg-gpl command and a removable media containing the GPL being loaded must be in the removable media drive on the E5-MCAP card of the active MASP.
The audit parameter is required only when turning the GPL auditing on or off.
ACT-GPL Command
The act-gpl command changes the state of the trial GPL from “trial” to “approved.” This is also referred to as activating the GPL. The state of the previously approved GPL is changed from “approved” to “trial.”
The version of the GPL shown in the RELEASE column of the rtrv-gpl output (the GPL version in the system release ID table) is updated to the new approved version when this command is performed.
The act-gpl command uses these parameters:
Displaying GPL Information
Two commands can be used to display the GPL information in the database, rept-stat-gpl and rtrv-gpl. The rept-stat-gpl command shows the versions of the GPLs that are running on the cards in the EAGLE. The rtrv-gpl command shows the versions of the GPLs contained on the fixed disks.
REPT-STAT-GPL Command
The rept-stat-gpl command output contains these five columns and displays this information.
  • GPL – The GPLs contained on the TDMs (Terminal Disk Modules). The TDMs contain the fixed disks.
  • CARD – The cards that are running the GPLs
  • RUNNING – The version number of the GPLs the cards are running
  • APPROVED – The version numbers of the approved GPLs
  • TRIAL – The version numbers of the trial GPLs
The following is an example of the rept-stat-gpl command output.
rept-stat-gpl:loc=1103
    tklc9010801 16-09-07 00:21:39 EST  EAGLE 46.4.0.0.0-69.10.0
    GPL Auditing  ON
    GPL        CARD      RUNNING            APPROVED      TRIAL
    SS7HC      1103      139-010-000        139-010-000   139-010-000
           BLMCAP         139-010-000        139-010-000   085-009-009
    Command Completed.
The example rept-stat-gpl output shows that the card in slot 1103 is running the SS7HC GPL, version number 139-010-000, which is also the approved version of the SS7HC GPL. The trial version number of the SS7HC GPL is also 139-010-000.
You can display all the GPLs used by all the cards in the EAGLE except the flash (or communication) GPLs, a specific GPL, or all application and flash GPLs used by all the cards in the EAGLE. The flash GPLs are the BLMCAP, BLDC32, BLDC64, BLSLC32, BLSLC64, BLSLC932, and HIPR2 GPLs. The application GPLs are the other GPLs in the EAGLE.
If you specify the rept-stat-gpl command with no parameters, all the GPLs on all the cards in the EAGLE are displayed except for the communication GPLs, as shown in this example.
tklc9010801 16-09-07 00:22:18 EST  EAGLE 46.4.0.0.0-69.10.0
    GPL Auditing  ON
    OAMHC      1113      139-010-000        139-010-000   139-010-000
    OAMHC      1115      139-010-000        139-010-000   139-010-000
    SS7HC      1104      139-010-000        139-010-000   139-010-000
    SS7HC      1107      139-010-000        139-010-000   139-010-000
    SS7HC      1108      139-010-000        139-010-000   139-010-000
    SS7HC      1203      139-010-000        139-010-000   139-010-000
    SS7HC      1207      139-010-000        139-010-000   139-010-000
    SS7HC      1208      139-010-000        139-010-000   139-010-000
    SS7HC      1213      139-010-000        139-010-000   139-010-000
    SS7HC      1303      139-010-000        139-010-000   139-010-000
    SS7HC      1304      139-010-000        139-010-000   139-010-000
    SS7HC      1307      139-010-000        139-010-000   139-010-000
    SS7HC      1308      139-010-000        139-010-000   139-010-000
    SS7HC      1313      139-010-000        139-010-000   139-010-000
    SS7HC      1314      139-010-000        139-010-000   139-010-000
    GLSHC      1102      139-010-000        139-010-000   139-010-000
    ATMHC      2102      139-010-000        139-010-000   139-010-000
    ATMHC      3306      139-010-000        139-010-000   139-010-000
    ATMHC      6101      139-010-000        139-010-000   139-010-000
    ATMHC      6102      139-010-000        139-010-000   139-010-000
    IPSG       1101      139-010-000        139-010-000   139-010-000
    IPSG       1105      139-010-000        139-010-000   139-010-000
    IPSG       1106      139-010-000        139-010-000   139-010-000
    IPSG       1201      139-010-000        139-010-000   139-010-000
    IPSG       1211      139-010-000        139-010-000   139-010-000
    IPSG       1301      139-010-000        139-010-000   139-010-000
    IPSG       1305      139-010-000        139-010-000   139-010-000
    IPSG       1306      139-010-000        139-010-000   139-010-000
    MCPHC      1212      139-010-000        139-010-000   139-010-000
    MCPHC      5302      139-010-000        139-010-000   139-010-000
    ENUM64     2305      139-010-000        139-010-000   139-010-000
    ENUM64     3105      139-010-000        139-010-000   139-010-000
    ENUM64     3115      139-010-000        139-010-000   139-010-000
    ENUM64     3117      139-010-000        139-010-000   139-010-000
    DEIR64     3215      139-010-000        139-010-000   042-010-003
    DEIR64     3217      139-010-000        139-010-000   042-010-003
    DEIR64     3315      139-010-000        139-010-000   042-010-003
    Command Completed.
If a specific GPL, including the communication GPLs, is specified, then all the cards running that GPL are displayed. For example, if the rept-stat-gpl:gpl=ss7hc command is entered, then all cards running the SS7HC GPL are displayed as shown in the following example.
tklc9010801 16-09-07 00:22:40 EST  EAGLE 46.4.0.0.0-69.10.0
    GPL Auditing  ON
    Command Completed.
If a communication GPL (BLMCAP ) is specified with the rept-stat-gpl command, for example, rept-stat-gpl:gpl=blmcap, then all cards running the communication GPL are displayed. In the following example, all the cards running the BLMCAP GPL are displayed as the output for the rept-stat-gpl:gpl=blmcap command.
    eagle1 16-09-09 18:53:40 MST  EAGLE 46.4.0.0.0-69.8.0
    GPL Auditing  ON
    BLMCAP      1101      138-022-000 ALM    139-002-000   139-002-000
    BLMCAP      1102      138-011-000 ALM    139-002-000   139-002-000
    BLMCAP      1112      139-001-000 ALM    139-002-000   139-002-000
    BLMCAP      1205      138-011-000 ALM    139-002-000   139-002-000
    BLMCAP      1206      138-011-000 ALM    139-002-000   139-002-000
    BLMCAP      1207      139-010-000 ALM    139-002-000   139-002-000
    Command Completed.
If the display=all parameter is specified with the rept-stat-gpl command, then all GPLs, application and communication GPLs used by all the cards in the EAGLE are displayed as shown in these examples.
This example shows the output when the display=all parameter is specified. IMT and application GPL information is shown.:
tekelecstp 18-01-18 21:30:11 EST  EAGLE 46.5.1.5.0-73.10.0
    rept-stat-gpl:display=all
    Command entered at terminal #18.
Command Accepted - Processing
    GPL Auditing  ON
    OAMHC      1113      033-010-001        033-010-001   -----------  *
           BLMCAP        033-010-001        033-010-001   033-010-001
    OAMHC      1115      033-010-001        033-010-001   -----------  *
    HIPR2      1109      141-003-000 ALM    143-005-000   143-005-000
    HIPR2      1110      141-003-000 ALM    143-005-000   143-005-000
    SFAPP      1103      009-011-001        009-011-001   033-010-000
           BLDC64        143-006-000 ALM    000-000-000   033-010-001
    SS7HC      1106      033-010-000        033-010-000   033-010-000
           BLMCAP        077-005-000 ALM    033-010-001   033-010-001
    IPSHC      1112      033-010-000        033-010-000   033-010-000
           BLIXP         077-005-000 ALM    033-010-001   033-010-001
    SCCP64     1107      033-010-000        033-010-000   033-010-000
           BLDC64        064-011-000 ALM    000-000-000   033-010-001
    Command Completed.
Command Executed
If the loc parameter is specified with the rept-stat-gpl command, all the GPLs running on the specified card are displayed. For HC MIMs, this includes all non-activated flash GPLs, as shown in the following example.
eagle1 16-09-09 18:52:13 MST  EAGLE 46.4.0.0.0-69.8.0
    GPL Auditing  ON
    SS7HC      1102      139-006-000        139-006-000   139-008-000
    BLMCAP                139-002-000 +      139-002-000   139-002-000
    Command Completed.
Notes:
The display=all, gpl, and loc parameters cannot be specified in the same command.
If GPL auditing is on, a minor alarm is generated, and ALM is displayed for each GPL in the RUNNING column whose version does not match the version of the GPL shown in the system release ID table. The GPL versions in the system release ID table are shown in the RELEASE column of the rtrv-gpl command output.
If GPL auditing is off, the minor alarm is not generated, but ALM is displayed for each GPL whose version does not match the version of the GPL shown in the system release ID table. The detection, marking, and reporting of corrupt GPLs continues to be performed and is not affected by turning GPL auditing off.
If a GPL is not found, a version of “-----------” is displayed.
If a card is inhibited, “-----------” is displayed in the RUNNING column.
A plus (+) symbol appears in the output when any of the communication or flash GPLs are specified for the rept-stat-gpl command. The plus symbol indicates that the specified GPL currently running on the card has not yet been activated on the card.
RTRV-GPL Command
The rtrv-gpl command output contains these six columns and displays this information.
  • GPL – The GPLs contained on the TDMs.
  • CARD – The card location of the TDMs, either card locations 1114 or 1116
  • RELEASE – The version number of the GPL contained in the system release ID table.
  • REMOVE TRIAL – The version number of the GPLs contained on the removable media. Entries in the REMOVE TRIAL column are shown only if the removable media is inserted into the removable media drive. If the removable media is not inserted in an E5-MCAP card, dashes are shown in the REMOVE TRIAL column. Dashes are displayed in the RELEASE, APPROVED, and TRIAL columns.
For E5-based control cards installed in the EAGLE installed in the E5-MCAP card of the active MASP (card location 1113), the following is an example of the rtrv-gpl command output. In this example, removable media is installed in the E5-MCAP card of the active MASP (card location 1113), shown by the GPL version number in the REMOVE TRIAL column for card location 1114. Removable media is not installed in the E5-MCAP card of the standby MASP (card location 1115), shown by the dashes in the REMOVE TRIAL column for card location 1116.
tklc9010801 16-09-07 00:26:49 EST  EAGLE 46.4.0.0.0-69.10.0
    GPL Auditing  ON
    GPL       CARD  RELEASE      APPROVED         TRIAL        REMOVE TRIAL
    SS7HC     1114  139-010-000  139-010-000      139-010-000  139-010-000
    SS7HC     1116  139-010-000  139-010-000      139-010-000  -----------
    SS7HC     1113  -----------  -----------      -----------  -----------
You can display all the GPLs in the EAGLE or a specific GPL in the EAGLE.
If you specify the rtrv-gpl command with no parameters, all the GPLs in the EAGLE are displayed as shown in this example. This is an example of the rtrv-gpl output when E5-based control cards are installed in the EAGLE:
tklc9010801 16-09-07 00:28:42 EST  EAGLE 46.4.0.0.0-69.10.0
    GPL Auditing  ON
    BLMCAP    1114  139-010-000  139-010-000      085-009-012  085-009-012
    BLMCAP    1116  139-010-000  139-010-000      085-009-012  085-009-012
    BLMCAP    1113  -----------  -----------      -----------  -----------
    OAMHC     1114  139-010-000  139-010-000      139-010-000  139-010-000
    OAMHC     1116  139-010-000  139-010-000      139-010-000  139-010-000
    OAMHC     1113  -----------  -----------      -----------  -----------
    HIPR2     1114  139-009-000  139-009-000      139-009-000  139-009-000
    HIPR2     1116  139-009-000  139-009-000      139-009-000  139-009-000
    HIPR2     1113  -----------  -----------      -----------  -----------
    SS7HC     1116  139-010-000  139-010-000      139-010-000  139-010-000
    GLSHC     1114  139-010-000  139-010-000      139-010-000  139-010-000
    GLSHC     1116  139-010-000  139-010-000      139-010-000  139-010-000
    GLSHC     1113  -----------  -----------      -----------  -----------
    SCCP64    1114  139-010-000  139-010-000      139-010-000  139-010-000
    SCCP64    1116  139-010-000  139-010-000      139-010-000  139-010-000
    SCCP64    1113  -----------  -----------      -----------  -----------
    ERTHC     1114  139-010-000  139-010-000      139-010-000  139-010-000
    ERTHC     1116  139-010-000  139-010-000      139-010-000  139-010-000
    ERTHC     1113  -----------  -----------      -----------  -----------
    IPSHC     1114  139-010-000  139-010-000      139-010-000  139-010-000
    IPSHC     1116  139-010-000  139-010-000      139-010-000  139-010-000
    IPSHC     1113  -----------  -----------      -----------  -----------
    ATMHC     1114  139-010-000  139-010-000      139-010-000  139-010-000
    ATMHC     1116  139-010-000  139-010-000      139-010-000  139-010-000
    ATMHC     1113  -----------  -----------      -----------  -----------
    IPSG      1114  139-010-000  139-010-000      139-010-000  139-010-000
    IPSG      1116  139-010-000  139-010-000      139-010-000  139-010-000
    IPSG      1113  -----------  -----------      -----------  -----------
    PKTGHC    1114  169-010-000  169-010-000      169-010-000  169-010-000
    PKTGHC    1116  169-010-000  169-010-000      169-010-000  169-010-000
    PKTGHC    1113  -----------  -----------      -----------  -----------
    BLMCAP    1114  139-010-000  139-010-000      085-009-009  139-010-000
    BLMCAP    1116  139-010-000  139-010-000      085-009-009  139-010-000
    MCPHC     1114  139-010-000  139-010-000      139-010-000  139-010-000
    MCPHC     1116  139-010-000  139-010-000      139-010-000  139-010-000
    MCPHC     1113  -----------  -----------      -----------  -----------
    SIPHC     1114  139-010-000  139-010-000      139-010-000  139-010-000
    SIPHC     1116  139-010-000  139-010-000      139-010-000  139-010-000
    SIPHC     1113  -----------  -----------      -----------  -----------
    DEIR64    1114  139-010-000  139-010-000      139-010-000  139-010-000
    DEIR64    1116  139-010-000  139-010-000      139-010-000  139-010-000
    DEIR64    1113  -----------  -----------      -----------  -----------
    ENUM64    1114  139-010-000  139-010-000      139-010-000  139-010-000
    ENUM64    1116  139-010-000  139-010-000      139-010-000  139-010-000
    ENUM64    1113  -----------  -----------      -----------  -----------
    PKTG64    1114  169-010-000  169-010-000      169-010-000  169-010-000
    PKTG64    1116  169-010-000  169-010-000      169-010-000  169-010-000
    PKTG64    1113  -----------  -----------      -----------  -----------
    BLDC64    1114  139-010-000  139-010-000      085-009-006  139-010-000
    BLDC64    1116  139-010-000  139-010-000      085-009-006  139-010-000
    BLDC64    1113  -----------  -----------      -----------  -----------
    BLSLC32   1114  139-010-000  139-010-000      085-009-009  139-010-000
    BLSLC32   1116  139-010-000  139-010-000      085-009-009  139-010-000
    BLSLC32   1113  -----------  -----------      -----------  -----------
    BLSLC64   1114  139-010-000  139-010-000      042-010-003  139-010-000
    BLSLC64   1116  139-010-000  139-010-000      042-010-003  139-010-000
    BLSLC64   1113  -----------  -----------      -----------  -----------
    SIP64     1114  139-010-000  139-010-000      139-010-000  139-010-000
    SIP64     1116  139-010-000  139-010-000      139-010-000  139-010-000
    SIP64     1113  -----------  -----------      -----------  -----------
    DEIR64    1114  139-010-000  139-010-000      042-010-003  139-010-000
    DEIR64    1116  139-010-000  139-010-000      042-010-003  139-010-000
Command Executed
In this example, removable media is installed in both MASPs.
If a specific GPL is specified, then only that GPL is displayed. For example, if the rtrv-gpl:gpl=ss7hc command is entered, then only the SS7HC GPL is displayed as shown in the following example.
eagle1 16-09-12 12:03:53 MST  EAGLE 46.4.0.0.0-69.8.0
    GPL Auditing  ON
If GPL auditing is on, a minor alarm is generated, and ALM is displayed for each approved GPL version that does not match the GPL version shown in the RELEASE column. If GPL auditing is off, the minor alarm is not generated, but ALM is displayed for each GPL version that does not match the GPL version shown in the RELEASE column. The detection, marking, and reporting of corrupt GPLs continues to be performed and is not affected by turning GPL auditing off. The GPL version shown in the RELEASE column is updated when the act-gpl command is performed.
Loading a GPL onto the System
This section gives a general overview as to how a GPL is loaded onto the EAGLE to be used by the applicable cards. The requirements and steps for each GPL are different and are detailed in the procedures contained in this chapter. The rtrv-gpl examples shown in this section are examples that are shown when E5-based control cards are installed in the EAGLE.
  1. A removable media is inserted into the removable media drive on the E5-MCAP card of the active MASP. If a specific GPL is displayed with the rtrv-gpl command, for example the SS7HC GPL, the following would be displayed.
        eagle1 16-09-09 18:30:48 MST  EAGLE 46.4.0.0.0-69.6.0
        GPL Auditing  ON
        SS7HC     1114  139-006-000  139-006-000      139-004-000  -----------
        SS7HC     1116  139-006-000  139-006-000      139-004-000  139-008-000
        SS7HC     1115  -----------  -----------      -----------  -----------
    Command Executed
    Displaying the SS7HC GPL with the rept-stat-gpl command would display all the cards running the SS7HC GPL, as shown in this example.
    eagle1 16-09-09 18:31:17 MST  EAGLE 46.4.0.0.0-69.6.0
        GPL Auditing  ON
        SS7HC      1102      139-006-000        139-006-000   139-004-000
        SS7HC      1205      139-006-000        139-006-000   139-004-000
        SS7HC      1206      139-006-000        139-006-000   139-004-000
        SS7HC      1207      139-006-000        139-006-000   139-004-000
        Command Completed
  2. When the chg-gpl command is executed, the specific GPL is copied from the removable media to the fixed disks. The specific GPL and the version number of the GPL on the removable media must be specified with the chg-gpl command. The version number is found in the REMOVE TRIAL column of the rtrv-gpl output. For this example the chg-gpl :gpl:SS7HC:ver=139-008-000 command would be entered at the EAGLE terminal.
  3. The new version of the GPL is now the trial version of the GPL as shown in the examples of the rtrv-gpl and rept-stat-gpl outputs.
    rtrv-gpl:gpl=ss7hc
    eagle1 16-09-09 18:33:48 MST  EAGLE 46.4.0.0.0-69.6.0
        GPL Auditing  ON
        SS7HC     1114  139-006-000  139-006-000      139-008-000  -----------
        SS7HC     1116  139-006-000  139-006-000      139-008-000  139-008-000
    eagle1 16-09-09 18:34:26 MST  EAGLE 46.4.0.0.0-69.6.0
        GPL Auditing  ON
        SS7HC      1205      139-006-000        139-006-000   139-008-000
        SS7HC      1206      139-006-000        139-006-000   139-008-000
        SS7HC      1207      139-006-000        139-006-000   139-008-000
        Command Completed.
  4. To make the trial version of the GPL the approved version, the act-gpl command is executed after the GPL has been copied from the removable media with the chg-gpl command (steps 1 to 3). The trial and approved versions of the specific GPL are swapped as shown in these rtrv-gpl and rept-stat-gpl output examples.
    rtrv-gpl:gpl=ss7hc
    eagle1 16-09-09 18:35:31 MST  EAGLE 46.4.0.0.0-69.8.0
        GPL Auditing  ON
        SS7HC     1114  139-008-000  139-008-000      139-006-000  -----------
        SS7HC     1116  139-008-000  139-008-000      139-006-000  139-008-000
    The system release ID table is updated with the version of the GPL specified with the act-gpl command. This GPL version is shown in the RELEASE column of the rtrv-gpl output after the act-gpl command is performed.
    The ALM indicator is not displayed in the rtrv-gpl output because the approved version of the GPL matches the version in the system release ID table.
        eagle1 16-09-09 18:35:52 MST  EAGLE 46.4.0.0.0-69.8.0
        GPL Auditing  ON
        SS7HC      1102      139-006-000 ALM    139-008-000   139-006-000
        SS7HC      1205      139-006-000 ALM    139-008-000   139-006-000
        SS7HC      1206      139-006-000 ALM    139-008-000   139-006-000
        SS7HC      1207      139-006-000 ALM    139-008-000   139-006-000
        Command Completed.
    The ALM indicator is displayed for the cards that are running the version of the GPL that does not match the version in the system release ID table (shown in the RELEASE column of the rtrv-gpl output). In this example, the cards are running the trial version which does not match the version in the system release ID table.
  5. To load the card with the new version of the application GPL, the card must be inhibited with the inh-card command, then placed back into service with the alw-card command. To load the approved version of the GPL onto the card, the code=appr parameter can be specified with the alw-card command. It is not necessary to specify the code=appr parameter to load the approved version of the GPL. Entering the alw-card command without the code parameter loads the approved version of the GPL onto the card.
    If you wish to load the trial version of the GPL onto the card, the code=trial parameter must be specified with the alw-card command.
    To load the card with the new version of the flash GPL, the card must be inhibited with the inh-card command and flashed with the init-flash command. The new flash GPL on the card should be activated with the act-flash command and then placed back into service with the alw-card command.
    The following examples show the outputs of the rtrv-gpl and rept-stat-gpl commands after the card has been reloaded. The outputs will vary depending on whether or not the new version of the GPL has been made the approved version with the act-gpl command, and which version (trial or approved) of the GPL is loaded onto the card.
    Example 1
    The new GPL is the APPROVED version and the card 1102 was reloaded with the APPROVED version of the GPL. Card 1102 is now running the APPROVED and RELEASE versions of the GPL. The ALM indicator is not shown in the rtrv-gpl output and is not shown for card 1102 in rept-stat-gpl output. The ALM indicator is shown for cards 1205, 1206, and 1207 because they are not running the RELEASE version of the GPL.
    RTRV-GPL Output
    eagle1 16-09-09 18:36:26 MST  EAGLE 46.4.0.0.0-69.8.0
        GPL Auditing  ON
    REPT-STAT-GPL Output
        eagle1 16-09-09 18:38:34 MST  EAGLE 46.4.0.0.0-69.8.0
        GPL Auditing  ON
        SS7HC      1102      139-008-000        139-008-000   139-006-000
        Command Completed.
    Example 2
    The new GPL is the APPROVED version and the card 1102 was reloaded with the TRIAL version of the GPL. The card is now running the TRIAL version of the GPL which is not the RELEASE version of the GPL. The ALM indicator is not shown in the rtrv-gpl output, but is shown for all the cards in rept-stat-gpl output because they are not running the RELEASE version of the GPL.
    RTRV-GPL Output
        eagle1 16-09-09 18:41:06 MST  EAGLE 46.4.0.0.0-69.8.0
        GPL Auditing  ON
    eagle1 16-09-09 18:41:59 MST  EAGLE 46.4.0.0.0-69.8.0
        GPL Auditing  ON
        Command Completed.
    Example 3
    The new GPL is the TRIAL version and the card 1102 was reloaded with the TRIAL version of the GPL. Card 1102 is now running the TRIAL version of the GPL, but not the RELEASE version of the GPL. The ALM indicator is not shown in the rtrv-gpl output because the RELEASE version of the GPL has not changed. The ALM indicator is shown for card 1102 in the rept-stat-gpl output because card 1102 is not running the RELEASE version of the GPL.
    RTRV-GPL Output
    eagle1 16-09-09 18:43:39 MST  EAGLE 46.4.0.0.0-69.6.0
        GPL Auditing  ON
        eagle1 16-09-09 18:44:12 MST  EAGLE 46.4.0.0.0-69.6.0
        GPL Auditing  ON
        SS7HC      1102      139-008-000 ALM    139-006-000   139-008-000
        Command Completed.
    Example 4
    The new GPL is the TRIAL version and the card 1102 was reloaded with the APPROVED version of the GPL. Card 1102 is now running the APPROVED version of the GPL which is the RELEASE version of the GPL. The ALM indicator is not shown in the rtrv-gpl output, and for all the cards in rept-stat-gpl output because they are running the RELEASE version of the GPL.
    RTRV-GPL Output
        eagle1 16-09-09 18:46:20 MST  EAGLE 46.4.0.0.0-69.6.0
        GPL Auditing  ON
        eagle1 16-09-09 18:46:41 MST  EAGLE 46.4.0.0.0-69.6.0
        GPL Auditing  ON
        Command Completed
Updating the BLMCAP and OAMHC GPLs
This procedure updates the BLMCAP and OAMHC GPLs on the E5-MCAP cards in card locations 1113 and 1115 as a trial version from the removable media, then making the trial version of these GPLs the approved version of these GPLs. The E5-MCAP card in card locations 1113 and 1115 is used in combination with the TDM to form the Maintenance and Administration Subsystem Processor (MASP).
The BLMCAP GPL is updated using the chg-gpl, act-gpl, and flash-card commands.
Caution:
The flash-card command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed.
The OAMHC GPL is updated using the chg-gpl command.
Caution:
This procedure can be performed only on EAGLEs that contain E5-based control cards. Refer to Maintenance and Administration Subsystem for more information about the control cards.
If any card is not running the version of the GPL shown in the RELEASE column of the rtrv-gpl output, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output, and next to the GPL version in the APPROVED column in the rtrv-gpl output.
Removable media containing the BLMCAP and OAMHC GPLs that are being updated is required.
  1. Verify the control cards that are installed in the EAGLE.
    Refer to Maintenance and Administration Subsystem for information about the control cards.
    If E5-based control cards are installed in the EAGLE, continue the procedure with 2.
  2. Check the E5-MASPs for removable media.
    If removable media is installed in one of the E5-MASPs, continue the procedure with 4.
    If removable media is not installed in either E5-MASPs, continue the procedure with 3.
  3. Verify the active MASP by entering the rept-stat-db command.
    This is an example of the possible output.
    eagle1 16-09-09 17:51:57 MST  EAGLE 46.4.0.0.0-69.6.0
        DATABASE STATUS: >> OK <<
                TDM 1114 ( STDBY)                 TDM 1116 ( ACTV )
                C   LEVEL    TIME LAST BACKUP     C   LEVEL    TIME LAST BACKUP
        FD BKUP Y        1     -        -         Y        1     -        -
        FD CRNT Y       93                        Y       93
                MCAP 1113                         MCAP 1115
        RD BKUP -    -         -        -         Y        1     -        -
        USB BKP -    -         -        -         -    -         -        -
    If removable media is installed in the active MASP, continue the procedure with 4.
    If removable media is not installed in the active MASP, insert the removable media in the removable media drive in the active MASP. For more information about inserting removable media in the removable media drive, refer to Removable USB Drive. After the removable media has been inserted in the removable media drive in the active MASP, continue the procedure with 4.
  4. Display the BLMCAP and OAM HC GPLs on the fixed disk and on the removable media using the rtrv-gpl command with the gpl parameter value equal to the GPL being updated. Perform these substeps.
    1. Display the BLMCAP GPL by entering this command.
      rtrv-gpl:gpl=blmcap
      eagle1 16-09-09 18:28:48 MST  EAGLE 46.4.0.0.0-69.6.0
          GPL Auditing  ON
          BLMCAP    1114  139-005-000  139-005-000      139-005-000  -----------
          BLMCAP    1116  139-005-000  139-005-000      139-005-000  139-008-000
          BLMCAP    1115  -----------  -----------      -----------  -----------
    2. Display the OAMHC GPL by entering this command.
      rtrv-gpl:gpl=oamhc
      eagle1 16-09-09 18:30:03 MST  EAGLE 46.4.0.0.0-69.6.0
          GPL Auditing  ON
          OAMHC     1114  139-006-000  139-006-000      -----------  -----------
          OAMHC     1116  139-006-000  139-006-000      139-008-000  139-008-000
          OAMHC     1115  -----------  -----------      -----------  -----------
    If the version of either GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP.
    Insert the removable media that contains the GPLs that are being updated into the removable media drive in the active MASP. If 3 was performed, repeat this step. If 3 was not performed, repeat this procedure from 3.
    For more information about inserting removable media in the removable media drive, or removing removable media from the removable media drive, refer to Removable USB Drive.
    If the versions of the GPLs shown in the REMOVE TRIAL column of the rtrv-gpl output are the versions that are to be loaded onto the cards, continue the procedure with 5.
  5. Change the BLMCAP and OAMHC GPLs using the chg-gpl command and specifying the value for the trial BLMCAP and OAMHC GPLs shown in the REMOVE TRIAL column in the output of the rtrv-gpl command (in 4). Perform these substeps.
    1. For the BLMCAP GPL in this example, enter this command.
      chg-gpl:gpl=blmcap:ver=139-008-000
      These messages should appear.
          eagle1 16-09-09 18:47:55 MST  EAGLE 46.4.0.0.0-69.6.0
          BLMCAP upload to 1116 completed
          BLMCAP upload to 1114 completed
          System Release ID table upload to 1116 completed
          System Release ID table upload to 1114 completed
    2. For the OAMHC GPL in this example, enter this command.
      chg-gpl:gpl=oamhc:ver=139-008-000
          eagle1 16-09-09 18:48:30 MST  EAGLE 46.4.0.0.0-69.6.0
          OAMHC upload to 1116 completed
          OAMHC upload to 1114 completed
  6. Activate the trial BLMCAP GPL, using the act-gpl command and specifying the name and version of the trial BLMCAP GPL specified in Substep a in 5. Enter this command.
    act-gpl:gpl=blmcap:ver=139-008-000
        eagle1 16-09-09 18:48:53 MST  EAGLE 46.4.0.0.0-69.8.0
        BLMCAP activate on 1116 completed
        BLMCAP activate on 1114 completed
  7. Verify that the trial BLMCAP and OAM HC GPLs have been made the approved GPLs using the rtrv-gpl command. Perform these substeps.
    1. For the BLMCAP GPL, enter the rtrv-gpl:gpl=blmcap command.
          eagle1 16-09-09 18:49:10 MST  EAGLE 46.4.0.0.0-69.8.0
          GPL Auditing  ON
          BLMCAP    1114  139-008-000  139-008-000      139-005-000  -----------
          BLMCAP    1116  139-008-000  139-008-000      139-005-000  139-008-000
    2. For the OAMHC GPL, enter the rtrv-gpl:gpl=oamhc command.
      GPL Auditing  ON
      OAMHC     1114  139-008-000  139-008-000      139-005-000  139-008-000
      OAMHC     1116  139-008-000  139-008-000      139-005-000  139-008-000
  8. Verify the GPLs that are running on the E5-MCAP cards by performing these substeps.
    1. For the BLMCAP GPL, enter the rept-stat-gpl:gpl=blmcap command.
      GPL Auditing  ON
      BLMCAP  1113   139-005-000 ALM   139-008-000   139-005-000
      BLMCAP  1115   139-005-000 ALM   139-008-000   139-005-000
      Command Completed
      The flash-card command will load only the BLMCAP GPLs whose approved versions are different from the versions that the card is running. The version of the BLMCAP GPL that the card is running is shown in the RUNNING column in the rept-stat-gpl output. The approved version of the BLMCAP GPL is shown in the APPROVED column of the rept-stat-gpl output. If the running and approved versions of a BLMCAP GPL are the same, the flash-card command will not load that BLMCAP GPL.
    2. For the OAMHC GPL, enter the rept-stat-gpl:gpl=oamhc command.
      OAMHC    1113   139-005-000 ALM   139-008-000   139-005-000
      OAMHC    1115   139-005-000 ALM   139-008-000   139-005-000
      Command Completed
  9. Display the terminal configuration in the database with the rtrv-trm command.
    All the SEAS terminals must be placed out of service in order to load the BLMCAP and OAMHC GPLs onto the E5-MCAP cards. The SEAS terminals are shown in the output with the entry SEAS in the TYPE field. This is an example of the possible output. In this example, the SEAS terminals are terminals 18 and 27.
    TRM  TYPE    COMM        FC    TMOUT MXINV DURAL
    1    VT320    9600-7-E-1 SW    30    5     99:59:59
    2    KSR      9600-7-E-1 HW    30    5     INDEF
    3    PRINTER  4800-7-E-1 HW    30    0     00:00:00
    4    VT320    2400-7-E-1 BOTH  30    5     00:30:00
    5    VT320    9600-7-O-1 NONE  30    5     00:00:30
    6    VT320    9600-7-O-1 NONE  30    5     00:00:30
    7    PRINTER  9600-7-N-2 HW    30    5     00:30:00
    8    KSR     19200-7-E-2 BOTH  30    5     00:30:00
    9    VT320    9600-7-O-1 NONE  30    5     00:00:30
    10   VT320    9600-7-E-1 HW    30    5     00:30:00
    11   VT320    4800-7-E-1 HW    30    5     00:30:00
    12   PRINTER  9600-7-E-1 HW    30    4     00:30:00
    13   VT320    9600-7-O-1 NONE  30    5     00:30:00
    14   VT320    9600-7-E-2 SW    30    8     00:30:00
    15   VT320    9600-7-N-2 HW    30    5     00:30:00
    16   VT320    9600-7-E-2 BOTH  30    3     00:30:00
    TRM  TYPE      LOC              TMOUT MXINV DURAL
    17   TELNET    1303             60    5     00:30:00
    18   SEAS      1201             60    5     00:30:00
    19   TELNET    1303             60    5     00:30:00
    20   TELNET    1303             60    5     00:30:00
    21   TELNET    1303             60    5     00:30:00
    22   TELNET    1303             60    5     00:30:00
    23   TELNET    1303             60    5     00:30:00
    24   TELNET    1303             60    5     00:30:00
    25   TELNET    1203             60    5     00:30:00
    26   TELNET    1203             60    5     00:30:00
    27   SEAS      1203             60    5     00:30:00
    28   TELNET    1203             60    5     00:30:00
    39   TELNET    1203             60    5     00:30:00
    30   TELNET    1203             60    5     00:30:00
    31   TELNET    1203             60    5     00:30:00
    32   TELNET    1203             60    5     00:30:00
    33   TELNET    1208             60    5     00:30:00
    34   TELNET    1208             60    5     00:30:00
    35   TELNET    1208             60    5     00:30:00
    36   TELNET    1208             60    5     00:30:00
    37   TELNET    1208             60    5     00:30:00
    38   TELNET    1208             60    5     00:30:00
    39   TELNET    1208             60    5     00:30:00
    40   TELNET    1208             60    5     00:30:00
    The rtrv-trm command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-trm command, see the rtrv-trm command description in Commands User's Guide.
    If SEAS terminals are shown in the rtrv-trm command output, continue the procedure with 10.
    If no SEAS terminals are shown in the rtrv-trm command output, perform one of these steps to continue the procedure.
    • If the rept-stat-db command in 3 was not performed, continue the procedure with 13.
    • If the rept-stat-db command in 3 was performed, continue the procedure with 14.
  10. Display the status of the terminals with the rept-stat-trm command with the terminal number of the SEAS terminals.
    For this example, enter these commands.
    rept-stat-trm:trm=18
    TRM   PST           SST           AST
    18     IS-NR         Active        -----
    Command Completed.
    rept-stat-trm:trm=27
    TRM   PST           SST           AST
    27     IS-NR         Active        -----
    Command Completed.
  11. Place the SEAS terminals out of service using the rmv-trm command with the number of the terminal displayed in 10 whose state is not OOS-MT-DSBLD.
    The force=yes parameter must be used when placing the last SEAS terminal out of service. For this example, enter these commands.
    rmv-trm:trm=18
    rmv-trm:trm=27:force=yes
    If the status of the SEAS terminals shown in the PST field in 10 is OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
    This message should appear when each of these commands have successfully completed.
    Inhibit message sent to terminal
    Command Completed.
  12. Change the terminal type of the SEAS terminals to NONE with the chg-trm command, the type=none parameter, and with the values of the SEAS terminals used in 11.
    chg-trm:trm=18:type=none
    chg-trm:trm=27:type=none
    This message should appear when these commands have successfully completed.
    CHG-TRM: MASP B - COMPLTD
    Continue the procedure with by performing one of these steps.
  13. To load the BLMCAP and OAMHC GPLs, they must be loaded on the standby MASP (E5-MCAP) first.
    To determine which MASP is active, enter the rept-stat-db command. This is an example of the possible output.
            E5TDM 1114 ( STDBY)                 E5TDM 1116 ( ACTV )
    FD BKUP Y       36 09-02-19 09:38:25 GMT  Y       36 09-02-19 09:38:25 GMT
    FD CRNT Y       39                        Y       39
            E5MCAP 1113                         E5MCAP 1115
    RD BKUP -    -         -        -         Y       36 09-02-19 09:27:17 GMT
    USB BKP -    -         -        -         Y        3 09-02-07 01:11:22 GMT
    The output of the rept-stat-db command shows which MASP is active with the indicator ( ACTV ) following the TDM card location. The indicator ( STDBY) following the TDM card location shows which MASP is standby.
    For this example, the MASP associated with TDM 1116 is active and the MASP associated with TDM 1114 is standby.
  14. Using the outputs of 8 and either 3 or 13 as a guide, place the E5-MCAP card making up the standby MASP card out of service using the rmv-card command.
    For this example, enter this command.
    rmv-card:loc=1113
    When this command has successfully completed, this message should appear.
    Card has been inhibited.
  15. Load the approved version of the BLMCAP GPLs onto the card inhibited in 14 using the flash-card command with the code=appr parameter.
    Caution:
    The flash-card command will load only those BLMCAP GPLs whose approved versions are different from the versions that the card is running. The version of the BLMCAP GPL that the card is running is shown in the RUNNING column in the rept-stat-gpl output. The approved version of the BLMCAP GPL is shown in the APPROVED column of the rept-stat-gpl output. If the running and approved versions of an BLMCAP GPL are the same, the flash-card command will not load that BLMCAP GPL.
    flash-card:code=appr:loc=1113
    When this command has successfully completed, these messages should appear.
        Flash Card: FLASH GPL(s) required to be downloaded on card 1113
          BLMCAP   : Running version 134-015-000  Expected version 134-016-000
        Flash Card: Downloading BLMCAP on card 1113
        Flash Card: Card(s) will reset after the flash GPL download.
        Flash Card: Card 1113 download BLMCAP complete.
        Flash Card: FLASH GPL(s) required to be activated on card 1113
          BLMCAP   : Running inactive version 134-016-000
        Flash Card: Activating BLMCAP on card 1113
        Flash Card: Card 1113 activation BLMCAP complete.
        Command Completed.
    The E5-MCAP card specified in the flash-card command will be re-initialized when the BLMCAP GPL download is complete.
  16. Put the card that was taken out of service in 14 back into service using the rst-card command.
    The rst-card command also loads the approved version of the BLMCAP and OAMHC GPLs onto the card.
    rst-card:loc=1113
    Card has been allowed.
  17. Verify that the BLMCAP and OAMHC GPLs from 15 have been loaded and that the card has returned to its in-service normal (IS-NR) state using the rept-stat-card command.
    rept-stat-card:loc=1113
    CARD   VERSION      TYPE      GPL        PST            SST        AST
    1113   139-008-000  E5MCAP    OAMHC      IS-NR          Active     -----
      ALARM STATUS       = No Alarms.
      BLMCAP  GPL version = 139-008-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CURRENT TEMPERATURE   =  30C ( 86F)
      PEAK TEMPERATURE:     =  33C ( 92F)     [02-01-05 07:18]
    Command Completed.
    If the versions of the BLMCAP or OAMHC GPLs shown in the rept-stat-card command output are not the versions specified in 6, contact the Customer Care Center. Refer to My Oracle Support (MOS) for the contact information. The reminder of this procedure should not be performed.
  18. To load the new BLMCAP and OAMHC GPLs onto the E5-MCAP card making up the active MASP, enter the init-card command specifying the location of the E5-MCAP card making up active MASP. For this example, enter the init-card:loc=1115 command. This message should appear.
    Init Card command issued to card 1115
    After this step has been performed, repeat steps 14, 15, 16, and 17 using the card location specified in this step as the loc parameter value in these steps. After these steps have been performed, continue the procedure with either 19 or 21 based on the following conditions:
    • If SEAS terminals were not shown in the rtrv-trm command output in 9, continue the procedure with 21.
    • If SEAS terminals were shown in the rtrv-trm command output in 9, continue the procedure with 19.
  19. Change the terminal type of the terminals that were changed to NONE in 12 to the terminal type SEAS with the chg-trm command and the type=seas parameter.
    The terminal type is shown in the TYPE field in the rtrv-trm command output in 9.
    chg-trm:trm=18:type=seas
    chg-trm:trm=27:type=seas
  20. Put the SEAS terminals back into service using the rst-trm command with the number of the terminals specified in 19.
    rst-trm:trm=18
    rst-trm:trm=27
    Allow message sent to terminal
    Command Completed.
  21. This procedure is finished.
Figure 3-1 Updating the BLMCAP and OAMHC GPLs
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
Updating the Signaling Link and Data Link GPLs
This procedure is used to update the following GPLs: SS7IPGW, IPGWI, SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, and IPSG. These names are used as the value of the gpl parameter of the chg-gpl, act-gpl, rept-stat-gpl, and rtrv-gpl commands.
Signaling links are assigned to cards running the following GPLs: SS7IPGW, IPGWI, SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, and IPSG. The signaling link GPLs are assigned to the card types shown in Table 3-1.
Table 3-1 SS7 LIM Card Types
GPL Card Type
atmansi, atmhc
limatm (cards running the atmhc GPL must be E5-ATM cards)
atmitu, atmhc
lime1atm (cards running the atmhc GPL must be E5-ATM cards)
ss7ipgw, ipgwi, iplhc, ipghc, ipsg
dcm (cards running the iplhc, ipghc, or ipsg GPLs must be E5-ENET cards)
ss7hc
lime1, limt1 (these cards can be HC MIMs or E5-E1T1 cards)
The card types shown in Table 3-1 are the values used for the type parameter of the ent-card command.
The cards running the SS7HC GPL are E5-E1T1-B cards. E5-E1T1-B cards are single-slot cards that can support up to 32 signaling links. These cards are either LIM-E1 or LIM-T1 cards. The rtrv-card output shows these cards running either the SS7ANSI or CCS7ITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the SS7HC GPL.
The cards running the SS7EPM GPL are E5-E1T1 cards which are single-slot cards that can support up to 32 signaling links. The E5-E1T1 cards are either LIM-E1 or LIM-T1 cards. The rtrv-card output shows these cards running either the SS7ANSI or CCS7ITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the SS7EPM GPL.
The cards running the IPLHC and IPGHC GPLs are E5-ENET, E5-ENET-B and SLIC cards supporting IP signaling links. The rtrv-card output shows this card running either the IPLIM or IPLIMI applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the IPLHC GPL. The IPGHC GPL allows the E5-ENET card to support SS7IPGW (ANSI IP Gateway) or IPGWI (ITU IP Gateway) signaling links. The rtrv-card output shows this card running either the SS7IPGW or IPGWI applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the IPGHC GPL.
The cards running the ATMHC GPL are cards that can contain the ATM high-speed signaling links on E5-ATM cards. The rtrv-card output shows these cards running either the ATMANSI or ATMITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the ATMHC GPL.
If the GPL is being updated to a new version, a removable media containing the GPL being updated is required.
Canceling the REPT-STAT-SLK and RTRV-SLK Commands
Because the rept-stat-slk and rtrv-slk commands used in this procedure can output information for a long period of time, the rept-stat-slk and rtrv-slk commands can be canceled and the output to the terminal stopped. There are three ways that the rept-stat-slk and rtrv-slk commands can be canceled.
  • Press the F9 function key on the keyboard at the terminal where the rept-stat-slk or rtrv-slk commands command were entered.
  • Enter the canc-cmd without the trm parameter at the terminal where the rept-stat-slk or rtrv-slk commands were entered.
  • Enter the canc-cmd:trm=<xx>, where <xx> is the terminal where the rept-stat-slk or rtrv-slk commands were entered, from another terminal other that the terminal where the rept-stat-slk or rtrv-slk commands were entered. To enter the canc-cmd:trm=<xx> command, the terminal must allow Security Administration commands to be entered from it and the user must be allowed to enter Security Administration commands. The terminal’s permissions can be verified with the rtrv-secu-trm command. The user’s permissions can be verified with the rtrv-user or rtrv-secu-user commands.
For more information about the canc-cmd command, go to Commands User's Guide.
    If removable media is installed in both E5-MASPs, continue the procedure with 4.
    If removable media is not installed in both E5-MASPs, continue the procedure with 3.
    rlghncxa03w 09-03-16 15:25:40 GMT  EAGLE 46.3.0
    FD CRNT Y       39                        Y       39
  4. Display the GPLs on the fixed disk using the rtrv-gpl command with the gpl parameter value equal to the GPL being updated. These are examples of the possible output.
    rtrv-gpl:gpl=ss7hc
    rlghncxa03w 09-03-16 11:34:04 GMT  EAGLE 46.3.0
    GPL Auditing  ON
    SS7HC     1114  132-002-000  132-002-000      132-001-000  132-003-000
    SS7HC     1116  132-002-000  132-002-000      132-001-000  132-003-000
    If the version of the GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP.
    Insert the removable media that contains the GPL that is being updated into the removable media drive in the active MASP and repeat this step.
    If the version of the GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is the version that is to be loaded onto the cards, continue the procedure with 5.
  5. Change the GPLs, using the chg-gpl command and specifying the value for the trial GPL shown in the REMOVE TRIAL column in the output of the rtrv-gpl command used in 4.
    chg-gpl:gpl=ss7hc:ver=123-003-000
    rlghncxa03w 09-03-16  11:43:04  GMT  EAGLE 46.3.0
    GPL Auditing  ON
    SS7HC upload on 1114 completed
    SS7HC upload on 1116 completed
    System Release ID table upload 1114 completed
    System Release ID table upload 1116 completed
  6. Activate the trial GPL, using the act-gpl command and specifying the value for the trial GPL shown in 5.
    act-gpl:gpl=ss7hc:ver=123-003-000
    rlghncxa03w 09-03-16 06:54:39 GMT EAGLE 46.3.0
    SS7HC activate on 1114 completed
    SS7HC activate on 1116 completed
  7. Verify that the trial GPL has been made the approved GPL using the rtrv-gpl command with the gpl parameter value specified in 5 and 6.
    rtrv-gpl:gpl=ss7hc
    GPL Auditing  ON
    SS7HC     1114  132-003-000  132-003-000      132-002-000  132-003-000
    SS7HC     1116  132-003-000  132-003-000      132-002-000  -----------
    If E5-based control cards are installed in the EAGLE, this is an example of the possible output.
    GPL Auditing  ON
    SS7HC     1116  132-003-000  132-003-000      132-002-000  132-003-000
  8. Verify which cards are running the GPL using the rept-stat-gpl command with the gpl parameter value specified in 7.
    rlghncxa03w 09-03-16 11:40:26 GMT  EAGLE 46.3.0
    SS7HC    1201   132-002-000 ALM   132-003-000   132-002-000
    SS7HC    1204   132-002-000 ALM   132-003-000   132-002-000
    SS7HC    1211   132-002-000 ALM   132-003-000   132-002-000
    SS7HC    1215   132-002-000 ALM   132-003-000   132-002-000
    SS7HC    1307   132-002-000 ALM   132-003-000   132-002-000
    SS7HC    2111   132-002-000 ALM   132-003-000   132-002-000
    SS7HC    2112   132-002-000 ALM   132-003-000   132-002-000
    SS7HC    2115   132-002-000 ALM   132-003-000   132-002-000
    SS7HC    2116   132-002-000 ALM   132-003-000   132-002-000
    Command Completed
    Continue the procedure by performing one of these steps.
    • If one of these GPLs is being updated: SS7IPGW, IPGWI, SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, or IPSG, continue the procedure with 9.
  9. Display the signaling links associated with the cards shown in 8.
    Enter the rtrv-slk command. This is an example of the possible output.
    rlghncxa03w 09-07-16 21:16:37 GMT EAGLE 41.1.0
                                       L2T               PCR  PCR
    LOC  LINK LSN         SLC TYPE     SET  BPS    ECM   N1   N2
    1201 A    lsnmpl1      0  LIMDS0   2    56000  BASIC ---  -----
    1201 B    lsnmpl2      0  LIMDS0   3    56000  PCR   76   3800
    1201 A1   lsnmpl3      0  LIMDS0   2    56000  PCR   120  5034
    1201 B1   lsnmpl4      0  LIMDS0   1    56000  BASIC ---  -----
    1204 A    lsnmpl1      1  LIMDS0   2    56000  BASIC ---  -----
    1204 B    lsnmpl2      1  LIMDS0   3    56000  PCR   76   3800
    1204 A2   lsnmpl3      1  LIMDS0   2    56000  PCR   120  5034
    1204 B2   lsnmpl5      0  LIMDS0   3    56000  PCR   76   3800
    1211 A    lsnmpl1      2  LIMDS0   2    56000  BASIC ---  -----
    1211 B    lsnmpl3      2  LIMDS0   2    56000  PCR   120  5034
    1211 A3   lsnmpl5      1  LIMDS0   3    56000  PCR   76   3800
    1211 B3   lsnmpl6      0  LIMDS0   1    56000  PCR   120  5034
    1215 A1   lsnmpl7      0  LIMDS0   1    56000  BASIC ---  -----
    1215 B2   lsnmpl1      3  LIMDS0   2    56000  BASIC ---  -----
    1215 A3   lsnmpl6      1  LIMDS0   1    56000  PCR   120  5034
    1215 B3   lsnmpl7      1  LIMDS0   1    56000  BASIC ---  -----
    1307 A    lsnmpl6      2  LIMDS0   1    56000  PCR   120  5034
    1307 B2   lsnmpl7      2  LIMDS0   1    56000  BASIC ---  -----
    1307 A3   lsnmpl6      3  LIMDS0   1    56000  PCR   120  5034
    1307 B3   lsnmpl7      3  LIMDS0   1    56000  BASIC ---  -----
                                       LP            ATM
    LOC  LINK LSN         SLC TYPE     SET  BPS      TSEL      VCI    VPI   LL
    1302 A    atm1302a     5  LIMATM   3    1544000  INTERNAL  35     15    0
    1305 A    atm1305a     5  LIMATM   5    1544000  LINE      5      0     2
                                       LP         ATM                    E1ATM
    LOC  LINK LSN         SLC TYPE     SET BPS    TSEL     VCI   VPI  CRC4 SI SN
    2101 A    atmitu1      0  LIME1ATM 5   2.048M LINE     150   2    ON   1  20
    2105 A    atmitu1      1  LIME1ATM 5   2.048M LINE     35    15   ON   2  15
                                       L2T               PCR  PCR   E1   E1
    LOC  LINK LSN         SLC TYPE     SET  BPS    ECM   N1   N2    LOC  PORT TS
    2111 A    lsne145      0  LIME1    1    56000  BASIC ---  ----- 2111 2    10
    2112 A    lsne145      1  LIMCH    1    56000  BASIC ---  ----- 2111 1    14
    2112 A2   lsne145      2  LIMCH    1    56000  BASIC ---  ----- 2111 1    20
                                       L2T               PCR  PCR   T1   T1
    2115 A    lsnt145      0  LIMT1    1    56000  BASIC ---  ----- 2115 2    3
    2116 A    lsnt145      1  LIMCH    1    56000  BASIC ---  ----- 2115 1    11
    2116 A2   lsnt145      2  LIMCH    1    56000  BASIC ---  ----- 2115 1    19
    SLK table is (30 of 1200) 3% full.
  10. Using the outputs of 8 and 9 as a guide, select a card to load the approved GPL onto.
    Deactivate the SS7 signaling links on that card using the dact-slk command. For this example, enter these commands.
    dact-slk:loc=1201:link=a
    dact-slk:loc=1201:link=b
    dact-slk:loc=1201:link=a1
    dact-slk:loc=1201:link=b1
    Caution:
    These command examples place the SS7 signaling links on card 1201 out of service. This will interrupt service on the SS7 signaling links on card 1201 and allow the approved GPL to be loaded on to card 1201.
    Do not deactivate all the SS7 signaling links in the EAGLE at the same time. Doing so will take all the SS7 signaling links out of service and isolate the EAGLE from the network.
    When each of these commands have successfully completed, this message should appear.
    rlghncxa03w 09-03-16 11:45:18 GMT  EAGLE 46.3.0
    Deactivate SLK message sent to card
    Continue the procedure with 13.
  11. Display the data links, and their status, associated with the cards shown in 8.
    Enter the rept-stat-dlk command. This is an example of the possible output.
    rlghncxa03w 09-03-16 17:00:36 GMT  EAGLE 46.3.0
    DLK    PST           SST        AST
    2105   IS-NR         Avail      ---
    2113   IS-NR         Avail      ---
    2301   IS-NR         Avail      ---
    Command Completed.
  12. Deactivate the TCP/IP data link on the card (shown in 11) that you wish to load the trial GPL onto, using the canc-dlk command.
    canc-dlk:loc=2105
    Caution:
    This command example places the TCP/IP data link on card 2105 out of service. This will interrupt service on the TCP/IP data link on card 2105 and allow the trial GPL to be loaded on to card 2105.
    Deactivate Link message sent to card.
    Command Completed.
  13. Place the card specified in either 10 or 12 out of service using the rmv-card command.
    If the card contains the last signaling link in a linkset, the force=yes parameter must be specified. For this example, enter this command.
    rmv-card:loc=1201:force=yes
    rmv-card:loc=2105
    rlghncxa03w 09-03-16  11:11:28 GMT  EAGLE 46.3.0
  14. Put the cards that were inhibited in 13 back into service using the rst-card command.
    The rst-card command also loads the approved version of the GPL onto the card.
    rst-card:loc=1201
    rst-card:loc=2105
  15. Verify the GPLs on the cards using the rept-stat-gpl command with the gpl parameter value specified in 8.
    If any card is not running the release version of the GPL, shown in the RELEASE column of the rtrv-gpl output in 7, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output. For this example, enter these commands.
    SS7HC    1201   132-003-000       132-003-000   132-002-000
    Command Completed
    • If one of these GPLs is being updated: SS7IPGW, IPGWI, SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, or IPSG, continue the procedure with 16.
  16. Place the signaling links that were deactivated in 10 back into service using the act-slk command.
    rlghncxa03w 09-03-16 11:55:49 GMT  EAGLE 46.3.0
    Activate SLK message sent to card
  17. Verify that the signaling links activated in 16 are back in service using the rept-stat-slk command with the card location and signaling link.
    rept-stat-slk:loc=1201:link=a
    rlghncxa03w 09-03-16 13:06:25 GMT EAGLE 46.3.0
    SLK      LSN       CLLI        PST          SST       AST
    1201,A   lsnmpl1   ----------- IS-NR        Avail     ----
      UNAVAIL REASON     = --
    rept-stat-slk:loc=1201:link=b
    1201,B   lsnmpl2   ----------- IS-NR        Avail     ----
      UNAVAIL REASON     = --
    rept-stat-slk:loc=1201:link=a1
    1201,A1  lsnmpl3   ----------- IS-NR        Avail     ----
      UNAVAIL REASON     = --
    rept-stat-slk:loc=1201:link=b1
    1201,B1  lsnmpl4   ----------- IS-NR        Avail     ----
      UNAVAIL REASON     = --
    Command Completed.
  18. Place the TCP/IP data link that was deactivated in 12 back into service using the act-dlk command.
    act-dlk:loc=2105
    Activate Link message sent to card.
  19. Verify that the TCP/IP date links activated in 18 are back in service with the rept-stat-dlk command.
    rlghncxa03w 09-03-16 12:57:50 GMT EAGLE 46.3.0
    DLK    PST           SST        AST
    Command Completed.
  20. Continue the procedure by performing these actions.
    When the E5-based control cards are installed in the EAGLE, continue the procedure by performing one of these actions:
    • If you wish to load the new GPL onto the other cards shown in 8, repeat this procedure from either 10 or 12 for each card shown in 8.
    • If the new GPL will not be loaded onto other cards but other GPLs will be updated, repeat this procedure from 1.
    • If the new GPL will not be loaded onto other cards and no other GPLs are being updated, then this procedure is finished.
Figure 3-2 Updating the Signaling Link and Data Link GPLs
Sheet 1 of 5
Sheet 2 of 5
Sheet 3 of 5
Sheet 4 of 5
Sheet 5 of 5
Updating the Service GPLs
This procedure is used to update these GPLs: GLS, SCCPHC, and IPSHC. These names are used as the value of the gpl parameter of the chg-gpl, act-gpl, rept-stat-gpl, and rtrv-gpl commands.
These GPLs are assigned to the card types shown in Table 3-2.
Table 3-2 Service GPL Card Types
GPL Card Type
sccphc dsm (these cards must be E5-SM4G/E5-SM8G cards)
iphsc ipsm (these cards must be E5-ENET-B or SLIC cards)
glshc tsm (these cards must be E5-TSM cards)
The card types shown in Table 3-2 are the values used for the type parameter of the ent-card command.
If the GPL is being updated to a new version, a removable cartridge containing the GPL being updated is required.
    rlghncxa03w 09-03-01 15:25:40 GMT  EAGLE5 40.1.0
    FD CRNT Y       39                        Y       39
  4. Display the GPLs on the fixed disk and on the removable cartridge using the rtrv-gpl command with the gpl parameter value equal to the GPL being updated. These are examples of the possible output.
    rtrv-gpl:gpl=vsccp
    rlghncxa03w 09-03-01 11:34:04 GMT  EAGLE5 40.1.0
    GPL Auditing  ON
    VSCCP     1114  132-002-000  132-002-000      132-001-000  132-003-000
    VSCCP     1116  132-002-000  132-002-000      132-001-000  132-003-000
    VSCCP     1115  -----------  -----------      -----------  -----------
  5. Change the GPLs, using the chg-gpl command and specifying the value for the trial GPL shown in the REMOVE TRIAL column in the output of the rtrv-gpl command.
    chg-gpl:gpl=vsccp:ver=132-003-000
    rlghncxa03w 09-03-01  11:43:04  GMT  EAGLE5 40.1.0
    GPL Auditing  ON
    VSCCP upload on 1114 completed
    VSCCP upload on 1116 completed
    act-gpl:gpl=vsccp:ver=132-003-000
    rlghncxa03w 09-03-01 06:54:39 GMT EAGLE5 40.1.0
    VSCCP activate on 1114 completed
    VSCCP activate on 1116 completed
    rtrv-gpl:gpl=vsccp
    GPL Auditing  ON
    VSCCP     1114  132-003-000  132-003-000      132-002-000  132-003-000
    VSCCP     1116  132-003-000  132-003-000      132-002-000  -----------
    GPL Auditing  ON
    VSCCP     1116  132-003-000  132-003-000      132-002-000  132-003-000
    rept-stat-gpl:gpl=vsccp
    rlghncxa03w 09-03-01 11:40:26 GMT  EAGLE5 40.1.0
    VSCCP    1101   132-002-000 ALM   132-003-000   132-002-000
    VSCCP    1102   132-002-000 ALM   132-003-000   132-002-000
    VSCCP    1103   132-002-000 ALM   132-003-000   132-002-000
    Command Completed
    If the GLSHC GPL is being loaded onto the cards, continue the procedure with 16.
    If the GPL that is being loaded onto the card is not GLSHC, continue the procedure with 9.
  9. 10 through 15 are performed based on the GPL being updated (shown in the rept-stat-gpl output in 8).
    The following list shows the steps that are performed for the GPL being updated.
    • SCCPHC – Perform 10, then continue the procedure with 16.
    • MCP – Perform 11, then continue the procedure with 16.
    • IPSHC – Continue the procedure with 12.
  10. Display the status of the service modules by entering the rept-stat-sccp command.
    rlghncxa03w 09-03-01 09:57:31 GMT  EAGLE5 40.1.0
    CARD  VERSION      PST             SST        AST       MSU USAGE  CPU USAGE
    1101  132-002-001  IS-NR           Active     -----       47%         81%
    1102  132-002-001  IS-NR           Active     -----       34%         50%
    1103  132-002-001  IS-NR           Active     -----       21%         29%
    SCCP Service Average MSU Capacity = 36%       Average CPU Capacity = 56%
    Command Completed.
    Continue the procedure with 16.
    The rept-stat-sccp command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rept-stat-sccp command, see the rept-stat-sccp command description in Commands User's Guide.
  11. Display the status of the MCPMs in the database by entering the rept-stat-meas command.
    rlghncxa03w 09-03-01 16:43:42 GMT  EAGLE5 40.1.0
                          PST            SST       AST
    MEAS SS               IS-NR          Active    -----
        CARD   VERSION         TYPE    PST           SST        AST
        2107 P 132-002-000     EDSM    IS-NR         Active     -----
           IP Link A                   IS-NR         Active     Available
        2108   132-200-000     EDSM    IS-NR         Active     -----
        2111   132-002-000     EDSM    IS-NR         Active     -----
        CARD 2107 ALARM STATUS = No Alarms
        CARD 2108 ALARM STATUS = No Alarms
        CARD 2111 ALARM STATUS = No Alarms
  12. Display the status of the IPSMs (if the IPSHCGPL is being updated) using the rept-stat-card command and specifying the location of the card shown in the rept-stat-gpl output in 8.
    rept-stat-card:loc=2301
    rlghncxa03w 09-03-01 09:12:36 GMT  EAGLE5 40.1.0
    2301   132-001-000  IPSM      IPS        IS-NR          Active     -----
      BPDCM GPL          = 132-002-000
      IMT BUS A          = Conn
      IMT BUS B          = Conn
    Command Completed.
  13. Display the terminal configuration in the database with the rtrv-trm command.
    The IP terminals are shown by the terminal numbers 17 through 40. The rtrv-trm output shows the location of the IPSM associated with the IP terminals. This is an example of the possible output.
    rlghncxa03w 10-07-01 16:02:08 GMT EAGLE5 42.0.0
    17   TELNET    3101             60    5     00:30:00
    18   TELNET    3101             60    5     00:30:00
    19   TELNET    3101             60    5     00:30:00
    20   TELNET    3101             60    5     00:30:00
    21   TELNET    3101             60    5     00:30:00
    22   TELNET    3101             60    5     00:30:00
    23   TELNET    3101             60    5     00:30:00
    24   TELNET    3101             60    5     00:30:00
    25   TELNET    3105             60    5     00:30:00
    26   TELNET    3105             60    5     00:30:00
    27   TELNET    3105             60    5     00:30:00
    28   TELNET    3105             60    5     00:30:00
    39   TELNET    3105             60    5     00:30:00
    30   TELNET    3105             60    5     00:30:00
    31   TELNET    3105             60    5     00:30:00
    32   TELNET    3105             60    5     00:30:00
    33   TELNET    3111             60    5     00:30:00
    34   TELNET    3111             60    5     00:30:00
    35   TELNET    3111             60    5     00:30:00
    36   TELNET    3111             60    5     00:30:00
    37   TELNET    3111             60    5     00:30:00
    38   TELNET    3111             60    5     00:30:00
    39   TELNET    3111             60    5     00:30:00
    40   TELNET    3111             60    5     00:30:00
  14. Display the status of the terminals with the rept-stat-trm command.
    rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0
    TRM   PST           SST           AST
    2     IS-NR         Active        -----
    3     IS-NR         Active        -----
    4     IS-NR         Active        -----
    5     IS-NR         Active        -----
    6     IS-NR         Active        -----
    9     IS-NR         Active        -----
    10    IS-NR         Active        -----
    11    IS-NR         Active        -----
    12    IS-NR         Active        -----
    13    IS-NR         Active        -----
    14    IS-NR         Active        -----
    15    IS-NR         Active        -----
    16    IS-NR         Active        -----
    17    IS-NR         Active        -----
    19    IS-NR         Active        -----
    20    IS-NR         Active        -----
    21    IS-NR         Active        -----
    22    IS-NR         Active        -----
    23    IS-NR         Active        -----
    24    IS-NR         Active        -----
    25    IS-NR         Active        -----
    26    IS-NR         Active        -----
    28    IS-NR         Active        -----
    29    IS-NR         Active        -----
    30    IS-NR         Active        -----
    31    IS-NR         Active        -----
    32    IS-NR         Active        -----
    33    IS-NR         Active        -----
    34    IS-NR         Active        -----
    35    IS-NR         Active        -----
    36    IS-NR         Active        -----
    37    IS-NR         Active        -----
    38    IS-NR         Active        -----
    39    IS-NR         Active        -----
    40    IS-NR         Active        -----
    Command Completed.
  15. Place the terminals associated with the IPSM that will be updated with the new IPSHCGPL out of service using the rmv-trm command.
    If the last in service SEAS terminal is assigned to the card containing the terminals that are being inhibited in this step, the force=yes parameter must be specified for that terminal.
    rmv-trm:trm=17
    rmv-trm:trm=18
    rmv-trm:trm=19
    rmv-trm:trm=20
    rmv-trm:trm=21
    rmv-trm:trm=22
    rmv-trm:trm=23
    rmv-trm:trm=24
    Caution:
    Placing these terminals out of service will disable any sessions running on these terminals.
    If the status of any of the terminals shown in the PST field in 14 is OOS-MT-DSBLD (out-of-service maintenance disabled), that terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
    Command Completed.
  16. The card that the new version of the GPL will be loaded onto must be out of service.
    Place the card, selected from the outputs of 8, 10, 11, or 12, out of service using the rmv-card command. If there is only one of these cards running these GPLs in service (GLSHC), the force=yes parameter must be specified with the rmv-card command.
    rmv-card:loc=1101
    Caution:
    Do not place all the cards running the same GPL in the EAGLE out of service at the same time. Doing so will cause all traffic carried by these cards to be lost and disable the feature associated with these cards.
    Caution:
    If there is only one in service card running the GPL being updated in the EAGLE, placing the card out of service will cause the traffic carried by this card to be lost and disable the feature associated with this card.
    rlghncxa03w 09-03-01  11:11:28 GMT  EAGLE5 40.1.0
  17. Put the card that was inhibited in 16 back into service using the rst-card command.
    rst-card:loc=1101
  18. Verify the GPLs on the cards using the rept-stat-gpl command with the gpl parameter value equal to the gpl parameter value specified in 8.
    VSCCP    1101   132-003-000       132-003-000   132-002-000
    Command Completed
    If the IPSHC GPL is not being updated in this procedure, continue the procedure with 21.
  19. Put the terminals that were placed out of service in 15 back into service using the rst-trm command.
    rst-trm:trm=17
    rst-trm:trm=18
    rst-trm:trm=19
    rst-trm:trm=20
    rst-trm:trm=21
    rst-trm:trm=22
    rst-trm:trm=23
    rst-trm:trm=24
    Command Completed.
  20. Verify that the terminals are in service with the rept-stat-trm command.
    TRM   PST           SST           AST
    Command Completed.
  21. Continue the procedure by performing these actions.
    When the E5-based control cards are installed in the EAGLE, continue the procedure by performing one of these actions.
    • If you wish to load the new GPL onto the other cards shown in 8, repeat this procedure from 9 for each card shown in 8.
Figure 3-3 Updating the Service GPLs
Sheet 1 of 7
Sheet 2 of 7
Sheet 3 of 7
Sheet 4 of 7
Sheet 5 of 7
Sheet 6 of 7
Sheet 7 of 7
Updating the Flash GPLs
This procedure is used to update GPLs: The GPLs are used as the value of the gpl parameter of the chg-gpl, act-gpl, rept-stat-gpl, and rtrv-gpl commands.
Table 3-3 EAGLE Card Applications and GPLs
Intended Application GPL Card configuration (rtrv-card) Hardware Type Used Required Flash GPL
APPL Type
SCCP64 VSCCP DSM SM8G-B BLDC64
VSCCP DSM/SLIC SLIC BLSLC64
IPSG IPSG ENET/ENETB E5-ENET-B BLMCAP
IPSG ENET/ENETB/SLIC SLIC BLSLC32
IPSG32 IPSG SLIC SLIC BLSLC32
IPSHC69 IPS IPSM E5-ENET-B BLDC32
IPS IPSM SLIC BLSL932
MCPHC69 MCP MCPM E5-MCPM-B BLDC32
MCP MCPM SLIC BLSL932
OAMHC69 OAM E5-MCAP E5-MASP BLDC32
SIP64 SIPHC DSM SM8G-B BLDC64
SIPHC DSM/SLIC SLIC BLSLC64
DEIR64 DEIRHC DSM SM8G-B BLDC64
DEIRHC DSM/SLIC SLIC BLSLC64
ENUM64 ENUMHC DSM SM8G-B BLDC64
ENUMHC DSM/SLIC SLIC BLSLC64
SFAPP SFAPP SLIC SLIC BLSLC64
ATMHC ATMITU LIME1ATM E5-ATM-B BLMCAP
ATMANSI LIMATM E5-ATM-B BLMCAP
ERTHC EROUTE STC E5-ENET-B BLMCAP
EROUTE STC SLIC BLSLC32
SS7HC CCS7ITU LIME1 E5-E1T1-B BLMCAP
SLIC BLSLC32
SS7ANSI LIMT1 E5-E1T1-B BLMCAP
SLIC BLSLC32
Updating the BLMCAP GPL for the E5-MASPs is not covered in this procedure. To update the OAMHC GPLs, perform Updating the BLMCAP and OAMHC GPLs .
If the GPL is being updated to a new version, removable media containing the GPL being updated is required.
    If removable media is installed in both E5-MASPs, continue the procedure with 5.
            E5-MASP 1114 ( STDBY)                 E5-MASP 1116 ( ACTV )
    FD CRNT Y       39                        Y       39
            MCAP 1113                         MCAP 1115
    If removable media is installed in the active MASP, continue the procedure with 5.
    If removable media is not installed in the active MASP, insert the removable media in the removable media drive in the active MASP. For more information about inserting removable media in the removable media drive, refer to Removable USB Drive. After the removable media has been inserted in the removable media drive in the active MASP, continue the procedure with 5.
  4. Determine the flash GPL for the card location by entering the rtrv-card:loc<xxxx> command:
    rtrv-card:loc=1203
        eagle1 18-02-20 11:27:40 EST  EAGLE 46.6.0.0.0-73.13.0
        rtrv-card:loc=1203
        Command entered at terminal #13.
        CARD   TYPE      APPL      DATA    LSET NAME   LINK SLC LSET NAME   LINK SLC
        1203   LIME1     CCS7ITU           mgtsitu     A    0
    followed by the rtrv-bip:loc<xxxx> command:
    rtrv-bip:loc=1203
        eagle1 18-02-20 11:27:49 EST  EAGLE 46.6.0.0.0-73.13.0
        rtrv-bip:loc=1203
        Part Number:    7094646
        Revision:       17                         Week/Year:        15/2017
        Serial Number:  10217152084
        Software Match ID:   EG - 001              Max Power Rating :  826mA
        END OF REPORT
    View the table in the EAGLE Card Applications and GPLs table in order to determine the appropriate GPL for the location.
  5. Display the flash GPLs on the fixed disk and on the removable media using the rtrv-gpl command with the gpl parameter value equal to the flash GPL being updated. For this example, enter this command.
    rtrv-gpl:gpl=xxxx
    This is an example of the possible output:
    tekelecstp 18-01-18 21:23:11 EST  EAGLE 46.5.1.5.0-73.10.0
    GPL Auditing  ON
    BLMCAP    1114  143-010-000  143-010-000      143-010-000  -----------
    BLMCAP    1116  143-010-000  143-010-000      143-010-000  -----------
    If the version of the flash GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP.
    Insert the removable media that contains the flash GPL that is being updated into the removable media drive in the active MASP and repeat this step.
    If the version of the flash GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is the version that is to be loaded onto the cards, continue the procedure with 6.
  6. Change the flash GPLs, using the chg-gpl command and specifying the value for the flash GPL shown in the REMOVE TRIAL column in the output of the rtrv-gpl command.
    chg-gpl:gpl=blmcap:ver=002-003-000
    GPL Auditing  ON
    BLMCAP upload on 1114 completed
    BLMCAP upload on 1116 completed
  7. Activate the trial flash GPL, using the act-gpl command and specifying the name and version of the trial flash GPL specified in 6.
    act-gpl:gpl=blmcap:ver=002-003-000
  8. Verify that the flash GPL on the or removable media is the approved flash GPL on the fixed disk using the rtrv-gpl command with the gpl parameter value specified in 7.
    rtrv-gpl:gpl=blmcap
    GPL Auditing  ON
  9. Display the status of the card, shown in the rept-stat-gpl output, that the flash GPL will be loaded onto using the rept-stat-card command and specifying the location of the card.
    rept-stat-card:loc=2105
  10. rtrv-card
  11. Display the signaling links associated with the card shown in 9.
    Enter the rtrv-slk command with the card location specified in 9. This is an example of the possible output.
    rlghncxa03w 09-07-01 21:16:37 GMT  EAGLE5 41.1.0
                                       L2T               PCR  PCR
    1201 A    lsn1201a     0  LIMDS0   1   56000   BASIC ---  -----
    1201 B    lsn1201b     0  LIMDS0   1   56000   BASIC ---  -----
    1201 A1   lsn1201a     1  LIMDS0   1   56000   BASIC ---  -----
    1201 B1   lsn1201b     1  LIMDS0   1   56000   BASIC —  -----
  12. Deactivate the SS7 signaling links on the card using the dact-slk command.
    Caution:
    These command examples place the SS7 signaling links on card 1201 out of service. This will interrupt service on the SS7 signaling links on card 1201 and allow the approved flash GPL to be loaded on to card 1201.
    Caution:
    Do not deactivate all the SS7 signaling links in the EAGLE at the same time. Doing so will take all the SS7signaling links out of service and isolate the EAGLE from the network.
    Continue the procedure with 22.
  13. Display the TCP/IP data links, and their status, associated with the cards.
    rlghncxa03w 06-10-01 17:00:36 GMT  EAGLE5 36.0.0
    DLK    PST           SST        AST
    1303   IS-NR         Avail      ---
    2101   IS-NR         Avail      ---
    2103   IS-NR         Avail      ---
    Command Completed.
  14. Deactivate the TCP/IP data link on the card that you wish to load the flash GPL onto, shown in 13, using the canc-dlk command.
    canc-dlk:loc=2105
    Caution:
    This command example places the TCP/IP data link on card 2105 out of service. This will interrupt service on the TCP/IP data link on card 2105 and allow the trial flash GPL to be loaded on to card 2105.
    rlghncxa03w 06-10-01 11:45:18 GMT  EAGLE5 36.0.0
    Command Completed.
  15. Display the status of the service modules by entering the rept-stat-sccp command.
    rlghncxa03w 06-10-01 09:57:31 GMT  EAGLE5 36.0.0
    2311  132-002-001  IS-NR           Active     -----       47%         81%
    3101  132-002-001  IS-NR           Active     -----       34%         50%
    3103  132-002-001  IS-NR           Active     -----       21%         29%
    SCCP Service Average MSU Capacity = 34%       Average CPU Capacity = 54%
    Command Completed.
  16. Display the status of the MCPMs in the database with the rept-stat-meas command.
    rlghncxa03w 09-02-01 16:43:42 GMT  EAGLE5 40.0.0
                          PST            SST       AST
        2108   132-002-000     EDSM    IS-NR         Active     -----
  17. To load the BLMCAP GPL on the E5-MASP, it must be loaded on the standby MASP (E5-MASP) first.
    rlghncxa03w 06-10-01 16:07:48 GMT EAGLE5 36.0.0
    FD BKUP Y 35 05-03-01 10:19:18 GMT Y 35 05-03-01 10:19:18 GMT
    FD CRNT Y 106 Y 106
    E5-MDAL 1117
    RD BKUP Y 106 05-02-31 20:27:53 GMT
    The output of the rept-stat-db command shows which MASP is active with the indicator (ACTV) following the E5-MASP card location. The indicator (STDBY) following the E5-MASP card location shows which MASP is standby.
    For this example, the MASP associated with E5-MASP 1116 is active and the MASP associated with E5-MASP 1114 is standby.
  18. Display the terminal configuration in the database with the rtrv-trm command.
    If the application GPL running on the card is IPS, the Telnet terminals associated with the card shown in 9 must be taken out of service. The Telnet terminals are shown in the output with the entry TELNET in the TYPE field.
    This is an example of the possible output. In this example, the SEAS terminals are terminals 27 and 36. The Telnet terminals that must be taken out of service are terminals 17 to 24.
    7    PRINTER  9600-7-N–2  HW    30    5     00:30:00
    15   VT320    9600-7-N–2  HW    30    5     00:30:00
    TRM  TYPE      LOC              TMOUT MXINV DURAL      SECURE
    17   TELNET    1201             60    5     00:30:00   yes
    18   TELNET    1201             60    5     00:30:00   yes
    19   TELNET    1201             60    5     00:30:00   yes
    20   TELNET    1201             60    5     00:30:00   yes
    21   TELNET    1201             60    5     00:30:00   yes
    22   TELNET    1201             60    5     00:30:00   yes
    23   TELNET    1201             60    5     00:30:00   yes
    24   TELNET    1201             60    5     00:30:00   yes
    25   TELNET    1203             60    5     00:30:00   yes
    26   TELNET    1203             60    5     00:30:00   yes
    27   SEAS      1203             60    5     00:30:00   yes
    28   TELNET    1203             60    5     00:30:00   yes
    29   TELNET    1203             60    5     00:30:00   yes
    30   TELNET    1203             60    5     00:30:00   yes
    31   TELNET    1203             60    5     00:30:00   yes
    32   TELNET    1203             60    5     00:30:00   yes
    33   TELNET    1205             60    5     00:30:00   yes
    34   TELNET    1205             60    5     00:30:00   yes
    35   TELNET    1205             60    5     00:30:00   yes
    36   SEAS      1205             60    5     00:30:00   yes
    37   TELNET    1205             60    5     00:30:00   yes
    38   TELNET    1205             60    5     00:30:00   yes
    39   TELNET    1205             60    5     00:30:00   yes
    40   TELNET    1205             60    5     00:30:00   yes
  19. Display the status of the terminals with the rept-stat-trm command.
    rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0
    TRM   PST           SST           AST
    Command Completed.
  20. Place the required terminals out of service using the rmv-trm command.
    To place the SEAS terminals out of service in this example, enter these commands.
    rmv-trm:trm=27
    rmv-trm:trm=36:force=yes
    Caution:
    Placing the SEAS terminals out of service will disable the SEAS feature on the EAGLE.
    To place the Telnet terminals out of service in this example, enter these commands.
    rmv-trm:trm=17
    rmv-trm:trm=18
    rmv-trm:trm=19
    rmv-trm:trm=20
    rmv-trm:trm=21
    rmv-trm:trm=22
    rmv-trm:trm=23
    rmv-trm:trm=24
    Caution:
    Placing the Telnet terminals out of service will disable any Telnet sessions running on these terminals.
    If the status of any of the terminals shown in the PST field in 19 is OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
    Command Completed.
    • 21 is performed only if the SEAS terminals were placed out of service in this step. If the SEAS terminals were not placed out of service in this step, continue the procedure with 22.
    • If the SEAS terminals were placed out of service in this step, continue the procedure with 21.
  21. Change the terminal type of the SEAS terminals to NONE with the chg-trm command, the type=none parameter, and with the values of the SEAS terminals used in 20.
    chg-trm:trm=36:type=none
    rlghncxa03w 06-10-01  11:11:28 GMT  EAGLE5 36.0.0
  22. Place the card shown in 9 out of service using the rmv-card command.
    Caution:
    Multiple cards running the same flash GPL can be updated at the same time with the init-flash command (25). This requires that the cards in the locations specified with the init-flash command in 25 are out of service. All the cards running one of these application GPLs (OAMHC or BLMCAP ) can be placed out of service. However, it is recommended that only some of the cards running a specific application GPL are placed out of service. Placing all the cards running a specific application GPL out of service will cause the traffic carried by these cards to be lost and disable the features supported by these cards.
    Caution:
    If the EOAM GPL is being updated, the card being placed out of service must be the E5-MASP associated with the standby MASP. Both cards running the EOAM GPL cannot be placed out of service at the same time.
    Caution:
    If there is only one card running these application GPLs (OAMHC or BLMCAP), shown in the GPL column in the rept-stat-card output in 9, in the EAGLE, placing the card out of service will cause the traffic carried by this card to be lost and disable the feature that this card supports.
    rmv-card:loc=2105
    If more than one card running the same flash GPL is to be updated in 25, repeat this step for those cards.
    If the card is running the OAMHC or BLMCAP application GPLs, and the card contains the last signaling link in a linkset, the force=yes parameter must be specified.
    If you do not wish to reload the TDM clock LCA bitfile, continue the procedure with 25.
  23. Verify the status of the high-speed clocks by entering the rept-stat-clk command.
    rlghncxa03w 08-06-01 11:34:04 GMT  EAGLE5 39.0.0
    COMPOSITE                              PST           SST       AST
        SYSTEM CLOCK                       IS-NR         Active    -----
        Primary Comp Clk 1114   (CLK A)    IS-NR         Active    -----
        Primary Comp Clk 1116   (CLK B)    IS-NR         Active    -----
        Secondary Comp Clk 1114 (CLK A)    IS-NR         Idle      -----
        Secondary Comp Clk 1116 (CLK B)    IS-NR         Idle      -----
    Clock      Using         Bad
    CLK A        9            0
    CLK B        0            0
    CLK I        0            --
    HIGH SPEED                             PST           SST       AST
        SYSTEM CLOCK                       IS-NR         Idle      -----
        Primary HS Clk 1114    (HS CLK A)  IS-NR         Active    -----
        Primary HS Clk 1116    (HS CLK B)  IS-NR         Active    -----
        Secondary HS Clk 1114  (HS CLK A)  IS-NR         Idle      -----
        Secondary HS Clk 1116  (HS CLK B)  IS-NR         Idle      -----
    HS CLK TYPE 1114     = RS422
    HS CLK LINELEN 1114  = LONGHAUL
    HS CLK TYPE 1116     = RS422
    HS CLK LINELEN 1116  = LONGHAUL
    Clock      Using         Bad
    HS CLK A     2            0
    HS CLK B     0            0
    HS CLK I     0            --
    Command Completed
    If the rept-stat-clk output does not show any high-speed clocks (HIGH SPEED SYSTEM CLOCK, Primary HS Clk, Secondary HS Clk, HS CLK TYPE, and HS CLK LINELEN fields), the EAGLE does not contain any cards that are capable of using high-speed source timing.
    If the HS CLK TYPE and HS CLK LINELEN values are set to the system default values (HS CLK TYPE = RS422 and HS CLK LINELEN = LONGHAUL), continue the procedure with 25.
  24. Visually verify the part numbers of both E5-OAMs in the EAGLE.
    To load the E5-OAM clock LCA bitfile, the part numbers of both E5-OAMs must be either an E5-MDAL or E5-MASP.
    Proceed to 26.
  25. Load the flash GPL onto the card inhibited in 22 using the init-flash command with the code=appr parameter to load the approved version of the flash GPL onto the card.
    Caution:
    The init-flash command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed.
    init-flash:code=appr:loc=2105
        FLASH Memory Downloading for card 2105 Started.
        BPHCAP Downloading for card 2105 Complete.
        Command Completed.
    Caution:
    If reloading the clock LCA bitfile would cause a system clock outage, the force=yes parameter must be used with the init-flash command. A system clock outage can be caused by either the EAGLE having only one E5-OAM (a simplex MASP configuration) or if the status of the high-speed clocks, shown in the rept-stat-clk output in 23, on the TDM which is not being reset is Fault. A system clock outage will result in a loss of traffic on some or all signaling links.
    The following command example loads the flash GPL onto the E5-OAM card and reloads the clock LCA bitfile.
    init-flash:initclk=yes:loc=1113:code=appr
        FLASH Memory Download for card 1113 Started.
        FLASH Memory Download for card 1113 Completed.
    Updating more than One Card at the Same Time
    If more than one card running the same flash GPL is being updated, enter the init-flash command with these parameters along with the code=appr parameter:
    sloc – the first card location in the range of card locations
    eloc – the last card location in the range of card locations
    gpl – the flash GPL being updated
    The sloc, eloc, and gpl parameters cannot be specified with the loc parameter. When the sloc, eloc, and gpl parameters are specified, only the cards running the flash GPL specified by the gpl parameter and within the range specified by the sloc and eloc parameters are updated. All other cards in the range specified by the sloc and eloc parameters are skipped.
    Entering this example command will update the cards in the locations 1101 to 2115 running the OAMHC flash GPL with the approved version of the OAMHC GPL.
    init-flash:code=appr:sloc=1101:eloc=2115:gpl=blmcap
        FLASH Memory Download for cards 1101 - 2115 Started.
        FLASH Memory Download for cards 1101 - 2115 Completed.
        LOC 1101 : PASSED
        LOC 1102 : PASSED
        LOC 1112 : PASSED
        LOC 2105 : PASSED
        LOC 2107 : PASSED
        LOC 2111 : PASSED
        LOC 2112 : PASSED
        LOC 2115 : PASSED
        ALL CARD RESULTS PASSED
        Command Completed.
    When the init-flash command has completed successfully, the card specified in the init-flash command is rebooted.
  26. Put the cards that were inhibited in 22 back into service using the alw-card command.
    For this example, enter this command:
    alw-card:loc=2105
  27. Verify that the flash GPL from 25 has loaded and that the card has returned to its in-service normal (IS-NR) state using the rept-stat-card command.
    If the version number of the OAMHC GPL shown in the rept-stat-card command output is different than the version specified in 9, contact the Customer Care Center. Refer to My Oracle Support (MOS) for the contact information.
  28. Activate the approved flash GPL loaded onto the cards in 25 using the act-flash command.
    Caution:
    The act-flash command cannot be entered if the Extended Bit Error Rate Test (BERT) is being performed.
    act-flash:loc=2105
        FLASH Memory Activation for card 2105 Completed.
        Command Completed.
    Activating more than One Card at the Same Time
    If more than one card running the same flash GPL was updated in 25, enter the act-flash command with these parameters:
    gpl – the flash GPL being activated
    Entering this example command will activate the flash GPLs on the cards in the locations 1101 to 2115.
    act-flash:sloc=1101:eloc=2115:gpl=blmcap
        FLASH Memory Activation for cards 1101 - 2115 Started.
        FLASH Memory Activation for cards 1101 - 2115 Completed.
        LOC 1101 : PASSED
        LOC 1102 : PASSED
        LOC 1112 : PASSED
        LOC 2105 : PASSED
        LOC 2107 : PASSED
        LOC 2111 : PASSED
        LOC 2112 : PASSED
        LOC 2115 : PASSED
        Command Completed.
  29. Verify the flash GPLs on the cards using the rept-stat-gpl command with the gpl parameter value specified in 7.
    If any card is not running the release version of the flash GPL, shown in the RELEASE column of the rtrv-gpl output in 8, the indicator ALM is displayed next to the flash GPL version in the RUNNING column of the rept-stat-gpl output. For this example, enter this command.
    rlghncxa03w 06-10-01 11:40:26 GMT  EAGLE5 46.3.0
    GPL      CARD   RUNNING           APPROVED      TRIAL
    OAMHC    1113   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    1115   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    1303   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    1307   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2101   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2103   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2105   132-003-000       132-003-000   132-002-000
    OAMHC    2113   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2205   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2207   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2213   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2301   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2303   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2305   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2307   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    2311   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    3101   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    3103   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    3105   132-002-000 ALM   132-003-000   132-002-000
    OAMHC    3107   132-002-000 ALM   132-003-000   132-002-000
    Command Completed
    If the flash GPL being displayed by the rept-stat-gpl command is the OAMHC GPL, the output of the rept-stat-gpl command will show any E5-OAM cards that are inserted in the EAGLE, whether they are configured in the database or not.
    If the card’s application GPL, shown in the rept-stat-card output in 9, is OAMHC or BLMCAP perform 30 and 31, then go to 38. Skip 32 through 37.
  30. Place the signaling links that were deactivated in 12 back into service using the act-slk command.
    rlghncxa03w 06-10-01 11:55:49 GMT  EAGLE5 36.0.0
  31. Verify that the signaling links activated in 30 are back in service using the rept-stat-slk command with the card location and signaling link.
    rlghncxa03w 06-10-01 13:06:25 GMT EAGLE5 36.0.0
      UNAVAIL REASON     = --
      UNAVAIL REASON     = --
      UNAVAIL REASON     = --
      UNAVAIL REASON     = --
    Command Completed.
  32. Place the TCP/IP data link that was deactivated in 14 back into service using the act-dlk command.
    act-dlk:loc=2105
  33. Verify that the TCP/IP data links activated in 32 are back in service with the rept-stat-dlk command.
    DLK    PST           SST        AST
    If the application GPL running on the card is not EOAM, continue the procedure with 38.
    If the application GPL running on the card is IPS, perform 36 and 37, then go to 38. Skip 34 and 35.
  34. If you wish to load the new GPL onto the E5-OAM card making up the active MASP, enter the init-card command specifying the location of the E5-OAM card making up active MASP.
    After the init-card command has completed, repeat this procedure from 22, specifying the card location used in the init-card command.
    If you did not wish to load the new version of the OAMHC GPL onto the other E5-OAM card running the EOAM application, continue this procedure with either 35 or 38 based on the following conditions:
    • If SEAS terminals were not shown in the rtrv-trm command output in 18, continue the procedure with 38.
    • If SEAS terminals were shown in the rtrv-trm command output in 18, continue the procedure with 35.
  35. Change the terminal type of the terminals that were changed to NONE in 21 to the terminal type SEAS with the chg-trm command and the type=seas parameter.
    The terminal type is shown in the TYPE field in the rtrv-trm command output in 18.
    chg-trm:trm=36:type=seas
  36. Put the required terminals back into service with the rst-trm command.
    rst-trm:trm=27
    rst-trm:trm=36
    If Telnet terminals were placed out of service in 20, for this example, enter these commands.
    rst-trm:trm=17
    rst-trm:trm=18
    rst-trm:trm=19
    rst-trm:trm=20
    rst-trm:trm=21
    rst-trm:trm=22
    rst-trm:trm=23
    rst-trm:trm=24
    Command Completed.
  37. Verify that the terminals are in service with the rept-stat-trm command.
    TRM   PST           SST           AST
    Command Completed.
  38. Continue the procedure by performing these actions.
    If E5-based control cards are installed in the EAGLE, continue the procedure by performing one of these actions.
    • If the GPL will be loaded onto other cards, repeat this procedure from 8.
    • If the GPL will not be loaded onto other cards, but other flash GPLs will be updated, repeat this procedure from 1.
    • If the GPL will not be loaded onto other cards, and other flash GPLs will not be updated, this procedure is finished.
Figure 3-4 Updating the Flash GPLs
Sheet 1 of 10
Sheet 2 of 10
Sheet 3 of 10
Sheet 4 of 10
Sheet 5 of 10
Sheet 6 of 10
Sheet 7 of 10
Sheet 8 of 10
Sheet 9 of 10
Sheet 10 of 10
Updating the HIPR2 GPL
This section presents the procedure for updating the HIPR2 generic program load (GPL). The HIPR2 GPL is used by the High-Speed IMT Packet Router 2 (HIPR2) card to control the IMT bus and resides on the fixed disk. The HIPR2 card resides only in slots 9 and 10 in each shelf in the EAGLE.
This section presents the procedure for loading the HIPR2 GPL onto the EAGLE as a trial version from a removable media, then making the trial version of the HIPR2 GPL the approved version.
If any card is not running the approved version of the GPL shown in the RELEASE column of the rtrv-gpl output, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output, and next to the GPL version in the APPROVED column in the rtrv-gpl output.
The removable media that contains the HIPR2 GPL to be loaded on to the EAGLE is required.
    rlghncxa03w 09-07-01 15:25:40 GMT  EAGLE5 41.1.0
    FD BKUP Y       36 09-06-19 09:38:25 GMT  Y       36 09-06-19 09:38:25 GMT
    FD CRNT Y       39                        Y       39
            MCAP 1113                         MCAP 1115
    RD BKUP -    -         -        -         Y       36 09-06-19 09:27:17 GMT
    USB BKP -    -         -        -         Y        3 09-06-07 01:11:22 GMT
  4. Display the HIPR2 GPLs on the fixed disk and on the removable media using the rtrv-gpl:gpl=hipr2 command.
    rlghncxa03w 09-07-01 11:34:04 GMT  EAGLE5 41.1.0
    GPL Auditing  ON
    GPL       CARD  RELEASE      APPROVED         TRIAL        REMOVE TRIAL
    HIPR2     1114  132-002-000  132-002-000      132-001-000  132-003-000
    HIPR2     1116  132-002-000  132-002-000      132-001-000  132-003-000
    HIPR2     1115  -----------  -----------      -----------  -----------
    If the version of the HIPR2 GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP.
    Insert the removable media that contains the HIPR2 GPL that is being updated into the removable media drive in the active MASP and repeat this step.
    If the version of the HIPR2 GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is the version that is to be loaded onto the cards, continue the procedure with 5.
  5. Change the GPLs, using the chg-gpl command and specifying the value for the trial HIPR2 GPL shown in the REMOVE TRIAL column in the output of the rtrv-gpl command used in 4.
    chg-gpl:gpl=hipr2:ver=132-003-000
    rlghncxa03w 09-07-01  11:43:04  GMT  EAGLE5 41.1.0
    GPL Auditing  ON
    HIPR2 upload on 1114 completed
    HIPR2 upload on 1116 completed
    If you wish to leave the HIPR2 cards running the trial version of the HIPR2 GPL, continue the procedure with 8.
  6. Activate the trial GPL, using the act-gpl command and specifying the value for the trial HIPR2 GPL shown in 5.
    act-gpl:gpl=hipr2:ver=132-003-000
    rlghncxa03w 09-07-01 06:54:39 GMT EAGLE5 41.1.0
    HIPR2 activate on 1114 completed
    HIPR2 activate on 1116 completed
  7. Verify that the HIPR2 GPL on the removable media is the approved GPL on the fixed disk using the rtrv-gpl:gpl=hipr2 command.
    GPL Auditing  ON
    HIPR2     1114  132-003-000  132-003-000      132-002-000  132-003-000
    HIPR2     1116  132-003-000  132-003-000      132-002-000  -----------
    GPL Auditing  ON
    HIPR2     1116  132-003-000  132-003-000      132-002-000  132-003-000
  8. Verify the HIPR2 GPLs on the fixed disk and the cards that are running the HIPR2 GPLs using the rept-stat-gpl:gpl=hipr2 command.
    rlghncxa03w 09-07-01 11:40:26 GMT  EAGLE5 41.1.0
    HIPR2    1109   132-002-000 ALM   132-003-000   132-002-000
    HIPR2    1110   132-002-000 ALM   132-003-000   132-002-000
    HIPR2    1209   132-002-000 ALM   132-003-000   132-002-000
    HIPR2    1210   132-002-000 ALM   132-003-000   132-002-000
    HIPR2    1309   132-002-000 ALM   132-003-000   132-002-000
    HIPR2    1310   132-002-000 ALM   132-003-000   132-002-000
    HIPR2    2109   132-002-000 ALM   132-003-000   132-002-000
    HIPR2    2110   132-002-000 ALM   132-003-000   132-002-000
    Command Completed
  9. Load the approved HIPR2 GPL onto a card selected from the cards shown in 8 using the init-flash:code=appr command.
    Caution:
    init-flash:code=appr:loc=1109
        rlghncxa03w 09-07-01  11:11:28 GMT  EAGLE5 41.1.0
        FLASH Memory Downloading for card 1109 Started.
        HIPR2 Downloading for card 1109 Complete.
        Command Completed.
    Updating more than One HIPR2 Card at the Same Time
    Multiple HIPR2 cards can be updated at the same time with the init-flash command. The multiple HIPR2 cards being updated must be on the same IMT bus. Specifying card locations XX09 for the sloc and eloc parameters specifies the HIPR2 cards on IMT bus A. Specifying card locations XX10 for the sloc and eloc parameters specifies the HIPR2 cards on IMT bus B.
    To update more than one HIPR2 card on the same IMT bus, enter the init-flash command with these parameters along with the code=appr parameter:
    gpl – hipr2
    For example, to update the HIPR2 cards on IMT Bus B shown in 8 with the approved version of the HIPR2 GPL, enter this command.
    init-flash:code=appr:sloc=1110:eloc=2110:gpl=hipr2
    To update the HIPR2 cards on IMT bus A shown in 8, the sloc=1109 and eloc=2109 parameters would be specified with the init-flash command.
        FLASH Memory Download for cards 1110 - 2110 Started.
        rlghncxa03w 09-07-01 13:07:15 GMT EAGLE5 41.1.0
        FLASH Memory Download for cards 1110 - 2110 Completed.
        LOC 1110 : PASSED
        LOC 1210 : PASSED
        LOC 1310 : PASSED
        LOC 2110 : PASSED
        Command Completed.
  10. Re-initialize the HIPR2 cards specified in 9 using the init-mux command with the loc parameter.
    Caution:
    The init-mux command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed.
    init-mux:loc=1109
    If more than one HMUX card was specified in 9, re-initialize the IMT bus containing the cards specified in 9 by entering init-mux command and specifying the IMT bus (the bus parameter) containing the cards specified in 9. Specifying card locations XX09 for the sloc and eloc parameters in 9 requires that IMT bus A is re-initialized. Specifying card locations XX10 for the sloc and eloc parameters in 9 requires that IMT bus B is re-initialized.
    init-mux:bus=a
    Command Completed.
    Executing this command produces two alarms: 0002 - Card is not running approved GPL, indicating that the version of the HIPR2 GPL running on the card is not the approved version, and 0004 - Card is running non-activated GPL, indicating that the new version of the HIPR2 GPL running on the card has not been activated.
  11. Verify that the approved HIPR2 GPL from 10 has loaded and that the state of the card is in-service normal (IS-NR) state using the rept-stat-card command.
    If more than one card was specified in 9 and 10, enter the rept-stat-card command for each specified card. For this example, enter this command.
    rept-stat-card:loc=1109:mode=full
    1109   132-003-000  HIPR2     HIPR2      IS-NR          Active     -----
      TRIAL  VERSION     = 132-003-000
      FPGA VERSION       = 022-005
    Command Completed.
    If the version number of the HIPR2 GPL shown in the rept-stat-card command output is different than the version specified5 in, contact the Customer Care Center. Refer to My Oracle Support (MOS) for the contact information.
  12. Activate the approved HIPR2 GPL loaded onto the card in 9 using the act-flash command.
    Caution:
    act-flash:loc=1109
        FLASH Memory Activation for card 1109 Completed.
        Command Completed.
    Activating the HIPR2 GPL on more than One HIPR2 card at the Same Time
    If more than one HIPR2 card was specified in 9, enter the act-flash command with these parameters:
    gpl – hipr2
    For example, to activate the HIPR2 GPL on the HIPR2 cards on IMT Bus B shown in 8 with the trial version of the HIPR2 GPL, enter this command.
    act-flash:sloc=1110:eloc=2110:gpl=hipr2
    To activate the HIPR2 GPL on the HIPR2 cards on IMT bus A shown in 8, the sloc=1109 and eloc=2109 parameters would be specified with the act-flash command.
        FLASH Memory Activation for cards 1110 - 2110 Started.
        FLASH Memory Activation for cards 1110 - 2110 Completed.
        LOC 1110 : PASSED
        LOC 1210 : PASSED
        LOC 1310 : PASSED
        LOC 2110 : PASSED
        Command Completed.
  13. Verify the HIPR2 GPLs on the fixed disk and the cards that are running the HIPR2 GPLs using the rept-stat-gpl:gpl=hipr2 command.
    HIPR2    1109   132-003-000       132-003-000   132-002-000
    Command Completed
  14. Continue the procedure by performing these actions.
    • If you wish to load the new HIPR2 GPL onto the other cards shown in 8, repeat this procedure from 9 for each card shown in 8.
    • If the new HIPR2 GPL has been loaded onto all the cards shown in 8, or if the new HIPR2 GPL will not be loaded onto the other cards shown in 8, then this procedure is finished.
Figure 3-5 Updating the HIPR2 GPL
Sheet 1 of 5
Sheet 2 of 5
Sheet 3 of 5
Sheet 4 of 5
Sheet 5 of 5
Making the Trial Utility GPL the Approved Utility GPL
This procedure is used to make the trial UTILITY generic program load (GPL) the approved UTILITY GPL.
The UTILITY GPL cannot be loaded and run from the removable cartridge like the other GPLs. The approved version of the UTILITY GPL is on the fixed disk. The trial version of the UTILITY GPL is located on the removable cartridge or removable media. This procedure loads the trial UTILITY GPL from the removable cartridge to the fixed disk and makes it the approved UTILITY GPL.
The removable cartridge or removable media that contains the UTILITY GPL to be loaded on to the EAGLE is required.
When the UTILITY GPL is displayed with the rtrv-gpl command, the entry CDU appears in the GPL column of the rtrv-gpl output.
  1. Verify the control cards that are installed in the EAGLE.
    Refer to Maintenance and Administration Subsystem for information about the control cards.
  2. Check the E5-MASPs for removable media.
  3. Verify the active MASP by entering the rept-stat-db command.
    DATABASE STATUS: >> OK <<
            TDM 1114 ( STDBY)                 TDM 1116 ( ACTV )
            C   LEVEL    TIME LAST BACKUP     C   LEVEL    TIME LAST BACKUP
    FD CRNT Y       39                        Y       39
            MCAP 1113                         MCAP 1115
    If removable media is installed in the active MASP, continue the procedure with 4.
    If removable media is not installed in the active MASP, insert the removable media in the removable media drive in the active MASP. For more information about inserting removable media in the removable media drive, refer to Removable USB Drive. After the removable media has been inserted in the removable media drive in the active MASP, continue the procedure with 4.
  4. Display the UTILITY GPLs on the fixed disk and on the removable media using the rtrv-gpl:gpl=utility command.
    rlghncxa03w 09-03-01 07:01:08 GMT EAGLE5 40.1.0
    GPL Auditing  ON
    CDU       1114  162-000-000  162-000-000      162-001-000  162-001-000
    CDU       1116  162-000-000  162-000-000      162-001-000  162-001-000
    CDU       1115  -----------  -----------      -----------  -----------
    If the version of the UTILITY GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP.
    Insert the removable media that contains the UTILITY GPL that is being updated into the removable media drive in the active MASP and repeat this step.
    For more information about inserting or removing removable media in the media drive, refer to Removable USB Drive.
    If the version of the UTILITY GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is the version that is to be loaded onto the cards, continue the procedure with 5.
  5. Change the GPLs, using the chg-gpl command and specifying the value for the trial UTILITY GPL shown in the output of the rtrv-gpl command used in 4.
    chg-gpl:gpl=utility:ver=162-001-000
    rlghncxa03w 09-03-01 06:52:20 GMT EAGLE5 40.1.0
    GPL Auditing  ON
    UTILITY upload to 1114 completed
    UTILITY upload to 1116 completed
  6. Display the UTILITY GPLs on the fixed disk and on the removable cartridge using the rtrv-gpl:gpl=utility command.
    GPL Auditing  ON
    CDU       1114  162-001-000  162-001-000      162-001-000  162-001-000
    CDU       1116  162-001-000  162-001-000      -----------  -----------
    GPL Auditing  ON
    CDU       1116  162-001-000  162-001-000      162-001-000  162-001-000
  7. This procedure is finished.
Figure 3-6 Making the Trial Utility GPL the Approved Utility GPL
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
Reloading the TDM LCA Clock Bitfile
This procedure is used to reload the clock LCA (logic cell array) bitfile on the TDMs using the init-card command. To reload the TDM clock LCA bitfile, the E5-MCAP card associated with the TDM being reloaded is initialized by entering the init-card command with the initclk=yes parameter.
It is recommended that the card specified in the init-card command is the GPSM-II or E5-MCAP card in the standby MASP. The rept-stat-db output in 7 shows which TDM is the standby TDM with the indicator ( STDBY) after the TDM’s card location. If the TDM in card location 1114 is the standby TDM, card location 1113 must be specified. If the TDM in card location 1116 is the standby TDM, card location 1115 must be specified.
The TDM clock LCA bitfile can be reloaded only on TDMs with part numbers 870-0774-15 or later. If the EAGLE contains older TDMs, these TDMs must be replaced with TDMs 870-0774-15 or later to perform this procedure.
Contact My Oracle Support (MOS) before replacing the TDMs.
The init-card also contains the force=yes parameter. The force=yes parameter can be used only with the initclk=yes parameter. The force=yes parameter must be used if reloading the TDM clock LCA bitfile would cause a system clock outage.
Caution:
A system clock outage can be caused by either the EAGLE having only one TDM (a simplex MASP configuration) or if the status of the high-speed clocks, shown in the rept-stat-clk output in 1, on the TDM which is not being reset is Fault. A system clock outage will result in a loss of traffic on some or all signaling links.
  1. Verify the status of the high-speed clocks by entering the rept-stat-clk command. This is an example of the possible output.
    Clock      Using         Bad
    CLK A        9            0
    CLK B        0            0
    CLK I        0            --
    ALARM STATUS = No Alarms.
    Clock      Using         Bad
    HS CLK A     2            0
    HS CLK B     0            0
    HS CLK I     0            --
    Command Completed
    If the rept-stat-clk output does not show any high-speed clocks HIGH SPEED SYSTEM CLOCK, Primary HS Clk, Secondary HS Clk, HS CLK TYPE, and HS CLK LINELEN fields), the EAGLE does not contain any cards that are capable of using high-speed source timing.
    • If the HS CLK TYPE and HS CLK LINELEN values shown in 1 are set to the system default values (HS CLK TYPE = RS422 and HS CLK LINELEN = LONGHAUL), continue the procedure with 3.
    • If the HS CLK TYPE and HS CLK LINELEN values shown in 1 are not set to the system default values (HS CLK TYPE = RS422 and HS CLK LINELEN = LONGHAUL), continue the procedure with 2.
  2. Visually verify the part numbers of both TDMs in the EAGLE. To load the TDM clock LCA bitfile, the part numbers of both TDMs must be 870-0774-15 or later.
    If the TDM part numbers are 870-0774-15 or later, continue the procedure with 3.
    If the TDM part numbers are not 870-0774-15 or later, the TDMs must be replaced with TDM part numbers 870-0774-15 or later. Contact the Customer Care Center before replacing the TDMs. Refer to My Oracle Support (MOS) for the contact information. If the older TDMs are not replaced, this procedure cannot be performed.
    If any SEAS terminals are present, they must be taken out of service. The SEAS terminals are shown in the output with the entry SEAS in the TYPE field. If no SEAS terminals are shown in the rtrv-trm command output, continue the procedure with 7.
    This is an example of the possible output. In this example, the SEAS terminals are terminals 18 and 27.
    TRM  TYPE     COMM        FC    TMOUT MXINV DURAL
    1    VT320    9600-7-E-1  SW    30    5     99:59:59
    2    KSR      9600-7-E-1  HW    30    5     INDEF
    3    PRINTER  4800-7-E-1  HW    30    0     00:00:00
    4    VT320    2400-7-E-1  BOTH  30    5     00:30:00
    5    VT320    9600-7-O-1  NONE  30    5     00:00:30
    6    VT320    9600-7-O-1  NONE  30    5     00:00:30
    7    PRINTER  9600-7-N-2  HW    30    5     00:30:00
    8    KSR     19200-7-E-2  BOTH  30    5     00:30:00
    9    VT320    9600-7-O-1  NONE  30    5     00:00:30
    10   VT320    9600-7-E-1  HW    30    5     00:30:00
    11   VT320    4800-7-E-1  HW    30    5     00:30:00
    12   PRINTER  9600-7-E-1  HW    30    4     00:30:00
    13   VT320    9600-7-O-1  NONE  30    5     00:30:00
    14   VT320    9600-7-E-2  SW    30    8     00:30:00
    15   VT320    9600-7-N-2  HW    30    5     00:30:00
    16   VT320    9600-7-E-2  BOTH  30    3     00:30:00
    18   SEAS      1201             60    5     00:30:00   yes
    36   TELNET    1205             60    5     00:30:00   yes
    The rtrv-trm command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-trm command, see the rtrv-trm command description in Commands User's Guide.
  4. Display the status of the terminals with the rept-stat-trm command. This is an example of the possible output.
    TRM   PST           SST           AST
    18    IS-NR         Active        -----
    27    IS-NR         Active        -----
    Command Completed.
  5. Place the SEAS terminals out of service using the rmv-trm command with the number of the terminal displayed in 4 whose state is not OOS-MT-DSBLD.
    The force=yes parameter must be used when placing the last SEAS terminal out of service.
    If SEAS terminals are shown in the rtrv-trm output in 3, for this example, enter these commands.
    rmv-trm:trm=18
    rmv-trm:trm=27:force=yes
    Caution:
    If the status of any of the terminals shown in the PST field in 4 is OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
    This message should appear when each of these commands have successfully completed.
    Inhibit message sent to terminal
    Command Completed.
    • 6 is performed only if the SEAS terminals were placed out of service in this step. If the SEAS terminals were not placed out of service in this step, continue the procedure with 7.
    • If the SEAS terminals were placed out of service in this step, continue the procedure with 6.
  6. Change the terminal type of the SEAS terminals to NONE with the chg-trm command, the type=none parameter, and with the values of the SEAS terminals used in 5.
    chg-trm:trm=18:type=none
    chg-trm:trm=27:type=none
    This message should appear when these commands have successfully completed.
    CHG-TRM: MASP B - COMPLTD
  7. Enter the rept-stat-db command, to determine which MASP is active, This is an example of the possible output.
    rlghncxa03w 09-03-01 16:07:48 GMT  EAGLE5 40.1.0
            TDM 1114 ( ACTV )                 TDM 1116 ( STDBY)
    FD BKUP  Y       35 09-02-19 10:19:18 GMT  Y       35 09-02-19 10:19:18 GMT
    FD CRNT  Y      106                        Y      106
             MDAL 1117
    RD BKUP  -    -         -        -
    FD CRNT Y       106                        Y      106
            MCAP 1113                         MCAP 1115
    RD BKUP -    -         -        -         -    -         -        -
    USB BKP -    -         -        -         Y        3 09-02-07 01:11:22 GMT
    The output of the rept-stat-db command shows which MASP is active with the indicator ( ACTV ) following the TDM card location. The indicator ( STDBY) following the TDM card location shows which MASP is standby.
    For this example, the MASP associated with TDM 1114 is active and the MASP associated with TDM 1116 is standby.
  8. Place the E5-MCAP card in the standby MASP out of service using the rmv-card command.
    The rept-stat-db output in 7 shows which TDM is the standby TDM with the entry (Standby ) after the TDMs card location. If the TDM in card location 1114 is the standby TDM, card location 1113 must be specified in this step. If the TDM in card location 1116 is the standby TDM, card location 1115 must be specified in this step.
    rmv-card:loc=1115
    When this command has successfully completed, this message should appear.
    Card has been inhibited.
  9. Load the TDM clock LCA bitfile onto the TDM associated with the E5-MCAP card inhibited in 8 using the init-card command with the initclk=yes parameter and the card location of the standby E5-MCAP card.
    Caution:
    If reloading the TDM clock LCA bitfile would cause a system clock outage, the force=yes parameter must be used with the init-card command. A system clock outage can be caused by either the EAGLE having only one TDM (a simplex MASP configuration) or if the status of the high-speed clocks, shown in the rept-stat-clk output in 1, on the TDM which is not being reset is Fault. A system clock outage will result in a loss of traffic on some or all signaling links.
    init-card:initclk=yes:loc=1115
    When this command has successfully completed, these messages should appear.
        rlghncxa03w 09-03-01 13:01:59 GMT  EAGLE5 40.1.0
        Init Card command issued to card 1115
    *   3021.0013  * CARD 1115 EOAM        Card is isolated from the system
        rlghncxa03w 09-03-01 13:03:10 GMT  EAGLE5 40.1.0
        3022.0014    CARD 1115 EOAM        Card is present
                     ASSY SN:  1216115
    *   3021.0013  * CARD 1115 OAMHC         Card is isolated from the system
        3022.0014    CARD 1115 OAMHC         Card is present
                     ASSY SN:  1216115
  10. Put the E5-MCAP card that was inhibited in 9 back into service using the rst-card command with the card location specified in 9. For this example, enter this command.
    rst-card:loc=1115
    Card has been allowed.
    • If the TDM clock LCA bitfile will not be loaded on the other TDM in the EAGLE, continue the procedure with 12.
    • If the TDM clock LCA bitfile will be loaded on the other TDM in the EAGLE, continue the procedure with 11.
  11. If you wish to load the TDM clock LCA bitfile onto the TDM making up the active MASP, enter the init-card command specifying the location of the E5-MCAP card making up active MASP. Initializing the E5-MCAP card of the active MASP makes the MASPs switch roles. The active MASP becomes the standby MASP, and the standby (text is missing from this point).
    For this example, enter the init-card:loc=1113 command. This message should appear.
    Init Card command issued to card 1113
    After the init-card command has completed, repeat the procedure from 8, specifying the card location used in the init-card command.
  12. Verify the status of the high-speed clocks by entering the rept-stat-clk command. This is an example of the possible output.
    Clock      Using         Bad
    CLK A        9            0
    CLK B        0            0
    CLK I        0            --
    Clock      Using         Bad
    HS CLK A     2            0
    HS CLK B     0            0
    HS CLK I     0            --
    Command Completed
    • If 6 was not performed, continue the procedure with 16.
    • If 6 was performed, continue the procedure with 13.
  13. If SEAS terminals were changed in 6, for this example, enter these commands.
    chg-trm:trm=18:type=seas
    chg-trm:trm=27:type=seas
  14. Put the SEAS terminals back into service using the rst-trm command with the number of the terminals specified in 13. For this example, enter these commands.
    rst-trm:trm=18
    rst-trm:trm=27
    Allow message sent to terminal
    Command Completed.
  15. Verify that the terminals are in service with the rept-stat-trm command. This is an example of the possible output.
    TRM   PST           SST           AST
    Command Completed.
  16. Back up the new changes using the chg-db:action=backup:dest=fixed command. These messages should appear, the active Maintenance and Administration Subsystem Processor (MASP) appears first.
    BACKUP (FIXED) : MASP A - Backup starts on active MASP.
    BACKUP (FIXED) : MASP A - Backup on active MASP to fixed disk complete.
    BACKUP (FIXED) : MASP A - Backup starts on standby MASP.
    BACKUP (FIXED) : MASP A - Backup on standby MASP to fixed disk complete.
Figure 3-7 Reloading the TDM LCA Clock Bitfile
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
Updating the BLIXP GPL
The BLIXP GPL is a tar image of all the flash GPLs that are necessary to operate the cards shown in Table 3-4. When the BLIXP GPL is downloaded to the card, the tar image is un-archived and the flash GPLs are loaded onto the card.
Table 3-4 High-Capacity Cards
HC MIM E5-E1T1 E5-ENET
E5-STC   E5-SM4G
E5-ATM E5-TSM
This procedure updates the BLIXP GPL using the init-flash and act-flash commands.
Caution:
The init-flash command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed. The act-flash command cannot be entered if the Extended Bit Error Rate Test (BERT) is being performed.
The applications and entities supported by the high-capacity cards are shown in Table 3-5.
Table 3-5 High-Capacity Card Applications
High-Capacity Card Card Name (as shown on the card label) Application Application GPL Running on the Card Supported Entities
HC MIM HC MIM SS7ANSI, CCS71TU SS7HC E1 or T1 signaling links
E5-E1T1 E5-E1T1 SS7ANSI, CCS71TU SS7HC E1 or T1 signaling links
E5-ENET E5-ENET SS7IPGW, IPLIM, IPLIMI, IPGWI, IPSG IPLHC, IPGHC, IPSG IP signaling links
E5-STC E5-ENET EROUTE ERTHC EAGLE 5 Integrated Monitoring Support
E5-SM4G E5-SM4G VSCCP SCCPHC GTT-related features
E5-ENET-B/SLIC
E5-ENET-B
SLIC
IPS IPSHC Telnet sessions for remote connections to the EAGLE and SEAS terminals for the SEAS over IP feature
E5-ATM E5-ATM ATMANSI, ATMITU ATMHC ANSI and ITU ATM high-speed signaling links
E5-TSM E5-TSM GLS GLSHC Gateway Screening related features
A removable cartridge or removable media containing the BLIXP GPL that is being updated is required.
Caution:
Before any high-capacity card can be updated with the BLIXP GPL, all the traffic hosted by the high-capacity card must be stopped, and the high-capacity card must be taken out of service.
Canceling the REPT-STAT-SLK and RTRV-SLK Commands
Because the rept-stat-slk and rtrv-slk commands used in this procedure can output information for a long period of time, the rept-stat-slk and rtrv-slk commands can be canceled and the output to the terminal stopped. There are three ways that the rept-stat-slk and rtrv-slk commands can be canceled.
  • Press the F9 function key on the keyboard at the terminal where the rept-stat-slk or rtrv-slk commands command were entered.
  • Enter the canc-cmd without the trm parameter at the terminal where the rept-stat-slk or rtrv-slk commands were entered.
  • Enter the canc-cmd:trm=<xx>, where <xx> is the terminal where the rept-stat-slk or rtrv-slk commands were entered, from another terminal other that the terminal where the rept-stat-slk or rtrv-slk commands were entered. To enter the canc-cmd:trm=<xx> command, the terminal must allow Security Administration commands to be entered from it and the user must be allowed to enter Security Administration commands. The terminal’s permissions can be verified with the rtrv-secu-trm command. The user’s permissions can be verified with the rtrv-user or rtrv-secu-user commands.
For more information about the canc-cmd command, go to Commands User's Guide.
    If E5-based control cards are installed in the EAGLE, continue the procedure with 2.
    If removable media is installed in both E5-MASPs, continue the procedure with 4.
    If removable media is not installed in both E5-MASPs, continue the procedure with 3.
    rlghncxa03w 10-12-01 15:25:40 GMT  EAGLE5 43.0.0
    FD BKUP Y       36 10-11-19 09:38:25 GMT  Y       36 10-11-19 09:38:25 GMT
    FD CRNT Y       39                        Y       39
            MCAP 1113                         MCAP 1115
    RD BKUP -    -         -        -         Y       36 10-11-19 09:27:17 GMT
    USB BKP -    -         -        -         Y        3 10-11-07 01:11:22 GMT
  4. Display the BLIXP GPL on the fixed disk and on the removable media by entering this command.
    rtrv-gpl:gpl=blixp
    rlghncxa03w 10-12-01 11:34:04 GMT  EAGLE5 43.0.0
    GPL Auditing  ON
    BLIXP     1114  133-002-000  133-002-000      133-001-000  133-003-000
    BLIXP     1116  133-002-000  133-002-000      133-001-000  133-003-000
    BLIXP     1115  -----------  -----------      -----------  -----------
    If the version of the BLIXP GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP. Insert the removable media that contains the BLIXP GPL that is being updated into the removable media drive in the active MASP and repeat this step. For more information about inserting removable media in the removable media drive, or removing removable media from the removable media drive, refer to Removable USB Drive.
    If the version of the BLIXP GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is the version that is to be loaded onto the cards, continue the procedure with 133-.
  5. Change the BLIXP GPL by entering the chg-gpl command with the gpl=blixp parameter and the version of the BLIXP GPL shown in the REMOVE TRIAL column in the output of the rtrv-gpl command used in 4.
    chg-gpl:gpl=blixp:ver=133-003-000
    These messages should appear.
    rlghncxa03w 10-12-01  11:43:04  GMT  EAGLE5 43.0.0
    GPL Auditing  ON
    BLIXP upload on 1114 completed
    BLIXP upload on 1116 completed
    System Release ID table upload 1114 completed
    System Release ID table upload 1116 completed
  6. Activate the trial GPL by entering the act-gpl command with the gpl=blixp parameter and the version of the trial GPL specified in 133-.
    act-gpl:gpl=blixp:ver=133-003-000
    rlghncxa03w 10-12-01 06:54:39 GMT EAGLE5 43.0.0
    BLIXP activate on 1114 completed
    BLIXP activate on 1116 completed
  7. Verify that the trial GPL has been made the approved GPL by entering this command.
    rtrv-gpl:gpl=blixp
    GPL Auditing ON
    BLIXP     1114  133-003-000  133-003-000      133-002-000  133-003-000
    BLIXP     1116  133-003-000  133-003-000      133-002-000  -----------
    If E5-based control cards are installed in the EAGLE, this is an example of the possible output.
    GPL Auditing  ON
    BLIXP     1116  133-003-000  133-003-000      133-002-000  133-003-000
  8. Verify the cards that are running the BLIXP GPL by entering this command
    rept-stat-gpl:gpl=blixp
    rlghncxa03w 10-12-01 11:40:26 GMT  EAGLE5 43.0.0
    BLIXP    1303   133-002-000 ALM   133-003-000   133-002-000
    BLIXP    2101   133-002-000 ALM   133-003-000   133-002-000
    BLIXP    2103   133-002-000 ALM   133-003-000   133-002-000
    BLIXP    2205   133-002-000 ALM   133-003-000   133-002-000
    BLIXP    2207   133-002-000 ALM   133-003-000   133-002-000
    BLIXP    2211   133-002-000 ALM   133-003-000   133-002-000
    Command Completed
  9. Display the status of the card, shown in the rept-stat-gpl output in 8, that the GPL will be loaded onto using the rept-stat-card command and specifying the location of the card.
    rept-stat-card:loc=1303
    For an HC MIM or E5-E1T1 card, this is an example of the possible output.
    rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0
    CARD   VERSION      TYPE      GPL        PST            SST        AST
    1303   134-003-000  LIME1     SS7HC      IS-NR          Active     -----
      BLIXP   GPL version = 133-002-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      SIGNALING LINK STATUS
          SLK    PST                LS            CLLI
          A      IS-NR              e11303a       -----------
          B      IS-NR              e11303b       -----------
          A1     IS-NR              e11303a       -----------
          B3     IS-NR              e11303b       -----------
    Command Completed.
      BLBIOS  GPL version = 133-002-000
      PLDPMC1 GPL version = 133-002-000
      BLROM1  GPL version = 133-002-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
    For an E5-E1T1 card, this is an example of the possible output.
    1303   134-003-000  LIME1     SS7EPM     IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CURRENT TEMPERATURE   =  32C ( 90F)     [ALARM TEMP:  60C (140F)]
      PEAK TEMPERATURE:     =  39C (103F)     [06-05-02 13:40]
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
    For an E5-ENET card, this is an example of the possible output.
    1303   134-003-000  DCM       IPLHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
    For an E5-STC card, this is an example of the possible output.
    1303   134-003-000  STC       ERTHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CURRENT TEMPERATURE   =  61C (142F)
      PEAK TEMPERATURE:     =  61C (142F)     [06-05-02 13:40]
      NTP broadcast = VALID
      STC IP PORT A:                         OOS-MT         Unavail    -----
          ALARM STATUS  = **  0084 IP Connection Unavailable
          ERROR STATUS  = DHCP Lease. Physical Link.
      STC IP PORT B:                         OOS-MT         Unavail    -----
    Command Completed.
    For an E5-SM4G card, this is an example of the possible output.
    1303   134-003-000  DSM       SCCPHC     IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CURRENT TEMPERATURE   =  31C ( 88F)
      PEAK TEMPERATURE:     =  32C ( 90F)     [07-05-12 15:55]
      SCCP % OCCUP        = 1%
    Command Completed.
      BLBSMG  GPL version = 133-002-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      SCCP % OCCUP        = 1%
    Command Completed.
    For an E5-ENET-B/SLIC card, this is an example of the possible output.
    1303   134-003-000  IPSM      IPSHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      Command Completed.
    For an E5-ATM card, this is an example of the possible output.
    1303   134-003-000  LIMATM    ATMHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CURRENT TEMPERATURE   =  38C (101F)
      PEAK TEMPERATURE:     =  38C (101F)     [07-11-23 06:10]
          SLK    PST                LS            CLLI
          A      IS-NR              ls1           -----------
    Command Completed.
    For an E5-TSM card, this is an example of the possible output.
    1303   134-003-000  TSM       GLSHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
    Command Completed.
    Continue the procedure by performing one of these actions:
    • If card is running one of these application GPLs: SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, IPSG (shown in the GPL column in the rept-stat-card output in 9), continue the procedure with 12.
    • If card is running the ERTHC application GPL, (shown in the GPL column in the rept-stat-card output in 9), continue the procedure with 19.
    • If the card is running the IPSHC application GPL, (shown in the GPL column in the rept-stat-card output in 9), continue the procedure with 16.
    • If card is running the GLSHC application GPL, (shown in the GPL column in the rept-stat-card output in 9), continue the procedure with 10.
    • If card is running the SCCPHC application GPL, (shown in the GPL column in the rept-stat-card output in 9), continue the procedure with 11.
  10. Display the GLS cards by entering this command.
    rept-stat-card:appl=gls
    The output from this command will display the TSMs that are running the GLS GPL and the E5-TSMs that are running the GLSHC GPL.
    1207   133-003-000  TSM       GLSHC      IS-NR          Active     -----
    1211   133-003-000  TSM       GLSHC      IS-NR          Active     -----
    1303   133-003-000  TSM       GLSHC      IS-NR          Active     -----
    Command Completed.
    Continue the procedure with 19.
  11. Display the service modules by entering the rept-stat-sccp command.
    The output from this command will display the DSMs that are running the VSCCP GPL and the E5-SM4G cards that are running the SCCPHC GPL.
    CARD  VERSION      PST             SST        AST       MSU USAGE  CPU USAGE
    1303  133-003-000  IS-NR           Active     -----       47%         81%
    2103  133-003-000  IS-NR           Active     -----       34%         50%
    2111  133-003-000  IS-NR           Active     -----       21%         29%
    2115  133-003-000  IS-NR           Active     -----       35%         52%
    2117  133-003-000  IS-NR           Active     -----       40%         71%
    SCCP Service Average MSU Capacity = 36%       Average CPU Capacity = 56%
    Command Completed.
    The rept-stat-sccp command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rept-stat-sccp command, refer to the rept-stat-sccp command description in Commands User's Guide.
  12. Display the signaling links associated with the card shown in 9.
    Enter the rtrv-slk command with the card location specified in 9. For this example, enter this command.
    rtrv-slk:loc=1303
    This is an example of the possible output for an HC MIM or E5-E1T1 card.
                                       L2T               PCR  PCR   E1   E1
    LOC  LINK LSN         SLC TYPE     SET  BPS    ECM   N1   N2    LOC  PORT TS
    1303 A    e11303a      0  LIME1    1    64000  PCR   76   3800  1303 2    12
    1303 B    e11303b      0  LIME1    1    56000  BASIC ---  ----- 1303 1    2
    1303 A1   e11303a      1  LIME1    1    56000  BASIC ---  ----- 1303 1    3
    1303 B3   e11303b      1  LIME1    1    56000  BASIC ---  ----- 1303 1    7
    This is an example of the possible output for an E5-ENET card.
    LOC  LINK LSN         SLC TYPE     IPLIML2
    1303 A    e11303a      0  IPLIM    M2PA
    1303 B    e11303b      0  IPLIM    M2PA
    1303 A1   e11303a      1  IPLIM    M2PA
    1303 B3   e11303b      1  IPLIM    M2PA
    This is an example of the possible output for an E5-ATM card.
                                       LP            ATM
    LOC  LINK LSN         SLC TYPE     SET  BPS      TSEL      VCI    VPI   LL
    1303 A    ls2          2  LIMATM   1    1544000  LINE      5      0     0
    1303 B    ls1          3  LIMATM   1    1544000  LINE      5      0     0
  13. Deactivate the SS7 signaling links on the card using the dact-slk command.
    dact-slk:loc=1303:link=a
    dact-slk:loc=1303:link=b
    dact-slk:loc=1303:link=a1
    dact-slk:loc=1303:link=b3
    Caution:
    These command examples place the signaling links on card 1303 out of service. This will interrupt service on the signaling links on card 1303 and allow the BLIXP GPL to be loaded on to card 1303.
    Caution:
    Do not deactivate all the signaling links assigned to these cards: HC MIMs, E5-E1T1, E5-ENET, E5-ATM, at the same time. Doing so will take all the E1, T1, IP, and ATM signaling links out of service, and the traffic on these signaling links could be lost.
    Caution:
    If the EAGLE contains only signaling links assigned to the card that is specified in this step, deactivating all of the signaling links that are assigned to the card will take all of these signaling links out of service and will isolate the EAGLE from the network.
    When each of these commands have successfully completed, this message should appear.
    Deactivate SLK message sent to card
  14. Display the data link, and its status, associated with the card shown in 9. Enter the rept-stat-dlk command with the card location specified in 9.
    rept-stat-dlk:loc=1303
    DLK             PST          SST       AST
    1303            IS-NR        Active    ----
      Alarm Status      = No Alarms.
    Command Completed.
  15. Deactivate the TCP/IP data link on the card that you wish to load the GPL onto using the canc-dlk command. For this example, enter this command.
    canc-dlk:loc=1303
    Caution:
    This command example places the TCP/IP data link on card 1303 out of service. This will interrupt service on the TCP//IP data link on card 1303 and allow the flash GPL to be loaded onto card 1303.
    Deactivate Link message sent to card.
    Command Completed.
  16. Display the terminal configuration in the database with the rtrv-trm command.
    The Telnet terminals associated with the card shown in 9 must be taken out of service. The Telnet terminals are shown in the output with the entry TELNET in the TYPE field. This is an example of the possible output. In this example, the Telnet terminals that must be taken out of service are terminals 17 to 24.
    7    PRINTER  9600-7-E–2 HW    30    5     00:30:00
    15   VT320    9600-7-E–2 HW    30    5     00:30:00
    17   TELNET    1303             60    5     00:30:00
    18   TELNET    1303             60    5     00:30:00
    19   TELNET    1303             60    5     00:30:00
    20   TELNET    1303             60    5     00:30:00
    21   TELNET    1303             60    5     00:30:00
    22   TELNET    1303             60    5     00:30:00
    23   TELNET    1303             60    5     00:30:00
    24   TELNET    1303             60    5     00:30:00
    27   TELNET    1203             60    5     00:30:00
    39   TELNET    1203             60    5     00:30:00
    33   TELNET    1208             60    5     00:30:00
    34   TELNET    1208             60    5     00:30:00
    35   TELNET    1208             60    5     00:30:00
    36   TELNET    1208             60    5     00:30:00
    37   TELNET    1208             60    5     00:30:00
    38   TELNET    1208             60    5     00:30:00
    39   TELNET    1208             60    5     00:30:00
    40   TELNET    1208             60    5     00:30:00
  17. Display the status of the terminals with the rept-stat-trm command. This is an example of the possible output.
    TRM   PST           SST           AST
    3     IS-NR         Active        -----
    4     IS-NR         Active        -----
    5     IS-NR         Active        -----
    6     IS-NR         Active        -----
    9     IS-NR         Active        -----
    10    IS-NR         Active        -----
    11    IS-NR         Active        -----
    12    IS-NR         Active        -----
    13    IS-NR         Active        -----
    14    IS-NR         Active        -----
    15    IS-NR         Active        -----
    16    IS-NR         Active        -----
    17    IS-NR         Active        -----
    19    IS-NR         Active        -----
    20    IS-NR         Active        -----
    21    IS-NR         Active        -----
    22    IS-NR         Active        -----
    23    IS-NR         Active        -----
    24    IS-NR         Active        -----
    25    IS-NR         Active        -----
    26    IS-NR         Active        -----
    28    IS-NR         Active        -----
    29    IS-NR         Active        -----
    30    IS-NR         Active        -----
    31    IS-NR         Active        -----
    32    IS-NR         Active        -----
    33    IS-NR         Active        -----
    34    IS-NR         Active        -----
    35    IS-NR         Active        -----
    36    IS-NR         Active        -----
    37    IS-NR         Active        -----
    38    IS-NR         Active        -----
    39    IS-NR         Active        -----
    40    IS-NR         Active        -----
    Command Completed.
  18. Place the required terminals out of service using the rmv-trm or inh-trm command. The function of the rmv-trm and the inh-trm commands are the same. For this example, enter these commands.
    rmv-trm:trm=17
    rmv-trm:trm=18
    rmv-trm:trm=19
    rmv-trm:trm=20
    rmv-trm:trm=21
    rmv-trm:trm=22
    rmv-trm:trm=23
    rmv-trm:trm=24
    If the terminal that is being taken out of service is the last in service SEAS terminal, theforce=yes parameter must be specified with thermv-trm command for that terminal.
    Caution:
    If the status of any of the terminals shown in the PST field in 17 is OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
    Command Completed.
  19. Place the card shown in 9 out of service using the rmv-card or inh-card command. The function of the rmv-card and the inh-card commands are the same.
    Caution:
    Multiple cards running the BLIXP GPL can be updated at the same time with the init-flash command (20). This requires that the cards in the locations specified with the init-flash command in 20 are out of service. All the high-capacity cards running the BLIXP GPL being updated can be placed out of service. However it is recommended that only some of these high-capacity cards are placed out of service. Placing all these high-capacity cards out of service will case all traffic hosted by high-capacity cards to be lost.
    Caution:
    If there is only one high-capacity card running the BLIXP GPL being updated, placing this card out of service will cause all the traffic hosted by this high-capacity card to be lost.
    rmv-card:loc=1303
    If more than one card running the same flash GPL is to be updated in 20, repeat this step for those cards.
    rlghncxa03w 10-12-01  11:11:28 GMT  EAGLE5 43.0.0
    The force=yes parameter must be specified in this step if any of these conditions exist.
    • The HC MIM, E5-E1T1, E5-ATM, or E5-ENET card contains the last signaling link in a linkset.
    • The E5-TSM is the last GLS card that is in service.
    • The service module is the last service module that is in service.
  20. Load the approved version of the BLIXP GPL onto the card inhibited in 19 using the init-flash command with the code=appr parameter.
    Caution:
    The flash-card command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed.
    init-flash:code=appr:loc=1303:gpl=blixp
        FLASH Memory Downloading for card 1303 Started.
        BLIXP Downloading for card 1303 Complete.
        Command Completed.
    If more than one card running the BLIXP GPL is being updated, enter the init-flash command with these parameters along with the code=appr parameter:
    sloc - the first card location in the range of card locations
    eloc - the last card location in the range of card locations
    gpl - blixp
    The sloc, eloc, and gpl parameters cannot be specified with the loc parameter. When the sloc, eloc, and gpl parameters are specified, only the cards running the BLIXP GPL and within the range specified by the sloc and eloc parameters are updated. All other cards in the range specified by the sloc and eloc parameters are skipped.
    Entering the example command will update the cards in the locations 1303 to 2103 running the BLIXP GPL with the approved version of the BLIXP GPL.
    init-flash:code=appr:sloc=1303:eloc=2103:gpl=blixp
        FLASH Memory Download for cards 1303 - 2103 Started.
        FLASH Memory Download for cards 1303 - 2103 Completed.
        LOC 1303 : PASSED
        LOC 2101 : PASSED
        LOC 2103 : PASSED
        Command Completed.
  21. Put the cards that were inhibited in 19 back into service using the rst-card or alw-card command. The function of the rst-card and the alw-card commands are the same.
    The rst-card command also loads the approved version of the GPL onto the card.
    rst-card:code=appr:loc=1303
  22. Verify that the BLIXP GPL from 21 has loaded and that the card has returned to its in-service normal (IS-NR) state using the rept-stat-card command.
      BLIXP   GPL version = 133-003-000 +
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
          A      OOS-MT-DSBLD       e11303a       -----------
          B      OOS-MT-DSBLD       e11303b       -----------
          A1     OOS-MT-DSBLD       e11303a       -----------
          B3     OOS-MT-DSBLD       e11303b       -----------
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
    1303   134-003-000  IPLIM     SS7EPM     IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      SCCP % OCCUP        = 1%
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      SCCP % OCCUP        = 1%
    Command Completed.
    For an E5-ENET-B or SLIC card, this is an example of the possible output.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
    Command Completed.
    The ’+’ symbol indicates that the BLIXP GPL has not been activated.
    If the version number of the BLIXP GPL that is shown in this step is not the version specified in 1, contact the Customer Care Center. Refer to the My Oracle Support (MOS) section for the contact information.
  23. Activate the BLIXP GPL loaded onto the cards specified in 20 by entering the act-flash command with the card location and the gpl=blixp parameter.
    Caution:
    act-flash:loc=1303:gpl=blixp
        FLASH Memory Activation for card 1303 Completed.
        Command Completed.
    If more than one card running the BLIXP GPL was updated in 20, enter the act-flash command with these parameters:
    gpl – blixp
    The sloc, eloc, and gpl parameters cannot be specified with the loc parameter. When the sloc, eloc, and gpl parameters are specified, only the cards running the BLIXP GPL and within the range specified by thesloc and eloc parameters are updated. All other cards in the range specified by the sloc and eloc parameters are skipped.
    Entering this example command will activate the BLIXP GPL on the cards in the locations 1303 to 2103.
    act-flash:sloc=1303:eloc=2103:gpl=blixp
        FLASH Memory Activation for cards 1303 - 2103 Started.
        FLASH Memory Activation for cards 1303 - 2103 Completed.
        LOC 1303 : PASSED
        LOC 2101 : PASSED
        LOC 2103 : PASSED
        Command Completed.
  24. Verify the flash GPLs on the cards by entering this command.
    If any card is not running the release version of the BLIXP GPL, shown in the RELEASE column of the rtrv-gpl output in 7, the indicator ALM is displayed next to the BLIXP GPL version in the RUNNING column of the rept-stat-gpl output. For this example, enter this command.
    BLIXP    1303   133-003-000       133-003-000   133-002-000
    BLIXP    2101   133-002-000       133-003-000   133-002-000
    BLIXP    2103   133-002-000       133-003-000   133-002-000
    Command Completed
    Continue the procedure by performing one of these actions.
    • If card is running one of these application GPLs: SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, IPSG (shown in the GPL column in the rept-stat-card output in 22), continue the procedure with 25.
    • If card is running one of these application GPLs: ERTHC, GLSHC, or SCCPHC, (shown in the GPL column in the rept-stat-card output in 22), continue the procedure with 31.
    • If the card is running the IPSHC application GPL, (shown in the GPL column in the rept-stat-card output in 22), continue the procedure with 29.
  25. Place the signaling links that were deactivated in 13 back into service using the act-slk command.
    Activate SLK message sent to card
  26. Verify that the signaling links activated in 25 are back in service using the rept-stat-slk command with the card location and signaling link.
    rept-stat-slk:loc=1303:link=a
    SLK      LSN       CLLI        PST          SST       AST
    1303,A   e11303a   ----------- IS-NR        Avail     ----
      UNAVAIL REASON     = --
    rept-stat-slk:loc=1303:link=b
    1303,B   e11303b   ----------- IS-NR        Avail     ----
      UNAVAIL REASON     = --
    rept-stat-slk:loc=1303:link=a1
    1303,A1  e11303a   ----------- IS-NR        Avail     ----
      UNAVAIL REASON     = --
    rept-stat-slk:loc=1303:link=b3
    1303,B3  e11303b   ----------- IS-NR        Avail     ----
      UNAVAIL REASON     = --
    Command Completed.
    Continue the procedure with 31.
  27. Place the TCP/IP data link that was deactivated in 15 back into using the act-dlk command. For this example, enter this command.
    act-dlk:loc=1303
    Activate Link message sent to card.
  28. Verify that the TCP/IP data link activated in 27 is back in service with the rept-stat-dlk command. For this example, enter this command.
    DLK             PST          SST       AST
    Command Completed.
  29. Put the required terminals back into service with the rst-trm or alw-trm command. The function of the rst-trm and the alw-trm commands are the same. For this example, enter these commands.
    rst-trm:trm=17
    rst-trm:trm=18
    rst-trm:trm=19
    rst-trm:trm=20
    rst-trm:trm=21
    rst-trm:trm=22
    rst-trm:trm=23
    rst-trm:trm=24
    Command Completed.
  30. Verify that the terminals are in service with the rept-stat-trm command. This is an example of the possible output.
    TRM   PST           SST           AST
    Command Completed.
  31. Continue the procedure by performing one of these actions.
    If you wish to load the new BLIXP GPL onto the other cards shown in 8, repeat this procedure from 9 for each card shown in 8.
    If the new BLIXP GPL will not be loaded onto other cards, then this procedure is finished.
Figure 3-8 Updating the BLIXP GPL
Sheet 1 of 7
Sheet 2 of 7
Sheet 3 of 7
Sheet 4 of 7
Sheet 5 of 7
Sheet 6 of 7
Sheet 7 of 7
Updating a High-Capacity Card to Run the BLIXP GPL
High-capacity cards that were issued before EAGLE Release 43.0 may not be loaded with the BLIXP GPL. This procedure updates the high-capacity card with the BLIXP GPL using the flash-card command. The BLIXP GPL is a tar image of all the flash GPLs that are necessary to operate the high-capacity cards. The high-capacity cards are shown in Table 3-6. When the BLIXP GPL is downloaded to the card, the tar image is un-archived and the flash GPLs are loaded onto the card.
Table 3-6 High-Capacity Cards
E5-STC   E5-SM4G
E5-ATM E5-TSM
Caution:
The applications and entities supported by the high-capacity cards are shown in Table 3-7.
Table 3-7 High-Capacity Card Applications
E5-ENET-B/SLIC
E5-ENET-B
SLIC
Caution:
  1. Display the BLIXP GPL on the fixed disk by entering this command.
    rtrv-gpl:gpl=blixp
    GPL Auditing  ON
  2. Display the status of the card that is being updated using the rept-stat-card command and specifying the location of the card.
    1303   133-003-000  LIME1     SS7HC      IS-NR          Active     -----
      IMTPCI  GPL version = 133-002-000
      BLCPLD  GPL version = 133-002-000
      BLDIAG6 GPL version = 133-002-000
      BLVXW6  GPL version = 133-002-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
    1303   133-003-000  LIME1     SS7EPM     IS-NR          Active     -----
      BLBEPM  GPL version = 133-002-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
    1303   133-003-000  DCM       IPLHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
    1303   133-003-000  STC       ERTHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      PEAK TEMPERATURE:     =  61C (142F)     [00-02-14 10:33]
      EROUTE % OCCUP     = 0%
    Command Completed.
    1303   133-003-000  DSM       SCCPHC     IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      SCCP % OCCUP        = 1%
    Command Completed.
    1303   133-003-000  IPSM      IPSHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      Command Completed.
    1303   133-003-000  LIMATM    ATMHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
    Command Completed.
    • If the card is running one of these application GPLs: SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, IPSG (shown in the GPL column in the rept-stat-card output in 2), continue the procedure with 5.
    • If the card is running the ERTHC application GPL, (shown in the GPL column in the rept-stat-card output in 2), continue the procedure with 12.
    • If the card is running the IPSHC application GPL, (shown in the GPL column in the rept-stat-card output in 2), continue the procedure with 9.
    • If the card is running the SCCPHC application GPL, (shown in the GPL column in the rept-stat-card output in 2), continue the procedure with 4.
    • If the card is running the GLSHC application GPL (shown in the GPL column in the rept-stat-card output in 2), continue the procedure with 3.
  3. Display the GLS cards by entering this command.
    Command Completed.
    Continue the procedure with 12.
  4. Display the service modules by entering the rept-stat-sccp command.
    Command Completed.
  5. Display the signaling links associated with the card shown in 2.
    Enter the rtrv-slk command with the card location specified in 2. For this example, enter this command.
    rtrv-slk:loc=1303
                                       L2T               PCR  PCR   E1   E1
                                       LP            ATM
  6. Deactivate the SS7 signaling links on the card using the dact-slk command.
    Caution:
    Caution:
  7. Display the data link, and its status, associated with the card shown in 2. Enter the rept-stat-dlk command with the card location specified in 2.
    DLK             PST          SST       AST
    Command Completed.
  8. Deactivate the TCP/IP data link on the card that you wish to load the GPL onto using the canc-dlk command. For this example, enter this command.
    canc-dlk:loc=1303
    Caution:
    Command Completed.
  9. Display the terminal configuration in the database with the rtrv-trm command.
    TRM  TYPE      LOC              TMOUT MXINV DURAL
    25   TELNET    1203             60    5     00:30:00
    26   TELNET    1203             60    5     00:30:00
    28   TELNET    1203             60    5     00:30:00
    30   TELNET    1203             60    5     00:30:00
    31   TELNET    1203             60    5     00:30:00
    32   TELNET    1203             60    5     00:30:00
  10. Display the status of the terminals with the rept-stat-trm command. This is an example of the possible output.
    TRM   PST           SST           AST
    Command Completed.
  11. Place the required terminals out of service using the rmv-trm or the inh-trm command. The function of the rmv-trm and the inh-trm commands are the same. For this example, enter these commands.
    rmv-trm:trm=17
    rmv-trm:trm=18
    rmv-trm:trm=19
    rmv-trm:trm=20
    rmv-trm:trm=21
    rmv-trm:trm=22
    rmv-trm:trm=23
    rmv-trm:trm=24
    Caution:
    Placing the Telnet terminals out of service will disable any Telnet sessions running on these terminals.
    If the status of any of the terminals shown in the PST field in 10 is OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
    Command Completed.
  12. Place the card shown in 2 out of service using the rmv-card or inh-card command. The function of the rmv-card and the inh-card commands are the same.
    rmv-card:loc=1303
  13. Load the approved version of the BLIXP GPL onto the card that was inhibited in 12 using the flash-card command with the code=appr and the card location parameters.
    Caution:
    flash-card:code=appr:loc=1303
        Flash Card: Downloading BLIXP on card 1303.
        Flash Card: Card 1303 download BLIXP complete.
        Flash Card: Activating BLIXP on card 1113.
        Flash Card: Card 1303 activation BLIXP complete.
        rrlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0
        Command Completed.
  14. Put the card that was inhibited in 12 back into service using the rst-card or alw-card command. The function of the rst-card and the alw-card commands are the same.
    The rst-card or alw-card command also loads the approved version of the BLIXP GPL onto the card.
  15. Verify that the BLIXP GPL from 14 has loaded and that the card has returned to its in-service normal (IS-NR) state using the rept-stat-card command.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
    1303   133-003-000  IPLIM     SS7EPM     IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      SCCP % OCCUP        = 1%
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
          SLK    PST                LS            CLLI
    Command Completed.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
    Command Completed.
    • If card is running one of these application GPLs: SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, IPSG (shown in the GPL column in the rept-stat-card output in 15), continue the procedure with 16.
    • If card is running one of these application GPLs: ERTHC, GLSHC, or SCCPHC, (shown in the GPL column in the rept-stat-card output in 15), continue the procedure with 22.
    • If the card is running the IPSHC application GPL, (shown in the GPL column in the rept-stat-card output in 15), continue the procedure with 20.
  16. Place the signaling links that were deactivated in 6 back into service using the act-slk command.
  17. Verify that the signaling links activated in 16 are back in service using the rept-stat-slk command with the card location and signaling link.
      UNAVAIL REASON     = --
      UNAVAIL REASON     = --
      UNAVAIL REASON     = --
      UNAVAIL REASON     = --
    Command Completed.
    Continue the procedure with 22.
  18. Place the TCP/IP data link that was deactivated in 8 back into using the act-dlk command. For this example, enter this command.
    act-dlk:loc=1303
  19. Verify that the TCP/IP data link activated in 18 is back in service with the rept-stat-dlk command. For this example, enter this command.
    DLK             PST          SST       AST
    Command Completed.
  20. Put the required terminals back into service with the rst-trm or alw-trm command. The function of the rst-trm and the alw-trm commands are the save. For this example, enter these commands.
    rst-trm:trm=17
    rst-trm:trm=18
    rst-trm:trm=19
    rst-trm:trm=20
    rst-trm:trm=21
    rst-trm:trm=22
    rst-trm:trm=23
    rst-trm:trm=24
    Command Completed.
  21. Verify that the terminals are in service with the rept-stat-trm command. This is an example of the possible output.
    TRM   PST           SST           AST
    Command Completed.
  22. This procedure is finished.
Figure 3-9 Updating a High-Capacity Card to Run the BLIXP GPL
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
Conversion of SM8G-B Cards
There are two types of cards that can operate in 32-bit or 64-bit mode: SM8G-B and SLIC cards. SM8G-B cards are equipped with 8G bytes of RAM. The operator must convert the cards to operate on 64-bit mode in order to enable access to memory ranges beyond the 4G byte, the memory range limit for 32-bit mode cards.
Because the GPL image contains either 32-bit or 64-bit mode code, the card must be flashed with the correct version before being able to run on the desired mode. Follow the steps in SM8G-B 32-bit to 64-bit Conversion or SM8G-B 64-bit to 32-bit Conversion in order to convert an SM8G-B card to operate from one mode to the other.
SM8G-B Bootloader Swap
An SM8G-B card running on a BLMCAP version from a release prior to EAGLE 46.3 may contain the 32-bit mode only bootloader. This bootloader must be updated before converting to 64-bit mode. The following procedure is used to update the 32-bit mode bootloader to 64-bit. Skip this procedure if the card is already running the BLDC64 GPL.
  1. Inhibit the target card with the inh-card:loc=<card_loc>:force=yes.
    The card will boot and return to state OOS-MT-DSBLD within 60 seconds.
  2. Flash the card with the init-flash:loc=<card_loc>:code=appr:gpl=blmcap command.
    After the flashing operations complete, the card will boot and return to state OOS-MT-DSBLD.
  3. Activate the new BLMCAP GPL with the act-flash:loc=<card_loc> command.
  4. Replace the card's bootloader with the init-flash:loc=xxxx:mode=rplcebl:bits=64 command.
    If the card was already running with the desired bootloader, the command does nothing.
The following procedure is used to convert the 32-bit mode to 64-bit. The target card must already be running on the BLMCAP GPL and had its bootloader swapped, as completed in SM8G-B Bootloader Swap. Skip this procedure if the card is already running the BLDC64 GPL.
  2. Flash the card with the init-flash:loc=<card_loc>:code=appr:mode=cnvrtbit:bits=64 command.
  3. Activate the new BLDC64 GPL with the act-flash:loc=<card_loc> command.
    The card will now run on 64-bit mode and will accept 64-bit mode applications from the OAM.
The following procedure is used to convert the 64-bit mode to 32-bit. The target card must already be running on the BLDC64 GPL and contain the correct bootloader, as completed in SM8G-B Bootloader Swap. Skip this procedure if the card is already running the BLMCAP GPL.
  2. Flash the card with the init-flash:loc=<card_loc>:code=appr:mode=cnvrtbit:bits=32 command.
    The card will now run on 32-bit mode and will accept 32-bit mode applications from the OAM.
Conversion of SLIC Cards
SLIC cards are equipped with 16G bytes of RAM. They can run on either the 32-bit mode BLSLC32 flash GPL or on the 64-bit mode BLSLC64 flash GPL.
Follow the steps in SLIC 32-bit to 64-bit Conversion or SLIC 64-bit to 32-bit Conversion in order to convert a SLIC card to operate from one mode to the other.
The following procedure is used to convert the 32-bit mode to 64-bit. The target card should already be running on the BLSLC32 GPL. Skip this procedure if the card is already running the BLSLC64 GPL.
  2. Flash the card with the init-flash:loc=<card_loc>:code=appr:gpl=BLSLC64 command.
  3. Activate the new BLSLC64 GPL with the act-flash:loc=<card_loc> command.
  4. Update/verify the SLIC bootloader using the init-flash:loc=<card_loc>:mode=rplcebl:bits=64 command.
    If the card was already running with the desired bootloader, the command has no effect; otherwise, the bootloader will be updated.
The following procedure is used to convert the 64-bit mode to 32-bit. The target card should already be running on the BLSLC64 GPL. Skip this procedure if the card is already running the BLSLC32 GPL.
  2. Flash the card with the init-flash:loc=<card_loc>:code=appr:gpl=BLSLC32 command.
  3. Activate the new BLSLC32 GPL with the act-flash:loc=<card_loc> command.
  4. A card previously running on the BLSLC64 should already be using the correct bootloader. If in doubt, update/verfiy the SLIC bootloader with the init-flash:loc=<card_loc>:mode=rplcebl:bits=64 command.
